fix the sysfs shunt resistor read access: return the shunt resistor
value, not the calibration register contents.
update email address
Signed-off-by: Lothar Felten <lothar.felten@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- PASID table handling updates for the Intel VT-d driver. It implements
a global PASID space now so that applications usings multiple devices
will just have one PASID.
- A new config option to make iommu passthroug mode the default.
- New sysfs attribute for iommu groups to export the type of the
default domain.
- A debugfs interface (for debug only) usable by IOMMU drivers to
export internals to user-space.
- R-Car Gen3 SoCs support for the ipmmu-vmsa driver
- The ARM-SMMU now aborts transactions from unknown devices and devices
not attached to any domain.
- Various cleanups and smaller fixes all over the place.
* tag 'iommu-updates-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (42 commits)
iommu/omap: Fix cache flushes on L2 table entries
iommu: Remove the ->map_sg indirection
iommu/arm-smmu-v3: Abort all transactions if SMMU is enabled in kdump kernel
iommu/arm-smmu-v3: Prevent any devices access to memory without registration
iommu/ipmmu-vmsa: Don't register as BUS IOMMU if machine doesn't have IPMMU-VMSA
iommu/ipmmu-vmsa: Clarify supported platforms
iommu/ipmmu-vmsa: Fix allocation in atomic context
iommu: Add config option to set passthrough as default
iommu: Add sysfs attribyte for domain type
iommu/arm-smmu-v3: sync the OVACKFLG to PRIQ consumer register
iommu/arm-smmu: Error out only if not enough context interrupts
iommu/io-pgtable-arm-v7s: Abort allocation when table address overflows the PTE
iommu/io-pgtable-arm: Fix pgtable allocation in selftest
iommu/vt-d: Remove the obsolete per iommu pasid tables
iommu/vt-d: Apply per pci device pasid table in SVA
iommu/vt-d: Allocate and free pasid table
iommu/vt-d: Per PCI device pasid table interfaces
iommu/vt-d: Add for_each_device_domain() helper
iommu/vt-d: Move device_domain_info to header
iommu/vt-d: Apply global PASID in SVA
The old @sunsite.dk address is no longer active, so update the references.
Signed-off-by: Peter Korsgaard <peter@korsgaard.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Pull ARM SoC driver updates from Olof Johansson:
"Some of the larger changes this merge window:
- Removal of drivers for Exynos5440, a Samsung SoC that never saw
widespread use.
- Uniphier support for USB3 and SPI reset handling
- Syste control and SRAM drivers and bindings for Allwinner platforms
- Qualcomm AOSS (Always-on subsystem) reset controller drivers
- Raspberry Pi hwmon driver for voltage
- Mediatek pwrap (pmic) support for MT6797 SoC"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (52 commits)
drivers/firmware: psci_checker: stash and use topology_core_cpumask for hotplug tests
soc: fsl: cleanup Kconfig menu
soc: fsl: dpio: Convert DPIO documentation to .rst
staging: fsl-mc: Remove remaining files
staging: fsl-mc: Move DPIO from staging to drivers/soc/fsl
staging: fsl-dpaa2: eth: move generic FD defines to DPIO
soc: fsl: qe: gpio: Add qe_gpio_set_multiple
usb: host: exynos: Remove support for Exynos5440
clk: samsung: Remove support for Exynos5440
soc: sunxi: Add the A13, A23 and H3 system control compatibles
reset: uniphier: add reset control support for SPI
cpufreq: exynos: Remove support for Exynos5440
ata: ahci-platform: Remove support for Exynos5440
soc: imx6qp: Use GENPD_FLAG_ALWAYS_ON for PU errata
soc: mediatek: pwrap: add mt6351 driver for mt6797 SoCs
soc: mediatek: pwrap: add pwrap driver for mt6797 SoCs
soc: mediatek: pwrap: fix cipher init setting error
dt-bindings: pwrap: mediatek: add pwrap support for MT6797
reset: uniphier: add USB3 core reset control
dt-bindings: reset: uniphier: add USB3 core reset support
Pull ARM 32-bit SoC platform updates from Olof Johansson:
"Most of the SoC updates in this cycle are cleanups and moves to more
modern infrastructure:
- Davinci was moved to common clock framework
- OMAP1-based Amstrad E3 "Superphone" saw a bunch of cleanups to the
keyboard interface (bitbanged AT keyboard via GPIO).
- Removal of some stale code for Renesas platforms
- Power management improvements for i.MX6LL"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (112 commits)
ARM: uniphier: select RESET_CONTROLLER
arm64: uniphier: select RESET_CONTROLLER
ARM: uniphier: remove empty Makefile
ARM: exynos: Clear global variable on init error path
ARM: exynos: Remove outdated maintainer information
ARM: shmobile: Always enable ARCH_TIMER on SoCs with A7 and/or A15
ARM: shmobile: r8a7779: hide unused r8a7779_platform_cpu_kill
soc: r9a06g032: don't build SMP files for non-SMP config
ARM: shmobile: Add the R9A06G032 SMP enabler driver
ARM: at91: pm: configure wakeup sources for ULP1 mode
ARM: at91: pm: add PMC fast startup registers defines
ARM: at91: pm: Add ULP1 mode support
ARM: at91: pm: Use ULP0 naming instead of slow clock
ARM: hisi: handle of_iomap and fix missing of_node_put
ARM: hisi: check of_iomap and fix missing of_node_put
ARM: hisi: fix error handling and missing of_node_put
ARM: mx5: Set the DBGEN bit in ARM_GPC register
ARM: imx51: Configure M4IF to avoid visual artifacts
ARM: imx: call imx6sx_cpuidle_init() conditionally for 6sll
ARM: imx: fix i.MX6SLL build
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
- touch_max detection improvements and quirk handling fixes in wacom
driver from Jason Gerecke and Ping Cheng
- Palm rejection from Dmitry Torokhov and _dial support from Benjamin
Tissoires for hid-multitouch driver
- Low voltage support for i2c-hid driver from Stephen Boyd
- Guitar-Hero support from Nicolas Adenis-Lamarre
- other assorted small fixes and device ID additions
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (40 commits)
HID: intel_ish-hid: tx_buf memory leak on probe/remove
HID: intel-ish-hid: Prevent loading of driver on Mehlow
HID: cougar: Add support for the Cougar 500k Gaming Keyboard
HID: cougar: make compare_device_paths reusable
HID: intel-ish-hid: remove redundant variable num_frags
HID: multitouch: handle palm for touchscreens
HID: multitouch: touchscreens also use confidence reports
HID: multitouch: report MT_TOOL_PALM for non-confident touches
HID: microsoft: support the Surface Dial
HID: core: do not upper bound the collection stack
HID: input: enable Totem on the Dell Canvas 27
HID: multitouch: remove one copy of values
HID: multitouch: ditch mt_report_id
HID: multitouch: store a per application quirks value
HID: multitouch: Store per collection multitouch data
HID: multitouch: make sure the static list of class is not changed
input: add MT_TOOL_DIAL
HID: elan: Add support for touchpad on the Toshiba Click Mini L9W
HID: elan: Add USB-id for HP x2 10-n000nd touchpad
HID: elan: Add a flag for selecting if the touchpad has a LED
Pull MMC updates from Ulf Hansson:
"Updates for MMC for v4.19.
MMC core:
- Add some fine-grained hooks to further support HS400 tuning
- Improve error path for bus width setting for HS400es
- Use a common method when checking R1 status
MMC host:
- renesas_sdhi: Add r8a77990 support
- renesas_sdhi: Add eMMC HS400 mode support
- tmio/renesas_sdhi: Improve tuning/clock management
- tmio: Add eMMC HS400 mode support
- sunxi: Add support for 3.3V eMMC DDR mode
- mmci: Initial support to manage variant specific callbacks
- sdhci: Don't try 3.3V I/O voltage if not supported
- sdhci-pci-dwc-mshc: Add driver to support Synopsys dwc mshc SDHCI PCI
- sdhci-of-dwcmshc: Add driver to support Synopsys DWC MSHC SDHCI
- sdhci-msm: Add support for new version sdcc V5
- sdhci-pci-o2micro: Add support for O2 eMMC HS200 mode
- sdhci-pci-o2micro: Add support for O2 hardware tuning
- sdhci-pci-o2micro: Add MSI interrupt support for O2 SD host
- sdhci-pci: Add support for Intel ICP
- sdhci-tegra: Prevent ACMD23 and HS200 mode on Tegra 3
- sdhci-tegra: Fix eMMC DDR52 mode
- sdhci-tegra: Improve clock management
- dw_mmc-rockchip: Document compatible string for px30
- sdhci-esdhc-imx: Add support for 3.3V eMMC DDR mode
- sdhci-of-esdhc: Set proper DMA mask for ls104x chips
- sdhci-of-esdhc: Improve clock management
- sdhci-of-arasan: Add a quirk to manage unstable clocks
- dw_mmc-exynos: Address potential external abort during system resume
- pxamci: Add support for common MMC DT bindings
- pxamci: Several cleanups and improvements
- pxamci: Merge immutable branch for pxa to switch to DMA slave maps"
* tag 'mmc-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: (56 commits)
mmc: core: improve reasonableness of bus width setting for HS400es
mmc: tmio: remove unneeded variable in tmio_mmc_start_command()
mmc: renesas_sdhi: Fix sampling clock position selecting
mmc: tmio: Fix tuning flow
mmc: sunxi: remove output of virtual base address
dt-bindings: mmc: rockchip-dw-mshc: add description for px30
mmc: renesas_sdhi: Add r8a77990 support
mmc: sunxi: allow 3.3V DDR when DDR is available
mmc: mmci: Add and implement a ->dma_setup() callback for qcom dml
mmc: mmci: Initial support to manage variant specific callbacks
mmc: tegra: Force correct divider calculation on DDR50/52
mmc: sdhci: Add MSI interrupt support for O2 SD host
mmc: sdhci: Add support for O2 hardware tuning
mmc: sdhci: Export sdhci tuning function symbol
mmc: sdhci: Change O2 Host HS200 mode clock frequency to 200MHz
mmc: sdhci: Add support for O2 eMMC HS200 mode
mmc: tegra: Add and use tegra_sdhci_get_max_clock()
mmc: sdhci-esdhc-imx: fix indent
mmc: sdhci-esdhc-imx: disable clocks before changing frequency
mmc: tegra: prevent ACMD23 on Tegra 3
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.19 kernel cycle.
I don't know if anything in particular stands out. Maybe the Aspeed
coprocessor thing from Benji: Aspeed is doing baseboard management
chips (BMC's) for servers etc.
These Aspeed's are ARM processors that exist inside (I guess) Intel
servers, and they are moving forward to using mainline Linux in those.
This is one of the pieces of the puzzle to achive that. They are doing
OpenBMC, it's pretty cool: https://lwn.net/Articles/683320/
Summary:
Core changes:
- Add a new API for explicitly naming GPIO consumers, when needed.
- Don't let userspace set values on input lines. While we do not
think anyone would do this crazy thing we better plug the hole
before someone uses it and think it's a nifty feature.
- Avoid calling chip->request() for unused GPIOs.
New drivers/subdrivers:
- The Mediatek MT7621 is supported which is a big win for OpenWRT and
similar router distributions using this chip, as it seems every
major router manufacturer on the planet has made products using
this chip: https://wikidevi.com/wiki/MediaTek_MT7621
- The Tegra 194 is now supported.
- The IT87 driver now supports IT8786E and IT8718F super-IO chips.
- Add support for Rockchip RK3328 in the syscon GPIO driver.
Driver changes:
- Handle the get/set_multiple() properly on MMIO chips with inverted
direction registers. We didn't have this problem until a new chip
appear that has get/set registers AND inverted direction bits, OK
now we handle it.
- A patch series making more error codes percolate upward properly
for different errors on gpiochip_lock_as_irq().
- Get/set multiple for the OMAP driver, accelerating these multiple
line operations if possible.
- A coprocessor interface for the Aspeed driver. Sometimes a few GPIO
lines need to be grabbed by a co-processor for doing automated
tasks, sometimes they are available as GPIO lines. By adding an
explicit API in this driver we make it possible for the two line
consumers to coexist. (This work was made available on the
ib-aspeed branch, which may be appearing in other pull requests.)
- Implemented .get_direction() and open drain in the SCH311x driver.
- Continuing cleanup of included headers in GPIO drivers"
* tag 'gpio-v4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (80 commits)
gpio: it87: Add support for IT8613
gpio: it87: add support for IT8718F Super I/O.
gpiolib: Avoid calling chip->request() for unused gpios
gpio: tegra: Include the right header
gpio: mmio: Fix up inverted direction registers
gpio: xilinx: Use the right include
gpio: timberdale: Include the right header
gpio: tb10x: Use the right include
gpiolib: Fix of_node inconsistency
gpio: vr41xx: Bail out on gpiochip_lock_as_irq() error
gpio: uniphier: Bail out on gpiochip_lock_as_irq() error
gpio: xgene-sb: Don't shadow error code of gpiochip_lock_as_irq()
gpio: em: Don't shadow error code of gpiochip_lock_as_irq()
gpio: dwapb: Don't shadow error code of gpiochip_lock_as_irq()
gpio: bcm-kona: Don't shadow error code of gpiochip_lock_as_irq()
gpiolib: Don't shadow error code of gpiochip_lock_as_irq()
gpio: syscon: rockchip: add GRF GPIO support for rk3328
gpio: omap: Add get/set_multiple() callbacks
gpio: pxa: remove set but not used variable 'gpio_offset'
gpio-it87: add support for IT8786E Super I/O
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- new Socionext MN88443x ISDB-S/T demodulator driver: mn88443x
- new sensor drivers: ak7375, ov2680 and rj54n1cb0c
- an old soc-camera sensor driver converted to the V4L2 framework:
mt9v111
- a new Voice-Coil Motor (VCM) driver: dw9807-vcm
- some cleanups at cx25821, removing legacy unused code
- some improvements at ddbridge driver
- new platform driver: vicodec
- some DVB API cleanups, removing ioctls and compat code for old
out-of-tree drivers that were never merged upstream
- improvements at DVB core to support frontents that support both
Satellite and non-satellite delivery systems
- got rid of the unused VIDIOC_RESERVED V4L2 ioctl
- some cleanups/improvements at gl861 ISDB driver
- several improvements on ov772x, ov7670 and ov5640, imx274, ov5645,
and smiapp sensor drivers
- fixes at em28xx to support dual TS devices
- some cleanups at V4L2/VB2 locking logic
- some API improvements at media controller
- some cec core and drivers improvements
- some uvcvideo improvements
- some improvements at platform drivers: stm32-dcmi, rcar-vin, coda,
reneseas-ceu, imx, vsp1, venus, camss
- lots of other cleanups and fixes
* tag 'media/v4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (406 commits)
Revert "media: vivid: shut up warnings due to a non-trivial logic"
siano: get rid of an unused return code for debugfs register
media: isp: fix a warning about a wrong struct initializer
media: radio-wl1273: fix return code for the polling routine
media: s3c-camif: fix return code for the polling routine
media: saa7164: fix return codes for the polling routine
media: exynos-gsc: fix return code if mutex was interrupted
media: mt9v111: Fix build error with no VIDEO_V4L2_SUBDEV_API
media: xc4000: get rid of uneeded casts
media: drxj: get rid of uneeded casts
media: tuner-xc2028: don't use casts for printing sizes
media: cleanup fall-through comments
media: rtl28xxu: be sure that it won't go past the array size
media: mt9v111: avoid going past the buffer
media: vsp1_dl: add a description for cmdpool field
media: sta2x11: add a missing parameter description
media: v4l2-mem2mem: add descriptions to MC fields
media: i2c: fix warning in Aptina MT9V111
media: imx: shut up a false positive warning
Pull networking updates from David Miller:
"Highlights:
- Gustavo A. R. Silva keeps working on the implicit switch fallthru
changes.
- Support 802.11ax High-Efficiency wireless in cfg80211 et al, From
Luca Coelho.
- Re-enable ASPM in r8169, from Kai-Heng Feng.
- Add virtual XFRM interfaces, which avoids all of the limitations of
existing IPSEC tunnels. From Steffen Klassert.
- Convert GRO over to use a hash table, so that when we have many
flows active we don't traverse a long list during accumluation.
- Many new self tests for routing, TC, tunnels, etc. Too many
contributors to mention them all, but I'm really happy to keep
seeing this stuff.
- Hardware timestamping support for dpaa_eth/fsl-fman from Yangbo Lu.
- Lots of cleanups and fixes in L2TP code from Guillaume Nault.
- Add IPSEC offload support to netdevsim, from Shannon Nelson.
- Add support for slotting with non-uniform distribution to netem
packet scheduler, from Yousuk Seung.
- Add UDP GSO support to mlx5e, from Boris Pismenny.
- Support offloading of Team LAG in NFP, from John Hurley.
- Allow to configure TX queue selection based upon RX queue, from
Amritha Nambiar.
- Support ethtool ring size configuration in aquantia, from Anton
Mikaev.
- Support DSCP and flowlabel per-transport in SCTP, from Xin Long.
- Support list based batching and stack traversal of SKBs, this is
very exciting work. From Edward Cree.
- Busyloop optimizations in vhost_net, from Toshiaki Makita.
- Introduce the ETF qdisc, which allows time based transmissions. IGB
can offload this in hardware. From Vinicius Costa Gomes.
- Add parameter support to devlink, from Moshe Shemesh.
- Several multiplication and division optimizations for BPF JIT in
nfp driver, from Jiong Wang.
- Lots of prepatory work to make more of the packet scheduler layer
lockless, when possible, from Vlad Buslov.
- Add ACK filter and NAT awareness to sch_cake packet scheduler, from
Toke Høiland-Jørgensen.
- Support regions and region snapshots in devlink, from Alex Vesker.
- Allow to attach XDP programs to both HW and SW at the same time on
a given device, with initial support in nfp. From Jakub Kicinski.
- Add TLS RX offload and support in mlx5, from Ilya Lesokhin.
- Use PHYLIB in r8169 driver, from Heiner Kallweit.
- All sorts of changes to support Spectrum 2 in mlxsw driver, from
Ido Schimmel.
- PTP support in mv88e6xxx DSA driver, from Andrew Lunn.
- Make TCP_USER_TIMEOUT socket option more accurate, from Jon
Maxwell.
- Support for templates in packet scheduler classifier, from Jiri
Pirko.
- IPV6 support in RDS, from Ka-Cheong Poon.
- Native tproxy support in nf_tables, from Máté Eckl.
- Maintain IP fragment queue in an rbtree, but optimize properly for
in-order frags. From Peter Oskolkov.
- Improvde handling of ACKs on hole repairs, from Yuchung Cheng"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1996 commits)
bpf: test: fix spelling mistake "REUSEEPORT" -> "REUSEPORT"
hv/netvsc: Fix NULL dereference at single queue mode fallback
net: filter: mark expected switch fall-through
xen-netfront: fix warn message as irq device name has '/'
cxgb4: Add new T5 PCI device ids 0x50af and 0x50b0
net: dsa: mv88e6xxx: missing unlock on error path
rds: fix building with IPV6=m
inet/connection_sock: prefer _THIS_IP_ to current_text_addr
net: dsa: mv88e6xxx: bitwise vs logical bug
net: sock_diag: Fix spectre v1 gadget in __sock_diag_cmd()
ieee802154: hwsim: using right kind of iteration
net: hns3: Add vlan filter setting by ethtool command -K
net: hns3: Set tx ring' tc info when netdev is up
net: hns3: Remove tx ring BD len register in hns3_enet
net: hns3: Fix desc num set to default when setting channel
net: hns3: Fix for phy link issue when using marvell phy driver
net: hns3: Fix for information of phydev lost problem when down/up
net: hns3: Fix for command format parsing error in hclge_is_all_function_id_zero
net: hns3: Add support for serdes loopback selftest
bnxt_en: take coredump_record structure off stack
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"It's been busy summer weeks and hence lots of changes, partly for a
few new drivers and partly for a wide range of fixes.
Here are highlights:
ALSA Core:
- Fix rawmidi buffer management, code cleanup / refactoring
- Fix the SG-buffer page handling with incorrect fallback size
- Fix the stall at virmidi trigger callback with a large buffer; also
offloading and code-refactoring along with it
- Various ALSA sequencer code cleanups
ASoC:
- Deploy the standard snd_pcm_stop_xrun() helper in several drivers
- Support for providing name prefixes to generic component nodes
- Quite a few fixes for DPCM as it gains a bit wider use and more
robust testing
- Generalization of the DIO2125 support to a simple amplifier driver
- Accessory detection support for the audio graph card
- DT support for PXA AC'97 devices
- Quirks for a number of new x86 systems
- Support for AM Logic Meson, Everest ES7154, Intel systems with
RT5682, Qualcomm QDSP6 and WCD9335, Realtek RT5682 and TI TAS5707
HD-audio:
- Code refactoring in HD-audio ext codec codes to drop own classes;
preliminary works for the upcoming legacy codec support
- Generalized DRM audio component for the upcoming radeon / amdgpu
support
- Unification of mic mute-LED and GPIO support for various codecs
- Further improvement of CA0132 codec support including Recon3D
- Proper vga_switcheroo handling for AMD i-GPU
- Update of model list in documentation
- Fixups for another HP Spectre x360, Conexant codecs, power-save
blacklist update
USB-audio:
- Fix the invalid sample rate setup with external clock
- Support of UAC3 selector units and processing units
- Basic UAC3 power-domain support
- Support for Encore mDSD and Thesycon-based DSD devices
- Preparation for future complete callback changes
Firewire:
- Add support for MOTU Traveler
Misc:
- The endianess notation fixes in various drivers
- Add fall-through comment in lots of drivers
- Various sparse warning fixes, e.g. about PCM format types"
* tag 'sound-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (529 commits)
ASoC: adav80x: mark expected switch fall-through
ASoC: da7219: Add delays to capture path to remove DC offset noise
ALSA: usb-audio: Mark expected switch fall-through
ALSA: mixart: Mark expected switch fall-through
ALSA: opl3: Mark expected switch fall-through
ALSA: hda/ca0132 - Add exit commands for Recon3D
ALSA: hda/ca0132 - Change mixer controls for Recon3D
ALSA: hda/ca0132 - Add Recon3D input and output select commands
ALSA: hda/ca0132 - Add DSP setup defaults for Recon3D
ALSA: hda/ca0132 - Add Recon3D startup functions and setup
ALSA: hda/ca0132 - Add bool variable to enable/disable pci region2 mmio
ALSA: hda/ca0132 - Add Recon3D pincfg
ALSA: hda/ca0132 - Add quirk ID and enum for Recon3D
ALSA: hda/ca0132 - Add alt_functions unsolicited response
ALSA: hda/ca0132 - Clean up ca0132_init function.
ALSA: hda/ca0132 - Create mmio gpio function to make code clearer
ASoC: wm_adsp: Make DSP name configurable by codec driver
ASoC: wm_adsp: Declare firmware controls from codec driver
ASoC: max98373: Added software reset register to readable registers
ASoC: wm_adsp: Correct DSP pointer for preloader control
The include/linux/platform_data/media/sii9234.h header file is unused,
let's remove it.
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
This is the pxa changes for 4.19 cycle :
- the pxa architecture is ported to dma slavemap
- some minor AC97 fixes
- some minor board fixes
* tag 'pxa-for-4.19-v2' of https://github.com/rjarzmik/linux:
net: smc91x: remove the dmaengine compat need
net: smc911x: remove the dmaengine compat need
ARM: pxa: zylonite: use the new ac97 bus support
ARM: pxa: add the missing AC97 clocks
ARM: pxa: mioa701 convert to the new AC97 bus
ARM: pxa: hx4700: fix the usb client
ARM: pxa: change SSP DMA channels allocation
ARM: pxa: remove the DMA IO resources
dmaengine: pxa: document pxad_param
ata: pata_pxa: remove the dmaengine compat need
mtd: rawnand: marvell: remove the dmaengine compat need
media: pxa_camera: remove the dmaengine compat need
mmc: pxamci: remove the dmaengine compat need
dmaengine: pxa: add a default requestor policy
ARM: pxa: add dma slave map
dmaengine: pxa: use a dma slave map
This way we will be able to compile the jz4740_nand driver when
COMPILE_TEST=y.
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Acked-by: Paul Burton <paul.burton@mips.com>
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
This way we will be able to compile the ndfmc driver when
COMPILE_TEST=y.
None of the boards seem to overload the ->dev_ready() hook, just drop
this field from orion_nand_data.
The field support_vsel is currently only used in the device tree
case. Get rid of it. No change in behavior.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc
SoC updates for omaps for v4.19 merge window
These changes are mostly PM related changes for am335x and
am437x to support RTC only suspend mode. Some of the clock
and driver related chances are still pending so it's not
yet fully functional.
Also included is a change for PM debug sysfs entry to use
DEFINE_SHOW_ATTRIBUTE.
* tag 'omap-for-v4.19/soc-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: sleep33/43xx: Add RTC-Mode support
ARM: OMAP2+: sleep33/43xx: Make sleep actions configurable
ARM: OMAP2+: reuse DEFINE_SHOW_ATTRIBUTE() macro
ARM: hwmod: RTC: Don't assume lock/unlock will be called with irq enabled
SoC updates for omap1 for v4.19 merge window
Mostly a series by Janusz Krzysztofik to clean up the
GPIO and input handling for ams-delta. Because of the
platform data changes, we decided that it's best to
merge the related input changes also via the arm-soc
tree so Dmitry Torokhov has acked the input changes.
Also included is a change to constify gpio_leds from
Arvind Yadav.
* tag 'omap-for-v4.19/omap1-v2-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP1: ams-delta: move late devices back to init_machine
Input: ams_delta_serio: Get FIQ buffer from platform_data
Input: ams_delta_serio: use IRQ resource
ARM: OMAP1: Get rid of <mach/ams-delta-fiq.h>
ARM: OMAP1: ams-delta FIQ: Keep serio input GPIOs requested
ARM: OMAP1: ams-delta FIQ: don't use static GPIO numbers
ARM: OMAP1: ams-delta: Hog "keybrd_dataout" GPIO pin
Input: ams_delta_serio: Replace power GPIO with regulator
Input: ams_delta_serio: use private structure
Input: ams_delta_serio: convert to platform driver
ARM: OMAP1: ams-delta: drop GPIO lookup table for serio device
ARM: OMAP1: ams-delta: assign LED GPIO numbers from descriptors
ARM: OMAP1: ams-delta: refactor late_init()
ARM: OMAP1: constify gpio_led
All users now register platform devices using the ti-aemif driver.
Remove the handcrafted aemif API.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Add support for RTC mode to low level suspend code. This includes
providing the rtc base address for the assembly code to configuring the
PMIC_PWR_EN line late in suspend to enter RTC+DDR mode.
Note: This patch also fold in left out space parameter for
am33xx_emif_sram_table and am43xx_emif_sram_table
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Signed-off-by: Keerthy <j-keerthy@ti.com>
Add an argument to the sleep33xx and sleep43xx code to allow us to set
flags to determine which portions of the code get called in order to use
the same code for multiple power saving modes. This patch allows us to
decide whether or not we flush and disable caches, save EMIF context,
put the memory into self refresh and disable the EMIF, and/or invoke
the wkup_m3 when entering into WFI.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
The dra76x MCAN generic interconnect module has a its own
format for the bits in the control registers.
Therefore add a new module type, new regbits and new capabilities
specific to the MCAN module.
Acked-by: Rob Herring <robh@kernel.org>
CC: Tony Lindgren <tony@atomide.com>
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
include/linux/platform_data/sh_ipmmu.h is unused since commit
ae50dc4874c5 ("iommu/shmobile: Remove unused Renesas IPMMU/IPMMUI")
Let's remove it.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Nothing in tree use this header which seems a remains of a staging
driver.
This patch remove it.
Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Instead of exporting the FIQ buffer symbol to be used in
ams-delta-serio driver, pass it to the driver as platform_data.
Signed-off-by: Janusz Krzysztofik <jmkrzyszt@gmail.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Split the header file into two parts and move them to directories where
they belong.
Information on internal structure of FIQ buffer is moved to
<linux/platform_data/ams-delta-fiq.h> for ams-delta-serio driver use.
Other information used by ams-delta board init file and FIQ code is
made local to mach-omap1 root directory.
Some wacom w9013 devices have a vddl supply for "low valtage"
requirements. Add support in this driver to turn on this low voltage
supply. We can also drop a handful of error messages because the
regulator core is already printing an error when bulk regulators fail to
enable or disable.
Cc: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Dmitry Torokhov <dtor@chromium.org>
Cc: Doug Anderson <dianders@chromium.org>
Cc: <devicetree@vger.kernel.org>
Signed-off-by: Stephen Boyd <swboyd@chromium.org>
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
In order to remove the specific knowledge of the dma mapping from PXA
drivers, add a default slave map for pxa architectures.
This won't impact MMP architecture, but is aimed only at all PXA boards.
This is the first step, and once all drivers are converted,
pxad_filter_fn() will be made static, and the DMA resources removed from
device.c.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Vinod Koul <vkoul@kernel.org>
Currently the driver assumes that the interrupts are continuous
and does platform_get_irq only once and assumes the rest are continuous,
instead call platform_get_irq for all the interrupts and store them
in an array for later use.
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Pull documentation fixes from Mauro Carvalho Chehab:
"This solves a series of broken links for files under Documentation,
and improves a script meant to detect such broken links (see
scripts/documentation-file-ref-check).
The changes on this series are:
- can.rst: fix a footnote reference;
- crypto_engine.rst: Fix two parsing warnings;
- Fix a lot of broken references to Documentation/*;
- improve the scripts/documentation-file-ref-check script, in order
to help detecting/fixing broken references, preventing
false-positives.
After this patch series, only 33 broken references to doc files are
detected by scripts/documentation-file-ref-check"
* tag 'docs-broken-links' of git://linuxtv.org/mchehab/experimental: (26 commits)
fix a series of Documentation/ broken file name references
Documentation: rstFlatTable.py: fix a broken reference
ABI: sysfs-devices-system-cpu: remove a broken reference
devicetree: fix a series of wrong file references
devicetree: fix name of pinctrl-bindings.txt
devicetree: fix some bindings file names
MAINTAINERS: fix location of DT npcm files
MAINTAINERS: fix location of some display DT bindings
kernel-parameters.txt: fix pointers to sound parameters
bindings: nvmem/zii: Fix location of nvmem.txt
docs: Fix more broken references
scripts/documentation-file-ref-check: check tools/*/Documentation
scripts/documentation-file-ref-check: get rid of false-positives
scripts/documentation-file-ref-check: hint: dash or underline
scripts/documentation-file-ref-check: add a fix logic for DT
scripts/documentation-file-ref-check: accept more wildcards at filenames
scripts/documentation-file-ref-check: fix help message
media: max2175: fix location of driver's companion documentation
media: v4l: fix broken video4linux docs locations
media: dvb: point to the location of the old README.dvb-usb file
Pull fbdev updates from Bartlomiej Zolnierkiewicz:
"There is nothing really major here, few small fixes, some cleanups and
dead drivers removal:
- mark omapfb drivers as orphans in MAINTAINERS file (Tomi Valkeinen)
- add missing module license tags to omap/omapfb driver (Arnd
Bergmann)
- add missing GPIOLIB dependendy to omap2/omapfb driver (Arnd
Bergmann)
- convert savagefb, aty128fb & radeonfb drivers to use msleep & co.
(Jia-Ju Bai)
- allow COMPILE_TEST build for viafb driver (media part was reviewed
by media subsystem Maintainer)
- remove unused MERAM support from sh_mobile_lcdcfb and shmob-drm
drivers (drm parts were acked by shmob-drm driver Maintainer)
- remove unused auo_k190xfb drivers
- misc cleanups (Souptick Joarder, Wolfram Sang, Markus Elfring, Andy
Shevchenko, Colin Ian King)"
* tag 'fbdev-v4.18' of git://github.com/bzolnier/linux: (26 commits)
fb_omap2: add gpiolib dependency
video/omap: add module license tags
MAINTAINERS: make omapfb orphan
video: fbdev: pxafb: match_string() conversion fixup
video: fbdev: nvidia: fix spelling mistake: "scaleing" -> "scaling"
video: fbdev: fix spelling mistake: "frambuffer" -> "framebuffer"
video: fbdev: pxafb: Convert to use match_string() helper
video: fbdev: via: allow COMPILE_TEST build
video: fbdev: remove unused sh_mobile_meram driver
drm: shmobile: remove unused MERAM support
video: fbdev: sh_mobile_lcdcfb: remove unused MERAM support
video: fbdev: remove unused auo_k190xfb drivers
video: omap: Improve a size determination in omapfb_do_probe()
video: sm501fb: Improve a size determination in sm501fb_probe()
video: fbdev-MMP: Improve a size determination in path_init()
video: fbdev-MMP: Delete an error message for a failed memory allocation in two functions
video: auo_k190x: Delete an error message for a failed memory allocation in auok190x_common_probe()
video: sh_mobile_lcdcfb: Delete an error message for a failed memory allocation in two functions
video: sh_mobile_meram: Delete an error message for a failed memory allocation in sh_mobile_meram_probe()
video: fbdev: sh_mobile_meram: Drop SUPERH platform dependency
As files move around, their previous links break. Fix the
references for them.
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Acked-by: Jonathan Corbet <corbet@lwn.net>
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"Several incremental improvements including new keycodes, new models,
new quirks, and related documentation. Adds LED platform driver
activation for Mellanox systems. Some minor optimizations and
cleanups. Includes several bug fixes, message silencing, mostly minor
Automated summary:
acer-wmi:
- add another KEY_POWER keycode
apple-gmux:
- fix gmux_get_client_id()'s return type
asus-laptop:
- Simplify getting .drvdata
asus-wireless:
- Fix format specifier
dell-laptop:
- Fix keyboard backlight timeout on XPS 13 9370
dell-smbios:
- Match on www.dell.com in OEM strings too
dell-wmi:
- Ignore new rfkill and fn-lock events
- Set correct keycode for Fn + left arrow
fujitsu-laptop:
- Simplify soft key handling
ideapad-laptop:
- Add E42-80 to no_hw_rfkill
- Add fn-lock setting
- Add MIIX 720-12IKB to no_hw_rfkill
lib/string_helpers:
- Add missed declaration of struct task_struct
intel_scu_ipc:
- Replace mdelay with usleep_range in intel_scu_ipc_i2c_cntrl
mlx-platform:
- Add LED platform driver activation
platform/mellanox:
- Add new ODM system types to mlx-platform
- mlxreg-hotplug: add extra cycle for hotplug work queue
- mlxreg-hotplug: Document fixes for hotplug private data
platform_data/mlxreg:
- Document fixes for hotplug device
silead_dmi:
- Add entry for Chuwi Hi8 tablet touchscreen
- Add touchscreen info for the Onda V891w tablet
- Add info for the PoV mobii TAB-P800W (v2.0)
- Add touchscreen info for the Jumper EZpad 6 Pro
thinkpad_acpi:
- silence false-positive-prone pr_warn
- do not report thermal sensor state for tablet mode switch
- silence HKEY 0x6032, 0x60f0, 0x6030"
* tag 'platform-drivers-x86-v4.18-1' of git://git.infradead.org/linux-platform-drivers-x86: (30 commits)
platform/x86: silead_dmi: Add entry for Chuwi Hi8 tablet touchscreen
platform/x86: dell-laptop: Fix keyboard backlight timeout on XPS 13 9370
platform/x86: dell-wmi: Ignore new rfkill and fn-lock events
platform/x86: mlx-platform: Add LED platform driver activation
platform/mellanox: Add new ODM system types to mlx-platform
platform/mellanox: mlxreg-hotplug: add extra cycle for hotplug work queue
platform/x86: ideapad-laptop: Add E42-80 to no_hw_rfkill
platform/x86: silead_dmi: Add touchscreen info for the Onda V891w tablet
platform/x86: silead_dmi: Add info for the PoV mobii TAB-P800W (v2.0)
platform/x86: silead_dmi: Add touchscreen info for the Jumper EZpad 6 Pro
platform/x86: asus-wireless: Fix format specifier
platform/x86: asus-wmi: Fix NULL pointer dereference
platform/x86: dell-wmi: Set correct keycode for Fn + left arrow
platform/x86: acer-wmi: add another KEY_POWER keycode
platform/x86: ideapad-laptop: Add fn-lock setting
platform/x86: ideapad-laptop: Add MIIX 720-12IKB to no_hw_rfkill
lib/string_helpers: Add missed declaration of struct task_struct
platform/x86: DELL_WMI use depends on instead of select for DELL_SMBIOS
platform/mellanox: mlxreg-hotplug: Document fixes for hotplug private data
platform_data/mlxreg: Document fixes for hotplug device
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- mainly feature additions to drivers (stm32f7, qup, xlp9xx, mlxcpld, ...)
- conversion to use the i2c_8bit_addr_from_msg macro consistently
- move includes to platform_data
- core updates to allow the (still in review) I3C subsystem to connect
- and the regular share of smaller driver updates
* 'i2c/for-4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (68 commits)
i2c: qup: fix building without CONFIG_ACPI
i2c: tegra: Remove suspend-resume
i2c: imx-lpi2c: Switch to SPDX identifier
i2c: mxs: Switch to SPDX identifier
i2c: busses: make use of i2c_8bit_addr_from_msg
i2c: algos: make use of i2c_8bit_addr_from_msg
i2c: rcar: document R8A77980 bindings
i2c: qup: Add command-line parameter to override SCL frequency
i2c: qup: Correct duty cycle for FM and FM+
i2c: qup: Add support for Fast Mode Plus
i2c: qup: add probe path for Centriq ACPI devices
i2c: robotfuzz-osif: drop pointless test
i2c: robotfuzz-osif: remove pointless local variable
i2c: rk3x: Don't print visible virtual mapping MMIO address
i2c: opal: don't check number of messages in the driver
i2c: ibm_iic: don't check number of messages in the driver
i2c: imx: Switch to SPDX identifier
i2c: mux: pca954x: merge calls to of_match_device and of_device_get_match_data
i2c: mux: demux-pinctrl: use proper parent device for demux adapter
i2c: mux: improve error message for failed symlink
"This contains platform-related driver updates for ARM and ARM64.
Highlights:
- ARM SCMI (System Control & Management Interface) driver cleanups
- Hisilicon support for LPC bus w/ ACPI
- Reset driver updates for several platforms: Uniphier,
- Rockchip power domain bindings and hardware descriptions for
several SoCs.
- Tegra memory controller reset improvements"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (59 commits)
ARM: tegra: fix compile-testing PCI host driver
soc: rockchip: power-domain: add power domain support for px30
dt-bindings: power: add binding for px30 power domains
dt-bindings: power: add PX30 SoCs header for power-domain
soc: rockchip: power-domain: add power domain support for rk3228
dt-bindings: power: add binding for rk3228 power domains
dt-bindings: power: add RK3228 SoCs header for power-domain
soc: rockchip: power-domain: add power domain support for rk3128
dt-bindings: power: add binding for rk3128 power domains
dt-bindings: power: add RK3128 SoCs header for power-domain
soc: rockchip: power-domain: add power domain support for rk3036
dt-bindings: power: add binding for rk3036 power domains
dt-bindings: power: add RK3036 SoCs header for power-domain
dt-bindings: memory: tegra: Remove Tegra114 SATA and AFI reset definitions
memory: tegra: Register SMMU after MC driver became ready
soc: mediatek: remove unneeded semicolon
soc: mediatek: add a fixed wait for SRAM stable
soc: mediatek: introduce a CAPS flag for scp_domain_data
soc: mediatek: reuse regmap_read_poll_timeout helpers
Pull ARM SoC platform updates from Olof Johansson:
"Here are the main updates for SoC support (besides DT additions) for
ARM 32- and 64-bit platforms. The branch also contains defconfig
updates to turn on drivers and options as needed on the various
platforms.
The largest parts of the delta are from cleanups moving platform data
and board file setup of TI platforms to ti-sysc bus drivers. There are
also some sweeping changes of eeprom and nand setup on Davinci, i.MX
and other platforms.
Samsung is removing support for Exynos5440, which was an oddball SoC
that hasn't been seen much use in designs.
Renesas is adding support for new SoCs (R-Car E3, RZ/G1C and RZ/N1D).
Linus Walleij is also removing support for ux500 (Sony Ericsson)
U8540/9540 SoCs that never made it to significant mass production and
products"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
MAINTAINERS: add NXP linux team maillist as i.MX reviewer
ARM: stm32: Don't select DMA unconditionally on STM32MP157C
arm64: defconfig: Enable PCIe on msm8996 and db820c
ARM: pxa3xx: enable external wakeup pins
ARM: pxa: stargate2: use device properties for at24 eeprom
arm64: defconfig: Enable HISILICON_LPC
arm64: defconfig: enable drivers for Poplar support
arm64: defconfig: Enable UFS on msm8996
ARM: berlin: switch to SPDX license identifier
arm: berlin: remove non-necessary flush_cache_all()
ARM: berlin: extend BG2CD Kconfig entry
OMAP: CLK: CLKSRC: Add suspend resume hooks
ARM: AM43XX: Add functions to save/restore am43xx control registers
ASoC: ams_delta: use GPIO lookup table
ARM: OMAP1: ams-delta: add GPIO lookup tables
bus: ti-sysc: Fix optional clocks array access
ARM: OMAP2+: Make sure LOGICRETSTATE bits are not cleared
ARM: OMAP2+: prm44xx: Inroduce cpu_pm notifiers for context save/restore
ARM: OMAP2+: prm44xx: Introduce context save/restore for am43 PRCM IO
ARM: OMAP2+: powerdomain: Introduce cpu_pm notifiers for context save/restore
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO updates from Greg KH:
"Here is the big staging and IIO driver update for 4.18-rc1.
It was delayed as I wanted to make sure the final driver deletions did
not cause any major merge issues, and all now looks good.
There are a lot of patches here, just over 1000. The diffstat summary
shows the major changes here:
1007 files changed, 16828 insertions(+), 227770 deletions(-)
Because of this, we might be close to shrinking the overall kernel
source code size for two releases in a row.
There was loads of work in this release cycle, primarily:
- tons of ks7010 driver cleanups
- lots of mt7621 driver fixes and cleanups
- most driver cleanups
- wilc1000 fixes and cleanups
- lots and lots of IIO driver cleanups and new additions
- debugfs cleanups for all staging drivers
- lots of other staging driver cleanups and fixes, the shortlog has
the full details.
but the big user-visable things here are the removal of 3 chunks of
code:
- ncpfs and ipx were removed on schedule, no one has cared about this
code since it moved to staging last year, and if it needs to come
back, it can be reverted.
- lustre file system is removed.
I've ranted at the lustre developers about once a year for the past
5 years, with no real forward progress at all to clean things up
and get the code into the "real" part of the kernel.
Given that the lustre developers continue to work on an external
tree and try to port those changes to the in-kernel tree every once
in a while, this whole thing really really is not working out at
all. So I'm deleting it so that the developers can spend the time
working in their out-of-tree location and get things cleaned up
properly to get merged into the tree correctly at a later date.
Because of these file removals, you will have merge issues on some of
these files (2 in the ipx code, 1 in the ncpfs code, and 1 in the
atomisp driver). Just delete those files, it's a simple merge :)
All of this has been in linux-next for a while with no reported
problems"
* tag 'staging-4.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1011 commits)
staging: ipx: delete it from the tree
ncpfs: remove uapi .h files
ncpfs: remove Documentation
ncpfs: remove compat functionality
staging: ncpfs: delete it
staging: lustre: delete the filesystem from the tree.
staging: vc04_services: no need to save the log debufs dentries
staging: vc04_services: vchiq_debugfs_log_entry can be a void *
staging: vc04_services: remove struct vchiq_debugfs_info
staging: vc04_services: move client dbg directory into static variable
staging: vc04_services: remove odd vchiq_debugfs_top() wrapper
staging: vc04_services: no need to check debugfs return values
staging: mt7621-gpio: reorder includes alphabetically
staging: mt7621-gpio: change gc_map to don't use pointers
staging: mt7621-gpio: use GPIOF_DIR_OUT and GPIOF_DIR_IN macros instead of custom values
staging: mt7621-gpio: change 'to_mediatek_gpio' to make just a one line return
staging: mt7621-gpio: dt-bindings: update documentation for #interrupt-cells property
staging: mt7621-gpio: update #interrupt-cells for the gpio node
staging: mt7621-gpio: dt-bindings: complete documentation for the gpio
staging: mt7621-dts: add missing properties to gpio node
"This is the bulk of GPIO changes for the v4.18 development cycle.
Core changes:
- We have killed off VLA from the core library and all drivers.
The background should be clear for everyone at this point:
https://lwn.net/Articles/749064/
Also I just don't like VLA's, kernel developers hate it when
compilers do things behind their back. It's as simple as that.
I'm sorry that they even slipped in to begin with. Kudos to Laura
Abbott for exorcising them.
- Support GPIO hogs in machines/board files.
New drivers and chip support:
- R-Car r8a77470 (RZ/G1C)
- R-Car r8a77965 (M3-N)
- R-Car r8a77990 (E3)
- PCA953x driver improvements to accomodate more variants.
Improvements and new features:
- Support one interrupt per line on port A in the DesignWare dwapb
driver.
Misc:
- Random cleanups, right header files in the drivers, some size
optimizations etc"
* tag 'gpio-v4.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (73 commits)
gpio: davinci: fix build warning when !CONFIG_OF
gpio: dwapb: Fix rework support for 1 interrupt per port A GPIO
gpio: pxa: Include the right header
gpio: pl061: Include the right header
gpio: pch: Include the right header
gpio: pcf857x: Include the right header
gpio: pca953x: Include the right header
gpio: palmas: Include the right header
gpio: omap: Include the right header
gpio: octeon: Include the right header
gpio: mxs: Switch to SPDX identifier
gpio: Remove VLA from stmpe driver
gpio: mxc: Switch to SPDX identifier
gpio: mxc: add clock operation
gpio: Remove VLA from gpiolib
gpio: aspeed: Use a cache of output data registers
gpio: aspeed: Set output latch before changing direction
gpio: pca953x: fix address calculation for pcal6524
gpio: pca953x: define masks for addressing common and extended registers
gpio: pca953x: set the PCA_PCAL flag also when matching by DT
- remove of atomisp driver from staging, as nobody would have time to
dedicate huge efforts to fix all the problems there. Also, we have a
feeling that the driver may not even run the way it is.
- move Zoran driver to staging, in order to be either fixed to use VB2
and the proper media kAPIs or to be removed
- remove videobuf-dvb driver, with is unused for a while
- some V4L2 documentation fixes/improvements
- new sensor drivers: imx258 and ov7251
- a new driver was added to allow using I2C transparent drivers
- several improvements at the ddbridge driver
- several improvements at the ISDB pt1 driver, making it more coherent
with the DVB framework
- added a new platform driver for MIPI CSI-2 RX: cadence
- now, all media drivers can be compiled on x86 with COMPILE_TEST
- almost all media drivers now build on non-x86 architectures with
COMPILE_TEST
- lots of other random stuff: cleanups, support for new board models,
bug fixes, etc
* tag 'media/v4.18-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (464 commits)
media: omap2: fix compile-testing with FB_OMAP2=m
media: media/radio/Kconfig: add back RADIO_ISA
media: v4l2-ioctl.c: fix missing unlock in __video_do_ioctl()
media: pxa_camera: ignore -ENOIOCTLCMD from v4l2_subdev_call for s_power
media: arch: sh: migor: Fix TW9910 PDN gpio
media: staging: tegra-vde: Reset VDE regardless of memory client resetting failure
media: marvel-ccic: mmp: select VIDEOBUF2_VMALLOC/DMA_CONTIG
media: marvel-ccic: allow ccic and mmp drivers to coexist
media: uvcvideo: Prevent setting unavailable flags
media: ddbridge: conditionally enable fast TS for stv0910-equipped bridges
media: dvb-frontends/stv0910: make TS speed configurable
media: ddbridge/mci: add identifiers to function definition arguments
media: ddbridge/mci: protect against out-of-bounds array access in stop()
media: rc: ensure input/lirc device can be opened after register
media: rc: nuvoton: Keep device enabled during reg init
media: rc: nuvoton: Keep track of users on CIR enable/disable
media: rc: nuvoton: Tweak the interrupt enabling dance
media: uvcvideo: Support realtek's UVC 1.5 device
media: uvcvideo: Fix driver reference counting
media: gspca_zc3xx: Enable short exposure times for OV7648
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
Pull drm updates from Dave Airlie:
"This starts to support NVIDIA volta hardware with nouveau, and adds
amdgpu support for the GPU in the Kabylake-G (the intel + radeon
single package chip), along with some initial Intel icelake enabling.
Summary:
New Drivers:
- v3d - driver for broadcom V3D V3.x+ hardware
- xen-front - XEN PV display frontend
core:
- handle zpos normalization in the core
- stop looking at legacy pointers in atomic paths
- improved scheduler documentation
- improved aspect ratio validation
- aspect ratio support for 64:27 and 256:135
- drop unused control node code.
i915:
- Icelake (ICL) enabling
- GuC/HuC refactoring
- PSR/PSR2 enabling and fixes
- DPLL management refactoring
- DP MST fixes
- NV12 enabling
- HDCP improvements
- GEM/Execlist/reset improvements
- GVT improvements
- stolen memory first 4k fix
amdgpu:
- Vega 20 support
- VEGAM support (Kabylake-G)
- preOS scanout buffer reservation
- power management gfxoff support for raven
- SR-IOV fixes
- Vega10 power profiles and clock voltage control
- scatter/gather display support on CZ/ST
amdkfd:
- GFX9 dGPU support
- userptr memory mapping
nouveau:
- major refactoring for Volta GV100 support
tda998x:
- HDMI i2c CEC support
etnaviv:
- removed unused logging code
- license text cleanups
- MMU handling improvements
- timeout fence fix for 50 days uptime
tegra:
- IOMMU support in gr2d/gr3d drivers
- zpos support
vc4:
- syncobj support
- CTM, plane alpha and async cursor support
analogix_dp:
- HPD and aux chan fixes
sun4i:
- MIPI DSI support
tilcdc:
- clock divider fixes for OMAP-l138 LCDK board
rcar-du:
- R8A77965 support
- dma-buf fences fixes
- hardware indexed crtc/du group handling
- generic zplane property support
atmel-hclcdc:
mediatek:
- use generic video mode function
exynos:
- S5PV210 FIMD variant support
- IPP v2 framework
- more HW overlays support"
* tag 'drm-next-2018-06-06-1' of git://anongit.freedesktop.org/drm/drm: (1286 commits)
drm/amdgpu: fix 32-bit build warning
drm/exynos: fimc: signedness bug in fimc_setup_clocks()
drm/exynos: scaler: fix static checker warning
drm/amdgpu: Use dev_info() to report amdkfd is not supported for this ASIC
drm/amd/display: Remove use of division operator for long longs
drm/amdgpu: Update GFX info structure to match what vega20 used
drm/amdgpu/pp: remove duplicate assignment
drm/sched: add rcu_barrier after entity fini
drm/amdgpu: move VM BOs on LRU again
drm/amdgpu: consistenly use VM moved flag
drm/amdgpu: kmap PDs/PTs in amdgpu_vm_update_directories
drm/amdgpu: further optimize amdgpu_vm_handle_moved
drm/amdgpu: cleanup amdgpu_vm_validate_pt_bos v2
drm/amdgpu: rework VM state machine lock handling v2
drm/amdgpu: Add runtime VCN PG support
drm/amdgpu: Enable VCN static PG by default on RV
drm/amdgpu: Add VCN static PG support on RV
drm/amdgpu: Enable VCN CG by default on RV
drm/amdgpu: Add static CG control for VCN on RV
drm/exynos: Fix default value for zpos plane property
Commit da069d5d2b814d9887989dcdb29fb0202eac8b38 ("gpio: dwapb: Rework
support for 1 interrupt per port A GPIO"), was an incremental patch that
was supposed to provide the delta between v5 and v6 patch set for
adding support for 1 interupt per port A GPIO. v5 was applied, then some
other feedback came afterwards.
However, in my haste I managed to drop the changes made to dwapb_port_property
struct. This patch includes those missing changes.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/soc
i.MX SoC update for 4.18:
- A series from Bartosz to convert all i.MX plaform code using
at24_platform_data to use at24 eeprom generic device properties.
- Enable pinctrl driver support for i.MX6SLL SoC.
- Clean up i.MX platform code using spi_imx platform data on outdated
documentation and chip select array usage.
* tag 'imx-soc-4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
ARM: imx: select imx6sll pinctrl when imx6sll enabled
ARM: imx: pcm037: use device properties for at24 eeprom
ARM: imx: pca100: use device properties for at24 eeprom
ARM: imx: pcm043: use device properties for at24 eeprom
ARM: imx: vpr200: drop at24_platform_data
ARM: imx: Update spi_imx platform data to reflect current state
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
DaVinci SoC support updates for v4.18
Mainly contains patches to move NAND chipselect to platform data
(currently platform device id is being used). These patches have
been acked by NAND maintainer and because of the driver dependency
an immutable branch has been provided to Boris.
The other patch is to remove an unnecessary postcore_initcall() on
DM644x which is needed for common clock framework conversion.
* tag 'davinci-for-v4.18/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: dm644x: remove unnecessary postcore_initcall()
ARM: davinci: aemif: stop using pdev->id as nand chipselect
mtd: rawnand: davinci: stop using pdev->id as chipselect
ARM: davinci: neuros-osd2: specify the chipselect in davinci_nand_pdata
ARM: davinci: dm646x-evm: specify the chipselect in davinci_nand_pdata
ARM: davinci: mityomapl138: specify the chipselect in davinci_nand_pdata
ARM: davinci: dm644x-evm: specify the chipselect in davinci_nand_pdata
ARM: davinci: dm365-evm: specify the chipselect in davinci_nand_pdata
ARM: davinci: dm355-leopard: specify the chipselect in davinci_nand_pdata
ARM: davinci: dm355-evm: specify the chipselect in davinci_nand_pdata
ARM: davinci: da850-evm: specify the chipselect in davinci_nand_pdata
ARM: davinci: da830-evm: specify the chipselect in davinci_nand_pdata
mtd: rawnand: davinci: store the core chipselect number in platform data
into drm-next
Please incorporate support for TDA998x I2C driver CEC
Link: https://patchwork.freedesktop.org/patch/msgid/20180424095456.GA32460@rmk-PC.armlinux.org.uk
The b53 driver already defines and internally uses platform data to let the
glue drivers specify parameters such as the chip id. What we were missing was
a way to tell the core DSA layer about the ports and their type.
Place a dsa_chip_data structure at the beginning of b53_platform_data for
dsa_register_switch() to access it. This does not require modifications to
b53_common.c which will pass platform_data trough.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Add the size of the EEPROM to the platform data, so it can also be
instantiated by a platform device.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Not all the world uses device tree. Some parts of the world still use
platform devices and platform data. Add basic support for probing a
Marvell switch via platform data.
