path: root/include/linux/platform_data/asoc-mx27vis.h
2012-09-17ASoC: mx27vis: retrieve gpio numbers from platform_dataShawn Guo
Rather than including mach/iomux-mx27.h to define gpio numbers and set up the pins, the patch moves all these into machine code and has the gpio numbers passed to driver via platform_data. As the result, we can remove the mach/iomux-mx27.h inclusion from driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
