path: root/include/linux/pktcdvd.h
2006-02-05[PATCH] pktcdvd: Allow larger packetsPhillip Susi
The pktcdvd driver uses a compile time macro constant to define the maximum supported packet length. I changed this from 32 sectors to 128 sectors because that allows over 100 MB of additional usable space on a 700 MB cdrw, and increases throughput. Note that you need a modified cdrwtool program that can format a CDRW disc with larger packets to benefit from this change. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] pktcdvd: Don't waste kernel memoryPeter Osterlund
Allocate memory for read-gathering at open time, when it is known just how much memory is needed. This avoids wasting kernel memory when the real packet size is smaller than the maximum packet size supported by the driver. This is always the case when using DVD discs. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] pktcdvd: Fix overflow for discs with large packetsPhillip Susi
The pktcdvd driver was using an 8 bit field to store the packet length obtained from the disc track info. This causes it to overflow packet length values of 128KB or more. I changed the field to 32 bits to fix this. The pktcdvd driver defaulted to its maximum allowed packet length when it detected a 0 in the track info field. I changed this to fail the operation and refuse to access the media. This seems more sane than attempting to access it with a value that almost certainly will not work. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] pktcdvd: BUG_ON cleanupsPeter Osterlund
Remove some redundant BUG_ON() statements in pktcdvd and move one run-time check to compile-time. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Improve CD/DVD packet driver write performancePeter Osterlund
This patch improves write performance for the CD/DVD packet writing driver. The logic for switching between reading and writing has been changed so that streaming writes are no longer interrupted by read requests. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
