path: root/include/linux/pagemap.h
2007-10-16fs: introduce write_begin, write_end, and perform_write aopsNick Piggin
These are intended to replace prepare_write and commit_write with more flexible alternatives that are also able to avoid the buffered write deadlock problems efficiently (which prepare_write is unable to do). [mark.fasheh@oracle.com: API design contributions, code review and fixes] [akpm@linux-foundation.org: various fixes] [dmonakhov@sw.ru: new aop block_write_begin fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm: fix pagecache write deadlocksNick Piggin
Modify the core write() code so that it won't take a pagefault while holding a lock on the pagecache page. There are a number of different deadlocks possible if we try to do such a thing: 1. generic_buffered_write 2. lock_page 3. prepare_write 4. unlock_page+vmtruncate 5. copy_from_user 6. mmap_sem(r) 7. handle_mm_fault 8. lock_page (filemap_nopage) 9. commit_write 10. unlock_page a. sys_munmap / sys_mlock / others b. mmap_sem(w) c. make_pages_present d. get_user_pages e. handle_mm_fault f. lock_page (filemap_nopage) 2,8 - recursive deadlock if page is same 2,8;2,8 - ABBA deadlock is page is different 2,6;b,f - ABBA deadlock if page is same The solution is as follows: 1. If we find the destination page is uptodate, continue as normal, but use atomic usercopies which do not take pagefaults and do not zero the uncopied tail of the destination. The destination is already uptodate, so we can commit_write the full length even if there was a partial copy: it does not matter that the tail was not modified, because if it is dirtied and written back to disk it will not cause any problems (uptodate *means* that the destination page is as new or newer than the copy on disk). 1a. The above requires that fault_in_pages_readable correctly returns access information, because atomic usercopies cannot distinguish between non-present pages in a readable mapping, from lack of a readable mapping. 2. If we find the destination page is non uptodate, unlock it (this could be made slightly more optimal), then allocate a temporary page to copy the source data into. Relock the destination page and continue with the copy. However, instead of a usercopy (which might take a fault), copy the data from the pinned temporary page via the kernel address space. (also, rename maxlen to seglen, because it was confusing) This increases the CPU/memory copy cost by almost 50% on the affected workloads. That will be solved by introducing a new set of pagecache write aops in a subsequent patch. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16filemap: convert some unsigned long to pgoff_tFengguang Wu
Convert some 'unsigned long' to pgoff_t. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Factor outstanding I/O error handlingGuillaume Chazarain
Cleanup: setting an outstanding error on a mapping was open coded too many times. Factor it out in mapping_set_error(). Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] mm: remove find_trylock_pageNick Piggin
Remove find_trylock_page as per the removal schedule. Signed-off-by: Nick Piggin <npiggin@suse.de> [ Let's see if anybody screams ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-28[PATCH] mm: clean up pagecache allocationNick Piggin
- Consolidate page_cache_alloc - Fix splice: only the pagecache pages and filesystem data need to use mapping_gfp_mask. - Fix grab_cache_page_nowait: same as splice, also honour NUMA placement. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm: non syncing lock_page()Nick Piggin
lock_page needs the caller to have a reference on the page->mapping inode due to sync_page, ergo set_page_dirty_lock is obviously buggy according to its comments. Solve it by introducing a new lock_page_nosync which does not do a sync_page. akpm: unpleasant solution to an unpleasant problem. If it goes wrong it could cause great slowdowns while the lock_page() caller waits for kblockd to perform the unplug. And if a filesystem has special sync_page() requirements (none presently do), permanent hangs are possible. otoh, set_page_dirty_lock() is usually (always?) called against userspace pages. They are always up-to-date, so there shouldn't be any pending read I/O against these pages. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_pagecache to per zone counterChristoph Lameter
Currently a single atomic variable is used to establish the size of the page cache in the whole machine. The zoned VM counters have the same method of implementation as the nr_pagecache code but also allow the determination of the pagecache size per zone. Remove the special implementation for nr_pagecache and make it a zoned counter named NR_FILE_PAGES. Updates of the page cache counters are always performed with interrupts off. We can therefore use the __ variant here. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-27[PATCH] Add find_get_pages_contig(): contiguous variant of find_get_pages()Jens Axboe
find_get_pages_contig() will break out if we hit a hole in the page cache. From Andrew Morton, small modifications and documentation by me. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-31[PATCH] mm: schedule find_trylock_page() removalNick Piggin
find_trylock_page() is an odd interface in that it doesn't take a reference like the others. Now that XFS no longer uses it, and its last remaining caller actually wants an elevated refcount, opencode that callsite and schedule find_trylock_page() for removal. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread page cache implementation and hooksPaul Jackson
Change the page cache allocation calls to support cpuset memory spreading. See the previous patch, cpuset_mem_spread, for an explanation of cpuset memory spreading. On systems without cpusets configured in the kernel, this is no change. On systems with cpusets configured in the kernel, but the "memory_spread" cpuset option not enabled for the current tasks cpuset, this adds a call to a cpuset routine and failed bit test of the processor state flag PF_SPREAD_PAGE. On tasks in cpusets with "memory_spread" enabled, this adds a call to a cpuset routine that computes which of the tasks mems_allowed nodes should be preferred for this allocation. If memory spreading applies to a particular allocation, then any other NUMA mempolicy does not apply. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] mm: gfp_noreclaim cleanupPaul Jackson
Remove last remnant of the defunct early reclaim page logic, the no longer used __GFP_NORECLAIM flag bit. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Martin Hicks <mort@bork.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: the restAl Viro
zone handling, mapping->flags handling Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: mm/* (easy parts)Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] VM: add __GFP_NORECLAIMMartin Hicks
When using the early zone reclaim, it was noticed that allocating new pages that should be spread across the whole system caused eviction of local pages. This adds a new GFP flag to prevent early reclaim from happening during certain allocation attempts. The example that is implemented here is for page cache pages. We want page cache pages to be spread across the whole system, and we don't want page cache pages to evict other pages to get local memory. Signed-off-by: Martin Hicks <mort@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
