[ Upstream commit 8fb156c9ee2db94f7127c930c89917634a1a9f56 ]
The implementation of split_page_owner() prefers a count rather than the
old order of the page. When we support a variable size THP, we won't
have the order at this point, but we will have the number of pages.
So change the interface to what the caller and callee would prefer.
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
Reviewed-by: SeongJae Park <sjpark@amazon.de>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Huang Ying <ying.huang@intel.com>
Link: https://lkml.kernel.org/r/20200908195539.25896-4-willy@infradead.org
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
There is no reason that page_owner specific function resides on
vmstat.c.
Link: http://lkml.kernel.org/r/1471315879-32294-4-git-send-email-iamjoonsoo.kim@lge.com
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Michal Hocko <mhocko@kernel.org>
split_page() calls set_page_owner() to set up page_owner to each pages.
But, it has a drawback that head page and the others have different
stacktrace because callsite of set_page_owner() is slightly differnt.
To avoid this problem, this patch copies head page's page_owner to the
others. It needs to introduce new function, split_page_owner() but it
also remove the other function, get_page_owner_gfp() so looks good to
do.
Link: http://lkml.kernel.org/r/1464230275-25791-4-git-send-email-iamjoonsoo.kim@lge.com
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Alexander Potapenko <glider@google.com>
The page_owner mechanism is useful for dealing with memory leaks. By
reading /sys/kernel/debug/page_owner one can determine the stack traces
leading to allocations of all pages, and find e.g. a buggy driver.
This information might be also potentially useful for debugging, such as
the VM_BUG_ON_PAGE() calls to dump_page(). So let's print the stored
info from dump_page().
Example output:
page:ffffea000292f1c0 count:1 mapcount:0 mapping:ffff8800b2f6cc18 index:0x91d
flags: 0x1fffff8001002c(referenced|uptodate|lru|mappedtodisk)
page dumped because: VM_BUG_ON_PAGE(1)
page->mem_cgroup:ffff8801392c5000
page allocated via order 0, migratetype Movable, gfp_mask 0x24213ca(GFP_HIGHUSER_MOVABLE|__GFP_COLD|__GFP_NOWARN|__GFP_NORETRY)
[<ffffffff811682c4>] __alloc_pages_nodemask+0x134/0x230
[<ffffffff811b40c8>] alloc_pages_current+0x88/0x120
[<ffffffff8115e386>] __page_cache_alloc+0xe6/0x120
[<ffffffff8116ba6c>] __do_page_cache_readahead+0xdc/0x240
[<ffffffff8116bd05>] ondemand_readahead+0x135/0x260
[<ffffffff8116be9c>] page_cache_async_readahead+0x6c/0x70
[<ffffffff811604c2>] generic_file_read_iter+0x3f2/0x760
[<ffffffff811e0dc7>] __vfs_read+0xa7/0xd0
page has been migrated, last migrate reason: compaction
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
During migration, page_owner info is now copied with the rest of the
page, so the stacktrace leading to free page allocation during migration
is overwritten. For debugging purposes, it might be however useful to
know that the page has been migrated since its initial allocation. This
might happen many times during the lifetime for different reasons and
fully tracking this, especially with stacktraces would incur extra
memory costs. As a compromise, store and print the migrate_reason of
the last migration that occurred to the page. This is enough to
distinguish compaction, numa balancing etc.
Example page_owner entry after the patch:
Page allocated via order 0, mask 0x24200ca(GFP_HIGHUSER_MOVABLE)
PFN 628753 type Movable Block 1228 type Movable Flags 0x1fffff80040030(dirty|lru|swapbacked)
[<ffffffff811b6325>] alloc_pages_vma+0xb5/0x250
[<ffffffff81177491>] shmem_alloc_page+0x61/0x90
[<ffffffff8117a438>] shmem_getpage_gfp+0x678/0x960
[<ffffffff8117c2b9>] shmem_fallocate+0x329/0x440
[<ffffffff811de600>] vfs_fallocate+0x140/0x230
[<ffffffff811df434>] SyS_fallocate+0x44/0x70
[<ffffffff8158cc2e>] entry_SYSCALL_64_fastpath+0x12/0x71
Page has been migrated, last migrate reason: compaction
Cc: Michal Hocko <mhocko@suse.com>
The page_owner mechanism stores gfp_flags of an allocation and stack
trace that lead to it. During page migration, the original information
is practically replaced by the allocation of free page as the migration
target. Arguably this is less useful and might lead to all the
page_owner info for migratable pages gradually converge towards
compaction or numa balancing migrations. It has also lead to
inaccuracies such as one fixed by commit e2cfc91120fa ("mm/page_owner:
set correct gfp_mask on page_owner").
This patch thus introduces copying the page_owner info during migration.
However, since the fact that the page has been migrated from its
original place might be useful for debugging, the next patch will
introduce a way to track that information as well.
CONFIG_PAGE_OWNER attempts to impose negligible runtime overhead when
enabled during compilation, but not actually enabled during runtime by
boot param page_owner=on. This overhead can be further reduced using
the static key mechanism, which this patch does.
Currently, we set wrong gfp_mask to page_owner info in case of isolated
freepage by compaction and split page. It causes incorrect mixed
pageblock report that we can get from '/proc/pagetypeinfo'. This metric
is really useful to measure fragmentation effect so should be accurate.
This patch fixes it by setting correct information.
Without this patch, after kernel build workload is finished, number of
mixed pageblock is 112 among roughly 210 movable pageblocks.
But, with this fix, output shows that mixed pageblock is just 57.
This is the page owner tracking code which is introduced so far ago. It
is resident on Andrew's tree, though, nobody tried to upstream so it
remain as is. Our company uses this feature actively to debug memory leak
or to find a memory hogger so I decide to upstream this feature.
This functionality help us to know who allocates the page. When
allocating a page, we store some information about allocation in extra
memory. Later, if we need to know status of all pages, we can get and
analyze it from this stored information.
In previous version of this feature, extra memory is statically defined in
struct page, but, in this version, extra memory is allocated outside of
struct page. It enables us to turn on/off this feature at boottime
without considerable memory waste.
Although we already have tracepoint for tracing page allocation/free,
using it to analyze page owner is rather complex. We need to enlarge the
trace buffer for preventing overlapping until userspace program launched.
And, launched program continually dump out the trace buffer for later
analysis and it would change system behaviour with more possibility rather
than just keeping it in memory, so bad for debug.
Moreover, we can use page_owner feature further for various purposes. For
example, we can use it for fragmentation statistics implemented in this
patch. And, I also plan to implement some CMA failure debugging feature
using this interface.
I'd like to give the credit for all developers contributed this feature,
but, it's not easy because I don't know exact history. Sorry about that.
Below is people who has "Signed-off-by" in the patches in Andrew's tree.
Contributor:
Alexander Nyberg <alexn@dsv.su.se>
Dave Hansen <dave@linux.vnet.ibm.com>
Michal Nazarewicz <mina86@mina86.com>
Jungsoo Son <jungsoo.son@lge.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Jungsoo Son <jungsoo.son@lge.com>
