Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
of_can_translate_address only checks some conditions for address
translation, but does not check other conditions like having range
properties. The checks it does do are redundant with
__of_address_translate. The only difference is printing a message or
not. Since we only have a single caller that does the full translation
anyway, just remove of_can_translate_address and quiet the error
message.
Cc: Grant Likely <grant.likely@linaro.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Tested-by: Frank Rowand <frank.rowand@sonymobile.com>
Reviewed-by: Frank Rowand <frank.rowand@sonymobile.com>
The of_dma_is_coherent() helper parses the given DT device
node to see if the "dma-coherent" property is supported and
returns true or false accordingly.
If the arch is always coherent or always noncoherent, then the default
DMA ops has to be specified accordingly.
Cc: Olof Johansson <olof@lixom.net>
Cc: Linus Walleij <linus.walleij@linaro.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
The of_dma_get_range() allows to find "dma-range" property for
the specified device and parse it.
dma-ranges format:
DMA addr (dma_addr) : naddr cells
CPU addr (phys_addr_t) : pna cells
of_translate_dma_address is implemented in common code, so move the
declaration there too.
Acked-by: Grant Likely <grant.likely@linaro.org>
Cc: linuxppc-dev@lists.ozlabs.org
Move of_address_to_resource and of_iomap declarations to common code. These
only differ on sparc, but the declarations are the same and don't need to
be in arch header.
Cc: sparclinux@vger.kernel.org
Implement pci_address_to_pio as weak function to remove the dependency on
asm/prom.h. This is in preparation to make prom.h optional.
Cc: x86@kernel.org
This patch factors out common implementation patterns to reduce overall kernel
code and provide a means for host bridge drivers to directly obtain struct
resources from the DT's ranges property without relying on architecture specific
DT handling. This will make it easier to write archiecture independent host bridge
drivers and mitigate against further duplication of DT parsing code.
This patch can be used in the following way:
struct of_pci_range_parser parser;
struct of_pci_range range;
if (of_pci_range_parser_init(&parser, np))
; //no ranges property
for_each_of_pci_range(&parser, &range) {
directly access properties of the address range, e.g.:
range.pci_space, range.pci_addr, range.cpu_addr,
range.size, range.flags
alternatively obtain a struct resource, e.g.:
struct resource res;
of_pci_range_to_resource(&range, np, &res);
Additionally the implementation takes care of adjacent ranges and merges them
into a single range (as was the case with powerpc and microblaze).
Signed-off-by: Andrew Murray <Andrew.Murray@arm.com>
Signed-off-by: Liviu Dudau <Liviu.Dudau@arm.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Rob Herring <rob.herring@calxeda.com>
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Tested-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This bug-fix makes sure that of_iomap is defined extern for sparc so that the
sparc-specific implementation of_iomap is once again used when including
include/linux/of_address.h in a sparc context. OF_GPIO that is now available for
sparc relies on this.
The bug was inadvertently introduced in a850a75, "of/address: add empty static
inlines for !CONFIG_OF", that added a static dummy inline for of_iomap when
!CONFIG_OF_ADDRESS. However, CONFIG_OF_ADDRESS is never defined for sparc, but
there is a sparc-specific implementation /arch/sparc/kernel/of_device_common.c.
This fix takes the same approach as 0bce04b that solved the equivalent problem
for of_address_to_resource.
Signed-off-by: Andreas Larsson <andreas@gaisler.com>
Acked-by: David Miller <davem@davemloft.net>
for sparc again
This bug-fix makes sure that of_address_to_resource is defined extern for sparc
so that the sparc-specific implementation of of_address_to_resource() is once
again used when including include/linux/of_address.h in a sparc context. A
number of drivers in mainline relies on this function working for sparc.
The bug was introduced in a850a7554442f08d3e910c6eeb4ee216868dda1e, "of/address:
add empty static inlines for !CONFIG_OF". Contrary to that commit title, the
static inlines are added for !CONFIG_OF_ADDRESS, and CONFIG_OF_ADDRESS is never
defined for sparc. This is good behavior for the other functions in
include/linux/of_address.h, as the extern functions defined in
drivers/of/address.c only gets linked when OF_ADDRESS is configured. However,
for of_address_to_resource there exists a sparc-specific implementation in
arch/sparc/arch/sparc/kernel/of_device_common.c
Solution suggested by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Rob Herring <rob.herring@calxeda.com>
drivers/of/address.c:66:29: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:66:29: expected restricted __be32 const [usertype] *cell
drivers/of/address.c:66:29: got unsigned int [usertype] *addr
drivers/of/address.c:87:32: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:87:32: expected restricted __be32 const [usertype] *cell
drivers/of/address.c:87:32: got unsigned int [usertype] *addr
drivers/of/address.c:91:30: warning: incorrect type in assignment (different base types)
drivers/of/address.c:91:30: expected unsigned int [unsigned] [usertype] <noident>
drivers/of/address.c:91:30: got restricted __be32 [usertype] <noident>
drivers/of/address.c:92:22: warning: incorrect type in assignment (different base types)
drivers/of/address.c:92:22: expected unsigned int [unsigned] [usertype] <noident>
drivers/of/address.c:92:22: got restricted __be32 [usertype] <noident>
drivers/of/address.c:147:35: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:147:35: expected restricted __be32 const [usertype] *addr
drivers/of/address.c:147:35: got unsigned int [usertype] *addr
drivers/of/address.c:157:34: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:157:34: expected restricted __be32 const [usertype] *cell
drivers/of/address.c:157:34: got unsigned int [usertype] *
drivers/of/address.c:256:29: warning: restricted __be32 degrades to integer
drivers/of/address.c:256:36: warning: restricted __be32 degrades to integer
drivers/of/address.c:262:34: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:262:34: expected restricted __be32 const [usertype] *cell
drivers/of/address.c:262:34: got unsigned int [usertype] *
drivers/of/address.c:372:41: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:372:41: expected restricted __be32 const [usertype] *cell
drivers/of/address.c:372:41: got unsigned int [usertype] *addr
drivers/of/address.c:395:53: warning: incorrect type in argument 2 (different base types)
drivers/of/address.c:395:53: expected restricted __be32 const [usertype] *addr
drivers/of/address.c:395:53: got unsigned int [usertype] *addr
drivers/of/address.c:443:50: warning: incorrect type in argument 2 (different base types)
drivers/of/address.c:443:50: expected restricted __be32 const [usertype] *addr
drivers/of/address.c:443:50: got unsigned int *<noident>
drivers/of/address.c:455:49: warning: incorrect type in argument 1 (different base types)
drivers/of/address.c:455:49: expected restricted __be32 const [usertype] *cell
drivers/of/address.c:455:49: got unsigned int *<noident>
drivers/of/address.c:480:60: warning: incorrect type in argument 2 (different base types)
drivers/of/address.c:480:60: expected restricted __be32 const [usertype] *addr
drivers/of/address.c:480:60: got unsigned int *<noident>
drivers/of/address.c:412:5: warning: symbol '__of_translate_address' was not declared. Should it be static?
drivers/of/address.c:520:14: error: symbol 'of_get_address' redeclared with different type (originally declared at include/linux/of_address.h:22) - different base types
It's quite legitimate for a DT node to specify #size-cells=0. One example
is a node that's used to collect a number of non-memory-mapped devices.
In that scenario, there may be multiple child nodes with the same name
(type) thus necessitating the use of unit addresses in node names, and
reg properties:
regulators {
compatible = "simple-bus";
#address-cells = <1>;
#size-cells = <0>;
regulator@0 {
compatible = "regulator-fixed";
reg = <0>;
regulator@1 {
reg = <1>;
However, #size-cells=0 prevents translation of reg property values into
the parent node's address space. In turn, this triggers the kernel to
emit error messages during boot, such as:
prom_parse: Bad cell count for /regulators/regulator@0
To prevent printing these error messages for legitimate DT content, a
number of changes are made:
1) of_get_address()/of_get_pci_address() are modified only to validate
the value of #address-cells, and not #size-cells.
2) of_can_translate_address() is added to indicate whether address
translation is possible.
3) of_device_make_bus_id() is modified to name devices based on the
translated address only where possible, and otherwise fall back to
using the (first cell of the) raw untranslated address.
4) of_device_alloc() is modified to create memory resources for a device
only if the address can be translated into the CPU's address space.
As the title says, this patch adds empty implementations for the address
translation functions so that they can be used when CONFIG_OF is disabled.
Cc: Rob Herring <rob.herring@calxeda.com>
of_address.h makes reference to some of the error code #defines, so it
needs to include errno.h. If CONFIG_PCI is not selected, then some files
will fail to compile.
of_find_matching_node_by_address() can be used to find a device tree
node for a device at a specific address.
This patch changes u32 to __be32 for all "ranges", "prop" and "addr" and
such. Those variables are pointing to the device tree which contains
integers in big endian format.
Most functions are doing it right because of_read_number() is doing the
right thing for them. of_bus_isa_get_flags(), of_bus_pci_get_flags() and
of_bus_isa_map() were accessing the data directly and were doing it wrong.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
This patch moves the declaration of of_get_address(), of_get_pci_address(),
and of_pci_address_to_resource() out of arch code and into the common
linux/of_address header file.
This patch also fixes some of the asm/prom.h ordering issues. It still
includes some header files that it ideally shouldn't be, but at least the
ordering is consistent now so that of_* overrides work.
Microblaze and PowerPC share a large chunk of code for translating
OF device tree data into usable addresses. Differences between the two
consist of cosmetic differences, and the addition of dma-ranges support
code to powerpc but not microblaze. This patch moves the powerpc
version into common code and applies many of the cosmetic (non-functional)
changes from the microblaze version.
CC: Michal Simek <monstr@monstr.eu>
CC: Wolfram Sang <w.sang@pengutronix.de>
CC: Stephen Rothwell <sfr@canb.auug.org.au>
Merge common code between PowerPC and Microblaze. This patch also
moves the prototype of pci_address_to_pio() out of pci-bridge.h and
into prom.h because the only user of pci_address_to_pio() is
of_address_to_resource().
Merge common code between Microblaze and PowerPC. This patch creates
new of_address.h and address.c files to containing address translation
and mapping routines. First routine to be moved it of_iomap()
