path: root/include/linux/nsproxy.h
2011-07-20make sure that nsproxy_cache is initialized early enoughAl Viro
2011-05-26cgroup: remove the ns_cgroupDaniel Lezcano
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and leads to some problems: * cgroup creation is out-of-control * cgroup name can conflict when pids are looping * it is not possible to have a single process handling a lot of namespaces without falling in a exponential creation time * we may want to create a namespace without creating a cgroup The ns_cgroup was replaced by a compatibility flag 'clone_children', where a newly created cgroup will copy the parent cgroup values. The userspace has to manually create a cgroup and add a task to the 'tasks' file. This patch removes the ns_cgroup as suggested in the following thread: https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html The 'cgroup_clone' function is removed because it is no longer used. This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a printk warning users that the feature is planned for removal. Since that time we have heard from XXX users who were affected by this. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-24User namespaces: set of cleanups (v2)Serge Hallyn
The user_ns is moved from nsproxy to user_struct, so that a struct cred by itself is sufficient to determine access (which it otherwise would not be). Corresponding ecryptfs fixes (by David Howells) are here as well. Fix refcounting. The following rules now apply: 1. The task pins the user struct. 2. The user struct pins its user namespace. 3. The user namespace pins the struct user which created it. User namespaces are cloned during copy_creds(). Unsharing a new user_ns is no longer possible. (We could re-add that, but it'll cause code duplication and doesn't seem useful if PAM doesn't need to clone user namespaces). When a user namespace is created, its first user (uid 0) gets empty keyrings and a clean group_info. This incorporates a previous patch by David Howells. Here is his original patch description: >I suggest adding the attached incremental patch. It makes the following >changes: > > (1) Provides a current_user_ns() macro to wrap accesses to current's user > namespace. > > (2) Fixes eCryptFS. > > (3) Renames create_new_userns() to create_user_ns() to be more consistent > with the other associated functions and because the 'new' in the name is > superfluous. > > (4) Moves the argument and permission checks made for CLONE_NEWUSER to the > beginning of do_fork() so that they're done prior to making any attempts > at allocation. > > (5) Calls create_user_ns() after prepare_creds(), and gives it the new creds > to fill in rather than have it return the new root user. I don't imagine > the new root user being used for anything other than filling in a cred > struct. > > This also permits me to get rid of a get_uid() and a free_uid(), as the > reference the creds were holding on the old user_struct can just be > transferred to the new namespace's creator pointer. > > (6) Makes create_user_ns() reset the UIDs and GIDs of the creds under > preparation rather than doing it in copy_creds(). > >David >Signed-off-by: David Howells <dhowells@redhat.com> Changelog: Oct 20: integrate dhowells comments 1. leave thread_keyring alone 2. use current_user_ns() in set_user() Signed-off-by: Serge Hallyn <serue@us.ibm.com>
2008-07-25cgroup_clone: use pid of newly created task for new cgroupSerge E. Hallyn
cgroup_clone creates a new cgroup with the pid of the task. This works correctly for unshare, but for clone cgroup_clone is called from copy_namespaces inside copy_process, which happens before the new pid is created. As a result, the new cgroup was created with current's pid. This patch: 1. Moves the call inside copy_process to after the new pid is created 2. Passes the struct pid into ns_cgroup_clone (as it is not yet attached to the task) 3. Passes a name from ns_cgroup_clone() into cgroup_clone() so as to keep cgroup_clone() itself simpler 4. Uses pid_vnr() to get the process id value, so that the pid used to name the new cgroup is always the pid as it would be known to the task which did the cloning or unsharing. I think that is the most intuitive thing to do. This way, task t1 does clone(CLONE_NEWPID) to get t2, which does clone(CLONE_NEWPID) to get t3, then the cgroup for t3 will be named for the pid by which t2 knows t3. (Thanks to Dan Smith for finding the main bug) Changelog: June 11: Incorporate Paul Menage's feedback: don't pass NULL to ns_cgroup_clone from unshare, and reduce patch size by using 'nodename' in cgroup_clone. June 10: Original version [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge Hallyn <serge@us.ibm.com> Acked-by: Paul Menage <menage@google.com> Tested-by: Dan Smith <danms@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Make access to task's nsproxy lighterPavel Emelyanov
When someone wants to deal with some other taks's namespaces it has to lock the task and then to get the desired namespace if the one exists. This is slow on read-only paths and may be impossible in some cases. E.g. Oleg recently noticed a race between unshare() and the (sent for review in cgroups) pid namespaces - when the task notifies the parent it has to know the parent's namespace, but taking the task_lock() is impossible there - the code is under write locked tasklist lock. On the other hand switching the namespace on task (daemonize) and releasing the namespace (after the last task exit) is rather rare operation and we can sacrifice its speed to solve the issues above. The access to other task namespaces is proposed to be performed like this: rcu_read_lock(); nsproxy = task_nsproxy(tsk); if (nsproxy != NULL) { / * * work with the namespaces here * e.g. get the reference on one of them * / } / * * NULL task_nsproxy() means that this task is * almost dead (zombie) * / rcu_read_unlock(); This patch has passed the review by Eric and Oleg :) and, of course, tested. [clg@fr.ibm.com: fix unshare()] [ebiederm@xmission.com: Update get_net_ns_by_pid] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cgroups: implement namespace tracking subsystemSerge E. Hallyn
When a task enters a new namespace via a clone() or unshare(), a new cgroup is created and the task moves into it. This version names cgroups which are automatically created using cgroup_clone() as "node_<pid>" where pid is the pid of the unsharing or cloned process. (Thanks Pavel for the idea) This is safe because if the process unshares again, it will create /cgroups/(...)/node_<pid>/node_<pid> The only possibilities (AFAICT) for a -EEXIST on unshare are 1. pid wraparound 2. a process fails an unshare, then tries again. Case 1 is unlikely enough that I ignore it (at least for now). In case 2, the node_<pid> will be empty and can be rmdir'ed to make the subsequent unshare() succeed. Changelog: Name cloned cgroups as "node_<pid>". [clg@fr.ibm.com: fix order of cgroup subsystems in init/Kconfig] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Remove unused member from nsproxyPavel Emelyanov
The nslock spinlock is not used in the kernel at all. Remove it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Add a network namespace parameter to tasksEric W. Biederman
This is the network namespace from which all which all sockets and anything else under user control ultimately get their network namespace parameters. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16namespace: ensure clone_flags are always stored in an unsigned longEric W. Biederman
While working on unshare support for the network namespace I noticed we were putting clone flags in an int. Which is weird because the syscall uses unsigned long and we at least need an unsigned to properly hold all of the unshare flags. So to make the code consistent, this patch updates the code to use unsigned long instead of int for the clone flags in those places where we get it wrong today. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16user namespace: add the frameworkCedric Le Goater
Basically, it will allow a process to unshare its user_struct table, resetting at the same time its own user_struct and all the associated accounting. A new root user (uid == 0) is added to the user namespace upon creation. Such root users have full privileges and it seems that theses privileges should be controlled through some means (process capabilities ?) The unshare is not included in this patch. Changes since [try #4]: - Updated get_user_ns and put_user_ns to accept NULL, and get_user_ns to return the namespace. Changes since [try #3]: - moved struct user_namespace to files user_namespace.{c,h} Changes since [try #2]: - removed struct user_namespace* argument from find_user() Changes since [try #1]: - removed struct user_namespace* argument from find_user() - added a root_user per user namespace Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Andrew Morgan <agm@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Revert "[PATCH] namespaces: fix exit race by splitting exit"Linus Torvalds
This reverts commit 7a238fcba0629b6f2edbcd37458bae56fcf36be5 in preparation for a better and simpler fix proposed by Eric Biederman (and fixed up by Serge Hallyn) Acked-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] namespaces: fix exit race by splitting exitSerge E. Hallyn
Fix exit race by splitting the nsproxy putting into two pieces. First piece reduces the nsproxy refcount. If we dropped the last reference, then it puts the mnt_ns, and returns the nsproxy as a hint to the caller. Else it returns NULL. The second piece of exiting task namespaces sets tsk->nsproxy to NULL, and drops the references to other namespaces and frees the nsproxy only if an nsproxy was passed in. A little awkward and should probably be reworked, but hopefully it fixes the NFS oops. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Daniel Hokka Zakrisson <daniel@hozac.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] Revert "[PATCH] identifier to nsproxy"Eric W. Biederman
This reverts commit 373beb35cd6b625e0ba4ad98baace12310a26aa8. No one is using this identifier yet. The purpose of this identifier is to export nsproxy to user space which is wrong. nsproxy is an internal implementation optimization, which should keep our fork times from getting slower as we increase the number of global namespaces you don't have to share. Adding a global identifier like this is inappropriate because it makes namespaces inherently non-recursive, greatly limiting what we can do with them in the future. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] to nsproxyCedric Le Goater
Add the pid namespace framework to the nsproxy object. The copy of the pid namespace only increases the refcount on the global pid namespace, init_pid_ns, and unshare is not implemented. There is no configuration option to activate or deactivate this feature because this not relevant for the moment. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] identifier to nsproxyCedric Le Goater
Add an identifier to nsproxy. The default init_ns_proxy has identifier 0 and allocated nsproxies are given -1. This identifier will be used by a new syscall sys_bind_ns. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] rename struct namespace to struct mnt_namespaceKirill Korotaev
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with other namespaces being developped for the containers : pid, uts, ipc, etc. 'namespace' variables and attributes are also renamed to 'mnt_ns' Signed-off-by: Kirill Korotaev <dev@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] mounstats NULL pointer dereferenceVasily Tarasov
OpenVZ developers team has encountered the following problem in 2.6.19-rc6 kernel. After some seconds of running script while [[ 1 ]] do find /proc -name mountstats | xargs cat done this Oops appears: BUG: unable to handle kernel NULL pointer dereference at virtual address 00000010 printing eip: c01a6b70 *pde = 00000000 Oops: 0000 [#1] SMP Modules linked in: xt_length ipt_ttl xt_tcpmss ipt_TCPMSS iptable_mangle iptable_filter xt_multiport xt_limit ipt_tos ipt_REJECT ip_tables x_tables parport_pc lp parport sunrpc af_packet thermal processor fan button battery asus_acpi ac ohci_hcd ehci_hcd usbcore i2c_nforce2 i2c_core tg3 floppy pata_amd ide_cd cdrom sata_nv libata CPU: 1 EIP: 0060:[<c01a6b70>] Not tainted VLI EFLAGS: 00010246 (2.6.19-rc6 #2) EIP is at mountstats_open+0x70/0xf0 eax: 00000000 ebx: e6247030 ecx: e62470f8 edx: 00000000 esi: 00000000 edi: c01a6b00 ebp: c33b83c0 esp: f4105eb4 ds: 007b es: 007b ss: 0068 Process cat (pid: 6044, ti=f4105000 task=f4104a70 task.ti=f4105000) Stack: c33b83c0 c04ee940 f46a4a80 c33b83c0 e4df31b4 c01a6b00 f4105000 c0169231 e4df31b4 c33b83c0 c33b83c0 f4105f20 00000003 f4105000 c0169445 f2503cf0 f7f8c4c0 00008000 c33b83c0 00000000 00008000 c0169350 f4105f20 00008000 Call Trace: [<c01a6b00>] mountstats_open+0x0/0xf0 [<c0169231>] __dentry_open+0x181/0x250 [<c0169445>] nameidata_to_filp+0x35/0x50 [<c0169350>] do_filp_open+0x50/0x60 [<c01873d6>] seq_read+0xc6/0x300 [<c0169511>] get_unused_fd+0x31/0xc0 [<c01696d3>] do_sys_open+0x63/0x110 [<c01697a7>] sys_open+0x27/0x30 [<c01030bd>] sysenter_past_esp+0x56/0x79 ======================= Code: 45 74 8b 54 24 20 89 44 24 08 8b 42 f0 31 d2 e8 47 cb f8 ff 85 c0 89 c3 74 51 8d 80 a0 04 00 00 e8 46 06 2c 00 8b 83 48 04 00 00 <8b> 78 10 85 ff 74 03 f0 ff 07 b0 01 86 83 a0 04 00 00 f0 ff 4b EIP: [<c01a6b70>] mountstats_open+0x70/0xf0 SS:ESP 0068:f4105eb4 The problem is that task->nsproxy can be equal NULL for some time during task exit. This patch fixes the BUG. Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace coreKirill Korotaev
This patch set allows to unshare IPCs and have a private set of IPC objects (sem, shm, msg) inside namespace. Basically, it is another building block of containers functionality. This patch implements core IPC namespace changes: - ipc_namespace structure - new config option CONFIG_IPC_NS - adds CLONE_NEWIPC flag - unshare support [clg@fr.ibm.com: small fix for unshare of ipc namespace] [akpm@osdl.org: build fix] Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: implement utsname namespacesSerge E. Hallyn
This patch defines the uts namespace and some manipulators. Adds the uts namespace to task_struct, and initializes a system-wide init namespace. It leaves a #define for system_utsname so sysctl will compile. This define will be removed in a separate patch. [akpm@osdl.org: build fix, cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: incorporate fs namespace into nsproxySerge E. Hallyn
This moves the mount namespace into the nsproxy. The mount namespace count now refers to the number of nsproxies point to it, rather than the number of tasks. As a result, the unshare_namespace() function in kernel/fork.c no longer checks whether it is being shared. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: add nsproxySerge E. Hallyn
This patch adds a nsproxy structure to the task struct. Later patches will move the fs namespace pointer into this structure, and introduce a new utsname namespace into the nsproxy. The vserver and openvz functionality, then, would be implemented in large part by virtualizing/isolating more and more resources into namespaces, each contained in the nsproxy. [akpm@osdl.org: build fix] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
