path: root/include/linux/node.h
2006-06-27[PATCH] node hotplug: register cpu: remove node structKAMEZAWA Hiroyuki
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now considering node-hot-add with cpu + memory on ACPI. I found acpi container, which describes node, could evaluate cpu before memory. This means cpu-hot-add occurs before memory hot add. In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(), which creates symbolic link from node to cpu, requires that node should be onlined before register_cpu(). When a node is onlined, its pgdat should be there. This patch-set holds off creating symbolic link from node to cpu until node is onlined. This removes node arguments from register_cpu(). Now, register_cpu() requires 'struct node' as its argument. But the array of struct node is now unified in driver/base/node.c now (By Goto's node hotplug patch). We can get struct node in generic way. So, this argument is not necessary now. This patch also guarantees add cpu under node only when node is onlined. It is necessary for node-hot-add vs. cpu-hot-add patch following this. Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard to its 'struct node *root' argument. This patch removes it. Also modify callers of register_cpu()/unregister_cpu, whose args are changed by register-cpu-remove-node-struct patch. [Brice.Goglin@ens-lyon.org: fix it] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] Register sysfs file for hotplugged new nodeYasunori Goto
When new node becomes enable by hot-add, new sysfs file must be created for new node. So, if new node is enabled by add_memory(), register_one_node() is called to create it. In addition, I386's arch_register_node() and a part of register_nodes() of powerpc are consolidated to register_one_node() as a generic_code(). This is tested by Tiger4(IPF) with node hot-plug emulation. Signed-off-by: Keiichiro Tokunaga <tokuanga.keiich@jp.fujitsu.com> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver core: unregister_node() for hotplug useKeiichiro Tokunaga
This adds a generic function 'unregister_node()'. It is used to remove objects of a node going away for hotplug. All the devices on the node must be unregistered before calling this function. Signed-off-by: Keiichiro Tokunaga <tokunaga.keiich@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -puN drivers/base/node.c~numa_hp_base drivers/base/node.c
