path: root/include/linux/nl80211.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-09-18cfg80211/nl80211: Notify connection request failure in AP modePandiyarajan Pitchaimuthu
In AP mode, when a station requests connection to an AP and if the request is failed for particular reason, userspace is notified about the failure through NL80211_CMD_CONN_FAILED command. Reason for the failure is sent through the attribute NL80211_ATTR_CONN_FAILED_REASON. Signed-off-by: Pandiyarajan Pitchaimuthu <c_ppitch@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-20cfg80211: add P2P Device abstractionJohannes Berg
In order to support using a different MAC address for the P2P Device address we must first have a P2P Device abstraction that can be assigned a MAC address. This abstraction will also be useful to support offloading P2P operations to the device, e.g. periodic listen for discoverability. Currently, the driver is responsible for assigning a MAC address to the P2P Device, but this could be changed by allowing a MAC address to be given to the NEW_INTERFACE command. As it has no associated netdev, a P2P Device can only be identified by its wdev identifier but the previous patches allowed using the wdev identifier in various APIs, e.g. remain-on-channel. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-17cfg80211: add cellular base station regulatory hint supportLuis R. Rodriguez
Cellular base stations can provide hints to cfg80211 about where they think we are. This can be done for example on a cell phone. To enable these hints we simply allow them through as user regulatory hints but we allow userspace to clasify the hint as either coming directly from the user or coming from a cellular base station. This option is only available when you enable CONFIG_CFG80211_CERTIFICATION_ONUS. The base station hints themselves will not be processed by the core unless at least one device on the system supports this feature. Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-17cfg80211: support TX error rate CQMThomas Pedersen
Let the user configure serveral TX error conection quality monitoring parameters: % error rate, survey interval, and # of attempted packets. On exceeding the TX failure rate over the given interval, the driver will send a CQM notify event with the actual TX failure rate and packets attempted. Signed-off-by: Thomas Pedersen <c_tpeder@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-09nl80211: prepare for non-netdev wireless devsJohannes Berg
In order to support a P2P device abstraction and Bluetooth high-speed AMPs, we need to have a way to identify virtual interfaces that don't have a netdev associated. Do this by adding a NL80211_ATTR_WDEV attribute to identify a wdev which may or may not also be a netdev. To simplify things, use a 64-bit value with the high 32 bits being the wiphy index for this new wdev identifier in the nl80211 API. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-05{nl,cfg}80211: support high bitratesVladimir Kondratiev
Until now, a u16 value was used to represent bitrate value. With VHT bitrates this becomes too small. Introduce a new 32-bit bitrate attribute. nl80211 will report both the new and the old attribute, unless the bitrate doesn't fit into the old u16 attribute in which case only the new one will be reported. User space tools encouraged to prefer the 32-bit attribute, if available (since it won't be available on older kernels.) Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> [reword commit message and comments a bit] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-02cfg80211: add 802.11ad (60gHz band) supportVladimir Kondratiev
Add enumerations for both cfg80211 and nl80211. This expands wiphy.bands etc. arrays. Extend channel <-> frequency translation to cover 60g band and modify the rate check logic since there are no legacy mandatory rates (only MCS is used.) Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-28cfg80211: allow advertising VHT capabilitiesMahesh Palivela
Allow drivers to advertise their VHT capabilities and export them to userspace via nl80211. Signed-off-by: Mahesh Palivela <maheshp@posedge.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-26nl80211: specify RSSI threshold in scheduled scanThomas Pedersen
Support configuring an RSSI threshold in dBm (s32) when requesting scheduled scan, below which a BSS won't be reported by the cfg80211 driver. Signed-off-by: Thomas Pedersen <c_tpeder@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-18{nl,cfg,mac}80211: implement dot11MeshHWMPconfirmationIntervalChun-Yeow Yeoh
As defined in section 13.10.9.3 Case D (802.11-2012), this control variable is used to limit the mesh STA to send only one PREQ to a root mesh STA within this interval of time (in TUs). The default value for this variable is set to 2000 TUs. However, for current implementation, the maximum configurable of dot11MeshHWMPconfirmationInterval is restricted by dot11MeshHWMPactivePathTimeout. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> [line-break commit log] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-14{nl,cfg,mac}80211: implement dot11MeshHWMProotInterval and ↵Chun-Yeow Yeoh
dot11MeshHWMPactivePathToRootTimeout Add the mesh configuration parameters dot11MeshHWMProotInterval and dot11MeshHWMPactivePathToRootTimeout to be used by proactive PREQ mechanism. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> [line-break commit log] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-13cfg80211/nl80211: fix kernel-docJohannes Berg
Add missing entries to nl80211.h and fix the kernel-doc notation in cfg80211.h. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-13nl80211: fix sched scan match attribute nameJohannes Berg
It should be NL80211_SCHED_SCAN_MATCH_ATTR_SSID as documented, not NL80211_ATTR_SCHED_SCAN_MATCH_SSID. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-11{nl,cfg,mac}80211: fix the coding style related to mesh parametersChun-Yeow Yeoh
fix the coding style related to mesh parameters, especially the indentation, as pointed out by Johannes Berg. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-06cfg80211: validate remain-on-channel time betterJohannes Berg
The remain-on-channel time validation shouldn't depend on the value of HZ, as it does now with the check against jiffies, since then you might use a value that works on one system but not on another. Fix it by checking against a minimum that's fixed. Also add validation of the wait duration for a management frame TX since this also translates into remain-on-channel internally. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05cfg80211: provide channel to start_ap functionJohannes Berg
Instead of setting the channel first and then starting the AP, let cfg80211 store the channel and provide it as one of the AP settings. This means that now you have to set the channel before you can start an AP interface, but since hostapd/wpa_supplicant always do that we're OK with this change. Alternatively, it's now possible to give the channel as an attribute to the start-ap nl80211 command, overriding any preset channel. Cc: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05nl80211: add new rssi event to indicate beacon lossEliad Peller
Tell userspace about beacon loss event. This event doesn't replace the deauth/disassoc that might come if the AP is not available. The driver can send this event in order to hint userspace what might follow (which in turn can use it as roaming trigger). Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16nl80211: prevent additions to old station flags APIJohannes Berg
We don't really want/need to maintain the old station flags API any more, so refuse changes to new (not yet defined) flags from the old flags API. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-15nl80211: fix typos in commentsZefir Kurtisi
Signed-off-by: Zefir Kurtisi <zefir.kurtisi@neratec.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-08{nl,cfg,mac}80211: Allow user to see/configure HT protection modeAshok Nagarajan
This patch introduces a new mesh configuration parameter "ht_opmode" and will allow user to check the current HT protection mode selected. Users could configure the protection mode by the command "iw mesh_iface set mesh_param mesh_ht_protection_mode=2". The default protection mode of mesh is set to non-HT mixed mode. Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> Reviewed-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-11cfg80211: add channel switch notify eventThomas Pedersen
The firmware may decide to switch channels while already beaconing, e.g. in response to a cfg80211 connect request on a different vif. Add this event to notify userspace when an AP or GO interface has successfully migrated to a new channel, so it can update its configuration accordingly. Signed-off-by: Thomas Pedersen <c_tpeder@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10{nl,cfg}80211: Support for mesh synchronizationJavier Cardona
Report Toffset to userspace. Let userspace select the mesh synchronization method. Signed-off-by: Marco Porsch <marco.porsch@s2005.tu-chemnitz.de> Signed-off-by: Pavel Zubarev <pavel.zubarev@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10cfg80211/nl80211: clarify TX queue APIJohannes Berg
With the plan to change mac80211's queue API to not map ACs to queues 1:1, it seems necessary to clarify some APIs that act on ACs rather than on queues to spell that out explicitly. Do this. Also verify that the AC number given is valid. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-12cfg80211: Add background scan period attribute.Bala Shanmugam
Receive background scan period as part of connect command and pass the same to the driver. Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06cfg80211/mac80211: report signal strength for mgmt framesJohannes Berg
Add the signal strength (in dBm only for now) to frames that are received via nl80211's various frame APIs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05cfg80211: Add an attribute to set inactivity timeout in AP modeVasanthakumar Thiagarajan
This patch adds an attribute, NL80211_ATTR_INACTIVITY_TIMEOUT, to set the inactivity timeout which can be used to remove the station in AP mode. This can be passed in NL80211_CMD_START_AP and used by the drivers which have AP MLME in firmware but don't support get_station() properly. To disable inactivity timer in userspace, wpa_s for example, there is a new flag, NL80211_FEATURE_INACTIVITY_TIMER, in nl80211_feature_flags through which drivers can register their capability to use the inactivity timeout to free the stations. Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05{nl,cfg,mac}80211: Implement RSSI threshold for mesh peeringAshok Nagarajan
Mesh peer links are established only if average rssi of the peer candidate satisfies the threshold. This is not in 802.11s specification but was requested by David Fulgham, an open80211s user. This is a way to avoid marginal peer links with stations that are barely within range. This patch adds a new mesh configuration parameter, mesh_rssi_threshold. This feature is supported only for hardwares that report signal in dBm. Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22cfg80211: restructure AP/GO mode APIJohannes Berg
The AP/GO mode API isn't very clearly defined, it has "set beacon" and "new beacon" etc. Modify the API to the following: * start AP -- all settings * change beacon -- new beacon data * stop AP -- stop AP mode operation This also reflects in the nl80211 API, rename the commands there correspondingly (but keep the old names for compatibility.) Overall, this makes it much clearer what's going on in the API. Kalle developed the ath6kl changes, I created the rest of the patch. Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30nl80211: add support for mcs masksSimon Wunderlich
Allow to set mcs masks through nl80211. We also allow to set MCS rates but no legacy rates (and vice versa). Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27{nl,cfg,mac}80211: Add support of setting non-forwarding entity in MeshChun-Yeow Yeoh
A mesh node that joins the mesh network is by default a forwarding entity. This patch allows the mesh node to set as non-forwarding entity. Whenever dot11MeshForwarding is set to 0, the mesh node can prevent itself from forwarding the traffic which is not destined to him. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-19cfg80211: Return beacon loss count in stationPaul Stewart
If station info contains a beacon loss count, return it to userspace. Signed-off-by: Paul Stewart <pstew@chromium.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-15cfg80211: validate nl80211 station handling betterJohannes Berg
The nl80211 station handling code is a bit messy and doesn't do a lot of validation. It seems like this could be an issue for drivers that don't use mac80211 to validate everything. As cfg80211 doesn't keep station state, move the validation of allowing supported_rates to change for TDLS only in station mode to mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-06nl80211: Parse channel type attribute in an ibss join requestAlexander Simon
Prepare cfg80211 for IBSS HT: * extend cfg80211 ibss struct with channel_type * Check if extension channel can be used * Export can_beacon_sec_chan for use in mac80211 (will be called from ibss.c later). Signed-off-by: Alexander Simon <an.alexsimon@googlemail.com> [siwu@hrz.tu-chemnitz.de: Updates] * fix cfg80211_can_beacon_ext_chan comment * remove implicit channel_type enum assumptions * remove radar channel flags check * add HT IBSS feature flag * reword commit message Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28{nl,cfg,mac}80211: implement dot11MeshHWMPperrMinIntervalThomas Pedersen
As per 802.11mb 13.9.11.3 Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28wireless: Add NoAck per tid supportSimon Wunderlich
This patch contains the configuration changes in nl80211/cfg80211. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21wireless: Support ht-capabilities over-rides.Ben Greear
This allows users to disable features such as HT, HT40, and to modify the MCS, AMPDU, and AMSDU settings for drivers that support it. The MCS, AMPDU, and AMSDU features that may be disabled are are reported in the phy-info netlink message as a mask. Attemping to disable features that are not supported will take no affect, but will not return errors. This is to aid backwards compatibility in user-space apps that may not be clever enough to deal with parsing the the capabilities mask. This patch only enables the infrastructure. An additional patch will enable the feature in mac80211. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21cfg80211: process regulatory DFS region for countriesLuis R. Rodriguez
The wireless-regdb now has support for mapping a country to one DFS region. CRDA sends this to us now so process it so we can provide that hint to drivers. This will later be used by code for processing DFS in a way that meets the criteria for the DFS region the country belongs to. Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11nl80211: Pass probe response data to driversArik Nemtsov
Pass probe-response data from usermode via beacon parameters. Signed-off-by: Guy Eilam <guy@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11nl80211: Add probe response offload attributeArik Nemtsov
Notify user-space about probe-response offloading support in the driver. A wiphy flag is used to indicate support and a bitmap of protocols determines which protocols are supported. Signed-off-by: Guy Eilam <guy@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09nl80211: advertise socket TX status capabilityJohannes Berg
The new wifi socket TX capability should be supported by wifi drivers, let them advertise whether they do or not. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09cfg80211/mac80211: allow management TX to not wait for ACKJohannes Berg
For probe responses it can be useful to not wait for ACK to avoid retransmissions if the station that sent the probe is already on the next channel, so allow userspace to request not caring about the ACK with a new nl80211 flag. Since mac80211 needs to be updated for the new function prototype anyway implement it right away -- it's just a few lines of code. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09cfg80211: add event for unexpected 4addr framesJohannes Berg
The frames are used by AP/STA WDS mode, and hostapd needs to know when such a frame was received to set up the VLAN appropriately to allow using it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09cfg80211: allow registering to beaconsJohannes Berg
Add the ability to register to received beacon frames to allow implementing OLBC logic in userspace. The registration is per wiphy since there's no point in receiving the same frame multiple times. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09nl80211: add API to probe a clientJohannes Berg
When the AP SME in hostapd is used it wants to probe the clients when they have been idle for some time. Add explicit API to support this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09nl80211: advertise device AP SMEJohannes Berg
Add the ability to advertise that the device contains the AP SME and what features it can support. There are currently no features in the bitmap -- probe response offload will be advertised by a few patches Arik is working on now (who took over from Guy Eilam) and a device with AP SME will typically implement and require response offload. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09nl80211: allow subscribing to unexpected class3 framesJohannes Berg
To implement AP mode without monitor interfaces we need to be able to send a deauth to stations that send frames without being associated. Enable this by adding a new nl80211 event for such frames that an application can subscribe to. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14nl80211: Add sta_flags to the station infoHelmut Schaa
Reuse the already existing struct nl80211_sta_flag_update to specify both, a flag mask and the flag set itself. This means nl80211_sta_flag_update is now used for setting station flags and also for getting station flags. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30nl80211/mac80211: allow adding TDLS peers as stationsArik Nemtsov
When adding a TDLS peer STA, mark it with a new flag in both nl80211 and mac80211. Before adding a peer, make sure the wiphy supports TDLS and our operating mode is appropriate (managed). In addition, make sure all peers are removed on disassociation. A TDLS peer is first added just before link setup is initiated. In later setup stages we have more info about peer supported rates, capabilities, etc. This info is reported via nl80211_set_station(). Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: Kalyan C Gaddam <chakkal@iit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30nl80211: support sending TDLS commands/framesArik Nemtsov
Add support for sending high-level TDLS commands and TDLS frames via NL80211_CMD_TDLS_OPER and NL80211_CMD_TDLS_MGMT, respectively. Add appropriate cfg80211 callbacks for lower level drivers. Add wiphy capability flags for TDLS support and advertise them via nl80211. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: Kalyan C Gaddam <chakkal@iit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
