Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Unused symbols waste space.
Commit 0e34e93177fb
"(netpoll: add generic support for bridge and bonding devices)"
added the symbol more than a year ago with the promise of "future use".
Because it is so far unused, remove it for now.
It can be easily readded if or when it actually needs to be used.
cc: WANG Cong <amwang@redhat.com>
The bonding driver currently modifies the netpoll structure in its xmit path
while sending frames from netpoll. This is racy, as other cpus can access the
netpoll structure in parallel. Since the bonding driver points np->dev to a
slave device, other cpus can inadvertently attempt to send data directly to
slave devices, leading to improper locking with the bonding master, lost frames,
and deadlocks. This patch fixes that up.
This patch also removes the real_dev pointer from the netpoll structure as that
data is really only used by bonding in the poll_controller, and we can emulate
its behavior by check each slave for IS_UP.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
We cannot use rcu_dereference_bh safely in netpoll_rx as we may
be called with IRQs disabled. We could however simply disable
IRQs as that too causes BH to be disabled and is safe in either
case.
Thanks to John Linville for discovering this bug and providing
a patch.
"netpoll: Use 'bool' for netpoll_rx() return type." missed the case when
CONFIG_NETPOLL is disabled.
Now that RCU debugging checks for matching rcu_dereference calls
and rcu_read_lock, we need to use the correct primitives or face
nasty warnings.
This patch adds the helper netpoll_tx_running for use within
ndo_start_xmit. It returns non-zero if ndo_start_xmit is being
invoked by netpoll, and zero otherwise.
This is currently implemented by simply looking at the hardirq
count. This is because for all non-netpoll uses of ndo_start_xmit,
IRQs must be enabled while netpoll always disables IRQs before
calling ndo_start_xmit.
This patch adds the functions __netpoll_setup/__netpoll_cleanup
which is designed to be called recursively through ndo_netpoll_seutp.
They must be called with RTNL held, and the caller must initialise
np->dev and ensure that it has a valid reference count.
The use of RCU in netpoll is incorrect in a number of places:
1) The initial setting is lacking a write barrier.
2) The synchronize_rcu is in the wrong place.
3) Read barriers are missing.
4) Some places are even missing rcu_read_lock.
5) npinfo is zeroed after freeing.
This patch fixes those issues. As most users are in BH context,
this also converts the RCU usage to the BH variant.
This whole patchset is for adding netpoll support to bridge and bonding
devices. I already tested it for bridge, bonding, bridge over bonding,
and bonding over bridge. It looks fine now.
To make bridge and bonding support netpoll, we need to adjust
some netpoll generic code. This patch does the following things:
1) introduce two new priv_flags for struct net_device:
IFF_IN_NETPOLL which identifies we are processing a netpoll;
IFF_DISABLE_NETPOLL is used to disable netpoll support for a device
at run-time;
2) introduce one new method for netdev_ops:
->ndo_netpoll_cleanup() is used to clean up netpoll when a device is
removed.
3) introduce netpoll_poll_dev() which takes a struct net_device * parameter;
export netpoll_send_skb() and netpoll_poll_dev() which will be used later;
4) hide a pointer to struct netpoll in struct netpoll_info, ditto.
5) introduce ->real_dev for struct netpoll.
6) introduce a new status NETDEV_BONDING_DESLAE, which is used to disable
netconsole before releasing a slave, to avoid deadlocks.
Cc: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: WANG Cong <amwang@redhat.com>
Signed-off-by: Daniel Borkmann <danborkmann@googlemail.com>
Allows for the removal of byteswapping in some places and
the removal of HIPQUAD (replaced by %pI4).
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
As my netpoll fix for net doesn't really work for net-next, we
need this update to move the checks into the right place. As it
stands we may pass freed skbs to netpoll_receive_skb.
This patch also introduces a netpoll_rx_on function to avoid GRO
completely if we're invoked through netpoll. This might seem
paranoid but as netpoll may have an external receive hook it's
better to be safe than sorry. I don't think we need this for
2.6.29 though since there's nothing immediately broken by it.
This patch also moves the GRO_* return values to netdevice.h since
VLAN needs them too (I tried to avoid this originally but alas
this seems to be the easiest way out). This fixes a bug in VLAN
where it continued to use the old return value 2 instead of the
correct GRO_DROP.
This patch adds the top-level GRO (Generic Receive Offload) infrastructure.
This is pretty similar to LRO except that this is protocol-independent.
Instead of holding packets in an lro_mgr structure, they're now held in
napi_struct.
For drivers that intend to use this, they can set the NETIF_F_GRO bit and
call napi_gro_receive instead of netif_receive_skb or just call netif_rx.
The latter will call napi_receive_skb automatically. When napi_gro_receive
is used, the driver must either call napi_complete/napi_rx_complete, or
call napi_gro_flush in softirq context if the driver uses the primitives
__napi_complete/__napi_rx_complete.
Protocols will set the gro_receive and gro_complete function pointers in
order to participate in this scheme.
In addition to the packet, gro_receive will get a list of currently held
packets. Each packet in the list has a same_flow field which is non-zero
if it is a potential match for the new packet. For each packet that may
match, they also have a flush field which is non-zero if the held packet
must not be merged with the new packet.
Once gro_receive has determined that the new skb matches a held packet,
the held packet may be processed immediately if the new skb cannot be
merged with it. In this case gro_receive should return the pointer to
the existing skb in gro_list. Otherwise the new skb should be merged into
the existing packet and NULL should be returned, unless the new skb makes
it impossible for any further merges to be made (e.g., FIN packet) where
the merged skb should be returned.
Whenever the skb is merged into an existing entry, the gro_receive
function should set NAPI_GRO_CB(skb)->same_flow. Note that if an skb
merely matches an existing entry but can't be merged with it, then
this shouldn't be set.
If gro_receive finds it pointless to hold the new skb for future merging,
it should set NAPI_GRO_CB(skb)->flush.
Held packets will be flushed by napi_gro_flush which is called by
napi_complete and napi_rx_complete.
Currently held packets are stored in a singly liked list just like LRO.
The list is limited to a maximum of 8 entries. In future, this may be
expanded to use a hash table to allow more flows to be held for merging.
Based upon a report by Andrew Morton and code analysis done
by Jarek Poplawski.
This reverts 33f807ba0d9259e7c75c7a2ce8bd2787e5b540c7 ("[NETPOLL]:
Kill NETPOLL_RX_DROP, set but never tested.") and
c7b6ea24b43afb5749cb704e143df19d70e23dea ("[NETPOLL]: Don't need
rx_flags.").
The rx_flags did get tested for zero vs. non-zero and therefore we do
need those tests and that code which sets NETPOLL_RX_DROP et al.
The rx_flags variable is redundant. Turning rx on/off is done
via setting the rx_np pointer.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
The local_mac is managed by the network device, no need to keep a
spare copy and all the management problems that could cause.
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>.
This patch introduces support for dynamic reconfiguration (adding, removing
and/or modifying parameters of netconsole targets at runtime) using a
userspace interface exported via configfs. Documentation is also updated
accordingly.
Issues and brief design overview:
(1) Kernel-initiated creation / destruction of kernel objects is not
possible with configfs -- the lifetimes of the "config items" is managed
exclusively from userspace. But netconsole must support boot/module
params too, and these are parsed in kernel and hence netpolls must be
setup from the kernel. Joel Becker suggested to separately manage the
lifetimes of the two kinds of netconsole_target objects -- those created
via configfs mkdir(2) from userspace and those specified from the
boot/module option string. This adds complexity and some redundancy here
and also means that boot/module param-created targets are not exposed
through the configfs namespace (and hence cannot be updated / destroyed
dynamically). However, this saves us from locking / refcounting
complexities that would need to be introduced in configfs to support
kernel-initiated item creation / destroy there.
(2) In configfs, item creation takes place in the call chain of the
mkdir(2) syscall in the driver subsystem. If we used an ioctl(2) to
create / destroy objects from userspace, the special userspace program is
able to fill out the structure to be passed into the ioctl and hence
specify attributes such as local interface that are required at the time
we set up the netpoll. For configfs, this information is not available at
the time of mkdir(2). So, we keep all newly-created targets (via
configfs) disabled by default. The user is expected to set various
attributes appropriately (including the local network interface if
required) and then write(2) "1" to the "enabled" attribute. Thus,
netpoll_setup() is then called on the set parameters in the context of
_this_ write(2) on the "enabled" attribute itself. This design enables
the user to reconfigure existing netconsole targets at runtime to be
attached to newly-come-up interfaces that may not have existed when
netconsole was loaded or when the targets were actually created. All this
effectively enables us to get rid of custom ioctls.
(3) Ultra-paranoid configfs attribute show() and store() operations, with
sanity and input range checking, using only safe string primitives, and
compliant with the recommendations in Documentation/filesystems/sysfs.txt.
(4) A new function netpoll_print_options() is created in the netpoll API,
that just prints out the configured parameters for a netpoll structure.
netpoll_parse_options() is modified to use that and it is also exported to
be used from netconsole.
Signed-off-by: Satyam Sharma <satyam@infradead.org>
Acked-by: Keiichi Kii <k-keiichi@bx.jp.nec.com>
Several devices have multiple independant RX queues per net
device, and some have a single interrupt doorbell for several
queues.
In either case, it's easier to support layouts like that if the
structure representing the poll is independant from the net
device itself.
The signature of the ->poll() call back goes from:
int foo_poll(struct net_device *dev, int *budget)
to
int foo_poll(struct napi_struct *napi, int budget)
The caller is returned the number of RX packets processed (or
the number of "NAPI credits" consumed if you want to get
abstract). The callee no longer messes around bumping
dev->quota, *budget, etc. because that is all handled in the
caller upon return.
The napi_struct is to be embedded in the device driver private data
structures.
Furthermore, it is the driver's responsibility to disable all NAPI
instances in it's ->stop() device close handler. Since the
napi_struct is privatized into the driver's private data structures,
only the driver knows how to get at all of the napi_struct instances
it may have per-device.
With lots of help and suggestions from Rusty Russell, Roland Dreier,
Michael Chan, Jeff Garzik, and Jamal Hadi Salim.
Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra,
Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan.
[ Ported to current tree and all drivers converted. Integrated
Stephen's follow-on kerneldoc additions, and restored poll_list
handling to the old style to fix mutual exclusion issues. -DaveM ]
Fix up arch-specific work items where possible to use the new work_struct and
delayed_work structs.
Three places that enqueue bits of their stack and then return have been marked
with #error as this is not permitted.
Signed-Off-By: David Howells <dhowells@redhat.com>
As Steve left netpoll beast, hopefully not to return soon.
He noticed that the header was messy. He straightened it
up and polished it a little, then waved goodbye.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
The beast had a long and not very happy history. At one
point, a friend (netdump) had asked that he open up a little.
Well, the friend was long gone now, and the beast had
this dangling piece hanging (netpoll_queue).
It wasn't hard to stitch the netpoll_queue back in
where it belonged and make everything tidy.
The netpoll beast was still not happy. If the beast got
clogged pipes, it tended to stare blankly off in space
for a long time.
The problem couldn't be completely fixed because the
beast talked with irq's disabled. But it could be made
less painful and shorter.
When the netpoll beast got really busy, it tended to clog
things, so it stored them for later. But the beast was putting
all it's skb's in one basket. This was bad because maybe some
pipes were clogged and others were not.
After looking harder, Steve noticed that the netpoll
beast leaked a little every time it shutdown for a nap.
Not a big leak, but a nuisance kind of thing.
He took out his refcount duct tape and patched the
leak. It was overkill since there was already other
locking in that area, but it looked clean and wouldn't
attract fleas.
The netpoll system currently has a rx to tx path via:
netpoll_rx
__netpoll_rx
arp_reply
netpoll_send_skb
dev->hard_start_tx
This rx->tx loop places network drivers at risk of inadvertently causing a
deadlock or BUG halt by recursively trying to acquire a spinlock that is
used in both their rx and tx paths (this problem was origionally reported
to me in the 3c59x driver, which shares a spinlock between the
boomerang_interrupt and boomerang_start_xmit routines).
This patch breaks this loop, by queueing arp frames, so that they can be
responded to after all receive operations have been completed. Tested by
myself and the reported with successful results.
Specifically it was tested with netdump. Heres the BZ with details:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=194055
Acked-by: Matt Mackall <mpm@selenic.com>
When netpoll is not being used, the macro that
defines the removed routing netpoll_poll_lock
defines the return as zero, but the real
routine returns a `void *`
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
This fixes a race during initialization with the NAPI softirq
processing by using an RCU approach.
This race was discovered when refill_skbs() was added to
the setup code.
Signed-off-by: Matt Mackall <mpm@selenic.com>
Add limited retry logic to netpoll_send_skb
Each time we attempt to send, decrement our per-device retry counter.
On every successful send, we reset the counter.
We delay 50us between attempts with up to 20000 retries for a total of
1 second. After we've exhausted our retries, subsequent failed
attempts will try only once until reset by success.
This patch provides support for registering multiple netpoll clients to the
same network device. Only one of these clients may register an rx_hook,
however. In practice, this restriction has not been problematic. It is
worth mentioning, though, that the current design can be easily extended to
allow for the registration of multiple rx_hooks.
The basic idea of the patch is that the rx_np pointer in the netpoll_info
structure points to the struct netpoll that has rx_hook filled in. Aside
from this one case, there is no need for a pointer from the struct
net_device to an individual struct netpoll.
A lock is introduced to protect the setting and clearing of the np_rx
pointer. The pointer will only be cleared upon netpoll client module
removal, and the lock should be uncontested.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
This patch introduces a netpoll_info structure, which the struct net_device
will now point to instead of pointing to a struct netpoll. The reason for
this is two-fold: 1) fields such as the rx_flags, poll_owner, and poll_lock
should be maintained per net_device, not per netpoll; and 2) this is a first
step in providing support for multiple netpoll clients to register against the
same net_device.
The struct netpoll is now pointed to by the netpoll_info structure. As
such, the previous behaviour of the code is preserved.
This trivial patch moves the assignment of poll_owner to -1 inside of
the lock. This fixes a potential SMP race in the code.
infrastructure for it.
Let it rip!
