path: root/include/linux/mtd/partitions.h
2014-01-03mtd: make register_mtd_parser return voidAxel Lin
register_mtd_parser never fails; hence make it return void. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-01-03mtd: make deregister_mtd_parser return voidAxel Lin
deregister_mtd_parser never fails; hence make it return void. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-01-03mtd: make mtd_partition.name constGeert Uytterhoeven
This allows to drop a few casts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2012-09-04mtd: mtdparts: introduce mtd_get_device_sizeRichard Genoud
'mtd_get_device_size()' returns the size of the whole MTD device, that is the mtd_info master size. This will be used by UBI to calculate the maximum number of bad blocks (MBB) on a MTD device. Artem: amended the patch a bit. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-09-04mtd: mark mtd_is_partition argument as constantRichard Genoud
'struct mtd_info' is not modified by 'mtd_is_partition()' so it can be marked as "const". Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2011-09-11mtd: remove put_partition_parser() from public headerDmitry Eremin-Solenikov
There is no need to pollute public header with a definition private to mtdpart.c. Move it from mtd/partitions.h to mtdpart.c Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: hide parse_mtd_partitionsDmitry Eremin-Solenikov
There is no need to export parse_mtd_partitions() now , as it's fully handled by registration functions. So move the definition to private header and remove respective EXPORT_SYMBOL_GPL. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: drop of_mtd_parse_partitions()Dmitry Eremin-Solenikov
All users have been converted to call of_mtd_parse_partitions through parse_mtd_partitions() multiplexer. Drop obsolete API. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2011-09-11mtd: prepare to convert of_mtd_parse_partitions to partition parserDmitry Eremin-Solenikov
Prepare to convert of_mtd_parse_partitions() to usual partitions parser: 1) Register ofpart parser 2) Internally don't use passed device for error printing 3) Add device_node to mtd_part_parser_data struct 4) Move of_mtd_parse_partitions from __devinit to common text section 5) add ofpart to the default list of partition parsers Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2011-09-11mtd: abstract last MTD partition parser argumentDmitry Eremin-Solenikov
Encapsulate last MTD partition parser argument into a separate structure. Currently it holds only 'origin' field for RedBoot parser, but will be extended in future to contain at least device_node for OF devices. Amended commentary to make kerneldoc happy Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2011-09-11mtd: add a flags for partitions which should just leave smth. after themDmitry Eremin-Solenikov
Add support for MTDPART_OFS_RETAIN: such partitions start at the current offset, take as much space as possible, but rain part->size bytes after the end of the partitions for other parts. Primarily this is intended for ts72xx arm platforms cleanup. Artem: tweaked the patch a bit Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: drop mtd_has_cmdlinepart()Dmitry Eremin-Solenikov
This function is unused now. Drop it. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-25mtd: remove add_mtd_partitions, add_mtd_device and friendsJamie Iles
These symbols are replaced with mtd_device_register() (and removal with mtd_device_unregister()) for public registration. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-25mtd: provide of_mtd_parse_partitions for !CONFIG_MTD_OF_PARTSJamie Iles
If we don't have OpenFirmware enabled then provide a stub of_mtd_parse_partitions that returns no partitions so drivers don't need ifdeffery inside. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-25mtd: introduce mtd_device_(un)register()Jamie Iles
To prepare for the removal of add_mtd_device and add_mtd_partitions(), introduce mtd_device_register(). This will create partitions if they are supplied or register the whole device if there are no partitions. Once all drivers are converted to use mtd_device_register(), add_mtd_device() and add_mtd_partitions() will be made internal only. v2: move kerneldoc to implementation file and fixup some kerneldoc warnings. Artem: tweak comments: remove junk tabs, use dots consistently. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-12-03mtd: fix master device identification for mtd repartitionRoman Tereshonkov
Function mtd_has_master renamed as mtd_is_partition to follow the function logic. The patch fixes the problem of checking the right mtd device for partition creation. To delete partition checking is not needed here so as it is done in mtd_del_partition. By master we consider the mtd device which does not belong to any partition. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-25mtd: prepare partition add and del functions for ioctl requestsRoman Tereshonkov
mtd_is_master, mtd_add_partition and mtd_del_partition functions are added to give the possibility of partition manipulation by ioctl request. The old partition add function is modified to fit the dynamic allocation. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-24mtd: nand: expand nand_ecc_layout, deprecate ioctl ECCGETLAYOUTBrian Norris
struct nand_ecclayout is too small for many new chips; OOB regions can be as large as 448 bytes and may increase more in the future. Thus, copying that struct to user-space with the ECCGETLAYOUT ioctl is not a good idea; the ioctl would have to be updated every time there's a change to the current largest size. Instead, the old nand_ecclayout is renamed to nand_ecclayout_user and a new struct nand_ecclayout is created that can accomodate larger sizes and expand without affecting the user-space. struct nand_ecclayout can still be used in board drivers without modification -- at least for now. A new function is provided to convert from the new to the old in order to allow the deprecated ioctl to continue to work with truncated data. Perhaps the ioctl, the conversion process, and the struct nand_ecclayout_user can be removed altogether in the future. Note: There are comments in nand/davinci_nand.c::nand_davinci_probe() regarding this issue; this driver (and maybe others) can be updated to account for extra space. All kernel drivers can use the expanded nand_ecclayout as a drop-in replacement and ignore its benefits. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-03mtd: let include/linux/mtd/partitions.h stand on its ownNicolas Pitre
When declaring static MTD partitions in board specific code, only including <include/linux/mtd/partitions.h> should suffice without gcc nagging us with: In file included from arch/arm/mach-kirkwood/sheevaplug-setup.c:14: include/linux/mtd/partitions.h:50: warning: 'struct mtd_info' declared inside parameter list include/linux/mtd/partitions.h:50: warning: its scope is only this definition or declaration, which is probably not what you want include/linux/mtd/partitions.h:51: warning: 'struct mtd_info' declared inside parameter list include/linux/mtd/partitions.h:61: warning: 'struct mtd_info' declared inside parameter list include/linux/mtd/partitions.h:67: warning: 'struct mtd_info' declared inside parameter list Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-26[MTD] Remove option for add_mtd_partitions() to not register partitions.David Woodhouse
This breaks the dilnetpc map driver, but it could be fixed not to use that option. We want to simplify the partition handling, and this is a step towards that. Remove superfluous 'index' field from private struct mtd_part too, while we're at it. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-20[MTD] partitioning utility predicatesDavid Brownell
Move mtd_has_partitions() and mtd_has_cmdlinepart() inlines from a DaVinci-specific driver to the <linux/mtd/partitions.h> header. Use those to eliminate #ifdefs in two drivers which had their own definitions of mtd_has_partitions(). Quite a lot of other MTD drivers could benefit from using use one or both of these to remove #ifdeffery. Maybe some Janitors would like to help. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10[MTD] Remove more strange u_intxx_t typesDavid Woodhouse
2008-12-10[MTD] update internal API to support 64-bit device sizeAdrian Hunter
MTD internal API presently uses 32-bit values to represent device size. This patch updates them to 64-bits but leaves the external API unchanged. Extending the external API is a separate issue for several reasons. First, no one needs it at the moment. Secondly, whether the implementation is done with IOCTLs, sysfs or both is still debated. Thirdly external API changes require the internal API to be accepted first. Note that although the MTD API will be able to support 64-bit device sizes, existing drivers do not and are not required to do so, although NAND base has been updated. In general, changing from 32-bit to 64-bit values cause little or no changes to the majority of the code with the following exceptions: - printk message formats - division and modulus of 64-bit values - NAND base support - 32-bit local variables used by mtdpart and mtdconcat - naughtily assuming one structure maps to another in MEMERASE ioctl Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-13[MTD] remove unused mtd parameter in of_mtd_parse_partitions()Sebastian Andrzej Siewior
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-03[MTD] Factor out OF partition support from the NOR driver.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-29[MTD] NAND Replace oobinfo by ecclayoutThomas Gleixner
The nand_oobinfo structure is not fitting the newer error correction demands anymore. Replace it by struct nand_ecclayout and fixup the users all over the place. Keep the nand_oobinfo based ioctl for user space compability reasons. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-07[MTD] includes: Clean up trailing white spacesThomas Gleixner
