In some environments it is to prefer to postpone the resume of the card
device until runtime_resume is being carried out, since it will mean a
signficant decrease of the total system resume time.
The reason of the decreased resume time is simply because of the actual
re-initalization of the card, which typically takes hundreds of
milliseconds, is performed outside the resume sequence and wont thus
affect it.
For removable card, the detect work tries to re-detect the card to make
sure it is still present, as a part of that sequence the card will also
be runtime_resumed and thus also fully resumed.
For a non-removable card, typically a mmc blk request will trigger a
runtime_resume and thus fully resume the card. This also means the
first request will likely suffer from an inital latency since the
re-initialization of the card needs to be performed.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
The are no more users of the deprecated mmc_suspend|resume_host API,
so let's remove it.
The negotiated ocr mask is directly related to the card. Once a card
gets removed, the mask shall be dropped. By moving the cache of the ocr
mask from the host struct to the card struct we have accomplished this.
MMC_CAP2_FULL_PWR_CYCLE shall be set by host drivers which are able to
do a complete power cycle of the card. In the eMMC case that includes
both vcc and vccq.
This CAP is providing the protocol layer with important information,
needed to take optimized decisions during card initialization and in
the suspend/resume sequence.
MMC_CAP2_POWEROFF_NOTIFY is replaced by MMC_CAP2_FULL_PWR_CYCLE, since
it makes sense to use a wider scope for it.
In addition to just logging errors encountered during DT parsing or
allocating GPIO slots for CD/WP, mmc_of_parse() now returns with an error.
In particular, this is needed if the GPIO allocation may return
EPROBE_DEFER.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
The mmc_card_sleep|awake APIs are not being used since the support is
already properly encapsulated within the suspend sequence. Sleep|awake
command is also specific for eMMC.
We remove the sleep|awake bus_ops, the mmc_card_sleep|awake APIs and
move the code into the mmc specific core instead. This also includes
the mmc ops function, mmc_sleepawake. All releated functions have then
become static and we have got far less code to maintain.
Additionally this patch also simplifies the code from mmc_sleepawake,
since it is only used to put the card to sleep and not awake.
Aggressive power management is suitable when saving power is
essential. At request inactivity timeout, aka pm runtime
autosuspend timeout, the card will be suspended.
Once a new request arrives, the card will be re-initalized and
thus the first request will suffer from a latency. This latency
is card-specific, experiments has shown in general that SD-cards
has quite poor initialization time, around 300ms-1100ms. eMMC is
not surprisingly far better but still a couple of hundreds of ms
has been observed.
Except for the request latency, it is important to know that
suspending the card will also prevent the card from executing
internal house-keeping operations in idle mode. This could mean
degradation in performance.
To use this feature make sure the request inactivity timeout is
chosen carefully. This has not been done as a part of this patch.
Enable this feature by using host cap MMC_CAP_AGGRESSIVE_PM and
by setting CONFIG_MMC_UNSAFE_RESUME.
The sanitize support is added as a user-app ioctl call, and
was removed from the block-device request, since its purpose is
to be invoked not via File-System but by a user.
This feature deletes the unmap memory region of the eMMC card,
by writing to a specific register in the EXT_CSD.
unmap region is the memory region that was previously deleted
(by erase, trim or discard operation).
In order to avoid timeout when sanitizing large-scale cards,
the timeout for sanitize operation is 240 seconds.
Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org>
Signed-off-by: Maya Erez <merez@codeaurora.org>
Previously the MMC_CAP2_DETECT_ON_ERR was invented for detecting
slow card removal. In was never a realy good solution and a proper
fix has been merged using gpio debouncing instead. We remove this
cap in this patch.
Although when using polling card detect mode, the code invented for
MMC_CAP2_DETECT_ON_ERR is re-used to complete card removal in an
earlier phase. There are no need waiting for the polling timeout to
elapse in this case.
Reviewed-by: Kevin Liu <kliu5@marvell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED subsystem updates from Bryan Wu:
- move LED trigger drivers into a new directory
- lp55xx common driver updates
- other led drivers updates and bug fixing
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds:
leds: leds-asic3: switch to using SIMPLE_DEV_PM_OPS
leds: leds-bd2802: add CONFIG_PM_SLEEP to suspend/resume functions
leds: lp55xx: configure the clock detection
leds: lp55xx: use common clock framework when external clock is used
leds: leds-ns2: fix oops at module removal
leds: leds-pwm: Defer led_pwm_set() if PWM can sleep
leds: lp55xx: fix the sysfs read operation
leds: lm355x, lm3642: support camera LED triggers for flash and torch
leds: add camera LED triggers
leds: trigger: use inline functions instead of macros
leds: tca6507: Use of_match_ptr() macro
leds: wm8350: Complain if we fail to reenable DCDC
leds: renesas: set gpio_request_one() flags param correctly
leds: leds-ns2: set devm_gpio_request_one() flags param correctly
leds: leds-lt3593: set devm_gpio_request_one() flags param correctly
leds: leds-bd2802: remove erroneous __exit annotation
leds: atmel-pwm: remove erroneous __exit annotation
leds: move LED trigger drivers into new subdirectory
leds: add new LP5562 LED driver
Commit fa5501890d8974301042e0202d342a6cbe8609f4 introduced a performance
regression by adding mmc_power_up() to mmc_start_host(). mmc_power_up()
is not necessary to host controller initialization, it is part of card
initialization and is performed anyway asynchronously.
This patch allows a driver to leave the power up in asynchronous code
(as it was before).
On my current target platform this reduces driver initialization from:
[ 1.313220] initcall sdhci_acpi_driver_init+0x0/0x12 returned 0 after 102008 usecs
to this:
[ 1.217209] initcall sdhci_acpi_driver_init+0x0/0x12 returned 0 after 8331 usecs
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Macros are used in case that an inline function doesn't work.
Otherwise, use an empty inline function.
(a) Case of !CONFIG_LEDS_TRIGGERS
Following macros are replaced with inline functions.
led_trigger_register_simple()
led_trigger_unregister_simple()
led_trigger_event()
To make inline types, the structure, 'led_trigger' should be defined.
This structure has no member at all.
(b) Case of !CONFIG_LEDS_TRIGGER_IDE_DISK
ledtrig_ide_activity() macro is replaced with an inline function as well.
(c) DEFINE_LED_TRIGGER() and DEFINE_LED_TRIGGER_GLOBAL()
Struct 'led_trigger' is defined both cases, with CONFIG_LEDS_TRIGGERS and
without CONFIG_LEDS_TRIGGERS.
Those macros are moved out of CONFIG_LED_TRIGGERS because of no-dependency
on CONFIG_LEDS_TRIGGERS.
(d) Fix build errors in mmc-core driver
After replacing macros with inline functions, following build errors occur.
(condition: CONFIG_LEDS_TRIGGERS is not set)
drivers/mmc/core/core.c: In function 'mmc_request_done':
drivers/mmc/core/core.c:164:25: error: 'struct mmc_host' has no member named 'led'
drivers/mmc/core/core.c: In function 'mmc_start_request':
drivers/mmc/core/core.c:254:24: error: 'struct mmc_host' has no member named 'led'
make[3]: *** [drivers/mmc/core/core.o] Error 1
The reason of these errors is non-existent member variable, 'led'.
It is only valid when CONFIG_LEDS_TRIGGERS is set.
But now, it can be used without this dependency.
To fix build errors, member 'led' is always used without its config option in
'include/linux/mmc/host.h'.
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
ACPI spec 5 defined the _ADR encoding for sdio bus as:
High word - slot number (0 based)
Low word - function number
This patch adds support for binding sdio function device with acpi node,
and if successful, involve acpi into its power management.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Reviewed-by: Adrian Hunter <adrian.hunter@intel.com>
The "extern" keyword isn't required in function declarations, remove it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
MMC defines a number of standard DT bindings. Having each driver parse
them individually adds code redundancy and is error prone. Provide a
standard function to unify the parsing. After all drivers are converted
to using it instead of their own parsers, this function can be integrated
into mmc_alloc_host().
This patch supports packed write command of eMMC4.5 devices. Several
writes can be grouped in packed command and all data of the individual
commands can be sent in a single transfer on the bus. Large amounts of
data in one transfer rather than several data of small size are
effective for eMMC write internally. As a result, packed command help
write throughput be improved. The following tables show the results
of packed write.
Type A:
test none | packed
iozone 25.8 | 31
tiotest 27.6 | 31.2
lmdd 31.2 | 35.4
Type B:
test none | packed
iozone 44.1 | 51.1
tiotest 47.9 | 52.5
lmdd 51.6 | 59.2
Type C:
test none | packed
iozone 19.5 | 32
tiotest 19.9 | 34.5
lmdd 22.8 | 40.7
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Reviewed-by: Maya Erez <merez@codeaurora.org>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
This patch adds packed command feature of eMMC4.5. The maximum number
for packing read (or write) is offered and exception event relevant to
packed command which is used for error handling is enabled. If host
wants to use this feature, MMC_CAP2_PACKED_CMD should be set.
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
4d55c5a1 ("mmc: sdhci: enable preset value after uhs initialization")
added preset value support and enabled it by default during sd card init.
Below are the enhancements introduced by this patch:
1. In current code, preset value is enabled after setting clock finished,
which means the clock is manually set by driver firstly and then suddenly
switched to preset value at this point. So the first setting is useless
and unnecessary. What's more, the first clock setting may differ from the
preset one. The better way is enable preset value just after switch to
UHS mode so the preset value can take effect immediately. So move preset
value enable from mmc_sd_init_card to sdhci_set_ios which will be called
during set timing.
2. In current code, preset value is disabled at the beginning of
mmc_attach_sd. It's too late since low freq (400khz) should be set in
mmc_power_up. So move preset value disable to sdhci_set_ios which will
be called during power up.
3. host->clock and ios->drv_type should also be updated according to the
preset value if it's enabled. Current code missed this.
4. This patch also introduce a quirk to disable preset value in case
preset value doesn't work.
This patch has been verified on sdhci-pxav3 platform with both preset
enabled and disabled.
Signed-off-by: Kevin Liu <kliu5@marvell.com>
This host_ops member is used to test if the card is signaling busy by
pulling dat[0:3] low.
Signed-off-by: Johan Rudholm <johan.rudholm@stericsson.com>
Tested-by: Wei WANG <wei_wang@realsil.com.cn>
When current request is running on the bus and if next request fetched
by mmcqd is NULL, mmc context (mmcqd thread) gets blocked until the
current request completes. This means that if new request comes in while
the mmcqd thread is blocked, this new request can not be prepared in
parallel to current ongoing request. This may result in delaying the new
request execution and increase it's latency.
This change allows to wake up the MMC thread on new request arrival.
Now once the MMC thread is woken up, a new request can be fetched and
prepared in parallel to the current running request which means this new
request can be started immediately after the current running request
completes.
With this change read throughput is improved by 16%.
Signed-off-by: Konstantin Dorfman <kdorfman@codeaurora.org>
Reviewed-by: Seungwon Jeon <tgih.jun@samsung.com>
According to UHS-I initialization sequence for SDIO 3.0 cards,
the host must set bit[24] (S18R) of OCR register during OCR
handshake to know whether the SDIO card is capable of doing
1.8V I/O.
Signed-off-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Reviewed-by: Johan Rudholm <johan.rudholm@stericsson.com>
Some hosts need to perform additional actions upon card insertion or
ejection. Add a host operation to be called from card detection handlers.
Reviewed-by: Shawn Guo <shawn.guo@linaro.org>
Both of MMC_TIMING_LEGACY and MMC_TIMING_UHS_SDR12 are defined
to 0. And ios->timing is set to MMC_TIMING_LEGACY during power up.
But set_ios can't distinguish these two timing if host support
spec 3.0. Just adjust timing values to be different can resolve
this issue without any other impact.
Reviewed-by: Girish K S <girish.shivananjappa@linaro.org>
There are discrepancies with regards to how MMC capabilities
are carried throughout the subsystem. Let's standardise them
to eliminate any confusion.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
This patch fixes up the broken suspend sequence for eMMC with sleep
support. Additionally it reworks the eMMC4.5 Power Off Notification
feature so it fits together with the existing sleep feature.
The CMD0 based re-initialization of the eMMC at resume is re-introduced
to maintain compatiblity for devices using sleep.
A host shall use MMC_CAP2_POWEROFF_NOTIFY to enable the Power Off
Notification feature. We might be able to remove this cap later on,
if we think that Power Off Notification always is preferred over
sleep, even if the host is not able to cut the eMMC VCCQ power.
Signed-off-by: Saugata Das <saugata.das@linaro.org>
If MMC_CAP_NONREMOVABLE is set, only issue a detect job on init.
Host has different current capabilities at different voltages, we need
to record these settings seperately. The defined voltages are 1.8/3.0/3.3.
For other voltages, we do not touch current limit setting.
Before we set the current limit for the sd card, find out the host's
operating voltage first and then find out the current capabilities of
the host at that voltage to set the current limit.
Signed-off-by: Aaron Lu <aaron.lu@amd.com>
Reviewed-by: Philip Rakity <prakity@marvell.com>
This prepares for the addition of further slot functions.
To handle CD and WP SD/MMC slot pins we need generic flags to specify their
polarity.
struct mmc_host::hotplug is becoming a generic hook for slot functions.
Rename it accordingly.
Add a function to get regulators, supplying card's Vdd and Vccq on a
specific host. If a Vdd supplying regulator is found, the function checks,
whether a valid OCR mask can be obtained from it. The Vccq regulator is
optional. A failure to get it is not fatal.
Reviwed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Commit 06e8935feb ("optimized SDIO IRQ handling for single irq")
introduced some spurious calls to SDIO function interrupt handlers,
such as when the SDIO IRQ thread is started, or the safety check
performed upon a system resume. Let's add a flag to perform the
optimization only when a real interrupt is signaled by the host
driver and we know there is no point confirming it.
Reported-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Cc: stable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
Core:
* Support for MMC 4.5 Data Tag feature -- we tag REQ_META, so devices
that support Data Tag will provide increased throughput for metadata.
* Faster detection of card removal on I/O errors.
Drivers:
* dw_mmc now supports eMMC Power Off Notify, has PCI support, and
implements pre_req and post_req for asynchronous requests.
* omap_hsmmc now supports device tree.
* esdhc now has power management support.
* sdhci-tegra now supports Tegra30 devices.
* sdhci-spear now supports hibernation.
* tmio_mmc now supports using a GPIO for card detection.
* Intel PCH now supports 8-bit bus transfers.
* tag 'mmc-merge-for-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits)
mmc: sh_mmcif: simplify bitmask macros
mmc: sh_mobile_sdhi: support modular mmc-core with non-standard hotplug
mmc: sh_mobile_sdhi: add a callback for board specific init code
mmc: tmio: cosmetic: prettify the tmio_mmc_set_ios() function
mmc: sh_mobile_sdhi: do not manage PM clocks manually
mmc: tmio_mmc: remove unused sdio_irq_enabled flag
mmc: tmio_mmc: power status flag doesn't have to be exposed in platform data
mmc: sh_mobile_sdhi: pass card hotplug GPIO number to TMIO MMC
mmc: tmio_mmc: support the generic MMC GPIO card hotplug helper
mmc: tmio: calculate the native hotplug condition only once
mmc: simplify mmc_cd_gpio_request() by removing two parameters
mmc: sdhci-pci: allow 8-bit bus width for Intel PCH
mmc: sdhci: check interrupt flags in ISR again
mmc: sdhci-pci: Add MSI support
mmc: core: warn when card doesn't support HPI
mmc: davinci: Poll status for small size transfers
mmc: davinci: Eliminate spurious interrupts
mmc: omap_hsmmc: Avoid a regulator voltage change with dt
mmc: omap_hsmmc: Convert hsmmc driver to use device tree
mmc: sdhci-pci: add SDHCI_QUIRK2_HOST_OFF_CARD_ON for Medfield SDIO
Let drivers specify the use of high-capacity erase size.
Most parts of the enable / disable API are no longer used and
can be removed.
Tested-by: Venkatraman S <svenkatr@ti.com>
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
To prevent I/O as soon as possible at card removal, a new detect work is
re-scheduled without a delay to let a rescan remove the card device as
soon as possible.
Additionally, MMC_CAP2_DETECT_ON_ERR can now be used to handle "slowly"
removed cards that a scheduled detect work did not detect as removed.
To prevent further I/O requests for these lingering removed cards,
check if card has been removed and then schedule a detect work to
properly remove it.
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/device.h> avoidance patches from Paul Gortmaker:
"Nearly every subsystem has some kind of header with a proto like:
void foo(struct device *dev);
and yet there is no reason for most of these guys to care about the
sub fields within the device struct. This allows us to significantly
reduce the scope of headers including headers. For this instance, a
reduction of about 40% is achieved by replacing the include with the
simple fact that the device is some kind of a struct.
Unlike the much larger module.h cleanup, this one is simply two
commits. One to fix the implicit <linux/device.h> users, and then one
to delete the device.h includes from the linux/include/ dir wherever
possible."
* tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
device.h: audit and cleanup users in main include dir
device.h: cleanup users outside of linux/include (C files)
The <linux/device.h> header includes a lot of stuff, and
it in turn gets a lot of use just for the basic "struct device"
which appears so often.
Clean up the users as follows:
1) For those headers only needing "struct device" as a pointer
in fcn args, replace the include with exactly that.
2) For headers not really using anything from device.h, simply
delete the include altogether.
3) For headers relying on getting device.h implicitly before
being included themselves, now explicitly include device.h
4) For files in which doing #1 or #2 uncovers an implicit
dependency on some other header, fix by explicitly adding
the required header(s).
Any C files that were implicitly relying on device.h to be
present have already been dealt with in advance.
Total removals from #1 and #2: 51. Total additions coming
from #3: 9. Total other implicit dependencies from #4: 7.
As of 3.3-rc1, there were 110, so a net removal of 42 gives
about a 38% reduction in device.h presence in include/*
There is an understood mismatch between the voltage the host controller is
set to and the voltage supplied to the card by a fixed voltage regulator.
Teaching the driver to accept the mismatch is overly complicated. Instead
just accept the regulator's voltage.
This patch adds MMC_CAP2_BROKEN_VOLTAGE.
If the voltage didn't satisfy between min_uV and max_uV, try to change
the voltage in core.c. When changing the voltage, maybe use
regulator_set_voltage().
In regulator_set_voltage(), check the below condition.
/* sanity check */
if (!rdev->desc->ops->set_voltage &&
!rdev->desc->ops->set_voltage_sel) {
ret = -EINVAL;
goto out;
If some board should use the fixed-regulator, always return -EINVAL.
Then, eMMC didn't initialize always.
So if use a fixed-regulator, we need to add the MMC_CAP2_BROKEN_VOLTAGE.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Ensure clocks are always enabled before any interaction with the
host controller driver. This makes sure that there is no race
between host execution and the core layer turning off clocks
in different context with clock gating framework.
Acked-by: Per Forlin <per.forlin@stericsson.com>
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1
* tag 'for-linus' of git://github.com/rustyrussell/linux:
module_param: check that bool parameters really are bool.
intelfbdrv.c: bailearly is an int module_param
paride/pcd: fix bool verbose module parameter.
module_param: make bool parameters really bool (drivers & misc)
module_param: make bool parameters really bool (arch)
module_param: make bool parameters really bool (core code)
kernel/async: remove redundant declaration.
printk: fix unnecessary module_param_name.
lirc_parallel: fix module parameter description.
module_param: avoid bool abuse, add bint for special cases.
module_param: check type correctness for module_param_array
modpost: use linker section to generate table.
modpost: use a table rather than a giant if/else statement.
modules: sysfs - export: taint, coresize, initsize
kernel/params: replace DEBUGP with pr_debug
module: replace DEBUGP with pr_debug
module: struct module_ref should contains long fields
module: Fix performance regression on modules with large symbol tables
module: Add comments describing how the "strmap" logic works
Fix up conflicts in scripts/mod/file2alias.c due to the new linker-
generated table approach to adding __mod_*_device_table entries. The
ARM sa11x0 mcp bus needed to be converted to that too.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
This patch adds the support of the HS200 bus speed for eMMC 4.5 devices.
The eMMC 4.5 devices have support for 200MHz bus speed. The function
prototype of the tuning function is modified to handle the tuning
command number which is different in sd and mmc case.
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
Signed-off-by: Philip Rakity <prakity@marvell.com>
Host may now use MMC_CAP2_NO_SLEEP_CMD to disable the use
of eMMC sleep/awake command.
This option can be used when your platform has a buggy
kernel crash dump software, which is supposed to store
the dump on the eMMC, but is not able to wake up the eMMC
from sleep state.
In particular, failures have been seen with u-boot; even if
it is fixed there, platforms will be slow to update their
bootloader binaries.
Reviewed-by: Hanumath Prasad <hanumath.prasad@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Subhash Jadavani <subhashj@codeaurora.org>
SD/MMC controllers provide different card insertion and removal detection
methods. On some of them the controller itself issues an interrupt, on
others polling is used, on yet others auxiliary means are used for this
purpose, e.g., a GPIO IRQ. Further, on some systems one of those methods
can be chosen at driver probing time and configured in software. E.g., on
some systems the SD/MMC controller card hot-plug detection pin can be
configured either as a respective controller functions, or an IRQ-capable
GPIO. To support such flexible configurations a card hot-plug context
is added by this patch.
Add a function mmc_detect_card_removed() which upper layers can use to
determine immediately if a card has been removed. This function should
be called after an I/O request fails so that all queued I/O requests
can be errored out immediately instead of waiting for the card device
to be removed.
Acked-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Current clock gating framework disables the MCI clock as soon as the
request is completed and enables it when a request arrives. This aggressive
clock gating framework, when enabled, cause following issues:
When there are back-to-back requests from the Queue layer, we unnecessarily
end up disabling and enabling the clocks between these requests since 8MCLK
clock cycles is a very short duration compared to the time delay between
back to back requests reaching the MMC layer. This overhead can effect the
overall performance depending on how long the clock enable and disable
calls take which is platform dependent. For example on some platforms we
can have clock control not on the local processor, but on a different
subsystem and the time taken to perform the clock enable/disable can add
significant overhead.
Also if the host controller driver decides to disable the host clock too
when mmc_set_ios function is called with ios.clock=0, it adds additional
delay and it is highly possible that the next request had already arrived
and unnecessarily blocked in enabling the clocks. This is seen frequently
when the processor is executing at high speeds and in multi-core platforms
thus reduces the overall throughput compared to if clock gating is
disabled.
Fix this by delaying turning off the clocks by posting request on
delayed workqueue. Also cancel the unscheduled pending work, if any,
when there is access to card.
sysfs entry is provided to tune the delay as needed, default
value set to 200ms.
This patch is to expose the actual SDCLK frequency in
/sys/kernel/debug/mmcX/ios entry.
For example, if the max clk for a normal speed card is 20MHz this
is reported in /sys/kernel/debug/mmcX/ios. Unfortunately the actual
SDCLK frequency (i.e. Baseclock / divisor) is not reported at all:
for example, in that case, on Arasan HC, it should be 48/4=12 (MHz).
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Due to hardware bugs, some MMC host controllers don't support
multiple-block reads[1]. To resolve, add a new MMC capability flag,
MMC_CAP2_NO_MULTI_READ, which can be set by affected host controller
drivers. When this capability is set, all reads will be issued one
sector at a time.
1. See for example Advisory 2.1.1.128 "MMC: Multiple Block Read
Operation Issue" in _OMAP3530/3525/3515/3503 Silicon Errata_
Revision F (October 2010) (SPRZ278F), available from
http://focus.ti.com/lit/er/sprz278f/sprz278f.pdf
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Dave Hylands <dhylands@gmail.com>
Tested-by: Steve Sakoman <sakoman@gmail.com>
This patch adds cache feature of eMMC4.5 Spec.
If device supports cache capability, host can utilize some specific
operations.
