git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA changes from Roland Dreier:
- Updates to the qib low-level driver
- First chunk of changes for SR-IOV support for mlx4 IB
- RDMA CM support for IPv6-only binding
- Other misc cleanups and fixes
Fix up some add-add conflicts in include/linux/mlx4/device.h and
drivers/net/ethernet/mellanox/mlx4/main.c
* tag 'rdma-for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (30 commits)
IB/qib: checkpatch fixes
IB/qib: Add congestion control agent implementation
IB/qib: Reduce sdma_lock contention
IB/qib: Fix an incorrect log message
IB/qib: Fix QP RCU sparse warnings
mlx4: Put physical GID and P_Key table sizes in mlx4_phys_caps struct and paravirtualize them
mlx4_core: Allow guests to have IB ports
mlx4_core: Implement mechanism for reserved Q_Keys
net/mlx4_core: Free ICM table in case of error
IB/cm: Destroy idr as part of the module init error flow
mlx4_core: Remove double function declarations
IB/mlx4: Fill the masked_atomic_cap attribute in query device
IB/mthca: Fill in sq_sig_type in query QP
IB/mthca: Warning about event for non-existent QPs should show event type
IB/qib: Fix sparse RCU warnings in qib_keys.c
net/mlx4_core: Initialize IB port capabilities for all slaves
mlx4: Use port management change event instead of smp_snoop
IB/qib: RCU locking for MR validation
IB/qib: Avoid returning EBUSY from MR deregister
IB/qib: Fix UC MR refs for immediate operations
Enable callers of mlx4_assign_eq to supply a pointer to cpu_rmap.
If supplied, the assigned IRQ is tracked using rmap infrastructure.
Signed-off-by: Amir Vadai <amirv@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Define this macro is one common place instead of duplicating it over the code
paravirtualize them
To allow easy paravirtualization of P_Key and GID table sizes, keep
paravirtualized sizes in mlx4_dev->caps, but save the actual physical
sizes from FW in struct: mlx4_dev->phys_cap.
In addition, in SR-IOV mode, do the following:
1. Reduce reported P_Key table size by 1.
This is done to reserve the highest P_Key index for internal use,
for declaring an invalid P_Key in P_Key paravirtualization.
We require a P_Key index which always contain an invalid P_Key
value for this purpose (i.e., one which cannot be modified by
the subnet manager). The way to do this is to reduce the
P_Key table size reported to the subnet manager by 1, so that
it will not attempt to access the P_Key at index #127.
2. Paravirtualize the GID table size to 1. Thus, each guest sees
only a single GID (at its paravirtualized index 0).
In addition, since we are paravirtualizing the GID table size to 1, we
add paravirtualization of the master GID event here (i.e., we do not
do ib_dispatch_event() for the GUID change event on the master, since
its (only) GUID never changes).
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <roland@purestorage.com>
The SR-IOV special QP tunneling mechanism uses proxy special QPs
(instead of the real special QPs) for MADs on guests. These proxy QPs
send their packets to a "tunnel" QP owned by the master. The master
then forwards the MAD (after any required paravirtualization) to the
real special QP, which sends out the MAD.
For security reasons (i.e., to prevent guests from sending MADs to
tunnel QPs belonging to other guests), each proxy-tunnel QP pair is
assigned a unique, reserved, Q_Key. These Q_Keys are available only
for proxy and tunnel QPs -- if the guest tries to use these Q_Keys
with other QPs, it will fail.
This patch introduces a mechanism for reserving a block of 64K Q_Keys
for proxy/tunneling use.
The patch introduces also two new fields into mlx4_dev: base_sqpn and
base_tunnel_sqpn.
In SR-IOV mode, the QP numbers for the "real," proxy, and tunnel sqps
are added to the reserved QPN area (so that they will not change).
There are 8 special QPs per port in the HCA, and each of them is
assigned both a proxy and a tunnel QP, for each VF and for the PF as
well in SR-IOV mode.
The QPNs for these QPs are arranged as follows:
1. The real SQP numbers (8)
2. The proxy SQPs (8 * (max number of VFs + max number of PFs)
3. The tunnel SQPs (8 * (max number of VFs + max number of PFs)
To support these QPs, two new fields are added to struct mlx4_dev:
base_sqp: this is the QP number of the first of the real SQPs
base_tunnel_sqp: this is the qp number of the first qp in the tunnel
sqp region. (On guests, this is the first tunnel
sqp of the 8 which are assigned to that guest).
In addition, in SR-IOV mode, sqp_start is the number of the first
proxy SQP in the proxy SQP region. (In guests, this is the first
proxy SQP of the 8 which are assigned to that guest)
Note that in non-SR-IOV mode, there are no proxies and no tunnels.
In this case, sqp_start is set to sqp_base -- which minimizes code
changes.
With IB SR-IOV, each slave has its own separate copy of the port
capabilities flags. For example, the master can run a subnet manager
(which causes the IsSM bit to be set in the master's port
capabilities) without affecting the port capabilities seen by the
slaves (the IsSM bit will be seen as cleared in the slaves).
Also add a static inline mlx4_master_func_num() to enhance readability
of the code.
The port management change event can replace smp_snoop. If the
capability bit for this event is set in dev-caps, the event is used
(by the driver setting the PORT_MNG_CHG_EVENT bit in the async event
mask in the MAP_EQ fw command). In this case, when the driver passes
incoming SMP PORT_INFO SET mads to the FW, the FW generates port
management change events to signal any changes to the driver.
If the FW generates these events, smp_snoop shouldn't be invoked in
ib_process_mad(), or duplicate events will occur (once from the
FW-generated event, and once from smp_snoop).
In the case where the FW does not generate port management change
events smp_snoop needs to be invoked to create these events. The flow
in smp_snoop has been modified to make use of the same procedures as
in the fw-generated-event event case to generate the port management
events (LID change, Client-rereg, Pkey change, and/or GID change).
Port management change event handling required changing the
mlx4_ib_event and mlx4_dispatch_event prototypes; the "param" argument
(last argument) had to be changed to unsigned long in order to
accomodate passing the EQE pointer.
We also needed to move the definition of struct mlx4_eqe from
net/mlx4.h to file device.h -- to make it available to the IB driver,
to handle port management change events.
Currently, VFs have 0 in their dev->caps.function field. This is a
valid pci id (usually of the PF). Instead, pass an invalid PCI id to
the VF via QUERY_FW, so that if the value gets accessed in the VF
driver, we'll catch the problem.
The device managed flow steering API has three promiscuous modes:
1. Uplink - captures all the packets that arrive to the port.
2. Allmulti - captures all multicast packets arriving to the port.
3. Function port - for future use, this mode is not implemented yet.
Use these modes with the flow_attach and flow_detach firmware commands
according to the promiscuous state of the netdevice.
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.co.il>
The driver is modified to support three operation modes.
If supported by firmware use the device managed flow steering
API, that which we call device managed steering mode. Else, if
the firmware supports the B0 steering mode use it, and finally,
if none of the above, use the A0 steering mode.
When the steering mode is device managed, the code is modified
such that L2 based rules set by the mlx4_en driver for Ethernet
unicast and multicast, and the IB stack multicast attach calls
done through the mlx4_ib driver are all routed to use the device
managed API.
When attaching rule using device managed flow steering API,
the firmware returns a 64 bit registration id, which is to be
provided during detach.
Currently the firmware is always programmed during HCA initialization
to use standard L2 hashing. Future work should be done to allow
configuring the flow-steering hash function with common, non
proprietary means.
Add support for firmware commands to attach/detach a new device managed
steering mode. Such network steering rules allow the user to provide an
L2/L3/L4 flow specification to the firmware and have the device to steer
traffic that matches that specification to the provided QP.
Instead of checking the firmware supported steering mode in various
places in the code, add a dedicated field in the mlx4 device capabilities
structure which is written once during the initialization flow and read
across the code.
This also set the grounds for add new steering modes. Currently two modes
are supported, and are named after the ConnectX HW versions A0 and B0.
A0 steering uses mac_index, vlan_index and priority to steer traffic
into pre-defined range of QPs.
B0 steering uses Ethernet L2 hashing rules and is enabled only
if the firmware supports both unicast and multicast B0 steering,
The current steering modes are relevant for Ethernet traffic only,
such that Infiniband steering remains untouched.
In SRIOV mode, the number of EQs used when computing the total ICM size
was incorrect.
To fix this, we do the following:
1. We add a new structure to mlx4_dev, mlx4_phys_caps, to contain physical HCA
capabilities. The PPF uses the phys capabilities when it computes things
like ICM size.
The dev_caps structure will then contain the paravirtualized values, making
bookkeeping much easier in SRIOV mode. We add a structure rather than a
single parameter because there will be other fields in the phys_caps.
The first field we add to the mlx4_phys_caps structure is num_phys_eqs.
2. In INIT_HCA, when running in SRIOV mode, the "log_num_eqs" parameter
passed to the FW is the number of EQs per VF/PF; each function (PF or VF)
has this number of EQs available.
However, the total number of EQs which must be allowed for in the ICM is
(1 << log_num_eqs) * (#VFs + #PFs). Rather than compute this quantity,
we allocate ICM space for 1024 EQs (which is the device maximum
number of EQs, and which is the value we place in the mlx4_phys_caps structure).
For INIT_HCA, however, we use the per-function number of EQs as described
above.
Signed-off-by: Marcel Apfelbaum <marcela@dev.mellanox.co.il>
Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com>
- Add ocrdma hardware driver for Emulex IB-over-Ethernet adapters
- Add generic and mlx4 support for "raw" QPs: allow suitably privileged
applications to send and receive arbitrary packets directly to/from
the hardware
- Add "doorbell drop" handling to the cxgb4 driver
- A fairly large batch of qib hardware driver changes
- A few fixes for lockdep-detected issues
- A few other miscellaneous fixes and cleanups
Fix up trivial conflict in drivers/net/ethernet/emulex/benet/be.h.
* tag 'rdma-for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (53 commits)
RDMA/cxgb4: Include vmalloc.h for vmalloc and vfree
IB/mlx4: Fix mlx4_ib_add() error flow
IB/core: Fix IB_SA_COMP_MASK macro
IB/iser: Fix error flow in iser ep connection establishment
IB/mlx4: Increase the number of vectors (EQs) available for ULPs
RDMA/cxgb4: Add query_qp support
RDMA/cxgb4: Remove kfifo usage
RDMA/cxgb4: Use vmalloc() for debugfs QP dump
RDMA/cxgb4: DB Drop Recovery for RDMA and LLD queues
RDMA/cxgb4: Disable interrupts in c4iw_ev_dispatch()
RDMA/cxgb4: Add DB Overflow Avoidance
RDMA/cxgb4: Add debugfs RDMA memory stats
cxgb4: Common platform specific changes for DB Drop Recovery
cxgb4: Detect DB FULL events and notify RDMA ULD
RDMA/cxgb4: Drop peer_abort when no endpoint found
RDMA/cxgb4: Always wake up waiters in c4iw_peer_abort_intr()
mlx4_core: Change bitmap allocator to work in round-robin fashion
RDMA/nes: Don't call event handler if pointer is NULL
RDMA/nes: Fix for the ORD value of the connecting peer
This patch adds a 64-bit flags2 features member to struct mlx4_dev to
export further features of the hardware. The original flags field
tracks features whose support bits are advertised by the firmware in
offsets 0x40 and 0x44 of the query device capabilities command.
flags2 will track features whose support bits are scattered at various
offsets.
RSS support is the first feature to be exported through flags2. RSS
capabilities are located at offset 0x2e. The size of the RSS
indirection table is also given in this offset.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
Otherwise CM packets going over MLX QP1 get fixed scheduling priority 0.
We want CM packets to get the same scheduling priority, and therefore
map to the same SQ (Schedule Queue) and eventually TC (Traffic Class),
as the application requested for the actual QP used for the connection.
Signed-off-by: Oren Duer <oren@mellanox.co.il>
Adding QoS firmware commands:
- mlx4_en_SET_PORT_PRIO2TC - set UP <=> TC
- mlx4_en_SET_PORT_SCHEDULER - set promised BW, max BW and PG number
Instead of relying on HW to change schedule queue by UP, schedule
queue is fixed for a tx_ring, and UP in WQE is ignored in this aspect. This
resolves two issues with untagged traffic:
1. untagged traffic has no UP in packet which is needed for QoS. The change
above allows setting the schedule queue (and by that the UP) of such a stream.
2. BlueFlame uses the same field used by vlan tag. So forcing UP from QPC
allows using BF for untagged but prioritized traffic.
In old firmware that force UP is not supported, untagged traffic will not subject to
QoS.
Because UP is set by QP, need to always have a tx ring per UP, even if pfcrx
module paramter is false.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/device.h> avoidance patches from Paul Gortmaker:
"Nearly every subsystem has some kind of header with a proto like:
void foo(struct device *dev);
and yet there is no reason for most of these guys to care about the
sub fields within the device struct. This allows us to significantly
reduce the scope of headers including headers. For this instance, a
reduction of about 40% is achieved by replacing the include with the
simple fact that the device is some kind of a struct.
Unlike the much larger module.h cleanup, this one is simply two
commits. One to fix the implicit <linux/device.h> users, and then one
to delete the device.h includes from the linux/include/ dir wherever
possible."
* tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
device.h: audit and cleanup users in main include dir
device.h: cleanup users outside of linux/include (C files)
Pull InfiniBand/RDMA changes for the 3.4 merge window from Roland Dreier:
"Nothing big really stands out; by patch count lots of fixes to the
mlx4 driver plus some cleanups and fixes to the core and other
drivers."
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (28 commits)
mlx4_core: Scale size of MTT table with system RAM
mlx4_core: Allow dynamic MTU configuration for IB ports
IB/mlx4: Fix info returned when querying IBoE ports
IB/mlx4: Fix possible missed completion event
mlx4_core: Report thermal error events
mlx4_core: Fix one more static exported function
IB: Change CQE "csum_ok" field to a bit flag
RDMA/iwcm: Reject connect requests if cmid is not in LISTEN state
RDMA/cxgb3: Don't pass irq flags to flush_qp()
mlx4_core: Get rid of redundant ext_port_cap flags
RDMA/ucma: Fix AB-BA deadlock
IB/ehca: Fix ilog2() compile failure
IB: Use central enum for speed instead of hard-coded values
IB/iser: Post initial receive buffers before sending the final login request
IB/iser: Free IB connection resources in the proper place
IB/srp: Consolidate repetitive sysfs code
IB/srp: Use pr_fmt() and pr_err()/pr_warn()
IB/core: Fix SDR rates in sysfs
mlx4: Enforce device max FMR maps in FMR alloc
IB/mlx4: Set bad_wr for invalid send opcode
The <linux/device.h> header includes a lot of stuff, and
it in turn gets a lot of use just for the basic "struct device"
which appears so often.
Clean up the users as follows:
1) For those headers only needing "struct device" as a pointer
in fcn args, replace the include with exactly that.
2) For headers not really using anything from device.h, simply
delete the include altogether.
3) For headers relying on getting device.h implicitly before
being included themselves, now explicitly include device.h
4) For files in which doing #1 or #2 uncovers an implicit
dependency on some other header, fix by explicitly adding
the required header(s).
Any C files that were implicitly relying on device.h to be
present have already been dealt with in advance.
Total removals from #1 and #2: 51. Total additions coming
from #3: 9. Total other implicit dependencies from #4: 7.
As of 3.3-rc1, there were 110, so a net removal of 42 gives
about a 38% reduction in device.h presence in include/*
drivers/infiniband/hw/mlx4/main.c
Set the MTU for IB ports in the driver instead of using the firmware
default of 2KB (the driver defaults to 4KB). Allow for dynamic mtu
configuration through a new, per-port sysfs entry.
Since there's a dependency between the port MTU and the max number of
HW VLs the port can support, apply a mim/max approach, using a loop
that goes down from the highest possible number of VLs to the lowest,
using the firmware return status to know whether the requested number
of VLs is possible with a given MTU.
For now, as with the dynamic link type change / VPI support, the sysfs
entry to change the mtu is exposed only when NOT running in SR-IOV
mode. To allow changing the MTU for the master in SR-IOV mode,
primary-function-initiated FLR (Function Level Reset) needs to be
implemented.
Print an error message when a thermal error async event is reported by the HW.
Signed-off-by: Dotan Barak <dotanb@mellanox.com>
While doing the work for commit a6f7feae6d ("IB/mlx4: pass SMP
vendor-specific attribute MADs to firmware") we realized that the
firmware would respond on all sorts of vendor-specific MADs.
Therefore commit 97285b7817 ("mlx4_core: Add extended port
capabilities support") adds redundant code into the driver, since
there's no real reaon to maintain the extended capabilities of the
port, as they can be queried on demand (e.g the FDR10 capability).
This patch reverts commit 97285b7817 and removes the check for
extended caps from the mlx4_ib driver port query flow.
The SET_PORT functions are implemented in port.c, which is part
of mlx4_core, these functions are exported. The functions are in use by
the mlx4_en module (were originally part of mlx4_en).
Their declaration remained in mlx4_en module, moving the declaration to the right location.
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
A driver xmit function is not allowed to change skb without special
care.
mlx4_en_xmit() should not call skb_reset_mac_header() and instead should
use skb->data to access ethernet header.
This removes a dumb test : if (ethh && ethh->h_dest)
Also remove this slow mlx4_en_mac_to_u64() call, we can use
get_unaligned() to get faster code.
Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
ConnectX devices have a limit on the number of mappings that can be
done on an FMR before having to call sync_tpt. The current
mlx4_ib driver reports the limit correctly in max_map_per_fmr in
.query_device(), but mlx4_core doesn't check it when actually
allocating FMRs.
Add a max_fmr_maps field to struct mlx4_caps and enforce this maximum
value on FMR allocations.
Signed-off-by: Eli Cohen <eli@mellanox.com>
In native mode display all available staticstics.
In SRIOV mode on VF display only SW counters statistics,
in SRIOV mode on hypervisor display SW counters and errors (got from FW)
statistics.
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.co.il>
Reviewed-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
New FW can give clues to driver regarding default port type
and whether or not we should default to link sensing on the port.
2 bits are added to QUERY_PORT command:
1. suggested_type: This bit gives a hint whether the default port type should be
IB or Ethernet.
The driver will use this hint in case the user didn't specify explicitly the link layer
type he wants to set.
2. default_sense: If this bit is set, we would sense the port type on start-up
and default the port to link sensing
For ConnectX3 devices, we allow link sensing only if FW explicitly
reported it supports the feature.
For older versions (ConnectX1 and 2), if the card supports both link layer types
(Ethenet and Infiniband), link sensing is supported.
1. Added module parameters sr_iov and probe_vf for controlling enablement of
SRIOV mode.
2. Increased default max num-qps, num-mpts and log_num_macs to accomodate
SRIOV mode
3. Added port_type_array as a module parameter to allow driver startup with
ports configured as desired.
In SRIOV mode, only ETH is supported, and this array is ignored; otherwise,
for the case where the FW supports both port types (ETH and IB), the
port_type_array parameter is used.
By default, the port_type_array is set to configure both ports as IB.
4. When running in sriov mode, the master needs to initialize the ICM eq table
to hold the eq's for itself and also for all the slaves.
5. mlx4_set_port_mask() now invoked from mlx4_init_hca, instead of in mlx4_dev_cap.
6. Introduced sriov VF (slave) device startup/teardown logic (mainly procedures
mlx4_init_slave, mlx4_slave_exit, mlx4_slave_cap, mlx4_slave_exit and flow
modifications in __mlx4_init_one, mlx4_init_hca, and mlx4_setup_hca).
VFs obtain their startup information from the PF (master) device via the
comm channel.
7. In SRIOV mode (both PF and VF), MSI_X must be enabled, or the driver
aborts loading the device.
8. Do not allow setting port type via sysfs when running in SRIOV mode.
9. mlx4_get_ownership: Currently, only one PF is supported by the driver.
If the HCA is burned with FW which enables more than one PF, only one
of the PFs is allowed to run. The first one up grabs a FW ownership
semaphone -- all other PFs will find that semaphore taken, and the
driver will not allow them to run.
Signed-off-by: Liran Liss <liranl@mellanox.co.il>
Signed-off-by: Marcel Apfelbaum <marcela@mellanox.co.il>
In the previous implementation mtts are managed by:
1. order - log(mtt segments), 'mtt segment' groups several mtts together.
2. first_seg - segment location relative to mtt table.
In the current implementation:
1. order - log(mtts) rather than segments
2. offset - mtt index in mtt table
Note: The actual mtt allocation is made in segments but it is
transparent to callers.
Rational: The mtt resource holders are not interested on how the allocation
of mtt is done, but rather on how they will use it.
Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
The physical port is now common to the PF and VFs.
The port resources and configuration is managed by the PF, VFs can
only influence the MTU of the port, it is set as max among all functions,
Each function allocates RX buffers of required size to meet it's MTU enforcement.
Port management code was moved to mlx4_core, as the mlx4_en module is
virtualization unaware
Move handling qp functionality to mlx4_get_eth_qp/mlx4_put_eth_qp
including reserve/release range and add/release unicast steering.
Let mlx4_register/unregister_mac deal only with MAC (un)registration.
When SRIOV is enabled on the chip (at FW burning time),
the HCA uses only 17 bits for the PD. The remaining 7 high-order bits
are ignored.
Change the allocator to return only 17 bits for the PD. The MSB 7
bits will be used to encode the slave number for consistency
checking later on in the resource tracker.
For SRIOV, some Hypervisor commands can be executed directly (native = 1).
Others should go through the command wrapper flow (for tracking resource
usage, for example, or for changing some HCA configurations that slaves
need to be notified of).
This patch sets the groundwork for this capability -- adding the correct
value of "native" in each case.
Note that if SRIOV is not activated, this parameter has no effect.
Port mask now has additional state.
Port can be set as "none". In this case neither the mlx4_en or mlx4_ib
drivers take ownership of the port.
In multifunction mode there is an option to set the vfs as single ported devices.
(in single function mode, both physical ports belong to same function)
These changes will not affect module operation as yet. They
are only to get some structs and enums in place for use by
subsequent patches (making those smaller).
Added here:
* sriov state structs and inlines (mlx4_is_master/slave/mfunc)
* comm-channel and vhcr support structures
* enum values for new FW and comm-channel virtual commands
(i.e., commands, passed via the comm channel to the PF-driver).
* prototypes for many command wrapper functions (used by the
PF context for processing FW commands passed to it by the VFs).
* struct mlx4_eqe is moved from eq.c to mlx4.h (it will be used
by other mlx4_core source files).
Device must be in promiscuous mode or DMAC must be same as the host MAC, or
else packet will be dropped by the HW rx filtering.
Signed-off-by: Amir Vadai <amirv@mellanox.co.il>
There are 2 capability bits for WOL, one for each port.
WOL handlers were looking only on the second bit, regardless of the port.
Towards adding RSS support for IB drivers/application who use
the mlx4 HW, make the RSS related definitions global and change
the mlx4_en driver to use them.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (62 commits)
mlx4_core: Deprecate log_num_vlan module param
IB/mlx4: Don't set VLAN in IBoE WQEs' control segment
IB/mlx4: Enable 4K mtu for IBoE
RDMA/cxgb4: Mark QP in error before disabling the queue in firmware
RDMA/cxgb4: Serialize calls to CQ's comp_handler
RDMA/cxgb3: Serialize calls to CQ's comp_handler
IB/qib: Fix issue with link states and QSFP cables
IB/mlx4: Configure extended active speeds
mlx4_core: Add extended port capabilities support
IB/qib: Hold links until tuning data is available
IB/qib: Clean up checkpatch issue
IB/qib: Remove s_lock around header validation
IB/qib: Precompute timeout jiffies to optimize latency
IB/qib: Use RCU for qpn lookup
IB/qib: Eliminate divide/mod in converting idx to egr buf pointer
IB/qib: Decode path MTU optimization
IB/qib: Optimize RC/UC code by IB operation
IPoIB: Use the right function to do DMA unmap pages
RDMA/cxgb4: Use correct QID in insert_recv_cqe()
RDMA/cxgb4: Make sure flush CQ entries are collected on connection close
'misc', 'mlx4', 'misc', 'nes', 'qib' and 'xrc' into for-next
An Extended Port Info packet is sent to each hw port during HCA init.
If it returns without error, we assume the port supports extended port
capabilities.
Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.com>
Canceling FCS removal where FW allows for better alignment
of incoming data.
Support the creation of XRC INI and TGT QPs. To handle the case where
a CQ or PD is not provided, we allocate them internally with the xrcd.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Allow the user to create XRC SRQs. This patch is based on a patch
from Jack Morgenstrein <jackm@dev.mellanox.co.il>.
Support creating and destroying XRC domains. Any sharing of the XRCD
is managed above the low-level driver.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Allocate flow counter per Ethernet/IBoE port, and attach this counter
to all the QPs created on that port. Based on patch by Eli Cohen
<eli@mellanox.co.il>.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.co.il>
