path: root/include/linux/marvell_phy.h
2010-11-22phylib: Add support for Marvell 88E1149R devices.David Daney
The 88E1149R is 10/100/1000 quad-gigabit Ethernet PHY. The .config_aneg function can be shared with 88E1118, but it needs its own .config_init. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: Cyril Chemparathy <cyril@ti.com> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-29phy/marvell: rename 88ec048 to 88e1318s and fix mscr1 addrCyril Chemparathy
The marvell 88ec048's official part number is 88e1318s. This patch renames definitions in the driver to reflect this. In addition, a minor bug fix has been added to write back the MSCR1 register value properly. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-16net/phy/marvell: Expose IDs and flags in a .h and add dns323 LEDs setup flagBenjamin Herrenschmidt
This moves the various known Marvell PHY IDs to include/linux/marvell_phy.h along with dev_flags definitions for use by the driver. I then added a flag that changes the PHY init code to setup the LEDs config to the values needed to operate a dns323 rev C1 NAS. I moved the existing "resistance" flag to the .h as well, though I've been unable to find whoever sets this to convert it to use that constant. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
