Replace copy_module_from_fd() with kernel_read_file_from_fd().
Although none of the upstreamed LSMs define a kernel_module_from_file
hook, IMA is called, based on policy, to prevent unsigned kernel modules
from being loaded by the original kernel module syscall and to
measure/appraise signed kernel modules.
The security function security_kernel_module_from_file() was called prior
to reading a kernel module. Preventing unsigned kernel modules from being
loaded by the original kernel module syscall remains on the pre-read
kernel_read_file() security hook. Instead of reading the kernel module
twice, once for measuring/appraising and again for loading the kernel
module, the signature validation is moved to the kernel_post_read_file()
security hook.
This patch removes the security_kernel_module_from_file() hook and security
call.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Acked-by: Luis R. Rodriguez <mcgrof@kernel.org>
The kernel_read_file security hook is called prior to reading the file
into memory.
Changelog v4+:
- export security_kernel_read_file()
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Replace the fw_read_file_contents with kernel_file_read_from_path().
Although none of the upstreamed LSMs define a kernel_fw_from_file hook,
IMA is called by the security function to prevent unsigned firmware from
being loaded and to measure/appraise signed firmware, based on policy.
Instead of reading the firmware twice, once for measuring/appraising the
firmware and again for reading the firmware contents into memory, the
kernel_post_read_file() security hook calculates the file hash based on
the in memory file buffer. The firmware is read once.
This patch removes the LSM kernel_fw_from_file() hook and security call.
Changelog v4+:
- revert dropped buf->size assignment - reported by Sergey Senozhatsky
v3:
- remove kernel_fw_from_file hook
- use kernel_file_read_from_path() - requested by Luis
v2:
- reordered and squashed firmware patches
- fix MAX firmware size (Kees Cook)
To differentiate between the kernel_read_file() callers, this patch
defines a new enumeration named kernel_read_file_id and includes the
caller identifier as an argument.
Subsequent patches define READING_KEXEC_IMAGE, READING_KEXEC_INITRAMFS,
READING_FIRMWARE, READING_MODULE, and READING_POLICY.
Changelog v3:
- Replace the IMA specific enumeration with a generic one.
For a while it was looked down upon to directly read files from Linux.
These days there exists a few mechanisms in the kernel that do just
this though to load a file into a local buffer. There are minor but
important checks differences on each. This patch set is the first
attempt at resolving some of these differences.
This patch introduces a common function for reading files from the kernel
with the corresponding security post-read hook and function.
Changelog v4+:
- export security_kernel_post_read_file() - Fengguang Wu
v3:
- additional bounds checking - Luis
v2:
- To simplify patch review, re-ordered patches
Reviewed-by: Luis R. Rodriguez <mcgrof@suse.com>
Add a hook to invalidate an inode's security label when the cached
information becomes invalid.
Add the new hook in selinux: set a flag when a security label becomes
invalid.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Reviewed-by: James Morris <james.l.morris@oracle.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Make the inode argument of the inode_getsecid hook non-const so that we
can use it to revalidate invalid security labels.
Make the inode argument of the inode_getsecurity hook non-const so that
we can use it to revalidate invalid security labels.
Now that minor LSMs can cleanly stack with major LSMs, remove the unneeded
config for Yama to be made to explicitly stack. Just selecting the main
Yama CONFIG will allow it to work, regardless of the major LSM. Since
distros using Yama are already forcing it to stack, this is effectively
a no-op change.
Additionally add MAINTAINERS entry.
Signed-off-by: James Morris <james.l.morris@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"The main change in this kernel is Casey's generalized LSM stacking
work, which removes the hard-coding of Capabilities and Yama stacking,
allowing multiple arbitrary "small" LSMs to be stacked with a default
monolithic module (e.g. SELinux, Smack, AppArmor).
See
https://lwn.net/Articles/636056/
This will allow smaller, simpler LSMs to be incorporated into the
mainline kernel and arbitrarily stacked by users. Also, this is a
useful cleanup of the LSM code in its own right"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add()
vTPM: set virtual device before passing to ibmvtpm_reset_crq
tpm_ibmvtpm: remove unneccessary message level.
ima: update builtin policies
ima: extend "mask" policy matching support
ima: add support for new "euid" policy condition
ima: fix ima_show_template_data_ascii()
Smack: freeing an error pointer in smk_write_revoke_subj()
selinux: fix setting of security labels on NFS
selinux: Remove unused permission definitions
selinux: enable genfscon labeling for sysfs and pstore files
selinux: enable per-file labeling for debugfs files.
selinux: update netlink socket classes
signals: don't abuse __flush_signals() in selinux_bprm_committed_creds()
selinux: Print 'sclass' as string when unrecognized netlink message occurs
Smack: allow multiple labels in onlycap
Smack: fix seq operations in smackfs
ima: pass iint to ima_add_violation()
ima: wrap event related data to the new ima_event_data structure
integrity: add validity checks for 'path' parameter
Instead of using a vector of security operations
with explicit, special case stacking of the capability
and yama hooks use lists of hooks with capability and
yama hooks included as appropriate.
The security_operations structure is no longer required.
Instead, there is a union of the function pointers that
allows all the hooks lists to use a common mechanism for
list management while retaining typing. Each module
supplies an array describing the hooks it provides instead
of a sparsely populated security_operations structure.
The description includes the element that gets put on
the hook list, avoiding the issues surrounding individual
element allocation.
The method for registering security modules is changed to
reflect the information available. The method for removing
a module, currently only used by SELinux, has also changed.
It should be generic now, however if there are potential
race conditions based on ordering of hook removal that needs
to be addressed by the calling module.
The security hooks are called from the lists and the first
failure is returned.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Acked-by: John Johansen <john.johansen@canonical.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Add a list header for each security hook. They aren't used until
later in the patch series. They are grouped together in a structure
so that there doesn't need to be an external address for each.
Macro-ize the initialization of the security_operations
for each security module in anticipation of changing out
the security_operations structure.
Add the large comment describing the content of the
security_operations structure to lsm_hooks.h. This
wasn't done in the previous (1/7) patch because it
would have exceeded the mail list size limits.
The security.h header file serves two purposes,
interfaces for users of the security modules and
interfaces for security modules. Users of the
security modules don't need to know about what's
in the security_operations structure, so pull it
out into it's own header, lsm_hooks.h
