path: root/include/linux/lru_cache.h
2013-03-22lru_cache: introduce lc_get_cumulative()Lars Ellenberg
New helper to be able to consolidate more updates into a single transaction. Without this, we can only grab a single refcount on an updated element while preparing a transaction. lc_get_cumulative - like lc_get; also finds to-be-changed elements @lc: the lru cache to operate on @enr: the label to look up Unlike lc_get this also returns the element for @enr, if it is belonging to a pending transaction, so the return values are like for lc_get(), plus: pointer to an element already on the "to_be_changed" list. In this case, the cache was already marked %LC_DIRTY. Caller needs to make sure that the pending transaction is completed, before proceeding to actually use this element. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Fixed up by Jens to export lc_get_cumulative(). Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-12-17Merge branch 'for-3.8/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver update from Jens Axboe: "Now that the core bits are in, here are the driver bits for 3.8. The branch contains: - A huge pile of drbd bits that were dumped from the 3.7 merge window. Following that, it was both made perfectly clear that there is going to be no more over-the-wall pulls and how the situation on individual pulls can be improved. - A few cleanups from Akinobu Mita for drbd and cciss. - Queue improvement for loop from Lukas. This grew into adding a generic interface for waiting/checking an even with a specific lock, allowing this to be pulled out of md and now loop and drbd is also using it. - A few fixes for xen back/front block driver from Roger Pau Monne. - Partition improvements from Stephen Warren, allowing partiion UUID to be used as an identifier." * 'for-3.8/drivers' of git://git.kernel.dk/linux-block: (609 commits) drbd: update Kconfig to match current dependencies drbd: Fix drbdsetup wait-connect, wait-sync etc... commands drbd: close race between drbd_set_role and drbd_connect drbd: respect no-md-barriers setting also when changed online via disk-options drbd: Remove obsolete check drbd: fixup after wait_even_lock_irq() addition to generic code loop: Limit the number of requests in the bio list wait: add wait_event_lock_irq() interface xen-blkfront: free allocated page xen-blkback: move free persistent grants code block: partition: msdos: provide UUIDs for partitions init: reduce PARTUUID min length to 1 from 36 block: store partition_meta_info.uuid as a string cciss: use check_signature() cciss: cleanup bitops usage drbd: use copy_highpage drbd: if the replication link breaks during handshake, keep retrying drbd: check return of kmalloc in receive_uuids drbd: Broadcast sync progress no more often than once per second drbd: don't try to clear bits once the disk has failed ...
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-14lru_cache: allow multiple changes per transactionLars Ellenberg
Allow multiple changes to the active set of elements in lru_cache. The only current user of lru_cache, drbd, is driving this generalisation. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-10-14drbd: use clear_bit_unlock() where appropriateLars Ellenberg
Some open-coded clear_bit(); smp_mb__after_clear_bit(); should in fact have been smp_mb__before_clear_bit(); clear_bit(); Instead, use clear_bit_unlock() to annotate the intention, and have it do the right thing. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24lru_cache.h: fix comments referring to ts_ instead of lc_Lars Ellenberg
For some time we contemplated calling the "struct lru_cache" a "struct tracked_set", and some comments kept the ts_ prefix. Fix those to match the member field names. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2010-06-16fix typos concerning "acquire"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-01The DRBD driverPhilipp Reisner
