path: root/include/linux/lock_dlm_plock.h
2008-04-21dlm: move plock code from gfs2David Teigland
Move the code that handles cluster posix locks from gfs2 into the dlm so that it can be used by both gfs2 and ocfs2. Signed-off-by: David Teigland <teigland@redhat.com>
2006-07-31[GFS2] add plock ownerDavid Teigland
We need to use fl_owner instead of fl_pid to track the owner of a posix lock. Pass the owner value out to user space where cluster plocks are managed. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-17[GFS2] An update of the GFS2 lock modulesDavid Teigland
This brings the lock modules uptodate and removes the stray .mod.c file which accidently got included in the last check in. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
