For some assemblers, they use another character as newline in a macro
(e.g. arc uses '`'), so for generic assembly code, need use ASM_NL (a
macro) instead of ';' for it.
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull mudule updates from Rusty Russell:
"We get rid of the general module prefix confusion with a binary config
option, fix a remove/insert race which Never Happens, and (my
favorite) handle the case when we have too many modules for a single
commandline. Seriously, the kernel is full, please go away!"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix unwanted VMLINUX_SYMBOL_STR expansion
X.509: Support parse long form of length octets in Authority Key Identifier
module: don't unlink the module until we've removed all exposure.
kernel: kallsyms: memory override issue, need check destination buffer length
MODSIGN: do not send garbage to stderr when enabling modules signature
modpost: handle huge numbers of modules.
modpost: add -T option to read module names from file/stdin.
modpost: minor cleanup.
genksyms: pass symbol-prefix instead of arch
module: fix symbol versioning with symbol prefixes
CONFIG_SYMBOL_PREFIX: cleanup.
Al's commit e1b5bb6d1236 ("consolidate cond_syscall and SYSCALL_ALIAS
declarations") broke the build on blackfin and metag due to the
following code:
#ifndef SYMBOL_NAME
#ifdef CONFIG_SYMBOL_PREFIX
#define SYMBOL_NAME(x) CONFIG_SYMBOL_PREFIX ## x
#else
#define SYMBOL_NAME(x) x
#endif
#endif
#define __SYMBOL_NAME(x) __stringify(SYMBOL_NAME(x))
__stringify literally stringifies CONFIG_SYMBOL_PREFIX ##x, so you get
lines like this in kernel/sys_ni.s:
.weak CONFIG_SYMBOL_PREFIXsys_quotactl
.set CONFIG_SYMBOL_PREFIXsys_quotactl,CONFIG_SYMBOL_PREFIXsys_ni_syscall
The patches in Rusty's modules-next tree such as "CONFIG_SYMBOL_PREFIX:
cleanup." cleans up the whole mess around symbol prefixes, so this patch
just attempts to fix the build in the meantime.
The intermediate definition of SYMBOL_NAME above isn't used and is
incorrect when CONFIG_SYMBOL_PREFIX is defined as CONFIG_SYMBOL_PREFIX
is a quoted string literal, so define __SYMBOL_NAME directly depending
on CONFIG_SYMBOL_PREFIX.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Mea-culpa-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: uclinux-dist-devel@blackfin.uclinux.org
take them to asm/linkage.h, with default in linux/linkage.h
The uses have been renamed so delete the unused macro.
It's a very old and now unused prototype marking so just delete it.
Neaten panic pointer argument style to keep checkpatch quiet.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
The only use in kernel.h is gone so remove the macro.
As UML does no longer need asmregparm we can remove it.
Signed-off-by: Richard Weinberger <richard@nod.at>
Cc: namhyung@gmail.com
Cc: davem@davemloft.net
Cc: fweisbec@gmail.com
Cc: dhowells@redhat.com
Link: http://lkml.kernel.org/r/%3C1306189085-29896-1-git-send-email-richard%40nod.at%3E
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Adding a reference to <linux/linkage.h> to x86's <asm/cache.h> causes
the x86 linker script to have syntax errors, because the ALIGN and
ENTRY keywords get redefined to the assembly implementations of those.
One could fix this by adjusting the include structure, but I think any
solution based on that approach would be fragile.
Currently, it is impossible when writing a header to do something
different for assembly files and linker scripts, even though there are
clearly cases where one wants them to define macros differently for
the two (ENTRY being an excellent example).
So I think the right solution here is to introduce a new preprocessor
definition, called LINKER_SCRIPT that is set along with __ASSEMBLY__
for linker scripts, and to use that to not define ALIGN and ENTRY in
linker scripts.
I suspect we'll find other uses for this mechanism in
the future.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This patch is preparation for replacing most uses of
".bss.page_aligned" and ".data.page_aligned" in the kernel with
macros, so that the section name can later be changed without having
to touch a lot of the kernel.
The long-term goal here is to be able to change the kernel's magic
section names to those that are compatible with -ffunction-sections
-fdata-sections. This requires renaming all magic sections with names
of the form ".data.foo".
entry_32.S is now the only user of KPROBE_ENTRY / KPROBE_END,
treewide. This patch reorders entry_64.S and explicitly generates
a separate section for functions that need the protection. The
generated code before and after the patch is equal.
The KPROBE_ENTRY and KPROBE_END macro's are removed too.
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
The notrace define belongs in compiler.h so that it can be used in
init.h
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
arch/x86/kernel/entry_32.S
arch/x86/kernel/process_32.c
arch/x86/kernel/process_64.c
arch/x86/lib/Makefile
include/asm-x86/irqflags.h
kernel/Makefile
kernel/sched.c
Making a variable page-aligned by using
__attribute__((section(".data.page_aligned"))) is fragile because if
sizeof(variable) is not also a multiple of page size, it leaves
variables in the remainder of the section unaligned.
This patch introduces two new qualifiers, __page_aligned_data and
__page_aligned_bss to set the section *and* the alignment of
variables. This makes page-aligned variables more robust because the
linker will make sure they're aligned properly. Unfortunately it
requires *all* page-aligned data to use these macros...
notrace signals that a function should not be traced. Most of the
time this is used by tracers to annotate code that cannot be
traced - it's in a volatile state (such as in user vdso context
or NMI context) or it's in the tracer internals.
git commit 54a015104136974262afa4b8ddd943ea70dec8a2 ("asmlinkage_protect
replaces prevent_tail_call") causes this build failure on s390:
AS arch/s390/kernel/entry64.o
In file included from arch/s390/kernel/entry64.S:14:
include/linux/linkage.h:34: error: syntax error in macro parameter list
make[1]: *** [arch/s390/kernel/entry64.o] Error 1
make: *** [arch/s390/kernel] Error 2
and some other architectures. The reason is that some architectures add
the "-traditional" flag to the invocation of $(AS), which disables
variadic macro argument support.
So just surround the new define with an #ifndef __ASSEMBLY__ to prevent
any side effects on asm code.
Cc: Roland McGrath <roland@redhat.com>
It's really a pretty ugly thing to need, and some day it will hopefully
be obviated by teaching gcc about the magic calling conventions for the
low-level system call code, but in the meantime we can at least add big
honking comments about why we need these insane and strange macros.
I took my comments from my version of the macro, but I ended up deciding
to just pick Roland's version of the actual code instead (with his
prettier syntax that uses vararg macros). Thus the previous two commits
that actually implement it.
The prevent_tail_call() macro works around the problem of the compiler
clobbering argument words on the stack, which for asmlinkage functions
is the caller's (user's) struct pt_regs. The tail/sibling-call
optimization is not the only way that the compiler can decide to use
stack argument words as scratch space, which we have to prevent.
Other optimizations can do it too.
Until we have new compiler support to make "asmlinkage" binding on the
compiler's own use of the stack argument frame, we have work around all
the manifestations of this issue that crop up.
More cases seem to be prevented by also keeping the incoming argument
variables live at the end of the function. This makes their original
stack slots attractive places to leave those variables, so the compiler
tends not clobber them for something else. It's still no guarantee, but
it handles some observed cases that prevent_tail_call() did not.
Signed-off-by: Roland McGrath <roland@redhat.com>
All users are gone, remove definitions and comments referring
to them.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
The ENDPROCs() were not used everywhere. Some code used just END() instead,
while other code used nothing. um/sys-i386/checksum.S didn't #include
<linux/linkage.h> . I also got confused because gcc puts the
.type near the ENTRY, while ENDPROC puts it on the opposite end.
Signed off by: John Reiser <jreiser@BitWagon.com>
introduce the "asmregparm" calling convention: for functions
implemented in assembly with a fixed regparm input parameters
calling convention.
mark the semaphore and rwsem slowpath functions with that.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
This patch moves the entry.S:error_entry to .kprobes.text section,
since code marked unsafe for kprobes jumps directly to entry.S::error_entry,
that must be marked unsafe as well.
This patch also moves all the ".previous.text" asm directives to ".previous"
for kprobes section.
AK: Following a similar i386 patch from Chuck Ebbert
AK: Also merged Jeremy's fix in.
+From: Jeremy Fitzhardinge <jeremy@goop.org>
KPROBE_ENTRY does a .section .kprobes.text, and expects its users to
do a .previous at the end of the function.
Unfortunately, if any code within the function switches sections, for
example .fixup, then the .previous ends up putting all subsequent code
into .fixup. Worse, any subsequent .fixup code gets intermingled with
the code its supposed to be fixing (which is also in .fixup). It's
surprising this didn't cause more havok.
The fix is to use .pushsection/.popsection, so this stuff nests
properly. A further cleanup would be to get rid of all
.section/.previous pairs, since they're inherently fragile.
+From: Chuck Ebbert <76306.1226@compuserve.com>
Because code marked unsafe for kprobes jumps directly to
entry.S::error_code, that must be marked unsafe as well.
The easiest way to do that is to move the page fault entry
point to just before error_code and let it inherit the same
section.
Also moved all the ".previous" asm directives for kprobes
sections to column 1 and removed ".text" from them.
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Provide abstraction for generating type and size information of assembly
routines and data, while permitting architectures to override these
defaults.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: "Russell King" <rmk@arm.linux.org.uk>
Cc: "Andi Kleen" <ak@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
There are possible race conditions if probes are placed on routines within the
kprobes files and routines used by the kprobes. For example if you put probe
on get_kprobe() routines, the system can hang while inserting probes on any
routine such as do_fork(). Because while inserting probes on do_fork(),
register_kprobes() routine grabs the kprobes spin lock and executes
get_kprobe() routine and to handle probe of get_kprobe(), kprobes_handler()
gets executed and tries to grab kprobes spin lock, and spins forever. This
patch avoids such possible race conditions by preventing probes on routines
within the kprobes file and routines used by kprobes.
I have modified the patches as per Andi Kleen's suggestion to move kprobes
routines and other routines used by kprobes to a seperate section
.kprobes.text.
Also moved page fault and exception handlers, general protection fault to
.kprobes.text section.
These patches have been tested on i386, x86_64 and ppc64 architectures, also
compiled on ia64 and sparc64 architectures.
Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com>
infrastructure for it.
Let it rip!
