path: root/include/linux/lightnvm.h
2018-06-01lightnvm: pass flag on graceful teardown to targetsJavier González
If the namespace is unregistered before the LightNVM target is removed (e.g., on hot unplug) it is too late for the target to store any metadata on the device - any attempt to write to the device will fail. In this case, pass on a "gracefull teardown" flag to the target to let it know when this happens. In the case of pblk, we pad the open line (close all open chunks) to improve data retention. In the event of an ungraceful shutdown, avoid this part and just clean up. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: pblk: implement get log report chunkJavier González
In preparation of pblk supporting 2.0, implement the get log report chunk in pblk. Also, define the chunk states as given in the 2.0 spec. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: implement get log report chunk helpersJavier González
The 2.0 spec provides a report chunk log page that can be retrieved using the stangard nvme get log page. This replaces the dedicated get/put bad block table in 1.2. This patch implements the helper functions to allow targets retrieve the chunk metadata using get log page. It makes nvme_get_log_ext available outside of nvme core so that we can use it form lightnvm. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: make address conversions depend on generic deviceJavier González
On address conversions, use the generic device, instead of the target device. This allows to use conversions outside of the target's realm. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: add support for 2.0 address formatJavier González
Add support for 2.0 address format. Also, align address bits for 1.2 and 2.0 to be able to operate on channel and luns without requiring a format conversion. Use a generic address format for this purpose. Also, convert the generic operations to the generic format in pblk. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: normalize geometry nomenclatureJavier González
Normalize nomenclature for naming channels, luns, chunks, planes and sectors as well as derivations in order to improve readability. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: complete geo structure with maxoc*Javier González
Complete the generic geometry structure with the maxoc and maxocpu felds, present in the 2.0 spec. Also, expose them through sysfs. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: add shorten OCSSD version in geoJavier González
Create a shorten version to use in the generic geometry. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: add minor version to generic geometryJavier González
Separate the version between major and minor on the generic geometry and represent it through sysfs in the 2.0 path. The 1.2 path only shows the major version to preserve the existing user space interface. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: simplify geometry structureJavier González
Currently, the device geometry is stored redundantly in the nvm_id and nvm_geo structures at a device level. Moreover, when instantiating targets on a specific number of LUNs, these structures are replicated and manually modified to fit the instance channel and LUN partitioning. Instead, create a generic geometry around nvm_geo, which can be used by (i) the underlying device to describe the geometry of the whole device, and (ii) instances to describe their geometry independently. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: remove nvm_dev_ops->max_phys_sectMatias Bjørling
The value of max_phys_sect is always static. Instead of defining it in the nvm_dev_ops structure, declare it as a global value. Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: remove max_rq_sizeMatias Bjørling
The field is no longer used. Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: add 2.0 geometry identificationMatias Bjørling
Implement the geometry data structures for 2.0 and enable a drive to be identified as one, including exposing the appropriate 2.0 sysfs entries. Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-29lightnvm: flatten nvm_id_group into nvm_idMatias Bjørling
There are no groups in the 2.0 specification, make sure that the nvm_id structure is flattened before 2.0 data structures are added. Signed-off-by: Matias Bjørling <mb@lightnvm.io> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-05lightnvm: set target over-provision on create ioctlJavier González
Allow to set the over-provision percentage on target creation. In case that the value is not provided, fall back to the default value set by the target. In pblk, set the default OP to 11% of the total size of the device Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Hans Holmberg <hans.holmberg@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-05lightnvm: make geometry structures 2.0 readyMatias Bjørling
Prepare for the 2.0 revision by adapting the geometry structures to coexist with the 1.2 revision. Signed-off-by: Matias Bjørling <m@bjorling.me> Reviewed-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-05lightnvm: remove lower page tablesMatias Bjørling
The lower page table is unused. All page tables reported by 1.2 devices are all reporting a sequential 1:1 page mapping. This is also not used going forward with the 2.0 revision. Signed-off-by: Matias Bjørling <m@bjorling.me> Reviewed-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-05lightnvm: remove unnecessary field from nvm_rqJavier González
Remove the wait filed in nvm_rq. It is not used anymore, as targets rely on the functionality provided by the LightNVM subsystem when sending sync I/O. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-05lightnvm: remove hybrid ocssd 1.2 supportMatias Bjørling
Now that rrpc have been removed. Also remove the hybrid 1.2 support from the core. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-05lightnvm: use internal pblk methodsMatias Bjørling
Now that rrpc has been removed, the only users of the ppa helpers is pblk. However, pblk already defines similar functions. Switch pblk to use the internal ones, and remove the generic ppa helpers. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-11-14Merge branch 'for-4.15/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block layer updates from Jens Axboe: "This is the main pull request for block storage for 4.15-rc1. Nothing out of the ordinary in here, and no API changes or anything like that. Just various new features for drivers, core changes, etc. In particular, this pull request contains: - A patch series from Bart, closing the whole on blk/scsi-mq queue quescing. - A series from Christoph, building towards hidden gendisks (for multipath) and ability to move bio chains around. - NVMe - Support for native multipath for NVMe (Christoph). - Userspace notifications for AENs (Keith). - Command side-effects support (Keith). - SGL support (Chaitanya Kulkarni) - FC fixes and improvements (James Smart) - Lots of fixes and tweaks (Various) - bcache - New maintainer (Michael Lyle) - Writeback control improvements (Michael) - Various fixes (Coly, Elena, Eric, Liang, et al) - lightnvm updates, mostly centered around the pblk interface (Javier, Hans, and Rakesh). - Removal of unused bio/bvec kmap atomic interfaces (me, Christoph) - Writeback series that fix the much discussed hundreds of millions of sync-all units. This goes all the way, as discussed previously (me). - Fix for missing wakeup on writeback timer adjustments (Yafang Shao). - Fix laptop mode on blk-mq (me). - {mq,name} tupple lookup for IO schedulers, allowing us to have alias names. This means you can use 'deadline' on both !mq and on mq (where it's called mq-deadline). (me). - blktrace race fix, oopsing on sg load (me). - blk-mq optimizations (me). - Obscure waitqueue race fix for kyber (Omar). - NBD fixes (Josef). - Disable writeback throttling by default on bfq, like we do on cfq (Luca Miccio). - Series from Ming that enable us to treat flush requests on blk-mq like any other request. This is a really nice cleanup. - Series from Ming that improves merging on blk-mq with schedulers, getting us closer to flipping the switch on scsi-mq again. - BFQ updates (Paolo). - blk-mq atomic flags memory ordering fixes (Peter Z). - Loop cgroup support (Shaohua). - Lots of minor fixes from lots of different folks, both for core and driver code" * 'for-4.15/block' of git://git.kernel.dk/linux-block: (294 commits) nvme: fix visibility of "uuid" ns attribute blk-mq: fixup some comment typos and lengths ide: ide-atapi: fix compile error with defining macro DEBUG blk-mq: improve tag waiting setup for non-shared tags brd: remove unused brd_mutex blk-mq: only run the hardware queue if IO is pending block: avoid null pointer dereference on null disk fs: guard_bio_eod() needs to consider partitions xtensa/simdisk: fix compile error nvme: expose subsys attribute to sysfs nvme: create 'slaves' and 'holders' entries for hidden controllers block: create 'slaves' and 'holders' entries for hidden gendisks nvme: also expose the namespace identification sysfs files for mpath nodes nvme: implement multipath access to nvme subsystems nvme: track shared namespaces nvme: introduce a nvme_ns_ids structure nvme: track subsystems block, nvme: Introduce blk_mq_req_flags_t block, scsi: Make SCSI quiesce and resume work reliably block: Add the QUEUE_FLAG_PREEMPT_ONLY request queue flag ...
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-13lightnvm: implement generic path for sync I/OJavier González
Implement a generic path for sending sync I/O on LightNVM. This allows to reuse the standard synchronous path trough blk_execute_rq(), instead of implementing a wait_for_completion on the target side (e.g., pblk). Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-10-13lightnvm: remove stale extern and unused exported symbolsRakesh Pandit
Not all exported symbols are being used outside core and there were some stale entries in lightnvm.h Signed-off-by: Rakesh Pandit <rakesh@tuxera.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-10-13lightnvm: remove unused argument from nvm_set_tgt_bb_tblRakesh Pandit
vblk isn't being used anyway and if we ever have a usecase we can introduce this again. This makes the logic easier and removes unnecessary checks. Signed-off-by: Rakesh Pandit <rakesh@tuxera.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-10-13lightnvm: prevent target type module removal when in useRakesh Pandit
If target type module e.g. pblk here is unloaded (rmmod) while module is in use (after creating target) system crashes. We fix this by using module API refcnt. Signed-off-by: Rakesh Pandit <rakesh@tuxera.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-04-16lightnvm: allow to init targets on factory modeJavier González
Target initialization has two responsibilities: creating the target partition and instantiating the target. This patch enables to create a factory partition (e.g., do not trigger recovery on the given target). This is useful for target development and for being able to restore the device state at any moment in time without requiring a full-device erase. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: rename scrambler controller hintJavier González
According to the OCSSD 1.2 specification, the 0x200 hint enables the media scrambler for the read/write opcode, providing that the controller has been correctly configured by the firmware. Rename the macro to represent this meaning. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: submit erases using the I/O pathJavier González
Until now erases have been submitted as synchronous commands through a dedicated erase function. In order to enable targets implementing asynchronous erases, refactor the erase path so that it uses the normal async I/O submission functions. If a target requires sync I/O, it can implement it internally. Also, adapt rrpc to use the new erase path. Signed-off-by: Javier González <javier@cnexlabs.com> Fixed spelling error. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: allow targets to use sysfsJavier González
In order to register through the sysfs interface, a driver needs to know its kobject. On a disk structure, this happens when the partition information is added (device_add_disk), which for lightnvm takes place after the target has been initialized. This means that on target initialization, the kboject has not been created yet. This patch adds a target function to let targets initialize their own kboject as a child of the disk kobject. Signed-off-by: Javier González <javier@cnexlabs.com> Added exit typedef and passed gendisk instead of void pointer for exit. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: Add CRC read errorJavier González
Let the host differentiate between a read error and a CRC check error on the device side. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: use end_io callback instead of instanceMatias Bjørling
When the lightnvm core had the "gennvm" layer between the device and the target, there was a need for the core to be able to figure out which target it should send an end_io callback to. Leading to a "double" end_io, first for the media manager instance, and then for the target instance. Now that core and gennvm is merged, there is no longer a need for this, and a single end_io callback will do. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: reduce number of nvm_id groups to oneMatias Bjørling
The number of configuration groups has been limited to one in current code, even if there is support for up to four. With the introduction of the open-channel SSD 1.3 specification, only a single group is exposed onwards. Reflect this in the nvm_id structure. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: cleanup nvm transformation functionsMatias Bjørling
Going from target specific ppa addresses to device was accomplished by first converting target to generic ppa addresses and generic to device addresses. The conversion was either open-coded or used the built-in nvm_trans_* and nvm_map_* functions for conversion. Simplify the interface and cleanup the calls to provide clean functions that now either take a list of ppas or a nvm_rq, and is exposed through: void nvm_ppa_* - target to/from device with a list of PPAs, void nvm_rq_* - target to/from device with a nvm_rq. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: remove nvm_get_bb_tbl and nvm_set_bb_tblMatias Bjørling
Since the merge of gennvm and core, there is no longer a need for the device specific bad block functions. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: remove nvm_submit_ppa* functionsMatias Bjørling
The nvm_submit_ppa* functions are no longer needed after gennvm and core have been merged. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: collapse nvm_erase_ppa and nvm_erase_blkMatias Bjørling
After gennvm and core have been merged, there are no more callers to nvm_erase_ppa. Therefore collapse the device specific and target specific erase functions. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: merge gennvm with coreMatias Bjørling
For the first iteration of Open-Channel SSDs, it was anticipated that there could be various media managers on top of an open-channel SSD, such to allow vendors to plug in their own host-side FTLs, without the media manager in between. Now that an Open-Channel SSD is exposed as a traditional block device, there is no longer a need for this. Therefore lets merge the gennvm code with core and simplify the stack. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: transform target get/set bad blockJavier González
Since targets are given a virtual target device, it is necessary to translate all communication between targets and the backend device. Implement the translation layer for get/set bad block table. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: use target nvm on target-specific ops.Javier González
On target-specific operations pass on nvm_tgt_dev instead of the generic nvm device. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: introduce max_phys_sects helper functionJavier González
Target devices do not have access to the device driver operations. Introduce a helper function that exposes the max. number of physical sectors supported by the underlying device. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: introduce helpers for generic ops in rrpcJavier González
Avoid calling media manager and device-specific operations directly from rrpc. Create helper functions on lightnvm's core instead. Signed-off-by: Javier González <javier@cnexlabs.com> Made it work with null_blk as well. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: eliminate nvm_lun abstraction in mmJavier González
In order to naturally support multi-target instances on an Open-Channel SSD, targets should own the LUNs they get blocks from and manage provisioning internally. This is done in several steps. Since targets own the LUNs the are instantiated on top of and manage the free block list internally, there is no need for a LUN abstraction in the media manager. LUNs are intrinsically managed as in the physical layout (ch:0,lun:0, ..., ch:0,lun:n, ch:1,lun:0, ch:1,lun:n, ..., ch:m,lun:0, ch:m,lun:n) and given to the targets based on the target creation ioctl. This simplifies LUN management and clears the path for a partition manager to sit directly underneath LightNVM targets. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: eliminate nvm_block abstraction on mmJavier González
In order to naturally support multi-target instances on an Open-Channel SSD, targets should own the LUNs they get blocks from and manage provisioning internally. This is done in several steps. A part of this transformation is that targets manage their blocks internally. This patch eliminates the nvm_block abstraction and moves block management to the target logic. The rrpc target is transformed. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: remove debug lun statistics from gennvmJavier González
Since LUNs are managed internally on targets, the media manager has no access to the free LUN lists. Thus, debug functions that show LUN information on the device should not be implemented on the media manager, but rather on the target in itself. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: remove get_lun operation on gennvmJavier González
Since LUNs are managed internally on the target, there is no need for the media manager to implement a get_lun operation. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: move block provisioning to targetsJavier González
In order to naturally support multi-target instances on an Open-Channel SSD, targets should own the LUNs they get blocks from and manage provisioning internally. This is done in several steps. This patch moves the block provisioning inside of the target and removes the get/put block interface from the media manager. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: manage lun partitions internally in mmJavier González
LUNs are exclusively owned by targets implementing a block device FTL. Doing this reservation requires at the moment a 2-way callback gennvm <-> target. The reason behind this is that LUNs were not assumed to always be exclusively owned by targets. However, this design decision goes against I/O determinism QoS (two targets would mix I/O on the same parallel unit in the device). This patch makes LUN reservation as part of the target creation on the media manager. This makes that LUNs are always exclusively owned by the target instantiated on top of them. LUN stripping and/or sharing should be implemented on the target itself or the layers on top. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: remove gen_lun abstractionJavier González
The gen_lun abstraction in the generic media manager was conceived on the assumption that a single target would instantiated on top of it. This has complicated target design to implement multi-instances. Remove this abstraction and move its logic to nvm_lun, which manages physical lun geometry and operations. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: make address conversion functions globalJavier González
Targets are assumed to used the same generic ppa format, where the address is partitioned on ch:lun:block:pg:pl:sec. Thus, make the function in charge of transforming the ppa address from a linear format to the generic one available to all targets. This function will be needed by the media manager in order to do target mapping translations when targets are divided on different physical partitions. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
