path: root/include/linux/libata.h
2007-04-28libata: separate ATA_EHI_DID_RESET into DID_SOFTRESET and DID_HARDRESETTejun Heo
Separate ATA_EHI_DID_RESET into ATA_EHI_DID_SOFTRESET and ATA_EHI_DID_HARDRESET. ATA_EHI_DID_RESET is redefined as OR of the two flags. This patch doesn't introduce any behavior change. This will be used later to determine whether _SDD is necessary or not. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: HPA supportAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Add support for ignoring the BIOS HPA result (off by default) and setting the disk to the full available size unless already frozen. Tested with various platforms/disks and confirmed to work with the Macintosh (which broke earlier) and ata_piix (breakage due to the LBA48 readback that Tejun fixed). For normal users this brings us, I believe, to feature parity with old IDE (and of course more featured in some areas too). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: kill probe_ent and related helpersTejun Heo
All drivers are converted to new init model. Kill probe_ent, ata_device_add() and ata_pci_init_native_mode(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: add init helpers including ata_pci_prepare_native_host()Tejun Heo
These will be used to convert LLDs to new init model. * Add irq_handler field to port_info. In new init model, requesting IRQ is LLD's responsibility and libata doesn't need to know about irq_handler. Most LLDs can simply register their irq_handler but some need different irq_handler depending on specific chip. The added port_info->irq_handler field can be used by LLDs to select the matching IRQ handler in such cases. * Add ata_dummy_port_info. * Implement ata_pci_prepare_native_host(), a helper to alloc ATA host, acquire all resources and init the host in one go. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: convert native PCI host handling to new init modelTejun Heo
Convert native PCI host handling to alloc-init-register model. New function ata_pci_init_native_host() follows the new init model and replaces ata_pci_init_native_mode(). As there are remaining LLD users, the old function isn't removed yet. ata_pci_init_one() is reimplemented using the new function and now fully converted to new init model. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: implement ata_host_alloc_pinfo() and ata_host_register()Tejun Heo
Implement ata_host_alloc_pinfo() and ata_host_register(). These helpers will be used in the following patches to adopt new init model. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: separate out ata_host_alloc() and ata_host_register()Tejun Heo
Reorganize ata_host_alloc() and its subroutines into the following three functions. * ata_host_alloc() : allocates host and its ports. shost is not registered automatically. * ata_scsi_add_hosts() : allocates and adds shosts associated with an ATA host. Used by ata_host_register(). * ata_host_register() : takes a fully initialized ata_host structure and registers it to libata layer and probes it. Only ata_host_alloc() and ata_host_register() are exported. ata_device_add() is rewritten using the above functions. This patch does not introduce any observable behavior change. Things worth mentioning. * print_id is assigned at registration time and LLDs are allowed to overallocate ports and reduce host->n_ports during initialization. ata_host_register() will throw away unused ports automatically. * All SCSI host initialization stuff now resides in ata_scsi_add_hosts() in libata-scsi.c, where it should be. * ipr is now the only user of ata_host_init(). Either kill it by converting ipr to use ata_host_alloc() and friends or rename and move it to libata-scsi.c Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: separate out ata_host_start()Tejun Heo
Separate out ata_host_start() from ata_device_add(). ata_host_start() calls ->port_start on each port if available and freezes the port. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: allocate ap separately from shostTejun Heo
Don't embed ap inside shost. Allocate it separately and point it back from shosts's hostdata. This makes port allocation more flexible and allows regular ATA and SAS share host alloc/init paths. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: add support for READ/WRITE LONGMark Lord
The READ/WRITE LONG commands are theoretically obsolete, but the majority of drives in existance still implement them. The WRITE_LONG and WRITE_LONG_ONCE commands are of particular interest for fault injection testing -- eg. creating "media errors" at specific locations on a disk. The fussy bit is that these commands require a non-standard sector size, usually 520 bytes instead of 512. This patch adds support to libata for READ/WRITE LONG commands issued via SG_IO/ATA_16. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: Change prototype of mode_filter to remove ata_port*Alan Cox
With Tejun having added adev->ap some time ago we can get rid of the almost unused port being passed to mode filters. And while we are doing filters, lets turn on the !IORDY filter as well. Signed-off-by: Alan Cox <alan@redhat.com> With some hand massaging from Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pata: expose set_mode method so it can be wrappedAlan
This splits set_mode into do_set_mode and the wrapper so that a driver can call the standard method inside its own. This in theory also obsoletes ->post_set_mode(). Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: cable detection fixesAlan Cox
2.6.21-rc has horrible problems with libata and PATA cable types (and thus speeds). This occurs because Tejun fixed a pile of other bugs and we now do cable detect enforcement for drive side detection properly. Unfortunately we don't do the process around cable detection right. Tejun identified the problem and pointed to the right Annex in the spec, this patch implements the rest of the needed changes. We add a ->cable_detect() method called after the identify sequence which allows a host to do host side detection at this point should it wish, or to modify the results of the drive side identify. This separate ->cable_detect method also cleans up a lot of code because many drivers have their own error_handler methods which really just set the cable type. If there is no ->cable_detect method the cable type is left alone so a driver setting it earlier (eg because it has the SATA flags set or because it uses the old error_handler approach) will still do the right thing (or at least the same thing) as before. This patch simply adds the cable_detect method and helpers it doesn't use them but other follow up patches will (ie Adrian please don't submit patches to unexport them ;)) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: dev_config does not need ap and adev passingAlan
It used to be impossible to get from ata_device to ata_port but that is no longer true. Various methods have been cleaned up over time but dev_config still takes both and most users don't need both anyway. Tidy this one up Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[libata] export sata_print_link_status()Jeff Garzik
To be used in sata_mv's exception handling code, and overall is a generally useful function. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-04libata: Limit ATAPI DMA to R/W commands only for TORiSAN DVD drives (take 3)Albert Lee
patch 4/4: Limit ATAPI DMA to R/W commands only for TORiSAN DRD-N216 DVD-ROM drives (http://bugzilla.kernel.org/show_bug.cgi?id=6710) Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-04libata: Limit max sector to 128 for TORiSAN DVD drives (take 3)Albert Lee
patch 3/4: The TORiSAN drive locks up when max sector == 256. Limit max sector to 128 for the TORiSAN DRD-N216 drives. (http://bugzilla.kernel.org/show_bug.cgi?id=6710) Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-04libata: reorder HSM_ST_FIRST for easier decoding (take 3)Albert Lee
patch 1/4: Reorder HSM_ST_FIRST, such that the task state transition is easier decoded with human eyes. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-02libata: add CONFIG_PM to libata core layerTejun Heo
Conditionalize all PM related stuff in libata core layer using CONFIG_PM. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-02libata-core: Fix simplex handlingAlan
The initial simplex handling code is fooled if you suspend and resume. This also causes problems with some single channel controllers which claim to be simplex. The fix is fairly simple, instead of keeping a flag to remember if we gave away the simplex channel we remember the actual owner. As the owner is always part of the host_set we don't even need a refcount. Knowing the owner also means we can reassign simplex DMA channels in future hotplug code etc if we need to Signed-off-by: Alan Cox <alan@redhat.com> (and a signed-off for the patch I sent before while I remember) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-25Add id_to_dma_mode function for printing DMA modesAlan
Also export dev_disable as this is needed by drivers doing slave decode filtering, which will follow shortly Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: s/ap->id/ap->print_id/gTejun Heo
ata_port has two different id fields - id and port_no. id is system-wide 1-based unique id for the port while port_no is 0-based host-wide port number. The former is primarily used to identify the ATA port to the user in printk messages while the latter is used in various places in libata core and LLDs to index the port inside the host. The two fields feel quite similar and sometimes ap->id is used in place of ap->port_no, which is very difficult to spot. This patch renames ap->id to ap->print_id to reduce the possibility of such bugs. Some printk messages are adjusted such that id string (ata%u[.%u]) isn't printed twice and/or to use ata_*_printk() instead of hardcoded id format. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: separate out ata_ncq_enabled()Tejun Heo
Separate out ata_ncq_enabled(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: put some intelligence into EH speed down sequenceTejun Heo
The current EH speed down code is more of a proof that the EH framework is capable of adjusting transfer speed in response to error. This patch puts some intelligence into EH speed down sequence. The rules are.. * If there have been more than three timeout, HSM violation or unclassified DEV errors for known supported commands during last 10 mins, NCQ is turned off. * If there have been more than three timeout or HSM violation for known supported command, transfer mode is slowed down. If DMA is active, it is first slowered by one grade (e.g. UDMA133->100). If that doesn't help, it's slowered to 40c limit (UDMA33). If PIO is active, it's slowered by one grade first. If that doesn't help, PIO0 is forced. Note that this rule does not change transfer mode. DMA is never degraded into PIO by this rule. * If there have been more than ten ATA bus, timeout, HSM violation or unclassified device errors for known supported commands && speeding down DMA mode didn't help, the device is forced into PIO mode. Note that this rule is considered only for PATA devices and is pretty difficult to trigger. One error can only trigger one rule at a time. After a rule is triggered, error history is cleared such that the next speed down happens only after some number of errors are accumulated. This makes sense because now speed down is done in bigger stride. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: PATA driver for CellebAkira Iguchi
This is the patch for PATA controller of Celleb. This driver uses the managed iomap (devres). Because this driver needs special taskfile accesses, there is a copy of ata_std_softreset(). ata_dev_try_classify() is exported so that it can be used in this function. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-16[PATCH] libata: ACPI and _GTF supportKristen Carlson Accardi
_GTF is an acpi method that is used to reinitialize the drive. It returns a task file containing ata commands that are sent back to the drive to restore it to boot up defaults. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> (cherry picked from 9c69cab24b51a89664f4c0dfaf8a436d32117624 commit)
2007-02-15libata: Add a host flag to indicate lack of IORDY capabilityAlan Cox
This is the first preparation to doing the !IORDY cases properly. Further diffs will then add the needed logic to do it right. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: kill ATA_ENABLE_PATAJeff Garzik
The ATA_ENABLE_PATA define was never meant to be permanent, and in recent kernels, it's already been unconditionally enabled. Remove. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (core and headers)Akira Iguchi
This patch is against the libata core and headers. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: remove unused functionsTejun Heo
Now that all LLDs are converted to use devres, default stop callbacks are unused. Remove them. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata core layer to use devresTejun Heo
Update libata core layer to use devres. * ata_device_add() acquires all resources in managed mode. * ata_host is allocated as devres associated with ata_host_release. * Port attached status is handled as devres associated with ata_host_attach_release(). * Initialization failure and host removal is handedl by releasing devres group. * Except for ata_scsi_release() removal, LLD interface remains the same. Some functions use hacky is_managed test to support both managed and unmanaged devices. These will go away once all LLDs are updated to use devres. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: implement ata_host_detach()Tejun Heo
Implement ata_host_detach() which calls ata_port_detach() for each port in the host and export it. ata_port_detach() is now internal and thus un-exported. ata_host_detach() will be used as the 'deregister from libata layer' function after devres conversion. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: kill qc->nsect and cursectTejun Heo
libata used two separate sets of variables to record request size and current offset for ATA and ATAPI. This is confusing and fragile. This patch replaces qc->nsect/cursect with qc->nbytes/curbytes and kills them. Also, ata_pio_sector() is updated to use bytes for qc->cursg_ofs instead of sectors. The field used to be used in bytes for ATAPI and in sectors for ATA. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: handle pci_enable_device() failure while resumingTejun Heo
Handle pci_enable_device() failure while resuming. This patch kills the "ignoring return value of 'pci_enable_device'" warning message and propagates __must_check through ata_pci_device_do_resume(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09[PATCH] pci: Move PCI_VDEVICE from libata to coreAlan Cox
Updated diff which doesn't move the comment as per Jeff's request and corrects the docs as per report on l/k Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09[libata] trim trailing whitespaceJeff Garzik
Most of these contributed by that mysterious figger known as A.C. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-02libata: Fix ata_busy_wait() kernel docsAlan
> Looks like you should use ata_busy_wait() here, rather than reproducing > the same code again. It waits in 10uS chunks while 1uS chunks were used in the workaround. Could indeed do that once I know the fix is right. While I'm at it the ata_busy_wait kerneldoc is borked so here's a fix Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-25libata: implement ATA_FLAG_IGN_SIMPLEX and use it in sata_uliTejun Heo
Some uli controllers have stuck SIMPLEX bit which can't be cleared with ata_pci_clear_simplex(), but the controller is capable of doing DMAs on both channels simultaneously. Implement ATA_FLAG_IGN_SIMPLEX which makes libata ignore the simplex bit and use it in sata_uli. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-24libata: set_mode, Fix the FIXMEAlan
When set_mode() changed ->set_mode didn't adapt. This makes the needed changes and removes the relevant FIXME case. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-24libata: Initialize qc->pad_lenBrian King
Initialize qc->pad_len for each new command. This ensures that pad_len is not set to a stale value for zero data length commands. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-24libata: Fixup n_elem initializationBrian King
Fixup the inialization of qc->n_elem. It currently gets initialized to 1 for commands that do not transfer any data. Fix this by initializing n_elem to 0 and only setting to 1 in ata_scsi_qc_new when there is data to transfer. This fixes some problems seen with SATA devices attached to ipr adapters. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-19libata: initialize qc->dma_dir to DMA_NONETejun Heo
libata didn't used to init qc->dma_dir to any specific value on qc initialization and command translation path didn't set qc->dma_dir if the command doesn't need data transfer. This made non-data commands to have random qc->dma_dir. This usually doesn't cause problem because LLDs usually check qc->protocol first and look at qc->dma_dir iff the command needs data transfer but this doesn't hold for all LLDs. It might be worthwhile to rename qc->dma_dir to qc->data_dir as we use the field to tag data direction for both PIO and DMA protocols. This problem has been spotted by James Bottomley. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-03[PATCH] libata: always use polling IDENTIFYTejun Heo
libata switched to IRQ-driven IDENTIFY when IRQ-driven PIO was introduced. This has caused a lot of problems including device misdetection and phantom device. ATA_FLAG_DETECT_POLLING was added recently to selectively use polling IDENTIFY on problemetic drivers but many controllers and devices are affected by this problem and trying to adding ATA_FLAG_DETECT_POLLING for each such case is diffcult and not very rewarding. This patch makes libata always use polling IDENTIFY. This is consistent with libata's original behavior and drivers/ide's behavior. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: implement ATA_FLAG_SETXFER_POLLING and use it in pata_via, ↵Tejun Heo
take #2 This patch implements ATA_FLAG_SETXFER_POLLING and use in pata_via. If this flag is set, transfer mode setting performed by polling not by interrupt. This should help those controllers which raise interrupt before the command is actually complete on SETXFER. Rationale for this approach. * uses existing facility and relatively simple * no busy sleep in the interrupt handler * updating drivers is easy While at it, kill now unused flag ATA_FLAG_SRST in pata_via. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-03[PATCH] libata: remove unused HSM_ST_UNKNOWNTejun Heo
HSM_ST_UNKNOWN is not used anywhere. Its value is zero and supposed to serve sanity check purpose but HSM_ST_IDLE is used for that purpose. This unused state causes confusion. After a port is initialized but before the first command is executed, the idle hsm state is UNKNOWN. However, once a command has completed, the idle hsm state is IDLE. This defeats sanity check in ata_pio_task() for the first command. This patch removes HSM_ST_UNKNOWN and consequently make HSM_ST_IDLE the default state. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[PATCH] libata: implement presence detection via polling IDENTIFYTejun Heo
On some controllers (ICHs in piix mode), there is *NO* reliable way to determine device presence other than issuing IDENTIFY and see how the transaction proceeds by watching the TF status register. libata acted this way before irq-pio and phantom devices caused very little problem but now that IDENTIFY is performed using IRQ drive PIO, such phantom devices now result in multiple 30sec timeouts during boot. This patch implements ATA_FLAG_DETECT_POLLING. If a LLD sets this flag, libata core issues the initial IDENTIFY in polling mode and if the initial data transfer fails w/ HSM violation, the port is considered to be empty thus replicating the old libata and IDE behavior. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-01[PATCH] libata: use FLUSH_EXT only when driver is larger than LBA28 limitTejun Heo
Many drives support LBA48 even when its capacity is smaller than 1<<28, as LBA48 is required for many functionalities. FLUSH_EXT is mandatory for drives w/ LBA48 support. Interestingly, at least one of such drives (ST960812A) has problems dealing with FLUSH_EXT. It eventually completes the command but takes around 7 seconds to finish in many cases thus drastically slowing down IO transactions. This seems to be a firmware bug which sneaked into production probably because no other ATA driver including linux IDE issues FLUSH_EXT to drives which report support for LBA48 & FLUSH_EXT but is smaller than 1<<28 blocks. This patch adds ATA_DFLAG_FLUSH_EXT which is set iff the drive supports LBA48 & FLUSH_EXT and is larger than LBA28 limit. Both cache flush paths are updated to issue FLUSH_EXT only when the flag is set. Note that the changed behavior is more inline with the rest of libata. libata prefers shorter commands whenever possible. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Danny Kukawka <dkukawka@novell.com> Cc: Stefan Seyfried <seife@novell.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-01[PATCH] libata: implement ATA_EHI_SETMODE and ATA_EHI_POST_SETMODETejun Heo
libata EH used to perform ata_set_mode() iff the EH session performed reset as indicated by ATA_EHI_DID_RESET. This is incorrect because ->dev_config() called by revalidation is allowed to modify transfer mode which ata_set_mode() should take care of. This patch implements the following two flags. * ATA_EHI_SETMODE: set during EH to schedule ata_set_mode(). Both new device attachment and revalidation set this flag. * ATA_EHI_POST_SETMODE: set while the device is revalidated after ata_set_mode(). Post-setmode revalidation is different from initial configuaration and EH revalidation in that ->dev_config() is not allowed tune transfer mode. LLD can use this flag to determine whether it's allowed to tune transfer mode. Note that POST_SETMODE ->dev_config() is guaranteed to be preceded by non-POST_SETMODE ->dev_config(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
