Commits e4d57e1ee1ab (KVM: Move irq notifier implementation into
eventfd.c, 2014-06-30) included the irq notifier code unconditionally
in eventfd.c, while it was under CONFIG_HAVE_KVM_IRQCHIP before.
Similarly, commit 297e21053a52 (KVM: Give IRQFD its own separate enabling
Kconfig option, 2014-06-30) moved code from CONFIG_HAVE_IRQ_ROUTING
to CONFIG_HAVE_KVM_IRQFD but forgot to move the pieces that used to be
under CONFIG_HAVE_KVM_IRQCHIP.
Together, this broke compilation without CONFIG_KVM_XICS. Fix by adding
or changing the #ifdefs so that they point at CONFIG_HAVE_KVM_IRQFD.
Currently, the IRQFD code is conditional on CONFIG_HAVE_KVM_IRQ_ROUTING.
So that we can have the IRQFD code compiled in without having the
IRQ routing code, this creates a new CONFIG_HAVE_KVM_IRQFD, makes
the IRQFD code conditional on it instead of CONFIG_HAVE_KVM_IRQ_ROUTING,
and makes all the platforms that currently select HAVE_KVM_IRQ_ROUTING
also select HAVE_KVM_IRQFD.
Tested-by: Eric Auger <eric.auger@linaro.org>
Tested-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Now that struct _irqfd does not keep a reference to storage pointed
to by the irq_routing field of struct kvm, we can move the statement
that updates it out from under the irqfds.lock and put it in
kvm_set_irq_routing() instead. That means we then have to take a
srcu_read_lock on kvm->irq_srcu around the irqfd_update call in
kvm_irqfd_assign(), since holding the kvm->irqfds.lock no longer
ensures that that the routing can't change.
Combined with changing kvm_irq_map_gsi() and kvm_irq_map_chip_pin()
to take a struct kvm * argument instead of the pointer to the routing
table, this allows us to to move all references to kvm->irq_routing
into irqchip.c. That in turn allows us to move the definition of the
kvm_irq_routing_table struct into irqchip.c as well.
This provides accessor functions for the KVM interrupt mappings, in
order to reduce the amount of code that accesses the fields of the
kvm_irq_routing_table struct, and restrict that code to one file,
virt/kvm/irqchip.c. The new functions are kvm_irq_map_gsi(), which
maps from a global interrupt number to a set of IRQ routing entries,
and kvm_irq_map_chip_pin, which maps from IRQ chip and pin numbers to
a global interrupt number.
This also moves the update of kvm_irq_routing_table::chip[][]
into irqchip.c, out of the various kvm_set_routing_entry
implementations. That means that none of the kvm_set_routing_entry
implementations need the kvm_irq_routing_table argument anymore,
so this removes it.
This does not change any locking or data lifetime rules.
In preparation to make the check_extension function available to VM scope
we add a struct kvm * argument to the function header and rename the function
accordingly. It will still be called from the /dev/kvm fd, but with a NULL
argument for struct kvm *.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Pull more scheduler updates from Ingo Molnar:
"Second round of scheduler changes:
- try-to-wakeup and IPI reduction speedups, from Andy Lutomirski
- continued power scheduling cleanups and refactorings, from Nicolas
Pitre
- misc fixes and enhancements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/deadline: Delete extraneous extern for to_ratio()
sched/idle: Optimize try-to-wake-up IPI
sched/idle: Simplify wake_up_idle_cpu()
sched/idle: Clear polling before descheduling the idle thread
sched, trace: Add a tracepoint for IPI-less remote wakeups
cpuidle: Set polling in poll_idle
sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...)
sched: Rename capacity related flags
sched: Final power vs. capacity cleanups
sched: Remove remaining dubious usage of "power"
sched: Let 'struct sched_group_power' care about CPU capacity
sched/fair: Disambiguate existing/remaining "capacity" usage
sched/fair: Change "has_capacity" to "has_free_capacity"
sched/fair: Remove "power" from 'struct numa_stats'
sched: Fix signedness bug in yield_to()
sched/fair: Use time_after() in record_wakee()
sched/balancing: Reduce the rate of needless idle load balancing
sched/fair: Fix unlocked reads of some cfs_b->quota/period
yield_to() is supposed to return -ESRCH if there is no task to
yield to, but because the type is bool that is the same as returning
true.
The only place I see which cares is kvm_vcpu_on_spin().
Reviewed-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: kvm@vger.kernel.org
Link: http://lkml.kernel.org/r/20140523102042.GA7267@mwanda
When starting lots of dataplane devices the bootup takes very long on
Christian's s390 with irqfd patches. With larger setups he is even
able to trigger some timeouts in some components. Turns out that the
KVM_SET_GSI_ROUTING ioctl takes very long (strace claims up to 0.1 sec)
when having multiple CPUs. This is caused by the synchronize_rcu and
the HZ=100 of s390. By changing the code to use a private srcu we can
speed things up. This patch reduces the boot time till mounting root
from 8 to 2 seconds on my s390 guest with 100 disks.
Uses of hlist_for_each_entry_rcu, hlist_add_head_rcu, hlist_del_init_rcu
are fine because they do not have lockdep checks (hlist_for_each_entry_rcu
uses rcu_dereference_raw rather than rcu_dereference, and write-sides
do not do rcu lockdep at all).
Note that we're hardly relying on the "sleepable" part of srcu. We just
want SRCU's faster detection of grace periods.
Testing was done by Andrew Theurer using netperf tests STREAM, MAERTS
and RR. The difference between results "before" and "after" the patch
has mean -0.2% and standard deviation 0.6%. Using a paired t-test on the
data points says that there is a 2.5% probability that the patch is the
cause of the performance difference (rather than a random fluctuation).
(Restricting the t-test to RR, which is the most likely to be affected,
changes the numbers to respectively -0.3% mean, 0.7% stdev, and 8%
probability that the numbers actually say something about the patch.
The probability increases mostly because there are fewer data points).
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> # s390
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
This patch enables the IBS facility when a single VCPU is running.
The facility is dynamically turned on/off as soon as other VCPUs
enter/leave the stopped state.
When this facility is operating, some instructions can be executed
faster for single-cpu guests.
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
This reverts commit 5befdc385ddb2d5ae8995ad89004529a3acf58fc.
Since we will allow flush tlb out of mmu-lock in the later
patch
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into queue
Lazy storage key handling
Linux does not use the ACC and F bits of the storage key. Newer Linux
versions also do not use the storage keys for dirty and reference
tracking. We can optimize the guest handling for those guests for faults
as well as page-in and page-out by simply not caring about the guest
visible storage key. We trap guest storage key instruction to enable
those keys only on demand.
Migration bitmap
Until now s390 never provided a proper dirty bitmap. Let's provide a
proper migration bitmap for s390. We also change the user dirty tracking
to a fault based mechanism. This makes the host completely independent
from the storage keys. Long term this will allow us to back guest memory
with large pages.
per-VM device attributes
To avoid the introduction of new ioctls, let's provide the
attribute semanantic also on the VM-"device".
Userspace controlled CMMA
The CMMA assist is changed from "always on" to "on if requested" via
per-VM device attributes. In addition a callback to reset all usage
states is provided.
Proper guest DAT handling for intercepts
While instructions handled by SIE take care of all addressing aspects,
KVM/s390 currently does not care about guest address translation of
intercepts. This worked out fine, because
- the s390 Linux kernel has a 1:1 mapping between kernel virtual<->real
for all pages up to memory size
- intercepts happen only for a small amount of cases
- all of these intercepts happen to be in the kernel text for current
distros
Of course we need to be better for other intercepts, kernel modules etc.
We provide the infrastructure and rework all in-kernel intercepts to work
on logical addresses (paging etc) instead of real ones. The code has
been running internally for several months now, so it is time for going
public.
GDB support
We provide breakpoints, single stepping and watchpoints.
Fixes/Cleanups
- Improve program check delivery
- Factor out the handling of transactional memory on program checks
- Use the existing define __LC_PGM_TDB
- Several cleanups in the lowcore structure
- Documentation
NOTES
- All patches touching base s390 are either ACKed or written by the s390
maintainers
- One base KVM patch "KVM: add kvm_is_error_gpa() helper"
- One patch introduces the notion of VM device attributes
include/uapi/linux/kvm.h
It's quite common (in the s390 guest access code) to test if a guest
physical address points to a valid guest memory area or not.
So add a simple helper function in common code, since this might be
of interest for other architectures as well.
Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com>
With KVM, MMIO is much slower than PIO, due to the need to
do page walk and emulation. But with EPT, it does not have to be: we
know the address from the VMCS so if the address is unique, we can look
up the eventfd directly, bypassing emulation.
Unfortunately, this only works if userspace does not need to match on
access length and data. The implementation adds a separate FAST_MMIO
bus internally. This serves two purposes:
- minimize overhead for old userspace that does not use eventfd with lengtth = 0
- minimize disruption in other code (since we don't know the length,
devices on the MMIO bus only get a valid address in write, this
way we don't need to touch all devices to teach them to handle
an invalid length)
At the moment, this optimization only has effect for EPT on x86.
It will be possible to speed up MMIO for NPT and MMU using the same
idea in the future.
With this patch applied, on VMX MMIO EVENTFD is essentially as fast as PIO.
I was unable to detect any measureable slowdown to non-eventfd MMIO.
Making MMIO faster is important for the upcoming virtio 1.0 which
includes an MMIO signalling capability.
The idea was suggested by Peter Anvin. Lots of thanks to Gleb for
pre-review and suggestions.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
The maximum number for irq routes is currently 1024, which is a bit on
the small size for s390: We support up to 4 x 64k virtual devices with
up to 64 queues, and we need one route for each of the queues if we want
to operate it via irqfd.
Let's bump this to 4k on s390 for now, as this at least covers the saner
setups.
We need to find a more general solution, though, as we can't just grow
the routing table indefinitly.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Introduce a new interrupt class for s390 adapter interrupts and enable
irqfds for s390.
This is depending on a new s390 specific vm capability, KVM_CAP_S390_IRQCHIP,
that needs to be enabled by userspace.
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
When this was introduced, kvm_flush_remote_tlbs() could be called
without holding mmu_lock. It is now acknowledged that the function
must be called before releasing mmu_lock, and all callers have already
been changed to do so.
There is no need to use smp_mb() and cmpxchg() any more.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
By setting a Kconfig option, the architecture can control when
guest notifications will be presented by the apf backend.
There is the default batch mechanism, working as before, where the vcpu
thread should pull in this information.
Opposite to this, there is now the direct mechanism, that will push the
information to the guest.
This way s390 can use an already existing architecture interface.
Still the vcpu thread should call check_completion to cleanup leftovers.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
This patch adds a floating irq controller as a kvm_device.
It will be necessary for migration of floating interrupts as well
as for hardening the reset code by allowing user space to explicitly
remove all pending floating interrupts.
Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com>
The function kvm_io_bus_read_cookie is defined but never used
in current in-tree code.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Running 'make namespacecheck' found lots of functions that
should be declared static, since only used in one file.
Support creating the ARM VGIC device through the KVM_CREATE_DEVICE
ioctl, which can then later be leveraged to use the
KVM_{GET/SET}_DEVICE_ATTR, which is useful both for setting addresses in
a more generic API than the ARM-specific one and is useful for
save/restore of VGIC state.
Adds KVM_CAP_DEVICE_CTRL to ARM capabilities.
Note that we change the check for creating a VGIC from bailing out if
any VCPUs were created, to bailing out if any VCPUs were ever run. This
is an important distinction that shouldn't break anything, but allows
creating the VGIC after the VCPUs have been created.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Since the commit 15ad7146 ("KVM: Use the scheduler preemption notifiers
to make kvm preemptible"), the remaining stuff in this function is a
simple cond_resched() call with an extra need_resched() check which was
there to avoid dropping VCPUs unnecessarily. Now it is meaningless.
arch/powerpc/include/asm/processor.h
fix up typo in comment.
We currently use some ad-hoc arch variables tied to legacy KVM device
assignment to manage emulation of instructions that depend on whether
non-coherent DMA is present. Create an interface for this, adapting
legacy KVM device assignment and adding VFIO via the KVM-VFIO device.
For now we assume that non-coherent DMA is possible any time we have a
VFIO group. Eventually an interface can be developed as part of the
VFIO external user interface to query the coherency of a group.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Default to operating in coherent mode. This simplifies the logic when
we switch to a model of registering and unregistering noncoherent I/O
with KVM.
So far we've succeeded at making KVM and VFIO mostly unaware of each
other, but areas are cropping up where a connection beyond eventfds
and irqfds needs to be made. This patch introduces a KVM-VFIO device
that is meant to be a gateway for such interaction. The user creates
the device and can add and remove VFIO groups to it via file
descriptors. When a group is added, KVM verifies the group is valid
and gets a reference to it via the VFIO external user interface.
We will use that in the later patch to find the kvm ops handler
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Page pinning is not mandatory in kvm async page fault processing since
after async page fault event is delivered to a guest it accesses page once
again and does its own GUP. Drop the FOLL_GET flag in GUP in async_pf
code, and do some simplifying in check/clear processing.
Suggested-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Gu zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: chai wen <chaiw.fnst@cn.fujitsu.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
The gfn_to_index function relies on huge page defines which either may
not make sense on systems that don't support huge pages or are defined
in an unconvenient way for other architectures. Since this is
x86-specific, move the function to arch/x86/include/asm/kvm_host.h.
In commit e935b8372cf8 ("KVM: Convert kvm_lock to raw_spinlock"),
the kvm_lock was made a raw lock. However, the kvm mmu_shrink()
function tries to grab the (non-raw) mmu_lock within the scope of
the raw locked kvm_lock being held. This leads to the following:
BUG: sleeping function called from invalid context at kernel/rtmutex.c:659
in_atomic(): 1, irqs_disabled(): 0, pid: 55, name: kswapd0
Preemption disabled at:[<ffffffffa0376eac>] mmu_shrink+0x5c/0x1b0 [kvm]
Pid: 55, comm: kswapd0 Not tainted 3.4.34_preempt-rt
Call Trace:
[<ffffffff8106f2ad>] __might_sleep+0xfd/0x160
[<ffffffff817d8d64>] rt_spin_lock+0x24/0x50
[<ffffffffa0376f3c>] mmu_shrink+0xec/0x1b0 [kvm]
[<ffffffff8111455d>] shrink_slab+0x17d/0x3a0
[<ffffffff81151f00>] ? mem_cgroup_iter+0x130/0x260
[<ffffffff8111824a>] balance_pgdat+0x54a/0x730
[<ffffffff8111fe47>] ? set_pgdat_percpu_threshold+0xa7/0xd0
[<ffffffff811185bf>] kswapd+0x18f/0x490
[<ffffffff81070961>] ? get_parent_ip+0x11/0x50
[<ffffffff81061970>] ? __init_waitqueue_head+0x50/0x50
[<ffffffff81118430>] ? balance_pgdat+0x730/0x730
[<ffffffff81060d2b>] kthread+0xdb/0xe0
[<ffffffff8106e122>] ? finish_task_switch+0x52/0x100
[<ffffffff817e1e94>] kernel_thread_helper+0x4/0x10
[<ffffffff81060c50>] ? __init_kthread_worker+0x
After the previous patch, kvm_lock need not be a raw spinlock anymore,
so change it back.
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: gleb@redhat.com
Cc: jan.kiszka@siemens.com
Reviewed-by: Gleb Natapov <gleb@redhat.com>
'.done' is used to mark the completion of 'async_pf_execute()', but
'cancel_work_sync()' returns true when the work was canceled, so we
use it instead.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Page tables in a read-only memory slot will currently cause a triple
fault because the page walker uses gfn_to_hva and it fails on such a slot.
OVMF uses such a page table; however, real hardware seems to be fine with
that as long as the accessed/dirty bits are set. Save whether the slot
is readonly, and later check it when updating the accessed and dirty bits.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Current common code uses PAGE_OFFSET to indicate a bad host virtual address.
As this check won't work on architectures that don't map kernel and user memory
into the same address space (e.g. s390), such architectures can now provide
their own KVM_HVA_ERR_BAD defines.
This is called right after the memslots is updated, i.e. when the result
of update_memslots() gets installed in install_new_memslots(). Since
the memslots needs to be updated twice when we delete or move a memslot,
kvm_arch_commit_memory_region() does not correspond to this exactly.
In the following patch, x86 will use this new API to check if the mmio
generation has reached its maximum value, in which case mmio sptes need
to be flushed out.
Acked-by: Alexander Graf <agraf@suse.de>
Add new functions kvm_io_bus_{read,write}_cookie() that allows users of
the kvm io infrastructure to use a cookie value to speed up lookup of a
device on an io bus.
Pull KVM fixes from Paolo Bonzini:
"On the x86 side, there are some optimizations and documentation
updates. The big ARM/KVM change for 3.11, support for AArch64, will
come through Catalin Marinas's tree. s390 and PPC have misc cleanups
and bugfixes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (87 commits)
KVM: PPC: Ignore PIR writes
KVM: PPC: Book3S PR: Invalidate SLB entries properly
KVM: PPC: Book3S PR: Allow guest to use 1TB segments
KVM: PPC: Book3S PR: Don't keep scanning HPTEG after we find a match
KVM: PPC: Book3S PR: Fix invalidation of SLB entry 0 on guest entry
KVM: PPC: Book3S PR: Fix proto-VSID calculations
KVM: PPC: Guard doorbell exception with CONFIG_PPC_DOORBELL
KVM: Fix RTC interrupt coalescing tracking
kvm: Add a tracepoint write_tsc_offset
KVM: MMU: Inform users of mmio generation wraparound
KVM: MMU: document fast invalidate all mmio sptes
KVM: MMU: document fast invalidate all pages
KVM: MMU: document fast page fault
KVM: MMU: document mmio page fault
KVM: MMU: document write_flooding_count
KVM: MMU: document clear_spte_count
KVM: MMU: drop kvm_mmu_zap_mmio_sptes
KVM: MMU: init kvm generation close to mmio wrap-around value
KVM: MMU: add tracepoint for check_mmio_spte
KVM: MMU: fast invalidate all mmio sptes
We can easily reach the 1000 limit by start VM with a couple
hundred I/O devices (multifunction=on). The hardcode limit
already been adjusted 3 times (6 ~ 200 ~ 300 ~ 1000).
In userspace, we already have maximum file descriptor to
limit ioeventfd count. But kvm_io_bus devices also are used
for pit, pic, ioapic, coalesced_mmio. They couldn't be limited
by maximum file descriptor.
Currently only ioeventfds take too much kvm_io_bus devices,
so just exclude it from counting kvm_io_range limit.
Also fixed one indent issue in kvm_host.h
Signed-off-by: Amos Kong <akong@redhat.com>
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
The kvm_host.h header file doesn't handle well
inclusion when archs don't support KVM.
This results in build crashes for such archs when they
want to implement context tracking because this subsystem
includes kvm_host.h in order to implement the
guest_enter/exit APIs but it doesn't handle KVM off case.
To fix this, move the guest_enter()/guest_exit()
declarations and generic implementation to the context
tracking headers. These generic APIs actually belong to
this subsystem, besides other domains boundary tracking
like user_enter() et al.
KVM now properly becomes a user of this library, not the
other buggy way around.
Reported-by: Kevin Hilman <khilman@linaro.org>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Kevin Hilman <khilman@linaro.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Gleb Natapov <gleb@redhat.com>
kvmclock updates which are isolated to a given vcpu, such as vcpu->cpu
migration, should not allow system_timestamp from the rest of the vcpus
to remain static. Otherwise ntp frequency correction applies to one
vcpu's system_timestamp but not the others.
So in those cases, request a kvmclock update for all vcpus. The worst
case for a remote vcpu to update its kvmclock is then bounded by maximum
nohz sleep latency.
Pull kvm updates from Gleb Natapov:
"Highlights of the updates are:
general:
- new emulated device API
- legacy device assignment is now optional
- irqfd interface is more generic and can be shared between arches
x86:
- VMCS shadow support and other nested VMX improvements
- APIC virtualization and Posted Interrupt hardware support
- Optimize mmio spte zapping
ppc:
- BookE: in-kernel MPIC emulation with irqfd support
- Book3S: in-kernel XICS emulation (incomplete)
- Book3S: HV: migration fixes
- BookE: more debug support preparation
- BookE: e6500 support
ARM:
- reworking of Hyp idmaps
s390:
- ioeventfd for virtio-ccw
And many other bug fixes, cleanups and improvements"
* tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits)
kvm: Add compat_ioctl for device control API
KVM: x86: Account for failing enable_irq_window for NMI window request
KVM: PPC: Book3S: Add API for in-kernel XICS emulation
kvm/ppc/mpic: fix missing unlock in set_base_addr()
kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write
kvm/ppc/mpic: remove users
kvm/ppc/mpic: fix mmio region lists when multiple guests used
kvm/ppc/mpic: remove default routes from documentation
kvm: KVM_CAP_IOMMU only available with device assignment
ARM: KVM: iterate over all CPUs for CPU compatibility check
KVM: ARM: Fix spelling in error message
ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally
KVM: ARM: Fix API documentation for ONE_REG encoding
ARM: KVM: promote vfp_host pointer to generic host cpu context
ARM: KVM: add architecture specific hook for capabilities
ARM: KVM: perform HYP initilization for hotplugged CPUs
ARM: KVM: switch to a dual-step HYP init code
ARM: KVM: rework HYP page table freeing
ARM: KVM: enforce maximum size for identity mapped code
ARM: KVM: move to a KVM provided HYP idmap
This adds the API for userspace to instantiate an XICS device in a VM
and connect VCPUs to it. The API consists of a new device type for
the KVM_CREATE_DEVICE ioctl, a new capability KVM_CAP_IRQ_XICS, which
functions similarly to KVM_CAP_IRQ_MPIC, and the KVM_IRQ_LINE ioctl,
which is used to assert and deassert interrupt inputs of the XICS.
The XICS device has one attribute group, KVM_DEV_XICS_GRP_SOURCES.
Each attribute within this group corresponds to the state of one
interrupt source. The attribute number is the same as the interrupt
source number.
This does not support irq routing or irqfd yet.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
We hope to at some point deprecate KVM legacy device assignment in
favor of VFIO-based assignment. Towards that end, allow legacy
device assignment to be deconfigured.
Reviewed-by: Alexander Graf <agraf@suse.de>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
The VMX implementation of enable_irq_window raised
KVM_REQ_IMMEDIATE_EXIT after we checked it in vcpu_enter_guest. This
caused infinite loops on vmentry. Fix it by letting enable_irq_window
signal the need for an immediate exit via its return value and drop
KVM_REQ_IMMEDIATE_EXIT.
This issue only affects nested VMX scenarios.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
The hassle of getting refcounting right was greater than the hassle
of keeping a list of devices to destroy on VM exit.
Hook the MPIC code up to the KVM interfaces, add locking, etc.
[agraf: add stub function for kvmppc_mpic_set_epr, non-booke, 64bit]
Currently, devices that are emulated inside KVM are configured in a
hardcoded manner based on an assumption that any given architecture
only has one way to do it. If there's any need to access device state,
it is done through inflexible one-purpose-only IOCTLs (e.g.
KVM_GET/SET_LAPIC). Defining new IOCTLs for every little thing is
cumbersome and depletes a limited numberspace.
This API provides a mechanism to instantiate a device of a certain
type, returning an ID that can be used to set/get attributes of the
device. Attributes may include configuration parameters (e.g.
register base address), device state, operational commands, etc. It
is similar to the ONE_REG API, except that it acts on devices rather
than vcpus.
Both device types and individual attributes can be tested without having
to create the device or get/set the attribute, without the need for
separately managing enumerated capabilities.
Setting up IRQ routes is nothing IOAPIC specific. Extract everything
that really is generic code into irqchip.c and only leave the ioapic
specific bits to irq_comm.c.
The prototype has been stale for a while, I can't spot any real function
define behind it. Let's just remove it.
