path: root/include/linux/kvm_host.h
2013-09-17KVM: mmu: allow page tables to be in read-only slotsPaolo Bonzini
Page tables in a read-only memory slot will currently cause a triple fault because the page walker uses gfn_to_hva and it fails on such a slot. OVMF uses such a page table; however, real hardware seems to be fine with that as long as the accessed/dirty bits are set. Save whether the slot is readonly, and later check it when updating the accessed and dirty bits. Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-07-29KVM: s390: Make KVM_HVA_ERR_BAD usable on s390Dominik Dingel
Current common code uses PAGE_OFFSET to indicate a bad host virtual address. As this check won't work on architectures that don't map kernel and user memory into the same address space (e.g. s390), such architectures can now provide their own KVM_HVA_ERR_BAD defines. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-07-18KVM: Introduce kvm_arch_memslots_updated()Takuya Yoshikawa
This is called right after the memslots is updated, i.e. when the result of update_memslots() gets installed in install_new_memslots(). Since the memslots needs to be updated twice when we delete or move a memslot, kvm_arch_commit_memory_region() does not correspond to this exactly. In the following patch, x86 will use this new API to check if the mmio generation has reached its maximum value, in which case mmio sptes need to be flushed out. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Acked-by: Alexander Graf <agraf@suse.de> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-07-18KVM: kvm-io: support cookiesCornelia Huck
Add new functions kvm_io_bus_{read,write}_cookie() that allows users of the kvm io infrastructure to use a cookie value to speed up lookup of a device on an io bus. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-07-03Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "On the x86 side, there are some optimizations and documentation updates. The big ARM/KVM change for 3.11, support for AArch64, will come through Catalin Marinas's tree. s390 and PPC have misc cleanups and bugfixes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (87 commits) KVM: PPC: Ignore PIR writes KVM: PPC: Book3S PR: Invalidate SLB entries properly KVM: PPC: Book3S PR: Allow guest to use 1TB segments KVM: PPC: Book3S PR: Don't keep scanning HPTEG after we find a match KVM: PPC: Book3S PR: Fix invalidation of SLB entry 0 on guest entry KVM: PPC: Book3S PR: Fix proto-VSID calculations KVM: PPC: Guard doorbell exception with CONFIG_PPC_DOORBELL KVM: Fix RTC interrupt coalescing tracking kvm: Add a tracepoint write_tsc_offset KVM: MMU: Inform users of mmio generation wraparound KVM: MMU: document fast invalidate all mmio sptes KVM: MMU: document fast invalidate all pages KVM: MMU: document fast page fault KVM: MMU: document mmio page fault KVM: MMU: document write_flooding_count KVM: MMU: document clear_spte_count KVM: MMU: drop kvm_mmu_zap_mmio_sptes KVM: MMU: init kvm generation close to mmio wrap-around value KVM: MMU: add tracepoint for check_mmio_spte KVM: MMU: fast invalidate all mmio sptes ...
2013-06-04kvm: exclude ioeventfd from counting kvm_io_range limitAmos Kong
We can easily reach the 1000 limit by start VM with a couple hundred I/O devices (multifunction=on). The hardcode limit already been adjusted 3 times (6 ~ 200 ~ 300 ~ 1000). In userspace, we already have maximum file descriptor to limit ioeventfd count. But kvm_io_bus devices also are used for pit, pic, ioapic, coalesced_mmio. They couldn't be limited by maximum file descriptor. Currently only ioeventfds take too much kvm_io_bus devices, so just exclude it from counting kvm_io_range limit. Also fixed one indent issue in kvm_host.h Signed-off-by: Amos Kong <akong@redhat.com> Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-05-31kvm: Move guest entry/exit APIs to context_trackingFrederic Weisbecker
The kvm_host.h header file doesn't handle well inclusion when archs don't support KVM. This results in build crashes for such archs when they want to implement context tracking because this subsystem includes kvm_host.h in order to implement the guest_enter/exit APIs but it doesn't handle KVM off case. To fix this, move the guest_enter()/guest_exit() declarations and generic implementation to the context tracking headers. These generic APIs actually belong to this subsystem, besides other domains boundary tracking like user_enter() et al. KVM now properly becomes a user of this library, not the other buggy way around. Reported-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Kevin Hilman <khilman@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-05-15KVM: x86: limit difference between kvmclock updatesMarcelo Tosatti
kvmclock updates which are isolated to a given vcpu, such as vcpu->cpu migration, should not allow system_timestamp from the rest of the vcpus to remain static. Otherwise ntp frequency correction applies to one vcpu's system_timestamp but not the others. So in those cases, request a kvmclock update for all vcpus. The worst case for a remote vcpu to update its kvmclock is then bounded by maximum nohz sleep latency. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-05-05Merge tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Gleb Natapov: "Highlights of the updates are: general: - new emulated device API - legacy device assignment is now optional - irqfd interface is more generic and can be shared between arches x86: - VMCS shadow support and other nested VMX improvements - APIC virtualization and Posted Interrupt hardware support - Optimize mmio spte zapping ppc: - BookE: in-kernel MPIC emulation with irqfd support - Book3S: in-kernel XICS emulation (incomplete) - Book3S: HV: migration fixes - BookE: more debug support preparation - BookE: e6500 support ARM: - reworking of Hyp idmaps s390: - ioeventfd for virtio-ccw And many other bug fixes, cleanups and improvements" * tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits) kvm: Add compat_ioctl for device control API KVM: x86: Account for failing enable_irq_window for NMI window request KVM: PPC: Book3S: Add API for in-kernel XICS emulation kvm/ppc/mpic: fix missing unlock in set_base_addr() kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write kvm/ppc/mpic: remove users kvm/ppc/mpic: fix mmio region lists when multiple guests used kvm/ppc/mpic: remove default routes from documentation kvm: KVM_CAP_IOMMU only available with device assignment ARM: KVM: iterate over all CPUs for CPU compatibility check KVM: ARM: Fix spelling in error message ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally KVM: ARM: Fix API documentation for ONE_REG encoding ARM: KVM: promote vfp_host pointer to generic host cpu context ARM: KVM: add architecture specific hook for capabilities ARM: KVM: perform HYP initilization for hotplugged CPUs ARM: KVM: switch to a dual-step HYP init code ARM: KVM: rework HYP page table freeing ARM: KVM: enforce maximum size for identity mapped code ARM: KVM: move to a KVM provided HYP idmap ...
2013-05-02KVM: PPC: Book3S: Add API for in-kernel XICS emulationPaul Mackerras
This adds the API for userspace to instantiate an XICS device in a VM and connect VCPUs to it. The API consists of a new device type for the KVM_CREATE_DEVICE ioctl, a new capability KVM_CAP_IRQ_XICS, which functions similarly to KVM_CAP_IRQ_MPIC, and the KVM_IRQ_LINE ioctl, which is used to assert and deassert interrupt inputs of the XICS. The XICS device has one attribute group, KVM_DEV_XICS_GRP_SOURCES. Each attribute within this group corresponds to the state of one interrupt source. The attribute number is the same as the interrupt source number. This does not support irq routing or irqfd yet. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-28kvm: Allow build-time configuration of KVM device assignmentAlex Williamson
We hope to at some point deprecate KVM legacy device assignment in favor of VFIO-based assignment. Towards that end, allow legacy device assignment to be deconfigured. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-28Merge git://github.com/agraf/linux-2.6.git kvm-ppc-next into queueGleb Natapov
2013-04-28KVM: x86: Rework request for immediate exitJan Kiszka
The VMX implementation of enable_irq_window raised KVM_REQ_IMMEDIATE_EXIT after we checked it in vcpu_enter_guest. This caused infinite loops on vmentry. Fix it by letting enable_irq_window signal the need for an immediate exit via its return value and drop KVM_REQ_IMMEDIATE_EXIT. This issue only affects nested VMX scenarios. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-26kvm: destroy emulated devices on VM exitScott Wood
The hassle of getting refcounting right was greater than the hassle of keeping a list of devices to destroy on VM exit. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: in-kernel MPIC emulationScott Wood
Hook the MPIC code up to the KVM interfaces, add locking, etc. Signed-off-by: Scott Wood <scottwood@freescale.com> [agraf: add stub function for kvmppc_mpic_set_epr, non-booke, 64bit] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm: add device control APIScott Wood
Currently, devices that are emulated inside KVM are configured in a hardcoded manner based on an assumption that any given architecture only has one way to do it. If there's any need to access device state, it is done through inflexible one-purpose-only IOCTLs (e.g. KVM_GET/SET_LAPIC). Defining new IOCTLs for every little thing is cumbersome and depletes a limited numberspace. This API provides a mechanism to instantiate a device of a certain type, returning an ID that can be used to set/get attributes of the device. Attributes may include configuration parameters (e.g. register base address), device state, operational commands, etc. It is similar to the ONE_REG API, except that it acts on devices rather than vcpus. Both device types and individual attributes can be tested without having to create the device or get/set the attribute, without the need for separately managing enumerated capabilities. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: Move irq routing setup to irqchip.cAlexander Graf
Setting up IRQ routes is nothing IOAPIC specific. Extract everything that really is generic code into irqchip.c and only leave the ioapic specific bits to irq_comm.c. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: Remove kvm_get_intr_delivery_bitmaskAlexander Graf
The prototype has been stale for a while, I can't spot any real function define behind it. Let's just remove it. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: Introduce CONFIG_HAVE_KVM_IRQ_ROUTINGAlexander Graf
Quite a bit of code in KVM has been conditionalized on availability of IOAPIC emulation. However, most of it is generically applicable to platforms that don't have an IOPIC, but a different type of irq chip. Make code that only relies on IRQ routing, not an APIC itself, on CONFIG_HAVE_KVM_IRQ_ROUTING, so that we can reuse it later. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: Add KVM_IRQCHIP_NUM_PINS in addition to KVM_IOAPIC_NUM_PINSAlexander Graf
The concept of routing interrupt lines to an irqchip is nothing that is IOAPIC specific. Every irqchip has a maximum number of pins that can be linked to irq lines. So let's add a new define that allows us to reuse generic code for non-IOAPIC platforms. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-16KVM: Call common update function when ioapic entry changed.Yang Zhang
Both TMR and EOI exit bitmap need to be updated when ioapic changed or vcpu's id/ldr/dfr changed. So use common function instead eoi exit bitmap specific function. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-15KVM: Let ioapic know the irq line statusYang Zhang
Userspace may deliver RTC interrupt without query the status. So we want to track RTC EOI for this case. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-08KVM: Move kvm_rebooting declaration out of x86Geoff Levand
The variable kvm_rebooting is a common kvm variable, so move its declaration from arch/x86/include/asm/kvm_host.h to include/asm/kvm_host.h. Fixes this sparse warning when building on arm64: virt/kvm/kvm_main.c:warning: symbol 'kvm_rebooting' was not declared. Should it be static? Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-08KVM: Move vm_list kvm_lock declarations out of x86Geoff Levand
The variables vm_list and kvm_lock are common to all architectures, so move the declarations from arch/x86/include/asm/kvm_host.h to include/linux/kvm_host.h. Fixes sparse warnings like these when building for arm64: virt/kvm/kvm_main.c: warning: symbol 'kvm_lock' was not declared. Should it be static? virt/kvm/kvm_main.c: warning: symbol 'vm_list' was not declared. Should it be static? Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-07KVM: Allow cross page reads and writes from cached translations.Andrew Honig
This patch adds support for kvm_gfn_to_hva_cache_init functions for reads and writes that will cross a page. If the range falls within the same memslot, then this will be a fast operation. If the range is split between two memslots, then the slower kvm_read_guest and kvm_write_guest are used. Tested: Test against kvm_clock unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-03-22Revert "KVM: allow host header to be included even for !CONFIG_KVM"Marcelo Tosatti
This reverts commit f445f11eb2cc265dd47da5b2e864df46cd6e5a82 as it breaks PPC with CONFIG_KVM=n. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-21Merge remote-tracking branch 'upstream/master' into queueMarcelo Tosatti
Merge reason: From: Alexander Graf <agraf@suse.de> "Just recently this really important patch got pulled into Linus' tree for 3.9: commit 1674400aaee5b466c595a8fc310488263ce888c7 Author: Anton Blanchard <anton <at> samba.org> Date: Tue Mar 12 01:51:51 2013 +0000 Without that commit, I can not boot my G5, thus I can't run automated tests on it against my queue. Could you please merge kvm/next against linus/master, so that I can base my trees against that?" * upstream/master: (653 commits) PCI: Use ROM images from firmware only if no other ROM source available sparc: remove unused "config BITS" sparc: delete "if !ULTRA_HAS_POPULATION_COUNT" KVM: Fix bounds checking in ioapic indirect register reads (CVE-2013-1798) KVM: x86: Convert MSR_KVM_SYSTEM_TIME to use gfn_to_hva_cache functions (CVE-2013-1797) KVM: x86: fix for buffer overflow in handling of MSR_KVM_SYSTEM_TIME (CVE-2013-1796) arm64: Kconfig.debug: Remove unused CONFIG_DEBUG_ERRORS arm64: Do not select GENERIC_HARDIRQS_NO_DEPRECATED inet: limit length of fragment queue hash table bucket lists qeth: Fix scatter-gather regression qeth: Fix invalid router settings handling qeth: delay feature trace sgy-cts1000: Remove __dev* attributes KVM: x86: fix deadlock in clock-in-progress request handling KVM: allow host header to be included even for !CONFIG_KVM hwmon: (lm75) Fix tcn75 prefix hwmon: (lm75.h) Update header inclusion MAINTAINERS: Remove Mark M. Hoffman xfs: ensure we capture IO errors correctly xfs: fix xfs_iomap_eof_prealloc_initial_size type ... Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-18KVM: allow host header to be included even for !CONFIG_KVMKevin Hilman
The new context tracking subsystem unconditionally includes kvm_host.h headers for the guest enter/exit macros. This causes a compile failure when KVM is not enabled. Fix by adding an IS_ENABLED(CONFIG_KVM) check to kvm_host so it can be included/compiled even when KVM is not enabled. Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-11kvm: Record the preemption status of vcpus using preempt notifiersRaghavendra K T
Note that we mark as preempted only when vcpu's task state was Running during preemption. Thanks Jiannan, Avi for preemption notifier ideas. Thanks Gleb, PeterZ for their precious suggestions. Thanks Srikar for an idea on avoiding rcu lock while checking task state that improved overcommit numbers. Reviewed-by: Chegu Vinod <chegu_vinod@hp.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-03-05KVM: Introduce KVM_VIRTIO_CCW_NOTIFY_BUS.Cornelia Huck
Add a new bus type for virtio-ccw devices on s390. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-05KVM: Initialize irqfd from kvm_init().Cornelia Huck
Currently, eventfd introduces module_init/module_exit functions to initialize/cleanup the irqfd workqueue. This only works, however, if no other module_init/module_exit functions are built into the same module. Let's just move the initialization and cleanup to kvm_init and kvm_exit. This way, it is also clearer where kvm startup may fail. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Refactor commit_memory_region()Takuya Yoshikawa
This patch makes the parameter old a const pointer to the old memory slot and adds a new parameter named change to know the change being requested: the former is for removing extra copying and the latter is for cleaning up the code. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Refactor prepare_memory_region()Takuya Yoshikawa
This patch drops the parameter old, a copy of the old memory slot, and adds a new parameter named change to know the change being requested. This not only cleans up the code but also removes extra copying of the memory slot structure. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Make kvm_mr_change available to arch codeTakuya Yoshikawa
This will be used for cleaning up prepare/commit_memory_region() later. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Drop user_alloc from set_memory_region()Takuya Yoshikawa
Except ia64's stale code, KVM_SET_MEMORY_REGION support, this is only used for sanity checks in __kvm_set_memory_region() which can easily be changed to use slot id instead. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Drop user_alloc from prepare/commit_memory_region()Takuya Yoshikawa
X86 does not use this any more. The remaining user, s390's !user_alloc check, can be simply removed since KVM_SET_MEMORY_REGION ioctl is no longer supported. Note: fixed powerpc's indentations with spaces to suppress checkpatch errors. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-02-24Merge tag 'kvm-3.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Marcelo Tosatti: "KVM updates for the 3.9 merge window, including x86 real mode emulation fixes, stronger memory slot interface restrictions, mmu_lock spinlock hold time reduction, improved handling of large page faults on shadow, initial APICv HW acceleration support, s390 channel IO based virtio, amongst others" * tag 'kvm-3.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) Revert "KVM: MMU: lazily drop large spte" x86: pvclock kvm: align allocation size to page size KVM: nVMX: Remove redundant get_vmcs12 from nested_vmx_exit_handled_msr x86 emulator: fix parity calculation for AAD instruction KVM: PPC: BookE: Handle alignment interrupts booke: Added DBCR4 SPR number KVM: PPC: booke: Allow multiple exception types KVM: PPC: booke: use vcpu reference from thread_struct KVM: Remove user_alloc from struct kvm_memory_slot KVM: VMX: disable apicv by default KVM: s390: Fix handling of iscs. KVM: MMU: cleanup __direct_map KVM: MMU: remove pt_access in mmu_set_spte KVM: MMU: cleanup mapping-level KVM: MMU: lazily drop large spte KVM: VMX: cleanup vmx_set_cr0(). KVM: VMX: add missing exit names to VMX_EXIT_REASONS array KVM: VMX: disable SMEP feature when guest is in non-paging mode KVM: Remove duplicate text in api.txt Revert "KVM: MMU: split kvm_mmu_free_page" ...
2013-02-11KVM: Remove user_alloc from struct kvm_memory_slotTakuya Yoshikawa
This field was needed to differentiate memory slots created by the new API, KVM_SET_USER_MEMORY_REGION, from those by the old equivalent, KVM_SET_MEMORY_REGION, whose support was dropped long before: commit b74a07beed0e64bfba413dcb70dd6749c57f43dc KVM: Remove kernel-allocated memory regions Although we also have private memory slots to which KVM allocates memory with vm_mmap(), !user_alloc slots in other words, the slot id should be enough for differentiating them. Note: corresponding function parameters will be removed later. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-29x86, apicv: add virtual interrupt delivery supportYang Zhang
Virtual interrupt delivery avoids KVM to inject vAPIC interrupts manually, which is fully taken care of by the hardware. This needs some special awareness into existing interrupr injection path: - for pending interrupt, instead of direct injection, we may need update architecture specific indicators before resuming to guest. - A pending interrupt, which is masked by ISR, should be also considered in above update action, since hardware will decide when to inject it at right time. Current has_interrupt and get_interrupt only returns a valid vector from injection p.o.v. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Kevin Tian <kevin.tian@intel.com> Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-27cputime: Safely read cputime of full dynticks CPUsFrederic Weisbecker
While remotely reading the cputime of a task running in a full dynticks CPU, the values stored in utime/stime fields of struct task_struct may be stale. Its values may be those of the last kernel <-> user transition time snapshot and we need to add the tickless time spent since this snapshot. To fix this, flush the cputime of the dynticks CPUs on kernel <-> user transition and record the time / context where we did this. Then on top of this snapshot and the current time, perform the fixup on the reader side from task_times() accessors. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> [fixed kvm module related build errors] Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
2013-01-27kvm: Prepare to add generic guest entry/exit callbacksFrederic Weisbecker
Do some ground preparatory work before adding guest_enter() and guest_exit() context tracking callbacks. Those will be later used to read the guest cputime safely when we run in full dynticks mode. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Gleb Natapov <gleb@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-01-10KVM: PPC: BookE: Implement EPR exitAlexander Graf
The External Proxy Facility in FSL BookE chips allows the interrupt controller to automatically acknowledge an interrupt as soon as a core gets its pending external interrupt delivered. Today, user space implements the interrupt controller, so we need to check on it during such a cycle. This patch implements logic for user space to enable EPR exiting, disable EPR exiting and EPR exiting itself, so that user space can acknowledge an interrupt when an external interrupt has successfully been delivered into the guest vcpu. Signed-off-by: Alexander Graf <agraf@suse.de>
2012-12-23kvm: Fix memory slot generation updatesAlex Williamson
Previous patch "kvm: Minor memory slot optimization" (b7f69c555ca43) overlooked the generation field of the memory slots. Re-using the original memory slots left us with with two slightly different memory slots with the same generation. To fix this, make update_memslots() take a new parameter to specify the last generation. This also makes generation management more explicit to avoid such problems in the future. Reported-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-12-13KVM: struct kvm_memory_slot.id -> shortAlex Williamson
We're currently offering a whopping 32 memory slots to user space, an int is a bit excessive for storing this. We would like to increase our memslots, but SHRT_MAX should be more than enough. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: struct kvm_memory_slot.flags -> u32Alex Williamson
struct kvm_userspace_memory_region.flags is a u32 with a comment that bits 0 ~ 15 are visible to userspace and the other bits are reserved for kvm internal use. KVM_MEMSLOT_INVALID is the only internal use flag and it has a comment that bits 16 ~ 31 are internally used and the other bits are visible to userspace. Therefore, let's define this as a u32 so we don't waste bytes on LP64 systems. Move to the end of the struct for alignment. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: struct kvm_memory_slot.user_alloc -> boolAlex Williamson
There's no need for this to be an int, it holds a boolean. Move to the end of the struct for alignment. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Make KVM_PRIVATE_MEM_SLOTS optionalAlex Williamson
Seems like everyone copied x86 and defined 4 private memory slots that never actually get used. Even x86 only uses 3 of the 4. These aren't exposed so there's no need to add padding. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Rename KVM_MEMORY_SLOTS -> KVM_USER_MEM_SLOTSAlex Williamson
It's easy to confuse KVM_MEMORY_SLOTS and KVM_MEM_SLOTS_NUM. One is the user accessible slots and the other is user + private. Make this more obvious. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13Merge tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Marcelo Tosatti: "Considerable KVM/PPC work, x86 kvmclock vsyscall support, IA32_TSC_ADJUST MSR emulation, amongst others." Fix up trivial conflict in kernel/sched/core.c due to cross-cpu migration notifier added next to rq migration call-back. * tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits) KVM: emulator: fix real mode segment checks in address linearization VMX: remove unneeded enable_unrestricted_guest check KVM: VMX: fix DPL during entry to protected mode x86/kexec: crash_vmclear_local_vmcss needs __rcu kvm: Fix irqfd resampler list walk KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary KVM: MMU: optimize for set_spte KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation KVM: PPC: bookehv: Add guest computation mode for irq delivery KVM: PPC: Make EPCR a valid field for booke64 and bookehv KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation KVM: PPC: e500: Add emulation helper for getting instruction ea KVM: PPC: bookehv64: Add support for interrupt handling KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler KVM: PPC: booke: Fix get_tb() compile error on 64-bit KVM: PPC: e500: Silence bogus GCC warning in tlb code ...
2012-12-09Merge branch 'for-upstream' of https://github.com/agraf/linux-2.6 into queueMarcelo Tosatti
* 'for-upstream' of https://github.com/agraf/linux-2.6: (28 commits) KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation KVM: PPC: bookehv: Add guest computation mode for irq delivery KVM: PPC: Make EPCR a valid field for booke64 and bookehv KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation KVM: PPC: e500: Add emulation helper for getting instruction ea KVM: PPC: bookehv64: Add support for interrupt handling KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler KVM: PPC: booke: Fix get_tb() compile error on 64-bit KVM: PPC: e500: Silence bogus GCC warning in tlb code KVM: PPC: Book3S HV: Handle guest-caused machine checks on POWER7 without panicking KVM: PPC: Book3S HV: Improve handling of local vs. global TLB invalidations MAINTAINERS: Add git tree link for PPC KVM KVM: PPC: Book3S PR: MSR_DE doesn't exist on Book 3S KVM: PPC: Book3S PR: Fix VSX handling KVM: PPC: Book3S PR: Emulate PURR, SPURR and DSCR registers KVM: PPC: Book3S HV: Don't give the guest RW access to RO pages KVM: PPC: Book3S HV: Report correct HPT entry index when reading HPT ...
