path: root/include/linux/kprobes.h
2009-02-21x86, mm, kprobes: fault.c, simplify notify_page_fault()Ingo Molnar
Impact: cleanup Remove an #ifdef from notify_page_fault(). The function still compiles to nothing in the !CONFIG_KPROBES case. Introduce kprobes_built_in() and kprobe_fault_handler() helpers to allow this - they returns 0 if !CONFIG_KPROBES. No code changed: text data bss dec hex filename 4618 32 24 4674 1242 fault.o.before 4618 32 24 4674 1242 fault.o.after Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-29kprobes: fix module compilation error with CONFIG_KPROBES=nMasami Hiramatsu
Define kprobes related data structures even if CONFIG_KPROBES is not set. This fixes compilation errors which occur if CONFIG_KPROBES is not set, in kprobe using modules. [akpm@linux-foundation.org: fix build for non-kprobes-supporting architectures] Reviewed-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: support probing module __exit functionMasami Hiramatsu
Allows kprobes to probe __exit routine. This adds flags member to struct kprobe. When module is freed(kprobes hooks module_notifier to get this event), kprobes which probe the functions in that module are set to "Gone" flag to the flags member. These "Gone" probes are never be enabled. Users can check the GONE flag through debugfs. This also removes mod_refcounted, because we couldn't free a module if kprobe incremented the refcount of that module. [akpm@linux-foundation.org: document some locking] [mhiramat@redhat.com: bugfix: pass aggr_kprobe to arch_remove_kprobe] [mhiramat@redhat.com: bugfix: release old_p's insn_slot before error return] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: add kprobe_insn_mutex and cleanup arch_remove_kprobe()Masami Hiramatsu
Add kprobe_insn_mutex for protecting kprobe_insn_pages hlist, and remove kprobe_mutex from architecture dependent code. This allows us to call arch_remove_kprobe() (and free_insn_slot) while holding kprobe_mutex. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14ftrace: ignore functions that cannot be kprobe-edIngo Molnar
kprobes already has an extensive list of annotations for functions that should not be instrumented. Add notrace annotations to these functions as well. This is particularly useful for functions called by the NMI path. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-25kprobes: improve kretprobe scalability with hashed lockingSrinivasa D S
Currently list of kretprobe instances are stored in kretprobe object (as used_instances,free_instances) and in kretprobe hash table. We have one global kretprobe lock to serialise the access to these lists. This causes only one kretprobe handler to execute at a time. Hence affects system performance, particularly on SMP systems and when return probe is set on lot of functions (like on all systemcalls). Solution proposed here gives fine-grain locks that performs better on SMP system compared to present kretprobe implementation. Solution: 1) Instead of having one global lock to protect kretprobe instances present in kretprobe object and kretprobe hash table. We will have two locks, one lock for protecting kretprobe hash table and another lock for kretporbe object. 2) We hold lock present in kretprobe object while we modify kretprobe instance in kretprobe object and we hold per-hash-list lock while modifying kretprobe instances present in that hash list. To prevent deadlock, we never grab a per-hash-list lock while holding a kretprobe lock. 3) We can remove used_instances from struct kretprobe, as we can track used instances of kretprobe instances using kretprobe hash table. Time duration for kernel compilation ("make -j 8") on a 8-way ppc64 system with return probes set on all systemcalls looks like this. cacheline non-cacheline Un-patched kernel aligned patch aligned patch =============================================================================== real 9m46.784s 9m54.412s 10m2.450s user 40m5.715s 40m7.142s 40m4.273s sys 2m57.754s 2m58.583s 3m17.430s =========================================================== Time duration for kernel compilation ("make -j 8) on the same system, when kernel is not probed. ========================= real 9m26.389s user 40m8.775s sys 2m7.283s ========================= Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-23kprobes: enable clean usage of get_kprobeAbhishek Sagar
Allow clean use of get_kprobe() outside of core kprobe code. Ftrace makes use of get_kprobe to identify probes installed on mcount call-sites. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: jkenisto@us.ibm.com Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-28kprobes: add (un)register_jprobes for batch registrationMasami Hiramatsu
Introduce unregister_/register_jprobes() for jprobe batch registration. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: David Miller <davem@davemloft.net> Cc: "Frank Ch. Eigler" <fche@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: add (un)register_kretprobes for batch registrationMasami Hiramatsu
Introduce unregister_/register_kretprobes() for kretprobe batch registration. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: David Miller <davem@davemloft.net> Cc: "Frank Ch. Eigler" <fche@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: add (un)register_kprobes for batch registrationMasami Hiramatsu
Introduce unregister_/register_kprobes() for kprobe batch registration. This can reduce waiting time for synchronized_sched() when a lot of probes have to be unregistered at once. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: David Miller <davem@davemloft.net> Cc: "Frank Ch. Eigler" <fche@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: prevent probing of preempt_schedule()Srinivasa Ds
Prohibit users from probing preempt_schedule(). One way of prohibiting the user from probing functions is by marking such functions with __kprobes. But this method doesn't work for those functions, which are already marked to different section like preempt_schedule() (belongs to __sched section). So we use blacklist approach to refuse user from probing these functions. In blacklist approach we populate the blacklisted function's starting address and its size in kprobe_blacklist structure. Then we verify the user specified address against start and end of the blacklisted function. So any attempt to register probe on blacklisted functions will be rejected. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kprobes: kretprobe user entry-handlerAbhishek Sagar
Provide support to add an optional user defined callback to be run at function entry of a kretprobe'd function. Also modify the kprobe smoke tests to include an entry-handler during the kretprobe sanity test. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: kprobes: add kprobes smoke tests that run on bootAnanth N Mavinakayanahalli
Here is a quick and naive smoke test for kprobes. This is intended to just verify if some unrelated change broke the *probes subsystem. It is self contained, architecture agnostic and isn't of any great use by itself. This needs to be built in the kernel and runs a basic set of tests to verify if kprobes, jprobes and kretprobes run fine on the kernel. In case of an error, it'll print out a message with a "BUG" prefix. This is a start; we intend to add more tests to this bucket over time. Thanks to Jim Keniston and Masami Hiramatsu for comments and suggestions. Tested on x86 (32/64) and powerpc. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-16kprobes: support kretprobe blacklistMasami Hiramatsu
Introduce architecture dependent kretprobe blacklists to prohibit users from inserting return probes on the function in which kprobes can be inserted but kretprobes can not. This patch also removes "__kprobes" mark from "__switch_to" on x86_64 and registers "__switch_to" to the blacklist on x86-64, because that mark is to prohibit user from inserting only kretprobe. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19jprobes: make jprobes a little safer for usersMichael Ellerman
I realise jprobes are a razor-blades-included type of interface, but that doesn't mean we can't try and make them safer to use. This guy I know once wrote code like this: struct jprobe jp = { .kp.symbol_name = "foo", .entry = "jprobe_foo" }; And then his kernel exploded. Oops. This patch adds an arch hook, arch_deref_entry_point() (I don't like it either) which takes the void * in a struct jprobe, and gives back the text address that it represents. We can then use that in register_jprobe() to check that the entry point we're passed is actually in the kernel text, rather than just some random value. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19jprobes: remove JPROBE_ENTRY()Michael Ellerman
AFAICT now that jprobe.entry is a void *, JPROBE_ENTRY doesn't do anything useful - so remove it .. I've left a do-nothing version so that out-of-tree jprobes code will still compile without modifications. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19jprobes: make struct jprobe.entry a void *Michael Ellerman
Currently jprobe.entry is a kprobe_opcode_t *, but that's a lie. On some platforms it doesn't point to an opcode at all, it points to a function descriptor. It's really a pointer to something that the arch code can turn into a function entry point. And that's what actually happens, none of the generic code ever looks at jprobe.entry, it's only ever dereferenced by arch code. So just make it a void *. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: The ON/OFF knob thru debugfsAnanth N Mavinakayanahalli
This patch provides a debugfs knob to turn kprobes on/off o A new file /debug/kprobes/enabled indicates if kprobes is enabled or not (default enabled) o Echoing 0 to this file will disarm all installed probes o Any new probe registration when disabled will register the probe but not arm it. A message will be printed out in such a case. o When a value 1 is echoed to the file, all probes (including ones registered in the intervening period) will be enabled o Unregistration will happen irrespective of whether probes are globally enabled or not. o Update Documentation/kprobes.txt to reflect these changes. While there also update the doc to make it current. We are also looking at providing sysrq key support to tie to the disabling feature provided by this patch. [akpm@linux-foundation.org: Use bool like a bool!] [akpm@linux-foundation.org: add printk facility levels] [cornelia.huck@de.ibm.com: Add the missing arch_trampoline_kprobe() for s390] Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: kretprobes simplificationsChristoph Hellwig
- consolidate duplicate code in all arch_prepare_kretprobe instances into common code - replace various odd helpers that use hlist_for_each_entry to get the first elemenet of a list with either a hlist_for_each_entry_save or an opencoded access to the first element in the caller - inline add_rp_inst into it's only remaining caller - use kretprobe_inst_table_head instead of opencoding it Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: print details of kretprobe on assertion failureAnanth N Mavinakayanahalli
In certain cases like when the real return address can't be found or when the number of tracked calls to a kretprobed function is less than the number of returns, we may not be able to find the correct return address after processing a kretprobe. Currently we just do a BUG_ON, but no information is provided about the actual failing kretprobe. Print out details of the kretprobe before calling BUG(). Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: Make kprobe.symbol_name constAnanth N Mavinakayanahalli
Kprobes doesn't scribble the kprobe.symbol_name field. Its only set by the module when registering the probe. Modules that exercise good hygiene using the "const" qualifier will see warnings... warning: assignment discards qualifiers from pointer target type Make struct kprobe.symbol_name const char * Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] kprobes: enable booster on the preemptible kernelMasami Hiramatsu
When we are unregistering a kprobe-booster, we can't release its instruction buffer immediately on the preemptive kernel, because some processes might be preempted on the buffer. The freeze_processes() and thaw_processes() functions can clean most of processes up from the buffer. There are still some non-frozen threads who have the PF_NOFREEZE flag. If those threads are sleeping (not preempted) at the known place outside the buffer, we can ensure safety of freeing. However, the processing of this check routine takes a long time. So, this patch introduces the garbage collection mechanism of insn_slot. It also introduces the "dirty" flag to free_insn_slot because of efficiency. The "clean" instruction slots (dirty flag is cleared) are released immediately. But the "dirty" slots which are used by boosted kprobes, are marked as garbages. collect_garbage_slots() will be invoked to release "dirty" slots if there are more than INSNS_PER_PAGE garbage slots or if there are no unused slots. Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "bibo,mao" <bibo.mao@intel.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Yumiko Sugita <yumiko.sugita.yf@hitachi.com> Cc: Satoshi Oshima <soshima@redhat.com> Cc: Hideo Aoki <haoki@redhat.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] kretprobe spinlock deadlock patchbibo,mao
kprobe_flush_task() possibly calls kfree function during holding kretprobe_lock spinlock, if kfree function is probed by kretprobe that will incur spinlock deadlock. This patch moves kfree function out scope of kretprobe_lock. Signed-off-by: bibo, mao <bibo.mao@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Kprobes: Make kprobe modules more portableAnanth N Mavinakayanahalli
In an effort to make kprobe modules more portable, here is a patch that: o Introduces the "symbol_name" field to struct kprobe. The symbol->address resolution now happens in the kernel in an architecture agnostic manner. 64-bit powerpc users no longer have to specify the ".symbols" o Introduces the "offset" field to struct kprobe to allow a user to specify an offset into a symbol. o The legacy mechanism of specifying the kprobe.addr is still supported. However, if both the kprobe.addr and kprobe.symbol_name are specified, probe registration fails with an -EINVAL. o The symbol resolution code uses kallsyms_lookup_name(). So CONFIG_KPROBES now depends on CONFIG_KALLSYMS o Apparantly kprobe modules were the only legitimate out-of-tree user of the kallsyms_lookup_name() EXPORT. Now that the symbol resolution happens in-kernel, remove the EXPORT as suggested by Christoph Hellwig o Modify tcp_probe.c that uses the kprobe interface so as to make it work on multiple platforms (in its earlier form, the code wouldn't work, say, on powerpc) Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-23[PATCH] sem2mutex: kprobesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] kprobes: fix unloading of self probed moduleKeshavamurthy Anil S
When a kprobes modules is written in such a way that probes are inserted on itself, then unload of that moudle was not possible due to reference couning on the same module. The below patch makes a check and incrementes the module refcount only if it is not a self probed module. We need to allow modules to probe themself for kprobes performance measurements This patch has been tested on several x86_64, ppc64 and IA64 architectures. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: fix build breakageAnanth N Mavinakayanahalli
The following patch (against 2.6.15-rc5-mm3) fixes a kprobes build break due to changes introduced in the kprobe locking in 2.6.15-rc5-mm3. In addition, the patch reverts back the open-coding of kprobe_mutex. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: arch_remove_kprobeAnil S Keshavamurthy
Currently arch_remove_kprobes() is only implemented/required for x86_64 and powerpc. All other architecture like IA64, i386 and sparc64 implementes a dummy function which is being called from arch independent kprobes.c file. This patch removes the dummy functions and replaces it with #define arch_remove_kprobe(p, s) do { } while(0) Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: changed from using spinlock to mutexAnil S Keshavamurthy
Since Kprobes runtime exception handlers is now lock free as this code path is now using RCU to walk through the list, there is no need for the register/unregister{_kprobe} to use spin_{lock/unlock}_isr{save/restore}. The serialization during registration/unregistration is now possible using just a mutex. In the above process, this patch also fixes a minor memory leak for x86_64 and powerpc. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] kprobes: increment kprobe missed count for multiprobesKeshavamurthy Anil S
When multiple probes are registered at the same address and if due to some recursion (probe getting triggered within a probe handler), we skip calling pre_handlers and just increment nmissed field. The below patch make sure it walks the list for multiple probes case. Without the below patch we get incorrect results of nmissed count for multiple probe case. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] kprobes: no probes on critical pathKeshavamurthy Anil S
For Kprobes critical path is the path from debug break exception handler till the control reaches kprobes exception code. No probes can be supported in this path as we will end up in recursion. This patch prevents this by moving the below function to safe __kprobes section onto which no probes can be inserted. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Kprobes: preempt_disable/enable() simplificationAnanth N Mavinakayanahalli
Reorganize the preempt_disable/enable calls to eliminate the extra preempt depth. Changes based on Paul McKenney's review suggestions for the kprobes RCU changeset. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Kprobes: Use RCU for (un)register synchronization - base changesAnanth N Mavinakayanahalli
Changes to the base kprobes infrastructure to use RCU for synchronization during kprobe registration and unregistration. These changes coupled with the arch kprobe changes (next in series): a. serialize registration and unregistration of kprobes. b. enable lockless execution of handlers. Handlers can now run in parallel. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Kprobes: Track kprobe on a per_cpu basis - base changesAnanth N Mavinakayanahalli
Changes to the base kprobe infrastructure to track kprobe execution on a per-cpu basis. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Kprobes: prevent possible race conditions genericPrasanna S Panchamukhi
There are possible race conditions if probes are placed on routines within the kprobes files and routines used by the kprobes. For example if you put probe on get_kprobe() routines, the system can hang while inserting probes on any routine such as do_fork(). Because while inserting probes on do_fork(), register_kprobes() routine grabs the kprobes spin lock and executes get_kprobe() routine and to handle probe of get_kprobe(), kprobes_handler() gets executed and tries to grab kprobes spin lock, and spins forever. This patch avoids such possible race conditions by preventing probes on routines within the kprobes file and routines used by kprobes. I have modified the patches as per Andi Kleen's suggestion to move kprobes routines and other routines used by kprobes to a seperate section .kprobes.text. Also moved page fault and exception handlers, general protection fault to .kprobes.text section. These patches have been tested on i386, x86_64 and ppc64 architectures, also compiled on ia64 and sparc64 architectures. Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-05[PATCH] kprobes: fix namespace problem and sparc64 buildRusty Lynch
The following renames arch_init, a kprobes function for performing any architecture specific initialization, to arch_init_kprobes in order to cleanup the namespace. Also, this patch adds arch_init_kprobes to sparc64 to fix the sparc64 kprobes build from the last return probe patch. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Return probe redesign: architecture independent changesRusty Lynch
The following is the second version of the function return probe patches I sent out earlier this week. Changes since my last submission include: * Fix in ppc64 code removing an unneeded call to re-enable preemption * Fix a build problem in ia64 when kprobes was turned off * Added another BUG_ON check to each of the architecture trampoline handlers My initial patch description ==> From my experiences with adding return probes to x86_64 and ia64, and the feedback on LKML to those patches, I think we can simplify the design for return probes. The following patch tweaks the original design such that: * Instead of storing the stack address in the return probe instance, the task pointer is stored. This gives us all we need in order to: - find the correct return probe instance when we enter the trampoline (even if we are recursing) - find all left-over return probe instances when the task is going away This has the side effect of simplifying the implementation since more work can be done in kernel/kprobes.c since architecture specific knowledge of the stack layout is no longer required. Specifically, we no longer have: - arch_get_kprobe_task() - arch_kprobe_flush_task() - get_rp_inst_tsk() - get_rp_inst() - trampoline_post_handler() <see next bullet> * Instead of splitting the return probe handling and cleanup logic across the pre and post trampoline handlers, all the work is pushed into the pre function (trampoline_probe_handler), and then we skip single stepping the original function. In this case the original instruction to be single stepped was just a NOP, and we can do without the extra interruption. The new flow of events to having a return probe handler execute when a target function exits is: * At system initialization time, a kprobe is inserted at the beginning of kretprobe_trampoline. kernel/kprobes.c use to handle this on it's own, but ia64 needed to do this a little differently (i.e. a function pointer is really a pointer to a structure containing the instruction pointer and a global pointer), so I added the notion of arch_init(), so that kernel/kprobes.c:init_kprobes() now allows architecture specific initialization by calling arch_init() before exiting. Each architecture now registers a kprobe on it's own trampoline function. * register_kretprobe() will insert a kprobe at the beginning of the targeted function with the kprobe pre_handler set to arch_prepare_kretprobe (still no change) * When the target function is entered, the kprobe is fired, calling arch_prepare_kretprobe (still no change) * In arch_prepare_kretprobe() we try to get a free instance and if one is available then we fill out the instance with a pointer to the return probe, the original return address, and a pointer to the task structure (instead of the stack address.) Just like before we change the return address to the trampoline function and mark the instance as used. If multiple return probes are registered for a given target function, then arch_prepare_kretprobe() will get called multiple times for the same task (since our kprobe implementation is able to handle multiple kprobes at the same address.) Past the first call to arch_prepare_kretprobe, we end up with the original address stored in the return probe instance pointing to our trampoline function. (This is a significant difference from the original arch_prepare_kretprobe design.) * Target function executes like normal and then returns to kretprobe_trampoline. * kprobe inserted on the first instruction of kretprobe_trampoline is fired and calls trampoline_probe_handler() (no change here) * trampoline_probe_handler() consumes each of the instances associated with the current task by calling the registered handler function and marking the instance as unused until an instance is found that has a return address different then the trampoline function. (change similar to my previous ia64 RFC) * If the task is killed with some left-over return probe instances (meaning that a target function was entered, but never returned), then we just free any instances associated with the task. (Not much different other then we can handle this without calling architecture specific functions.) There is a known problem that this patch does not yet solve where registering a return probe flush_old_exec or flush_thread will put us in a bad state. Most likely the best way to handle this is to not allow registering return probes on these two functions. (Significant change) This patch series applies to the 2.6.12-rc6-mm1 kernel, and provides: * kernel/kprobes.c changes * i386 patch of existing return probes implementation * x86_64 patch of existing return probe implementation * ia64 implementation * ppc64 implementation (provided by Ananth) This patch implements the architecture independant changes for a reworking of the kprobes based function return probes design. Changes include: * Removing functions for querying a return probe instance off a stack address * Removing the stack_addr field from the kretprobe_instance definition, and adding a task pointer * Adding architecture specific initialization via arch_init() * Removing extern definitions for the architecture trampoline functions (this isn't needed anymore since the architecture handles the initialization of the kprobe in the return probe trampoline function.) Signed-off-by: Rusty Lynch <rusty.lynch@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] kprobes: fix single-step out of line - take2Ananth N Mavinakayanahalli
Now that PPC64 has no-execute support, here is a second try to fix the single step out of line during kprobe execution. Kprobes on x86_64 already solved this problem by allocating an executable page and using it as the scratch area for stepping out of line. Reuse that. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] kprobes: Temporary disarming of reentrant probePrasanna S Panchamukhi
In situations where a kprobes handler calls a routine which has a probe on it, then kprobes_handler() disarms the new probe forever. This patch removes the above limitation by temporarily disarming the new probe. When the another probe hits while handling the old probe, the kprobes_handler() saves previous kprobes state and handles the new probe without calling the new kprobes registered handlers. kprobe_post_handler() restores back the previous kprobes state and the normal execution continues. However on x86_64 architecture, re-rentrancy is provided only through pre_handler(). If a routine having probe is referenced through post_handler(), then the probes on that routine are disarmed forever, since the exception stack is gets changed after the processor single steps the instruction of the new probe. This patch includes generic changes to support temporary disarming on reentrancy of probes. Signed-of-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] kprobes: moves lock-unlock to non-arch kprobe_flush_taskHien Nguyen
This patch moves the lock/unlock of the arch specific kprobe_flush_task() to the non-arch specific kprobe_flusk_task(). Signed-off-by: Hien Nguyen <hien@us.ibm.com> Acked-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Move kprobe [dis]arming into arch specific codeRusty Lynch
The architecture independent code of the current kprobes implementation is arming and disarming kprobes at registration time. The problem is that the code is assuming that arming and disarming is a just done by a simple write of some magic value to an address. This is problematic for ia64 where our instructions look more like structures, and we can not insert break points by just doing something like: *p->addr = BREAKPOINT_INSTRUCTION; The following patch to 2.6.12-rc4-mm2 adds two new architecture dependent functions: * void arch_arm_kprobe(struct kprobe *p) * void arch_disarm_kprobe(struct kprobe *p) and then adds the new functions for each of the architectures that already implement kprobes (spar64/ppc64/i386/x86_64). I thought arch_[dis]arm_kprobe was the most descriptive of what was really happening, but each of the architectures already had a disarm_kprobe() function that was really a "disarm and do some other clean-up items as needed when you stumble across a recursive kprobe." So... I took the liberty of changing the code that was calling disarm_kprobe() to call arch_disarm_kprobe(), and then do the cleanup in the block of code dealing with the recursive kprobe case. So far this patch as been tested on i386, x86_64, and ppc64, but still needs to be tested in sparc64. Signed-off-by: Rusty Lynch <rusty.lynch@intel.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] kprobes: function-return probesHien Nguyen
This patch adds function-return probes to kprobes for the i386 architecture. This enables you to establish a handler to be run when a function returns. 1. API Two new functions are added to kprobes: int register_kretprobe(struct kretprobe *rp); void unregister_kretprobe(struct kretprobe *rp); 2. Registration and unregistration 2.1 Register To register a function-return probe, the user populates the following fields in a kretprobe object and calls register_kretprobe() with the kretprobe address as an argument: kp.addr - the function's address handler - this function is run after the ret instruction executes, but before control returns to the return address in the caller. maxactive - The maximum number of instances of the probed function that can be active concurrently. For example, if the function is non- recursive and is called with a spinlock or mutex held, maxactive = 1 should be enough. If the function is non-recursive and can never relinquish the CPU (e.g., via a semaphore or preemption), NR_CPUS should be enough. maxactive is used to determine how many kretprobe_instance objects to allocate for this particular probed function. If maxactive <= 0, it is set to a default value (if CONFIG_PREEMPT maxactive=max(10, 2 * NR_CPUS) else maxactive=NR_CPUS) For example: struct kretprobe rp; rp.kp.addr = /* entrypoint address */ rp.handler = /*return probe handler */ rp.maxactive = /* e.g., 1 or NR_CPUS or 0, see the above explanation */ register_kretprobe(&rp); The following field may also be of interest: nmissed - Initialized to zero when the function-return probe is registered, and incremented every time the probed function is entered but there is no kretprobe_instance object available for establishing the function-return probe (i.e., because maxactive was set too low). 2.2 Unregister To unregiter a function-return probe, the user calls unregister_kretprobe() with the same kretprobe object as registered previously. If a probed function is running when the return probe is unregistered, the function will return as expected, but the handler won't be run. 3. Limitations 3.1 This patch supports only the i386 architecture, but patches for x86_64 and ppc64 are anticipated soon. 3.2 Return probes operates by replacing the return address in the stack (or in a known register, such as the lr register for ppc). This may cause __builtin_return_address(0), when invoked from the return-probed function, to return the address of the return-probes trampoline. 3.3 This implementation uses the "Multiprobes at an address" feature in 2.6.12-rc3-mm3. 3.4 Due to a limitation in multi-probes, you cannot currently establish a return probe and a jprobe on the same function. A patch to remove this limitation is being tested. This feature is required by SystemTap (http://sourceware.org/systemtap), and reflects ideas contributed by several SystemTap developers, including Will Cohen and Ananth Mavinakayanahalli. Signed-off-by: Hien Nguyen <hien@us.ibm.com> Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@laposte.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] kprobes: Allow multiple kprobes at the same addressAnanth N Mavinakayanahalli
Allow registration of multiple kprobes at an address in an architecture agnostic way. Corresponding handlers will be invoked in a sequence. But, a kprobe and a jprobe can't (yet) co-exist at the same address. Signed-off-by: Ananth N Mavinakayanahalli <amavin@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
