path: root/include/linux/key.h
2013-09-25KEYS: Add a 'trusted' flag and a 'trusted only' flagDavid Howells
Add KEY_FLAG_TRUSTED to indicate that a key either comes from a trusted source or had a cryptographic signature chain that led back to a trusted key the kernel already possessed. Add KEY_FLAGS_TRUSTED_ONLY to indicate that a keyring will only accept links to keys marked with KEY_FLAGS_TRUSTED. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org>
2013-09-24KEYS: Implement a big key type that can save to tmpfsDavid Howells
Implement a big key type that can save its contents to tmpfs and thus swapspace when memory is tight. This is useful for Kerberos ticket caches. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Simo Sorce <simo@redhat.com>
2013-09-24KEYS: Expand the capacity of a keyringDavid Howells
Expand the capacity of a keyring to be able to hold a lot more keys by using the previously added associative array implementation. Currently the maximum capacity is: (PAGE_SIZE - sizeof(header)) / sizeof(struct key *) which, on a 64-bit system, is a little more 500. However, since this is being used for the NFS uid mapper, we need more than that. The new implementation gives us effectively unlimited capacity. With some alterations, the keyutils testsuite runs successfully to completion after this patch is applied. The alterations are because (a) keyrings that are simply added to no longer appear ordered and (b) some of the errors have changed a bit. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Define a __key_get() wrapper to use rather than atomic_inc()David Howells
Define a __key_get() wrapper to use rather than atomic_inc() on the key usage count as this makes it easier to hook in refcount error debugging. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Consolidate the concept of an 'index key' for key accessDavid Howells
Consolidate the concept of an 'index key' for accessing keys. The index key is the search term needed to find a key directly - basically the key type and the key description. We can add to that the description length. This will be useful when turning a keyring into an associative array rather than just a pointer block. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Use bool in make_key_ref() and is_key_possessed()David Howells
Make make_key_ref() take a bool possession parameter and make is_key_possessed() return a bool. Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-10-02KEYS: Reduce initial permissions on keysDavid Howells
Reduce the initial permissions on new keys to grant the possessor everything, view permission only to the user (so the keys can be seen in /proc/keys) and nothing else. This gives the creator a chance to adjust the permissions mask before other processes can access the new key or create a link to it. To aid with this, keyring_alloc() now takes a permission argument rather than setting the permissions itself. The following permissions are now set: (1) The user and user-session keyrings grant the user that owns them full permissions and grant a possessor everything bar SETATTR. (2) The process and thread keyrings grant the possessor full permissions but only grant the user VIEW. This permits the user to see them in /proc/keys, but not to do anything with them. (3) Anonymous session keyrings grant the possessor full permissions, but only grant the user VIEW and READ. This means that the user can see them in /proc/keys and can list them, but nothing else. Possibly READ shouldn't be provided either. (4) Named session keyrings grant everything an anonymous session keyring does, plus they grant the user LINK permission. The whole point of named session keyrings is that others can also subscribe to them. Possibly this should be a separate permission to LINK. (5) The temporary session keyring created by call_sbin_request_key() gets the same permissions as an anonymous session keyring. (6) Keys created by add_key() get VIEW, SEARCH, LINK and SETATTR for the possessor, plus READ and/or WRITE if the key type supports them. The used only gets VIEW now. (7) Keys created by request_key() now get the same as those created by add_key(). Reported-by: Lennart Poettering <lennart@poettering.net> Reported-by: Stef Walter <stefw@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2012-09-13userns: Convert security/keys to the new userns infrastructureEric W. Biederman
- Replace key_user ->user_ns equality checks with kuid_has_mapping checks. - Use from_kuid to generate key descriptions - Use kuid_t and kgid_t and the associated helpers instead of uid_t and gid_t - Avoid potential problems with file descriptor passing by displaying keys in the user namespace of the opener of key status proc files. Cc: linux-security-module@vger.kernel.org Cc: keyrings@linux-nfs.org Cc: David Howells <dhowells@redhat.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-02key: Remove extraneous parentheses from rcu_assign_keypointer()Paul E. McKenney
This commit removes the extraneous parentheses from rcu_assign_keypointer() so that rcu_assign_pointer() can be wrapped in do-while. It also wraps rcu_assign_keypointer() in a do-while and parenthesizes its final argument, as suggested by David Howells. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-05-23keys: kill the dummy key_replace_session_keyring()Oleg Nesterov
After the previouse change key_replace_session_keyring() becomes a nop. Remove the dummy definition in key.h and update the callers in arch/*/kernel/signal.c. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Gordeev <agordeev@redhat.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Smith <dsmith@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-23keys: change keyctl_session_to_parent() to use task_work_add()Oleg Nesterov
Change keyctl_session_to_parent() to use task_work_add() and move key_replace_session_keyring() logic into task_work->func(). Note that we do task_work_cancel() before task_work_add() to ensure that only one work can be pending at any time. This is important, we must not allow user-space to abuse the parent's ->task_works list. The callback, replace_session_keyring(), checks PF_EXITING. I guess this is not really needed but looks better. As a side effect, this fixes the (unlikely) race. The callers of key_replace_session_keyring() and keyctl_session_to_parent() lack the necessary barriers, the parent can miss the request. Now we can remove task_struct->replacement_session_keyring and related code. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Gordeev <agordeev@redhat.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Smith <dsmith@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-16KEYS: Don't check for NULL key pointer in key_validate()David Howells
Don't bother checking for NULL key pointer in key_validate() as all of the places that call it will crash anyway if the relevant key pointer is NULL by the time they call key_validate(). Therefore, the checking must be done prior to calling here. Whilst we're at it, simplify the key_validate() function a bit and mark its argument const. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-11KEYS: Add invalidation supportDavid Howells
Add support for invalidating a key - which renders it immediately invisible to further searches and causes the garbage collector to immediately wake up, remove it from keyrings and then destroy it when it's no longer referenced. It's better not to do this with keyctl_revoke() as that marks the key to start returning -EKEYREVOKED to searches when what is actually desired is to have the key refetched. To invalidate a key the caller must be granted SEARCH permission by the key. This may be too strict. It may be better to also permit invalidation if the caller has any of READ, WRITE or SETATTR permission. The primary use for this is to evict keys that are cached in special keyrings, such as the DNS resolver or an ID mapper. Signed-off-by: David Howells <dhowells@redhat.com>
2012-05-11KEYS: Do LRU discard in full keyringsDavid Howells
Do an LRU discard in keyrings that are full rather than returning ENFILE. To perform this, a time_t is added to the key struct and updated by the creation of a link to a key and by a key being found as the result of a search. At the completion of a successful search, the keyrings in the path between the root of the search and the first found link to it also have their last-used times updated. Note that discarding a link to a key from a keyring does not necessarily destroy the key as there may be references held by other places. An alternate discard method that might suffice is to perform FIFO discard from the keyring, using the spare 2-byte hole in the keylist header as the index of the next link to be discarded. This is useful when using a keyring as a cache for DNS results or foreign filesystem IDs. This can be tested by the following. As root do: echo 1000 >/proc/sys/kernel/keys/root_maxkeys kr=`keyctl newring foo @s` for ((i=0; i<2000; i++)); do keyctl add user a$i a $kr; done Without this patch ENFILE should be reported when the keyring fills up. With this patch, the keyring discards keys in an LRU fashion. Note that the stored LRU time has a granularity of 1s. After doing this, /proc/key-users can be observed and should show that most of the 2000 keys have been discarded: [root@andromeda ~]# cat /proc/key-users 0: 517 516/516 513/1000 5249/20000 The "513/1000" here is the number of quota-accounted keys present for this user out of the maximum permitted. In /proc/keys, the keyring shows the number of keys it has and the number of slots it has allocated: [root@andromeda ~]# grep foo /proc/keys 200c64c4 I--Q-- 1 perm 3b3f0000 0 0 keyring foo: 509/509 The maximum is (PAGE_SIZE - header) / key pointer size. That's typically 509 on a 64-bit system and 1020 on a 32-bit system. Signed-off-by: David Howells <dhowells@redhat.com>
2012-05-11KEYS: Perform RCU synchronisation on keys prior to key destructionDavid Howells
Make the keys garbage collector invoke synchronize_rcu() prior to destroying keys with a zero usage count. This means that a key can be examined under the RCU read lock in the safe knowledge that it won't get deallocated until after the lock is released - even if its usage count becomes zero whilst we're looking at it. This is useful in keyring search vs key link. Consider a keyring containing a link to a key. That link can be replaced in-place in the keyring without requiring an RCU copy-and-replace on the keyring contents without breaking a search underway on that keyring when the displaced key is released, provided the key is actually destroyed only after the RCU read lock held by the search algorithm is released. This permits __key_link() to replace a key without having to reallocate the key payload. A key gets replaced if a new key being linked into a keyring has the same type and description. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2012-03-23Merge tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates for Linux 3.4 from Trond Myklebust: "New features include: - Add NFS client support for containers. This should enable most of the necessary functionality, including lockd support, and support for rpc.statd, NFSv4 idmapper and RPCSEC_GSS upcalls into the correct network namespace from which the mount system call was issued. - NFSv4 idmapper scalability improvements Base the idmapper cache on the keyring interface to allow concurrent access to idmapper entries. Start the process of migrating users from the single-threaded daemon-based approach to the multi-threaded request-key based approach. - NFSv4.1 implementation id. Allows the NFSv4.1 client and server to mutually identify each other for logging and debugging purposes. - Support the 'vers=4.1' mount option for mounting NFSv4.1 instead of having to use the more counterintuitive 'vers=4,minorversion=1'. - SUNRPC tracepoints. Start the process of adding tracepoints in order to improve debugging of the RPC layer. - pNFS object layout support for autologin. Important bugfixes include: - Fix a bug in rpc_wake_up/rpc_wake_up_status that caused them to fail to wake up all tasks when applied to priority waitqueues. - Ensure that we handle read delegations correctly, when we try to truncate a file. - A number of fixes for NFSv4 state manager loops (mostly to do with delegation recovery)." * tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (224 commits) NFS: fix sb->s_id in nfs debug prints xprtrdma: Remove assumption that each segment is <= PAGE_SIZE xprtrdma: The transport should not bug-check when a dup reply is received pnfs-obj: autologin: Add support for protocol autologin NFS: Remove nfs4_setup_sequence from generic rename code NFS: Remove nfs4_setup_sequence from generic unlink code NFS: Remove nfs4_setup_sequence from generic read code NFS: Remove nfs4_setup_sequence from generic write code NFS: Fix more NFS debug related build warnings SUNRPC/LOCKD: Fix build warnings when CONFIG_SUNRPC_DEBUG is undefined nfs: non void functions must return a value SUNRPC: Kill compiler warning when RPC_DEBUG is unset SUNRPC/NFS: Add Kbuild dependencies for NFS_DEBUG/RPC_DEBUG NFS: Use cond_resched_lock() to reduce latencies in the commit scans NFSv4: It is not safe to dereference lsp->ls_state in release_lockowner NFS: ncommit count is being double decremented SUNRPC: We must not use list_for_each_entry_safe() in rpc_wake_up() Try using machine credentials for RENEW calls NFSv4.1: Fix a few issues in filelayout_commit_pagelist NFSv4.1: Clean ups and bugfixes for the pNFS read/writeback/commit code ...
2012-03-01Created a function for setting timeouts on keysBryan Schumaker
The keyctl_set_timeout function isn't exported to other parts of the kernel, but I want to use it for the NFS idmapper. I already have the key, but I wanted a generic way to set the timeout. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-09Merge branch 'next-queue' into nextJames Morris
2012-01-19KEYS: Permit key_serial() to be called with a const key pointerDavid Howells
Permit key_serial() to be called with a const key pointer. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-19KEYS: Allow special keyrings to be clearedDavid Howells
The kernel contains some special internal keyrings, for instance the DNS resolver keyring : 2a93faf1 I----- 1 perm 1f030000 0 0 keyring .dns_resolver: empty It would occasionally be useful to allow the contents of such keyrings to be flushed by root (cache invalidation). Allow a flag to be set on a keyring to mark that someone possessing the sysadmin capability can clear the keyring, even without normal write access to the keyring. Set this flag on the special keyrings created by the DNS resolver, the NFS identity mapper and the CIFS identity mapper. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18keys: fix trusted/encrypted keys sparse rcu_assign_pointer messagesMimi Zohar
Define rcu_assign_keypointer(), which uses the key payload.rcudata instead of payload.data, to resolve the CONFIG_SPARSE_RCU_POINTER message: "incompatible types in comparison expression (different address spaces)" Replace the rcu_assign_pointer() calls in encrypted/trusted keys with rcu_assign_keypointer(). Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-05-19Create Documentation/security/,Randy Dunlap
2011-03-17KEYS: Improve /proc/keysDavid Howells
Improve /proc/keys by: (1) Don't attempt to summarise the payload of a negated key. It won't have one. To this end, a helper function - key_is_instantiated() has been added that allows the caller to find out whether the key is positively instantiated (as opposed to being uninstantiated or negatively instantiated). (2) Do show keys that are negative, expired or revoked rather than hiding them. This requires an override flag (no_state_check) to be passed to search_my_process_keyrings() and keyring_search_aux() to suppress this check. Without this, keys that are possessed by the caller, but only grant permissions to the caller if possessed are skipped as the possession check fails. Keys that are visible due to user, group or other checks are visible with or without this patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add a new keyctl op to reject a key with a specified error codeDavid Howells
Add a new keyctl op to reject a key with a specified error code. This works much the same as negating a key, and so keyctl_negate_key() is made a special case of keyctl_reject_key(). The difference is that keyctl_negate_key() selects ENOKEY as the error to be reported. Typically the key would be rejected with EKEYEXPIRED, EKEYREVOKED or EKEYREJECTED, but this is not mandatory. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add an RCU payload dereference macroDavid Howells
Add an RCU payload dereference macro as this seems to be a common piece of code amongst key types that use RCU referenced payloads. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-19keys: __rcu annotationsArnd Bergmann
Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add garbage collection for dead, revoked and expired keys. [try #6]David Howells
Add garbage collection for dead, revoked and expired keys. This involved erasing all links to such keys from keyrings that point to them. At that point, the key will be deleted in the normal manner. Keyrings from which garbage collection occurs are shrunk and their quota consumption reduced as appropriate. Dead keys (for which the key type has been removed) will be garbage collected immediately. Revoked and expired keys will hang around for a number of seconds, as set in /proc/sys/kernel/keys/gc_delay before being automatically removed. The default is 5 minutes. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-03kmemtrace, security: fix linux/key.h header file dependenciesPekka Enberg
Impact: cleanup We want to remove percpu.h from rcupdate.h (for upcoming kmemtrace changes), but this is not possible currently without breaking the build because key.h has an implicit include file dependency on rwsem.h: CC [M] fs/cifs/cifs_spnego.o In file included from include/keys/user-type.h:15, from fs/cifs/cifs_spnego.c:24: include/linux/key.h:128: error: field ‘sem’ has incomplete type make[2]: *** [fs/cifs/cifs_spnego.o] Error 1 make[1]: *** [fs/cifs] Error 2 make: *** [fs] Error 2 Fix it by making the dependency explicit. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237884886.25315.39.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-14CRED: Make execve() take advantage of copy-on-write credentialsDavid Howells
Make execve() take advantage of copy-on-write credentials, allowing it to set up the credentials in advance, and then commit the whole lot after the point of no return. This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). The credential bits from struct linux_binprm are, for the most part, replaced with a single credentials pointer (bprm->cred). This means that all the creds can be calculated in advance and then applied at the point of no return with no possibility of failure. I would like to replace bprm->cap_effective with: cap_isclear(bprm->cap_effective) but this seems impossible due to special behaviour for processes of pid 1 (they always retain their parent's capability masks where normally they'd be changed - see cap_bprm_set_creds()). The following sequence of events now happens: (a) At the start of do_execve, the current task's cred_exec_mutex is locked to prevent PTRACE_ATTACH from obsoleting the calculation of creds that we make. (a) prepare_exec_creds() is then called to make a copy of the current task's credentials and prepare it. This copy is then assigned to bprm->cred. This renders security_bprm_alloc() and security_bprm_free() unnecessary, and so they've been removed. (b) The determination of unsafe execution is now performed immediately after (a) rather than later on in the code. The result is stored in bprm->unsafe for future reference. (c) prepare_binprm() is called, possibly multiple times. (i) This applies the result of set[ug]id binaries to the new creds attached to bprm->cred. Personality bit clearance is recorded, but now deferred on the basis that the exec procedure may yet fail. (ii) This then calls the new security_bprm_set_creds(). This should calculate the new LSM and capability credentials into *bprm->cred. This folds together security_bprm_set() and parts of security_bprm_apply_creds() (these two have been removed). Anything that might fail must be done at this point. (iii) bprm->cred_prepared is set to 1. bprm->cred_prepared is 0 on the first pass of the security calculations, and 1 on all subsequent passes. This allows SELinux in (ii) to base its calculations only on the initial script and not on the interpreter. (d) flush_old_exec() is called to commit the task to execution. This performs the following steps with regard to credentials: (i) Clear pdeath_signal and set dumpable on certain circumstances that may not be covered by commit_creds(). (ii) Clear any bits in current->personality that were deferred from (c.i). (e) install_exec_creds() [compute_creds() as was] is called to install the new credentials. This performs the following steps with regard to credentials: (i) Calls security_bprm_committing_creds() to apply any security requirements, such as flushing unauthorised files in SELinux, that must be done before the credentials are changed. This is made up of bits of security_bprm_apply_creds() and security_bprm_post_apply_creds(), both of which have been removed. This function is not allowed to fail; anything that might fail must have been done in (c.ii). (ii) Calls commit_creds() to apply the new credentials in a single assignment (more or less). Possibly pdeath_signal and dumpable should be part of struct creds. (iii) Unlocks the task's cred_replace_mutex, thus allowing PTRACE_ATTACH to take place. (iv) Clears The bprm->cred pointer as the credentials it was holding are now immutable. (v) Calls security_bprm_committed_creds() to apply any security alterations that must be done after the creds have been changed. SELinux uses this to flush signals and signal handlers. (f) If an error occurs before (d.i), bprm_free() will call abort_creds() to destroy the proposed new credentials and will then unlock cred_replace_mutex. No changes to the credentials will have been made. (2) LSM interface. A number of functions have been changed, added or removed: (*) security_bprm_alloc(), ->bprm_alloc_security() (*) security_bprm_free(), ->bprm_free_security() Removed in favour of preparing new credentials and modifying those. (*) security_bprm_apply_creds(), ->bprm_apply_creds() (*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds() Removed; split between security_bprm_set_creds(), security_bprm_committing_creds() and security_bprm_committed_creds(). (*) security_bprm_set(), ->bprm_set_security() Removed; folded into security_bprm_set_creds(). (*) security_bprm_set_creds(), ->bprm_set_creds() New. The new credentials in bprm->creds should be checked and set up as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the second and subsequent calls. (*) security_bprm_committing_creds(), ->bprm_committing_creds() (*) security_bprm_committed_creds(), ->bprm_committed_creds() New. Apply the security effects of the new credentials. This includes closing unauthorised files in SELinux. This function may not fail. When the former is called, the creds haven't yet been applied to the process; when the latter is called, they have. The former may access bprm->cred, the latter may not. (3) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) The bprm_security_struct struct has been removed in favour of using the credentials-under-construction approach. (c) flush_unauthorized_files() now takes a cred pointer and passes it on to inode_has_perm(), file_has_perm() and dentry_open(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate per-task-group keyrings from signal_structDavid Howells
Separate per-task-group keyrings from signal_struct and dangle their anchor from the cred struct rather than the signal_struct. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14KEYS: Alter use of key instantiation link-to-keyring argumentDavid Howells
Alter the use of the key instantiation and negation functions' link-to-keyring arguments. Currently this specifies a keyring in the target process to link the key into, creating the keyring if it doesn't exist. This, however, can be a problem for copy-on-write credentials as it means that the instantiating process can alter the credentials of the requesting process. This patch alters the behaviour such that: (1) If keyctl_instantiate_key() or keyctl_negate_key() are given a specific keyring by ID (ringid >= 0), then that keyring will be used. (2) If keyctl_instantiate_key() or keyctl_negate_key() are given one of the special constants that refer to the requesting process's keyrings (KEY_SPEC_*_KEYRING, all <= 0), then: (a) If sys_request_key() was given a keyring to use (destringid) then the key will be attached to that keyring. (b) If sys_request_key() was given a NULL keyring, then the key being instantiated will be attached to the default keyring as set by keyctl_set_reqkey_keyring(). (3) No extra link will be made. Decision point (1) follows current behaviour, and allows those instantiators who've searched for a specifically named keyring in the requestor's keyring so as to partition the keys by type to still have their named keyrings. Decision point (2) allows the requestor to make sure that the key or keys that get produced by request_key() go where they want, whilst allowing the instantiator to request that the key is retained. This is mainly useful for situations where the instantiator makes a secondary request, the key for which should be retained by the initial requestor: +-----------+ +--------------+ +--------------+ | | | | | | | Requestor |------->| Instantiator |------->| Instantiator | | | | | | | +-----------+ +--------------+ +--------------+ request_key() request_key() This might be useful, for example, in Kerberos, where the requestor requests a ticket, and then the ticket instantiator requests the TGT, which someone else then has to go and fetch. The TGT, however, should be retained in the keyrings of the requestor, not the first instantiator. To make this explict an extra special keyring constant is also added. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-12add key_revoke() dummy for KEYS=nAdrian Bunk
This fixes the following build error with CONFIG_KEYS=n, caused by commit dfd15c46a6c2cafb006183c0c14f07e59eee4ac0 ("cifs: explicitly revoke SPNEGO key after session setup"): CC [M] fs/cifs/sess.o fs/cifs/sess.c: In function 'CIFS_SessSetup': fs/cifs/sess.c:628: error: implicit declaration of function 'key_revoke' make[3]: *** [fs/cifs/sess.o] Error 1 Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29keys: make key_serial() a function if CONFIG_KEYS=yDavid Howells
Make key_serial() an inline function rather than a macro if CONFIG_KEYS=y. This prevents double evaluation of the key pointer and also provides better type checking. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29keys: make the keyring quotas controllable through /proc/sysDavid Howells
Make the keyring quotas controllable through /proc/sys files: (*) /proc/sys/kernel/keys/root_maxkeys /proc/sys/kernel/keys/root_maxbytes Maximum number of keys that root may have and the maximum total number of bytes of data that root may have stored in those keys. (*) /proc/sys/kernel/keys/maxkeys /proc/sys/kernel/keys/maxbytes Maximum number of keys that each non-root user may have and the maximum total number of bytes of data that each of those users may have stored in their keys. Also increase the quotas as a number of people have been complaining that it's not big enough. I'm not sure that it's big enough now either, but on the other hand, it can now be set in /etc/sysctl.conf. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <kwc@citi.umich.edu> Cc: <arunsr@cse.iitk.ac.in> Cc: <dwalsh@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29keys: don't generate user and user session keyrings unless they're accessedDavid Howells
Don't generate the per-UID user and user session keyrings unless they're explicitly accessed. This solves a problem during a login process whereby set*uid() is called before the SELinux PAM module, resulting in the per-UID keyrings having the wrong security labels. This also cures the problem of multiple per-UID keyrings sometimes appearing due to PAM modules (including pam_keyinit) setuiding and causing user_structs to come into and go out of existence whilst the session keyring pins the user keyring. This is achieved by first searching for extant per-UID keyrings before inventing new ones. The serial bound argument is also dropped from find_keyring_by_name() as it's not currently made use of (setting it to 0 disables the feature). Signed-off-by: David Howells <dhowells@redhat.com> Cc: <kwc@citi.umich.edu> Cc: <arunsr@cse.iitk.ac.in> Cc: <dwalsh@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29keys: allow clients to set key perms in key_create_or_update()Arun Raghavan
The key_create_or_update() function provided by the keyring code has a default set of permissions that are always applied to the key when created. This might not be desirable to all clients. Here's a patch that adds a "perm" parameter to the function to address this, which can be set to KEY_PERM_UNDEF to revert to the current behaviour. Signed-off-by: Arun Raghavan <arunsr@cse.iitk.ac.in> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29keys: allow the callout data to be passed as a blob rather than a stringDavid Howells
Allow the callout data to be passed as a blob rather than a string for internal kernel services that call any request_key_*() interface other than request_key(). request_key() itself still takes a NUL-terminated string. The functions that change are: request_key_with_auxdata() request_key_async() request_key_async_with_auxdata() Signed-off-by: David Howells <dhowells@redhat.com> Cc: Paul Moore <paul.moore@hp.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08KEYS: fix macroSebastian Siewior
Commit 664cceb0093b755739e56572b836a99104ee8a75 changed the parameters of the function make_key_ref(). The macros that are used in case CONFIG_KEY is not defined did not change. Cc: David Howells <dhowells@redhat.com> Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17KEYS: Make request_key() and co fundamentally asynchronousDavid Howells
Make request_key() and co fundamentally asynchronous to make it easier for NFS to make use of them. There are now accessor functions that do asynchronous constructions, a wait function to wait for construction to complete, and a completion function for the key type to indicate completion of construction. Note that the construction queue is now gone. Instead, keys under construction are linked in to the appropriate keyring in advance, and that anyone encountering one must wait for it to be complete before they can use it. This is done automatically for userspace. The following auxiliary changes are also made: (1) Key type implementation stuff is split from linux/key.h into linux/key-type.h. (2) AF_RXRPC provides a way to allocate null rxrpc-type keys so that AFS does not need to call key_instantiate_and_link() directly. (3) Adjust the debugging macros so that they're -Wformat checked even if they are disabled, and make it so they can be enabled simply by defining __KDEBUG to be consistent with other code of mine. (3) Documentation. [alan@lxorguk.ukuu.org.uk: keys: missing word in documentation] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AF_RXRPC]: Key facility changes for AF_RXRPCDavid Howells
Export the keyring key type definition and document its availability. Add alternative types into the key's type_data union to make it more useful. Not all users necessarily want to use it as a list_head (AF_RXRPC doesn't, for example), so make it clear that it can be used in other ways. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[PATCH] Keys: Allow in-kernel key requestor to pass auxiliary data to upcallerDavid Howells
The proposed NFS key type uses its own method of passing key requests to userspace (upcalling) rather than invoking /sbin/request-key. This is because the responsible userspace daemon should already be running and will be contacted through rpc_pipefs. This patch permits the NFS filesystem to pass auxiliary data to the upcall operation (struct key_type::request_key) so that the upcaller can use a pre-existing communications channel more easily. Signed-off-by: David Howells <dhowells@redhat.com> Acked-By: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] keys: sort out key quota systemDavid Howells
Add the ability for key creation to overrun the user's quota in some circumstances - notably when a session keyring is created and assigned to a process that didn't previously have one. This means it's still possible to log in, should PAM require the creation of a new session keyring, and fix an overburdened key quota. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] Keys: Fix race between two instantiators of a keyDavid Howells
Add a revocation notification method to the key type and calls it whilst the key's semaphore is still write-locked after setting the revocation flag. The patch then uses this to maintain a reference on the task_struct of the process that calls request_key() for as long as the authorisation key remains unrevoked. This fixes a potential race between two processes both of which have assumed the authority to instantiate a key (one may have forked the other for example). The problem is that there's no locking around the check for revocation of the auth key and the use of the task_struct it points to, nor does the auth key keep a reference on the task_struct. Access to the "context" pointer in the auth key must thenceforth be done with the auth key semaphore held. The revocation method is called with the target key semaphore held write-locked and the search of the context process's keyrings is done with the auth key semaphore read-locked. The check for the revocation state of the auth key just prior to searching it is done after the auth key is read-locked for the search. This ensures that the auth key can't be revoked between the check and the search. The revocation notification method is added so that the context task_struct can be released as soon as instantiation happens rather than waiting for the auth key to be destroyed, thus avoiding the unnecessary pinning of the requesting process. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] selinux: add hooks for key subsystemMichael LeMay
Introduce SELinux hooks to support the access key retention subsystem within the kernel. Incorporate new flask headers from a modified version of the SELinux reference policy, with support for the new security class representing retained keys. Extend the "key_alloc" security hook with a task parameter representing the intended ownership context for the key being allocated. Attach security information to root's default keyrings within the SELinux initialization routine. Has passed David's testsuite. Signed-off-by: Michael LeMay <mdlemay@epoch.ncsc.mil> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] keys: Permit running process to instantiate keysDavid Howells
Make it possible for a running process (such as gssapid) to be able to instantiate a key, as was requested by Trond Myklebust for NFS4. The patch makes the following changes: (1) A new, optional key type method has been added. This permits a key type to intercept requests at the point /sbin/request-key is about to be spawned and do something else with them - passing them over the rpc_pipefs files or netlink sockets for instance. The uninstantiated key, the authorisation key and the intended operation name are passed to the method. (2) The callout_info is no longer passed as an argument to /sbin/request-key to prevent unauthorised viewing of this data using ps or by looking in /proc/pid/cmdline. This means that the old /sbin/request-key program will not work with the patched kernel as it will expect to see an extra argument that is no longer there. A revised keyutils package will be made available tomorrow. (3) The callout_info is now attached to the authorisation key. Reading this key will retrieve the information. (4) A new field has been added to the task_struct. This holds the authorisation key currently active for a thread. Searches now look here for the caller's set of keys rather than looking for an auth key in the lowest level of the session keyring. This permits a thread to be servicing multiple requests at once and to switch between them. Note that this is per-thread, not per-process, and so is usable in multithreaded programs. The setting of this field is inherited across fork and exec. (5) A new keyctl function (KEYCTL_ASSUME_AUTHORITY) has been added that permits a thread to assume the authority to deal with an uninstantiated key. Assumption is only permitted if the authorisation key associated with the uninstantiated key is somewhere in the thread's keyrings. This function can also clear the assumption. (6) A new magic key specifier has been added to refer to the currently assumed authorisation key (KEY_SPEC_REQKEY_AUTH_KEY). (7) Instantiation will only proceed if the appropriate authorisation key is assumed first. The assumed authorisation key is discarded if instantiation is successful. (8) key_validate() is moved from the file of request_key functions to the file of permissions functions. (9) The documentation is updated. From: <Valdis.Kletnieks@vt.edu> Build fix. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Alexander Zangerl <az@bond.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
