This avoids selecting IOMMU_HELPER just for this function. And we only
use it once or twice in normal builds so this often even is a size
reduction.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
A profile of a network benchmark showed iommu_num_pages rather high up:
0.52% iommu_num_pages
Looking at the profile, an integer divide is taking almost all of the time:
: c000000000376ea4 <.iommu_num_pages>:
1.93 : c000000000376ea4: fb e1 ff f8 std r31,-8(r1)
0.00 : c000000000376ea8: f8 21 ff c1 stdu r1,-64(r1)
0.00 : c000000000376eac: 7c 3f 0b 78 mr r31,r1
3.86 : c000000000376eb0: 38 84 ff ff addi r4,r4,-1
0.00 : c000000000376eb4: 38 05 ff ff addi r0,r5,-1
0.00 : c000000000376eb8: 7c 84 2a 14 add r4,r4,r5
46.95 : c000000000376ebc: 7c 00 18 38 and r0,r0,r3
45.66 : c000000000376ec0: 7c 84 02 14 add r4,r4,r0
0.00 : c000000000376ec4: 7c 64 2b 92 divdu r3,r4,r5
0.00 : c000000000376ec8: 38 3f 00 40 addi r1,r31,64
0.00 : c000000000376ecc: eb e1 ff f8 ld r31,-8(r1)
1.61 : c000000000376ed0: 4e 80 00 20 blr
Since every caller of iommu_num_pages passes in a constant power of two
we can inline this such that the divide is replaced by a shift. The
entire function is only a few instructions once optimised, so it is
a good candidate for inlining overall.
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Use bitmap library and kill some unused iommu helper functions.
1. s/iommu_area_free/bitmap_clear/
2. s/iommu_area_reserve/bitmap_set/
3. Use bitmap_find_next_zero_area instead of find_next_zero_area
This cannot be simple substitution because find_next_zero_area
doesn't check the last bit of the limit in bitmap
4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Joerg Roedel <joerg.roedel@amd.com>
This patch introduces the generic iommu_num_pages function. It can be used by
a given memory area.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
Cc: Dave Airlie <airlied@linux.ie>
include/linux/iommu-helper.h has no header guards, which breaks
sparc64 build. Add them.
x86 has set_bit_string() that does the exact same thing that
set_bit_area() in lib/iommu-helper.c does.
This patch exports set_bit_area() in lib/iommu-helper.c as
iommu_area_reserve(), converts GART, Calgary, and AMD IOMMU to use it.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Joerg Roedel <joerg.roedel@amd.com>
This function helps IOMMUs to know the highest address that a device
can access to.
This IOMMU helper function doesn't work for some architectures:
http://marc.info/?l=linux-kernel&m=121699304403202&w=2
It also breaks POWER and SPARC builds:
http://marc.info/?l=linux-kernel&m=121730388001890&w=2
Currently, only x86 IOMMUs use this so let's move it to x86 for
now.
Calculating the number of pages from given address and length numbers is a task
required in multiple IOMMU implementations. So implement this as a generic
function into the IOMMU helper code.
Cc: iommu@lists.linux-foundation.org
Cc: bhavna.sarathy@amd.com
Cc: robert.richter@amd.com
iommu_is_span_boundary is used internally in the IOMMU helper
(lib/iommu-helper.c), a primitive function that judges whether a memory area
spans LLD's segment boundary or not.
It's difficult to convert some IOMMUs to use the IOMMU helper but
iommu_is_span_boundary is still useful for them. So this patch exports it.
This is needed for the parisc iommu fixes.
Cc: Kyle McMartin <kyle@parisc-linux.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Grant Grundler <grundler@parisc-linux.org>
This adds IOMMU helper functions for the free area management. These
functions take care of LLD's segment boundary limit for IOMMUs. They would be
useful for IOMMUs that use bitmap for the free area management.
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
