path: root/include/linux/interrupt.h
2009-11-04irq: Remove unused debug_poll_all_shared_irqs()Thomas Gleixner
commit 74296a8ed added this function for debug purposes, but it was never used for anything. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-24cpumask: Remove mask field from commentsNobuhiro Iwamatsu
By 7be23e278f, mask field was deleted by irqaction. However, it was not deleted from comment. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> CC: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: remove unused mask field from struct irqaction.Rusty Russell
Up until 1.1.83, the primitive human tribes used struct sigaction for interrupts. The sa_mask field was overloaded to hold a pointer to the name. When someone created the new "struct irqaction" they carried across the "mask" field as a kind of ancestor worship: the fact that it was unused makes clear its spiritual significance. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-14Merge branch 'for-2.6.32' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.32' of git://git.kernel.dk/linux-2.6-block: (29 commits) block: use blkdev_issue_discard in blk_ioctl_discard Make DISCARD_BARRIER and DISCARD_NOBARRIER writes instead of reads block: don't assume device has a request list backing in nr_requests store block: Optimal I/O limit wrapper cfq: choose a new next_req when a request is dispatched Seperate read and write statistics of in_flight requests aoe: end barrier bios with EOPNOTSUPP block: trace bio queueing trial only when it occurs block: enable rq CPU completion affinity by default cfq: fix the log message after dispatched a request block: use printk_once cciss: memory leak in cciss_init_one() splice: update mtime and atime on files block: make blk_iopoll_prep_sched() follow normal 0/1 return convention cfq-iosched: get rid of must_alloc flag block: use interrupts disabled version of raise_softirq_irqoff() block: fix comment in blk-iopoll.c block: adjust default budget for blk-iopoll block: fix long lines in block/blk-iopoll.c block: add blk-iopoll, a NAPI like approach for block devices ...
2009-09-11block: add blk-iopoll, a NAPI like approach for block devicesJens Axboe
This borrows some code from NAPI and implements a polled completion mode for block devices. The idea is the same as NAPI - instead of doing the command completion when the irq occurs, schedule a dedicated softirq in the hopes that we will complete more IO when the iopoll handler is invoked. Devices have a budget of commands assigned, and will stay in polled mode as long as they continue to consume their budget from the iopoll softirq handler. If they do not, the device is set back to interrupt completion mode. This patch holds the core bits for blk-iopoll, device driver support sold separately. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-17genirq: Add oneshot supportThomas Gleixner
For threaded interrupt handlers we expect the hard interrupt handler part to mask the interrupt on the originating device. The interrupt line itself is reenabled after the hard interrupt handler has executed. This requires access to the originating device from hard interrupt context which is not always possible. There are devices which can only be accessed via a bus (i2c, spi, ...). The bus access requires thread context. For such devices we need to keep the interrupt line masked until the threaded handler has executed. Add a new flag IRQF_ONESHOT which allows drivers to request that the interrupt is not unmasked after the hard interrupt context handler has been executed and the thread has been woken. The interrupt line is unmasked after the thread handler function has been executed. Note that for now IRQF_ONESHOT cannot be used with IRQF_SHARED to avoid complex accounting mechanisms. For oneshot interrupts the primary handler simply returns IRQ_WAKE_THREAD and does nothing else. A generic implementation irq_default_primary_handler() is provided to avoid useless copies all over the place. It is automatically installed when request_threaded_irq() is called with handler=NULL and thread_fn!=NULL. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Trilok Soni <soni.trilok@gmail.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Brian Swetland <swetland@google.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: m.szyprowski@samsung.com Cc: t.fujak@samsung.com Cc: kyungmin.park@samsung.com, Cc: David Brownell <david-b@pacbell.net> Cc: Daniel Ribeiro <drwyrm@gmail.com> Cc: arve@android.com Cc: Barry Song <21cnbao@gmail.com>
2009-07-22Merge branch 'core-fixes-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softirq: introduce tasklet_hrtimer infrastructure
2009-07-22softirq: introduce tasklet_hrtimer infrastructurePeter Zijlstra
commit ca109491f (hrtimer: removing all ur callback modes) moved all hrtimer callbacks into hard interrupt context when high resolution timers are active. That breaks code which relied on the assumption that the callback happens in softirq context. Provide a generic infrastructure which combines tasklets and hrtimers together to provide an in-softirq hrtimer experience. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: torvalds@linux-foundation.org Cc: kaber@trash.net Cc: David Miller <davem@davemloft.net> LKML-Reference: <1248265724.27058.1366.camel@twins> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-07-21genirq: Delegate irq affinity setting to the irq threadThomas Gleixner
irq_set_thread_affinity() calls set_cpus_allowed_ptr() which might sleep, but irq_set_thread_affinity() is called with desc->lock held and can be called from hard interrupt context as well. The code has another bug as it does not hold a ref on the task struct as required by set_cpus_allowed_ptr(). Just set the IRQTF_AFFINITY bit in action->thread_flags. The next time the thread runs it migrates itself. Solves all of the above problems nicely. Add kerneldoc to irq_set_thread_affinity() while at it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <new-submission>
2009-06-15Merge commit 'linus/master' into HEADVegard Nossum
Conflicts: MAINTAINERS Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-13tasklets: new tasklet scheduling functionVegard Nossum
Rationale: kmemcheck needs to be able to schedule a tasklet without touching any dynamically allocated memory _at_ _all_ (since that would lead to a recursive page fault). This tasklet is used for writing the error reports to the kernel log. The new scheduling function avoids touching any other tasklets by inserting the new tasklist as the head of the "tasklet_hi" list instead of on the tail. Also don't wake up the softirq thread lest the scheduler access some tracked memory and we go down with a recursive page fault. In this case, we'd better just wait for the maximum time of 1/HZ for the message to appear. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-12PM: Add empty suspend/resume device irq functionsHeiko Carstens
git commit 0a0c5168 "PM: Introduce functions for suspending and resuming device interrupts" introduced some helper functions. However these functions are only available for architectures which support GENERIC_HARDIRQS. Other architectures will see this build error: drivers/built-in.o: In function `sysdev_suspend': (.text+0x15138): undefined reference to `check_wakeup_irqs' drivers/built-in.o: In function `device_power_up': (.text+0x1cb66): undefined reference to `resume_device_irqs' drivers/built-in.o: In function `device_power_down': (.text+0x1cb92): undefined reference to `suspend_device_irqs' To fix this add some empty inline functions for !GENERIC_HARDIRQS. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-04-28x86/irq: change irq_desc_alloc() to take node instead of cpuYinghai Lu
This simplifies the node awareness of the code. All our allocators only deal with a NUMA node ID locality not with CPU ids anyway - so there's no need to maintain (and transform) a CPU id all across the IRq layer. v2: keep move_irq_desc related [ Impact: cleanup, prepare IRQ code to be NUMA-aware ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@goop.org> LKML-Reference: <49F65536.2020300@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'irq/threaded' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq/threaded' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: fix devres.o build for GENERIC_HARDIRQS=n genirq: provide old request_irq() for CONFIG_GENERIC_HARDIRQ=n genirq: threaded irq handlers review fixups genirq: add support for threaded interrupts to devres genirq: add threaded interrupt handler support
2009-04-06Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: add stack dumps to asserts hrtimer: fix rq->lock inversion (again)
2009-04-06Merge branch 'linus' into irq/threadedIngo Molnar
Conflicts: include/linux/irq.h kernel/irq/handle.c
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-31hrtimer: fix rq->lock inversion (again)Peter Zijlstra
It appears I inadvertly introduced rq->lock recursion to the hrtimer_start() path when I delegated running already expired timers to softirq context. This patch fixes it by introducing a __hrtimer_start_range_ns() method that will not use raise_softirq_irqoff() but __raise_softirq_irqoff() which avoids the wakeup. It then also changes schedule() to check for pending softirqs and do the wakeup then, I'm not quite sure I like this last bit, nor am I convinced its really needed. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org LKML-Reference: <20090313112301.096138802@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-30PM: Introduce functions for suspending and resuming device interruptsRafael J. Wysocki
Introduce helper functions allowing us to prevent device drivers from getting any interrupts (without disabling interrupts on the CPU) during suspend (or hibernation) and to make them start to receive interrupts again during the subsequent resume. These functions make it possible to keep timer interrupts enabled while the "late" suspend and "early" resume callbacks provided by device drivers are being executed. In turn, this allows device drivers' "late" suspend and "early" resume callbacks to sleep, execute ACPI callbacks etc. The functions introduced here will be used to rework the handling of interrupts during suspend (hibernation) and resume. Namely, interrupts will only be disabled on the CPU right before suspending sysdevs, while device drivers will be prevented from receiving interrupts, with the help of the new helper function, before their "late" suspend callbacks run (and analogously during resume). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-25genirq: fix devres.o build for GENERIC_HARDIRQS=nThomas Gleixner
kernel/irq/devres.c is built by sparc (32bit) and m68k via the obscure ../../../kernel/irq/devres.o reference in arch/[sparc/m68k]/kernel/Makefile To avoid ifdeffery in devres.c provide request_threaded_irq as an inline for these users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-24genirq: provide old request_irq() for CONFIG_GENERIC_HARDIRQ=nThomas Gleixner
Impact: Undo compile breakage for archs with CONFIG_GENERIC_HARDIRQ=n The threaded interrupt handler patches changed request_irq from extern to inline. Architectures which do not use the generic irq code still have request_irq() as a global function and therefor fail to compile. Keep the extern declaration for CONFIG_GENERIC_HARDIRQ=n Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-24genirq: threaded irq handlers review fixupsThomas Gleixner
Delta patch to address the review comments. - Implement warning when IRQ_WAKE_THREAD is requested and no thread handler installed - coding style fixes Pointed-out-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-24genirq: add support for threaded interrupts to devresArjan van de Ven
Some devices use devres_request_irq() for to install their interrupt handler. Add support for threaded interrupts to devres as well. [tglx - simplified and adapted to latest threadirq version] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-24genirq: add threaded interrupt handler supportThomas Gleixner
Add support for threaded interrupt handlers: A device driver can request that its main interrupt handler runs in a thread. To achive this the device driver requests the interrupt with request_threaded_irq() and provides additionally to the handler a thread function. The handler function is called in hard interrupt context and needs to check whether the interrupt originated from the device. If the interrupt originated from the device then the handler can either return IRQ_HANDLED or IRQ_WAKE_THREAD. IRQ_HANDLED is returned when no further action is required. IRQ_WAKE_THREAD causes the genirq code to invoke the threaded (main) handler. When IRQ_WAKE_THREAD is returned handler must have disabled the interrupt on the device level. This is mandatory for shared interrupt handlers, but we need to do it as well for obscure x86 hardware where disabling an interrupt on the IO_APIC level redirects the interrupt to the legacy PIC interrupt lines. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2009-03-23Merge branch 'cpus4096' into irq/threadedThomas Gleixner
Conflicts: arch/parisc/kernel/irq.c kernel/irq/handle.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-13genirq: add doc to struct irqactionThomas Gleixner
Impact: documentation struct irqaction is not documented. Add kernel doc comments and add interrupt.h to the genirq docbook. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-12tracing: tracepoints for softirq entry/exit - add softirq-to-name arrayJason Baron
Create a 'softirq_to_name' array, which is indexed by softirq #, so that we can easily convert between the softirq index # and its name, in order to get more meaningful output messages. LKML-Reference: <20090312183336.GB3352@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-01-16irq: provide debug_poll_all_shared_irqs() method under CONFIG_DEBUG_SHIRQIngo Molnar
Provide a shared interrupt debug facility under CONFIG_DEBUG_SHIRQ: it uses the existing irqpoll facilities to iterate through all registered interrupt handlers and call those which can handle shared IRQ lines. This can be handy for suspend/resume debugging: if we call this function early during resume we can trigger crashes in those drivers which have incorrect assumptions about when exactly their ISRs will be called during suspend/resume. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-12x86: arch_probe_nr_irqsYinghai Lu
Impact: save RAM with large NR_CPUS, get smaller nr_irqs Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Mike Travis <travis@sgi.com>
2009-01-06Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimer: splitout peek ahead functionality, fix hrtimer: fixup comments hrtimer: fix recursion deadlock by re-introducing the softirq hrtimer: simplify hotplug migration hrtimer: fix HOTPLUG_CPU=n compile warning hrtimer: splitout peek ahead functionality
2009-01-06include/linux/interrupt.h: do not include linux/irqnr.h twiceJesper Juhl
Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05hrtimer: fix recursion deadlock by re-introducing the softirqPeter Zijlstra
Impact: fix rare runtime deadlock There are a few sites that do: spin_lock_irq(&foo) hrtimer_start(&bar) __run_hrtimer(&bar) func() spin_lock(&foo) which obviously deadlocks. In order to avoid this, never call __run_hrtimer() from hrtimer_start*() context, but instead defer this to softirq context. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-03Merge branch 'cpus4096-for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits) x86: setup_per_cpu_areas() cleanup cpumask: fix compile error when CONFIG_NR_CPUS is not defined cpumask: use alloc_cpumask_var_node where appropriate cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t x86: use cpumask_var_t in acpi/boot.c x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids sched: put back some stack hog changes that were undone in kernel/sched.c x86: enable cpus display of kernel_max and offlined cpus ia64: cpumask fix for is_affinity_mask_valid() cpumask: convert RCU implementations, fix xtensa: define __fls mn10300: define __fls m32r: define __fls h8300: define __fls frv: define __fls cris: define __fls cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS cpumask: zero extra bits in alloc_cpumask_var_node cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/ cpumask: convert mm/ ...
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2009-01-01cpumask: convert kernel/irqRusty Russell
Impact: Reduce stack usage, use new cpumask API. ALPHA mod! Main change is that irq_default_affinity becomes a cpumask_var_t, so treat it as a pointer (this effects alpha). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-31Merge branch 'irq-fixes-for-linus-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus-4' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sparseirq: move __weak symbols into separate compilation unit sparseirq: work around __weak alias bug sparseirq: fix hang with !SPARSE_IRQ sparseirq: set lock_class for legacy irq when sparse_irq is selected sparseirq: work around compiler optimizing away __weak functions sparseirq: fix desc->lock init sparseirq: do not printk when migrating IRQ descriptors sparseirq: remove duplicated arch_early_irq_init() irq: simplify for_each_irq_desc() usage proc: remove ifdef CONFIG_SPARSE_IRQ from stat.c irq: for_each_irq_desc() move to irqnr.h hrtimer: remove #include <linux/irq.h>
2008-12-31Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/x86/kernel/io_apic.c
2008-12-30Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, sparseirq: clean up Kconfig entry x86: turn CONFIG_SPARSE_IRQ off by default sparseirq: fix numa_migrate_irq_desc dependency and comments sparseirq: add kernel-doc notation for new member in irq_desc, -v2 locking, irq: enclose irq_desc_lock_class in CONFIG_LOCKDEP sparseirq, xen: make sure irq_desc is allocated for interrupts sparseirq: fix !SMP building, #2 x86, sparseirq: move irq_desc according to smp_affinity, v7 proc: enclose desc variable of show_stat() in CONFIG_SPARSE_IRQ sparse irqs: add irqnr.h to the user headers list sparse irqs: handle !GENIRQ platforms sparseirq: fix !SMP && !PCI_MSI && !HT_IRQ build sparseirq: fix Alpha build failure sparseirq: fix typo in !CONFIG_IO_APIC case x86, MSI: pass irq_cfg and irq_desc x86: MSI start irq numbering from nr_irqs_gsi x86: use NR_IRQS_LEGACY sparse irq_desc[] array: core kernel and x86 changes genirq: record IRQ_LEVEL in irq_desc[] irq.h: remove padding from irq_desc on 64bits
2008-12-29sparseirq: move __weak symbols into separate compilation unitYinghai Lu
GCC has a bug with __weak alias functions: if the functions are in the same compilation unit as their call site, GCC can decide to inline them - and thus rob the linker of the opportunity to override the weak alias with the real thing. So move all the IRQ handling related __weak symbols to kernel/irq/chip.c. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-13Merge ../linux-2.6-x86Rusty Russell
Conflicts: arch/x86/kernel/io_apic.c kernel/sched.c kernel/sched_stats.h
2008-12-13cpumask: make irq_set_affinity() take a const struct cpumaskRusty Russell
Impact: change existing irq_chip API Not much point with gentle transition here: the struct irq_chip's setaffinity method signature needs to change. Fortunately, not widely used code, but hits a few architectures. Note: In irq_select_affinity() I save a temporary in by mangling irq_desc[irq].affinity directly. Ingo, does this break anything? (Folded in fix from KOSAKI Motohiro) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Ingo Molnar <mingo@redhat.com> Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: jeremy@xensource.com Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
2008-12-12sparse irqs: handle !GENIRQ platformsIngo Molnar
Impact: build fix fix: In file included from /home/mingo/tip/arch/m68k/amiga/amiints.c:39: /home/mingo/tip/include/linux/interrupt.h:21: error: expected identifier or '(' /home/mingo/tip/arch/m68k/amiga/amiints.c: In function 'amiga_init_IRQ': Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-08sparse irq_desc[] array: core kernel and x86 changesYinghai Lu
Impact: new feature Problem on distro kernels: irq_desc[NR_IRQS] takes megabytes of RAM with NR_CPUS set to large values. The goal is to be able to scale up to much larger NR_IRQS value without impacting the (important) common case. To solve this, we generalize irq_desc[NR_IRQS] to an (optional) array of irq_desc pointers. When CONFIG_SPARSE_IRQ=y is used, we use kzalloc_node to get irq_desc, this also makes the IRQ descriptors NUMA-local (to the site that calls request_irq()). This gets rid of the irq_cfg[] static array on x86 as well: irq_cfg now uses desc->chip_data for x86 to store irq_cfg. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-25hrtimer: removing all ur callback modesPeter Zijlstra
Impact: cleanup, move all hrtimer processing into hardirq context This is an attempt at removing some of the hrtimer complexity by reducing the number of callback modes to 1. This means that all hrtimer callback functions will be ran from HARD-irq context. I went through all the 30 odd hrtimer callback functions in the kernel and saw only one that I'm not quite sure of, which is the one in net/can/bcm.c - hence I'm CC-ing the folks responsible for that code. Furthermore, the hrtimer core now calls callbacks directly with IRQs disabled in case you try to enqueue an expired timer. If this timer is a periodic timer (which should use hrtimer_forward() to advance its time) then it might be possible to end up in an inf. recursive loop due to the fact that hrtimer_forward() doesn't round up to the next timer granularity, and therefore keeps on calling the callback - obviously this needs a fix. Aside from that, this seems to compile and actually boot on my dual core test box - although I'm sure there are some bugs in, me not hitting any makes me certain :-) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20Merge branch 'genirq-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip This merges branches irq/genirq, irq/sparseirq-v4, timers/hpet-percpu and x86/uv. The sparseirq branch is just preliminary groundwork: no sparse IRQs are actually implemented by this tree anymore - just the new APIs are added while keeping the old way intact as well (the new APIs map 1:1 to irq_desc[]). The 'real' sparse IRQ support will then be a relatively small patch ontop of this - with a v2.6.29 merge target. * 'genirq-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (178 commits) genirq: improve include files intr_remapping: fix typo io_apic: make irq_mis_count available on 64-bit too genirq: fix name space collisions of nr_irqs in arch/* genirq: fix name space collision of nr_irqs in autoprobe.c genirq: use iterators for irq_desc loops proc: fixup irq iterator genirq: add reverse iterator for irq_desc x86: move ack_bad_irq() to irq.c x86: unify show_interrupts() and proc helpers x86: cleanup show_interrupts genirq: cleanup the sparseirq modifications genirq: remove artifacts from sparseirq removal genirq: revert dynarray genirq: remove irq_to_desc_alloc genirq: remove sparse irq code genirq: use inline function for irq_to_desc genirq: consolidate nr_irqs and for_each_irq_desc() x86: remove sparse irq from Kconfig genirq: define nr_irqs for architectures with GENERIC_HARDIRQS=n ...
2008-10-18genirq: improve include filesThomas Gleixner
Move the irq_desc related iterators out of irq.h, into irqnr.h, also available via interrupt.h. This way non-genirq (and even non-hardirq) architectures get the common definitions and iterators. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-17softirq: Add support for triggering softirq work on softirqs.David S. Miller
This is basically a genericization of Jens Axboe's block layer remote softirq changes. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-16genirq: consolidate nr_irqs and for_each_irq_desc()Thomas Gleixner
Move all of those to linux/irq.h where they belong. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
