path: root/include/linux/interrupt.h
2006-07-03[PATCH] lockdep: irqtrace subsystem, coreIngo Molnar
Accurate hard-IRQ-flags and softirq-flags state tracing. This allows us to attach extra functionality to IRQ flags on/off events (such as trace-on/off). Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: add local_irq_enable_in_hardirq() APIIngo Molnar
Introduce local_irq_enable_in_hardirq() API. It is currently aliased to local_irq_enable(), hence has no functional effects. This API will be used by lockdep, but even without lockdep this will better document places in the kernel where a hardirq context enables hardirqs. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: add disable/enable_irq_lockdep() APIIngo Molnar
lockdep wants to use the disable_irq()/enable_irq() prototypes before they are provied by the platform's asm/irq.h. So move them out of the CONFIG_GENERIC_HARDIRQS define - all architectures have a common prototype for this anyway. Add special lockdep variants of irq line disabling/enabling. These should be used for locking constructs that know that a particular irq context which is disabled, and which is the only irq-context user of a lock, that it's safe to take the lock in the irq-disabled section without disabling hardirqs. [akpm@osdl.org: build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] genirq:fixup missing SA_PERCPU replacementThomas Gleixner
The irqflags consolidation converted SA_PERCPU_IRQ to IRQF_PERCPU but did not define the new constant. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: consolidate flags for request_irqThomas Gleixner
The recent interrupt rework introduced bit value conflicts with sparc. Instead of introducing new architecture flags mess, move the interrupt SA_ flags out of the signal namespace and replace them by interrupt related flags. This allows to remove the obsolete SA_INTERRUPT flag and clean up the bit field values. This patch: Move the interrupt related SA_ flags out of linux/signal.h and rename them to IRQF_ . This moves the interrupt related flags out of the signal namespace and allows to remove the architecture dependencies. SA_INTERRUPT is not needed by userspace and glibc so it can be removed safely. The existing SA_ constants are kept for easy transition and will be removed after a 6 month grace period. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Greg KH <greg@kroah.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeff Garzik <jeff@garzik.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Karsten Keil <kkeil@suse.de> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@debian.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Dave Airlie <airlied@linux.ie> Cc: Jens Axboe <axboe@suse.de> Cc: Chris Zankel <chris@zankel.net> Cc: Andi Kleen <ak@muc.de> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add irq-wake (power-management) supportThomas Gleixner
Enable platforms to set the irq-wake (power-management) properties of an IRQ. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] adjust handle_IRR_event() return typeJan Beulich
Correct the return type of handle_IRQ_event() (inconsistency noticed during Xen development), and remove redundant declarations. The return type adjustment required breaking out the definition of irqreturn_t into a separate header, in order to satisfy current include order dependencies. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-09[SCSI] Kill the SCSI softirq handlingJens Axboe
This patch moves the SCSI softirq handling to the block layer version. There should be no functional changes. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09[BLOCK] ll_rw_blk: Enable out-of-order request completions through softirqJens Axboe
Request completion can be a quite heavy process, since it needs to iterate through the entire request and complete the bio's it holds. This patch adds blk_complete_request() which moves this processing into a dedicated block softirq. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-08[PATCH] remove semicolons from save_flags()Andrew Morton
2005-11-13[PATCH] m68k: thread_info header cleanupAl Viro
a) in smp_lock.h #include of sched.h and spinlock.h moved under #ifdef CONFIG_LOCK_KERNEL. b) interrupt.h now explicitly pulls sched.h (not via smp_lock.h from hardirq.h as it used to) c) in three more places we need changes to compensate for (a) - one place in arch/sparc needs string.h now, hardirq.h needs forward declaration of task_struct and preempt.h needs direct include of thread_info.h. d) thread_info-related helpers in sched.h and thread_info.h put under ifndef __HAVE_THREAD_FUNCTIONS. Obviously safe. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Some cleanup and optimization to the processor data area.Andi Kleen
- Remove unused irqrsp field - Remove pda->me - Optimize set_softirq_pending slightly Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
