path: root/include/linux/if_ether.h
2006-03-03[PATCH] bonding: suppress duplicate packetsJay Vosburgh
Originally submitted by Kenzo Iwami; his original description is: The current bonding driver receives duplicate packets when broadcast/ multicast packets are sent by other devices or packets are flooded by the switch. In this patch, new flags are added in priv_flags of net_device structure to let the bonding driver discard duplicate packets in dev.c:skb_bond(). Modified by Jay Vosburgh to change a define name, update some comments, rearrange the new skb_bond() for clarity, clear all bonding priv_flags on slave release, and update the driver version. Signed-off-by: Kenzo Iwami <k-iwami@cj.jp.nec.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-18[TIPC] Move ethernet protocol id to linux/if_ether.hPer Liden
Signed-off-by: Per Liden <per.liden@ericsson.com>
2005-11-10[NET]: Annotate h_proto in struct ethhdrPavel Roskin
The protocol field in ethernet headers is big-endian and should be annotated as such. This patch allows detection of missing ntohs() calls on the ethernet protocol field when sparse is run with __CHECK_ENDIAN__ defined. This is a revised version that includes <linux/types.h> so that the userspace programs are not confused by __be16. Thanks to David S. Miller. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-27[NET]: Fix GCC4 compile error: sysctl in linux/if_ether.hBen Dooks
The following is generated when compiling a recent (2.6.14-rc2-git5) kernel configured for ARM, with GCC4. CC init/main.o In file included from include/linux/netdevice.h:29, from include/net/sock.h:48, from init/main.c:50: include/linux/if_ether.h:114: error: array type has incomplete element type It seems that if CONFIG_SYSCTL is not set, then the compiler will throw an error due to the definition of the ether_table[] array Attached is a solution to the problem Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
