path: root/include/linux/ieee80211.h
2008-04-30mac80211: use 4-byte mesh sequence numberLuis Carlos Cobo
This follows the new 802.11s/D2.0 draft. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: update mesh EID valuesLuis Carlos Cobo
This patch updates mesh EID values, some of which where conflicting with already-approved 11h EIDs (pointed out by Tomas Winkler). I wanted to use the values suggested in the last available 802.11 draft (2.0) but it assigns 50 to MESH_CONFIG, the same value than EXT_SUPP_RATES. Using the values proposed in the draft incremented by one. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06wireless: various definitions for mesh networkingLuis Carlos Cobo
Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-01iwlwifi: Fix MIMO PS modeTomas Winkler
This patch setups correctly MIMO PS mode flags Signed-off-by: Guy Cohen <guy.cohen@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: fixing ieee80211_bar typesRon Rindjunsky
This patch changes ieee80211_bar control and start_seq_num to match the proper bitwise attribute expected from ieee 802.11 frame Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: A-MPDU Rx adding basic functionalityRon Rindjunsky
This patch adds the basic needed abilities and functions for A-MPDU Rx session changed functions: - ieee80211_sta_process_addba_request - Rx A-MPDU initialization enabled - ieee80211_stop - stops all A-MPDU Rx in case interface goes down added functions: - ieee80211_send_delba - used for sending out Del BA in A-MPDU sessions - ieee80211_sta_stop_rx_BA_session - stopping Rx A-MPDU session - sta_rx_agg_session_timer_expired - stops A-MPDU Rx use if load is too low Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: adding 802.11n definitions in ieee80211.hRon Rindjunsky
This patch adds several structs and definitions to ieee80211.h to support 802.11n draft specifications. As 802.11n depends on and extends the 802.11e standard in several issues, there are also several definitions that belong to 802.11e. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28ieee80211: Add IEEE80211_MAX_FRAME_LEN to linux/ieee80211.hMichael Wu
This patch adds IEEE80211_MAX_FRAME_LEN which is useful for drivers trying to determine how much to allocate for their RX buffers. It also updates the comment on IEEE80211_MAX_DATA_LEN based on revisions in 802.11e. IEEE80211_MAX_FRAG_THRESHOLD and IEEE80211_MAX_RTS_THRESHOLD are also revised due to the new maximum frame size. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] wireless networking: move frame inline functions to generic headerJohannes Berg
These inlines are generally useful, not just with mac80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-12[PATCH] mac80211: ERP IE handling improvementsDaniel Drake
The "protection needed" flag is currently parsed out of the ERP IE in beacons. This patch allows the ERP IE to be available at assocation time and causes the appropriate actions to be performed earlier. It is slightly complicated by the fact that most APs don't include the ERP IE in association responses. To work around this, we store ERP values in the ieee80211_sta_bss structure. Also added some WLAN_ERP defines for use by upcoming patches. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-05[MAC80211]: Add generic include/linux/ieee80211.hJiri Benc
Add generic IEEE 802.11 definitions. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
