path: root/include/linux/i2o.h
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-16i2o: Fix 32/64bit DMA lockingAlan Cox
The I2O ioctls assume 32bits. In itself that is fine as they are old cards and nobody uses 64bit. However on LKML it was noted this assumption is also made for allocated memory and is unsafe on 64bit systems. Fixing this is a mess. It turns out there is tons of crap buried in a header file that does racy 32/64bit filtering on the masks. So we: - Verify all callers of the racy code can sleep (i2o_dma_[re]alloc) - Move the code into a new i2o/memory.c file - Remove the gfp_mask argument so nobody can try and misuse the function - Wrap a mutex around the problem area (a single mutex is easy to do and none of this is performance relevant) - Switch the remaining problem kmalloc holdout to use i2o_dma_alloc Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28i2o: remove static inline forward declarationsIlpo Järvinen
Nothing in between of them and the later declaration with body needs them. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-16i2o: sg chaining supportJens Axboe
Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-16Use mutexes instead of semaphores in I2O driverMatthias Kaehlcke
The I2O driver uses two semaphores as mutexes. Use the mutex API instead of the (binary) semaphores. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] kernel-doc: fix fusion and i2o docsRandy Dunlap
Correct lots of typos, kernel-doc warnings, & kernel-doc usage in fusion and i2o drivers. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-06-10[PATCH] I2O: Bugfixes to get I2O working againMarkus Lidel
From: Markus Lidel <Markus.Lidel@shadowconnect.com> - Fixed locking of struct i2o_exec_wait in Executive-OSM - Removed LCT Notify in i2o_exec_probe() which caused freeing memory and accessing freed memory during first enumeration of I2O devices - Added missing locking in i2o_exec_lct_notify() - removed put_device() of I2O controller in i2o_iop_remove() which caused the controller structure get freed to early - Fixed size of mempool in i2o_iop_alloc() - Fixed access to freed memory in i2o_msg_get() See http://bugzilla.kernel.org/show_bug.cgi?id=6561 Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: use mempool_create_slab_pool()Matthew Dobson
Modify well over a dozen mempool users to call mempool_create_slab_pool() rather than calling mempool_create() with extra arguments, saving about 30 lines of code and increasing readability. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] I2O: fix and workaround for Motorola/Freescale controllerMarkus Lidel
- This controller violates the I2O spec for the I/O registers. The patch contains a workaround which moves the registers to the proper location. (originally author: Matthew Starzewski) - If a message frame is beyond the mapped address range a error is returned. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: BugfixesMarkus Lidel
- Removed some kmalloc's with __GFP_ZERO and replace it with memset() because it didn't work properly. - Fixed returned message frame in i2o_cfg_passthru() which caused raidutils to display wrong error message in case a disk was missing. - Fixed size of printk() in i2o_scsi.c. - Fixed get_device() and put_device() in probing of the I2O controller. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: Remove wrong I2O device classMarkus Lidel
Removed wrong I2O device class, which was only needed to add sysfs attributes. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: changed I2O API to create I2O messages in kernel memoryMarkus Lidel
Changed the I2O API to create I2O messages first in kernel memory and then transfer it at once over the PCI bus instead of sending each quad-word over the PCI bus. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] I2O: remove i2o_device_classDmitry Torokhov
I2O: cleanup - remove i2o_device_class I2O devices reside on their own bus so there should be no reason to also have i2c_device class that mirros i2o bus. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] I2O: Clean up some pretty bad driver model abuses in the i2o codeGreg Kroah-Hartman
2005-10-28[PATCH] gfp_t: remaining bits of drivers/*Al Viro
2005-06-24[PATCH] I2O: Lindent run and replacement of printk through osm printing ↵Markus Lidel
functions Lindent run and replaced printk() through the corresponding osm_*() function Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: second code cleanup of sparse warnings and unneeded syncronizationMarkus Lidel
Changes: - Added header "core.h" for i2o_core.ko internal definitions - More sparse fixes - Changed display of TID's in sysfs attributes from XXX to 0xXXX - Use the right functions for accessing I/O and normal memory - Removed error handling of SCSI device errors and let the SCSI layer take care of it - Added new device / removed device handling to SCSI-OSM - Make status access volatile - Cleaned up activation of I2O controller - Removed unnecessary wmb() and rmb() calls - Use own struct i2o_io for I/O memory instead of struct i2o_dma Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: Adaptec specific SG_IO access, firmware access through sysfs ↵Markus Lidel
and 2400A workaround Changes: - Provide SG_IO access to BLOCK and EXECUTIVE class on Adaptec controllers - Use PRIVATE messages in SCSI-OSM because on some controllers normal SCSI class commands like READ or READ CAPACITY cause errors - Use new DMA and SG list creation function - Added workaround to limit sectors per request for Adaptec 2400A controllers Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: new sysfs attributes and Adaptec specific block device access ↵Markus Lidel
and 64-bit DMA support Changes: - Added Bus-OSM which could be used by user space programs to reset a channel on the controller - Make ioctl's in Config-OSM obsolete in prefer for sysfs attributes and move those to its own file - Added sysfs attribute for firmware read and write access for I2O controllers - Added special handling of firmware read and write access for Adaptec controllers - Added vendor id and product id as sysfs-attribute to Executive classes - Added automatic notification of LCT change handling to Exec-OSM - Added flushing function to Block-OSM for later barrier implementation - Use PRIVATE messages for Block access on Adaptec controllers, which are faster then BLOCK class access - Cleaned up support for Promise controller - New messages are now detected using the IRQ status register as suggested by the I2O spec - Added i2o_dma_high() and i2o_dma_low() functions - Added facility for SG tablesize calculation when using 32-bit and 64-bit DMA addresses - Added i2o_dma_map_single() and i2o_dma_map_sg() which could build the SG list for 32-bit as well as 64-bit DMA addresses Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: first code cleanup of spare warnings and unused functionsMarkus Lidel
Changes: - Removed unnecessary checking of NULL before calling kfree() - Make some functions static - Changed pr_debug() into osm_debug() - Use i2o_msg_in_to_virt() for getting a pointer to the message frame - Cleaned up some comments - Changed some le32_to_cpu() into readl() where necessary - Make error messages of OSM's look the same - Cleaned up error handling in i2o_block_end_request() - Removed unused error handling of failed messages in Block-OSM, which are not allowed by the I2O spec - Corrected the blocksize detection in i2o_block - Added hrt and lct sysfs-attribute to controller - Call done() function in SCSI-OSM after freeing DMA buffers - Removed unneeded variable for message size calculation in i2o_scsi_queuecommand() - Make some changes to remove sparse warnings - Reordered some functions - Cleaned up controller initialization - Replaced some magic numbers by defines - Removed unnecessary dma_sync_single_for_cpu() call on coherent DMA - Removed some unused fields in i2o_controller and removed some unused functions Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: bugfixes and compability enhancementsMarkus Lidel
Changes: - Fixed sysfs bug where user and parent links where added to the I2O device itself - Fixed bug when calculating TID for the event handler and cleaned up the workflow of i2o_driver_dispatch() - Fixed oops when no I2O device could be found for an event delivered to Exec-OSM - Fixed initialization of spinlock in Exec-OSM - Fixed memory leak in i2o_cfg_passthru() and i2o_cfg_passthru() - Removed MTRR support - Added PCI ID of Promise SX6000 with firmware >= 1.20.x.x - Turn of caching for ioremapped memory of in_queue - Added initialization sequence for Promise controllers - Moved definition of u8 / u16 / u32 for raidutils before first use Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
