path: root/include/linux/i2c-id.h
2008-07-20V4L/DVB (8246): tvaudio: Stop I2C driver ID abuseJean Delvare
The tvaudio driver is using "official" I2C device IDs for internal purpose. There must be some historical reason behind this but anyway, it shouldn't do that. As the stored values are never used, the easiest way to fix the problem is simply to remove them altogether. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8245): ovcamchip: Delete stray I2C bus IDJean Delvare
I2C_HW_SMBUS_OVFX2 is referenced in ovcamchip_core.c, but no bus uses this driver ID, so we can remove the reference. As far as I can see, the Cypress FX2 webcam is handled by a different driver (dvb-usb). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-14i2c-dev: Delete empty detach_client callbackJean Delvare
Implementing detach_client is optional, so there is no point in an empty implementation. Likewise, i2c driver IDs are optional, and we don't need one. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Remove 3 deprecated bus driversAdrian Bunk
This patch contains the scheduled removal of i2c-i810, i2c-prosavage and i2c-savage4. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Drop unused RTC driver IDsJean Delvare
The x1208, pcf8563 and isl1208 RTC drivers have been converted to new-style i2c drivers, so they no longer use I2C driver IDs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <a.zummo@towertech.it>
2008-04-24V4L/DVB (7620): Adding support for a new i2c bridge typeSteven Toth
Adding support for a new i2c bridge type Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-07hwmon: Discard useless I2C driver IDsJean Delvare
Many I2C hwmon drivers define a driver ID but no other code references these, meaning that they are useless. Discard them, along with a few IDs which are defined but never used at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (w83781d) Misc cleanupsJean Delvare
* Drop unused defines * Drop unused driver ID * Remove trailing whitespace Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (gl520sm) Various cleanupsJean Delvare
* Drop trailing spaces * Drop unused driver ID * Drop stray backslashes in macros * Rename new_client to client * Drop redundant initializations to 0 Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (gl518sm) Various cleanupsJean Delvare
* Drop history, it doesn't belong there * Drop unused struct member * Drop bogus struct member comment * Drop unused driver ID * Rename new_client to client * Drop redundant initializations to 0 * Drop useless cast * Drop trailing space * Fix comment * Drop duplicate comment Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-01-27i2c: Discard unused driver IDsJean Delvare
Discard all I2C driver IDs that aren't used anywhere. That's not just a couple of them, but more like 49 or one quarter of all defined IDs! And this is just a first pass, next will come all IDs that are set but never used, or used but never set. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: some overdue driver removalAdrian Bunk
This patch contains the overdue removal of three I2C drivers. [JD: In fact only i2c-ixp4xx can be removed at the moment, the other two platforms don't implement the generic GPIO layer yet.] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: the scheduled I2C RTC driver removalAdrian Bunk
This patch contains the scheduled removal of legacy I2C RTC drivers with replacement drivers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-25V4L/DVB (6868): i2c-id.h: add I2C_DRIVERID_CS5345Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6487): i2c-id: add M52790 driver IDHans Verkuil
2008-01-14i2c: Driver IDs are optionalJean Delvare
Document the fact that I2C driver IDs are optional. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-16[ALSA] ASoC CS4270 codec device driverTimur Tabi
This patch adds ALSA SoC support for the Cirrus Logic CS4270 codec. The following features are suppored: 1) Stand-alone and software mode 2) Software mode via I2C only 3) Master mode, not Slave 4) No power management Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-09V4L/DVB (6149): Add I2C_HW_B_CX23885 for Conexant 23885/23887 PCIe bridgeSteven Toth
Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5929): Add vp27smpx driverHans Verkuil
This device is internal to the Panasonic VP27S tuner and is used to set the mono/stereo/bilingual setting of the tuner. It is used by two Japanese cx23416-based cards. Signed-off-by: Takahiro Adachi <tadachi@tadachi-net.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-20[ALSA] ASoC S3C24xx machine drivers - I2C ID for LM4857Liam Girdwood
This patch adds I2C ID for the LM4857 audio amp and corrects the spacing of the WM8731, WM8750 and WM8753 ID's. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] SoC WM8753 codec supportLiam Girdwood
This patch series adds support for the WM8753 codec as found on the OpenMoko Neo 1973 (other Neo 1973 and Samsung S3C24xx patches to follow today) as well other new devices. Features:- o HiFi and Voice DAI supported (inc runtime switching of DAI mode) o DAPM o All mixers o PLL calculator o 16,20 and 24bit samples. o WM8753 I2C ID added to include/linux/i2c-id.h From: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Harald Welte <laforge@openmoko.org> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Seth Forshee <seth.forshee@gmail.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-01i2c: Blackfin Two Wire Interface driverBryan Wu
The i2c linux driver for blackfin architecture which supports blackfin on-chip TWI controller i2c operation. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Reviewed-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Add IDs to adaptersStephen Hemminger
IDs have been defined but not used by most of the I2C adapters. By having a unique ID, clients can check for correct connection during probe. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Update the list of bus IDsJean Delvare
* The Voodoo3 has no SMBus, it has two bit-banged busses which already have an ID assigned (I2C_HW_B_VOO). * The i2c-ipmi bus driver was a non-sense, it'll never be ported to Linux 2.6. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Yani Ioannou <yani.ioannou@gmail.com>
2007-02-09[ALSA] ASoC codecs: WM8750 supportRichard Purdie
This patch adds ASoC support for the WM8750 codec. Supported features:- o Capture/Playback/Sidetone/Bypass. o 16 & 24 bit audio. o 8k - 96k sample rates. o DAPM. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC codecs: WM8731 supportRichard Purdie
This patch adds ASoC support for the WM8731 codec. Supported features:- o Capture/Playback/Sidetone/Bypass. o 16 & 24 bit audio. o 8k - 96k sample rates. o DAPM. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-13Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: Add MAINTAINERS entry for new ams driver hwmon: New AMS hardware monitoring driver hwmon/w83793: Add documentation and maintainer hwmon: New Winbond W83793 hardware monitoring driver hwmon: Update Rudolf Marek's e-mail address hwmon/f71805f: Fix the device address decoding hwmon/f71805f: Always create all fan inputs hwmon/f71805f: Add support for the Fintek F71872F/FG chip hwmon: New PC87427 hardware monitoring driver hwmon/it87: Remove the SMBus interface support hwmon/hdaps: Update the list of supported devices hwmon/hdaps: Move the DMI detection data to .data hwmon/pc87360: Autodetect the VRM version hwmon/f71805f: Document the fan control features hwmon/f71805f: Add support for "speed mode" fan speed control hwmon/f71805f: Support DC fan speed control mode hwmon/f71805f: Let the user adjust the PWM base frequency hwmon/f71805f: Add manual fan speed control hwmon/f71805f: Store the fan control registers
2006-12-12Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Fix OMAP clock prescaler to match the comment i2c: Refactor a kfree in i2c-dev i2c: Fix return value check in i2c-dev i2c: Enable PEC on more i2c-i801 devices i2c: Discard the i2c algo del_bus wrappers i2c: New ARM Versatile/Realview bus driver i2c: fix broken ds1337 initialization i2c: i2c-i801 documentation update i2c: Use the __ATTR macro where possible i2c: Whitespace cleanups i2c: Use put_user instead of copy_to_user where possible i2c: New Atmel AT91 bus driver i2c: Add support for nested i2c bus locking i2c: Cleanups to the i2c-nforce2 bus driver i2c: Add request/release_mem_region to i2c-ibm_iic bus driver i2c: New Philips PNX bus driver i2c: Delete the broken i2c-ite bus driver i2c: Update the list of driver IDs i2c: Fix documentation typos
2006-12-12hwmon/it87: Remove the SMBus interface supportJean Delvare
This interface was useless as the LPC ISA-like interface is always available, is faster, and is more reliable. This cuts the driver size by some 20%. This change is also required to later convert the it87 driver to a platform driver, so that we can get rid of i2c-isa in a near future. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Whitespace cleanupsDavid Brownell
Remove extraneous whitespace from various i2c headers and core files, like space-before-tab and whitespace at end of line. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Delete the broken i2c-ite bus driverJean Delvare
The rest of the ITE8172 support was already removed from MIPS tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-10i2c: Update the list of driver IDsJean Delvare
* A chip driver ID was assigned to the Radeon, while it is an adapter so it needs an i2c adapter ID. * The SAA7191 is a video decoder, not encoder. * The icspll driver is dead, and will never be ported to Linux 2.6. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10V4L/DVB (4798): OmniVision OV7670 driverJonathan Corbet
This patch adds a V4L2 driver for the OmniVision OV7670 camera. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4797): Marvell 88ALP01 "cafe" driverJonathan Corbet
A driver for the Marvell M88ALP01 "CAFE" CMOS integrated camera controller. This driver has been renamed "cafe_ccic" since my previous patch set. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-30Merge branch 'intelfb-patches' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6 * 'intelfb-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6: intelfbhw.c: intelfbhw_get_p1p2 defined but not used intelfb: fix mtrr_reg signedness intelfb: update doc and Kconfig (supported devices) intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support
2006-07-14[PATCH] RTC subsystem, Add ISL1208 supportHerbert Valerio Riedel
Add support for the I2C-attached Intersil ISL1208 RTC chip. [akpm@osdl.org: cleanups, fixlets] Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03intelfb: add preliminary i2c supportDennis Munsie
[01/07] i2c: add intelfb bit algorithm id Adds the intelfb bit algorithm id to i2c-id.h. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
2006-06-25V4L/DVB (4048): Add support for the Texas Instruments TLV320AIC23B audio codecScott Alfter
Signed-off-by: Scott Alfter <salfter@ssai.us> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3916): AverMedia 6 Eyes AVS6EYES supportMartin Samuelsson
Add support for the AverMedia 6 Eyes MJPEG card. - Updated drivers/media/video/Kconfig with AVS6EYES options. - Added CONFIG_VIDEO_ZORAN_AVS6EYES to drivers/media/video/Makefile. - Added I2C_DRIVERID_BT866 and I2C_DRIVERID_KS0127 to include/linux/i2c-id.h - Added drivers/media/video/ks0127.c, imported and modified from the Marvel project. - Added drivers/media/video/ks0127.h, imported and modified from the Marvel project. - Added drivers/media/video/bt866.c, ported from a 2.4 version by Christer Weinigel. - Added AVS6EYES to drivers/media/video/zoran_card.c - Added input_mux to all cards in drivers/media/video/zoran_card.c - Added input mux module parameter to drivers/media/video/zoran_card.c - Added AVS6EYES to card_type in drivers/media/video/zoran.h - Added input_mux to card_info in drivers/media/video/zoran.h - Upped BUZ_MAX_INPUT in drivers/media/video/zoran.h from 8 to 16, as the AVS6EYES has 10. - Updated Documentation/video4linux/Zoran with information about AVS6EYES. Signed-off-by: Martin Samuelsson <sam@home.se> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-27[PATCH] RTC subsystem: I2C driver idsAlessandro Zummo
This patch adds the I2C driver ids to i2c-id.h in preparation of the I2C direct probing method. This is kept separate so that it can be integrated to Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24V4L/DVB (3598): Add bit algorithm adapter for the Conexant CX2341X boards.Hans Verkuil
2006-03-23[PATCH] i2c: Drop the i2c-frodo bus driverJean Delvare
Drop the i2c-frodo bus driver. It isn't referenced by the build system, and depends on code which was never included in 2.6 kernels. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-15V4L/DVB (3365): i2c ids for upd64031a saa717x upd64083 wm8739Tyler Trafford
- Add i2c ids for drivers: upd64031a saa717x upd64083 wm8739 Signed-off-by: Tyler Trafford <tatrafford@comcast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3234): Included advanced debug option to tvp5150.cMauro Carvalho Chehab
- Included advanced debug option to tvp5150.c - Now, advanced debug info is the first item at V4L menu. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-05[PATCH] i2c: driver ID list cleanupsJean Delvare
Cleanups to i2c driver ID list: * Remove mostly bogus comments about driver ID ranges. * Drop experimental driver IDs, as the concept is pretty broken. * Drop now unused IDs of non-I2C (ISA) drivers. * Drop a few more IDs which are no more used. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-12[PATCH] V4L/DVB: (3151) I2C ID renamed to I2C_DRIVERID_INFRAREDMauro Carvalho Chehab
I2C ID renamed to I2C_DRIVERID_INFRARED Acked-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4L: Some funcions now static and I2C hw code for IRMauro Carvalho Chehab
- Some funcions are now declared as static - Added a I2C code for InfraRed. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[ARM] 3160/1: SharpSL: Add driver for Akita specific GPIOsRichard Purdie
Patch from Richard Purdie Add a driver for the extra GPIOs found on the Sharp SL-C1000 (Akita). These GPIOs are found on a Maxim MAX7310 I2C i/o expander chip. A generic GPIO driver for the MAX7310 was attempted but this mini driver is a much simpler and much more effective solution avoiding several issues and complexity the generic driver had (as discussed on LKML). The platform device is required so the device parent can be set correctly which ensures the device is one of the last to suspend and first to resume. Whilst the i2c suspend/resume calls can be influenced, nothing guarantees this is easlier/later than the subsystems the gpios are used on which are all independent of i2c (sound, irda, video/backlight etc.). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[PATCH] v4l: 887: i2c id h updated to reflect the newer driversMauro Carvalho Chehab
- I2c-id.h Updated to reflect the newer drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 885: second round of i2c ids redefinition cleanupJean Delvare
- Second round of i2c IDs redefinition cleanup. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
