path: root/include/linux/huge_mm.h
2013-07-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "This is the powerpc changes for the 3.11 merge window. In addition to the usual bug fixes and small updates, the main highlights are: - Support for transparent huge pages by Aneesh Kumar for 64-bit server processors. This allows the use of 16M pages as transparent huge pages on kernels compiled with a 64K base page size. - Base VFIO support for KVM on power by Alexey Kardashevskiy - Wiring up of our nvram to the pstore infrastructure, including putting compressed oopses in there by Aruna Balakrishnaiah - Move, rework and improve our "EEH" (basically PCI error handling and recovery) infrastructure. It is no longer specific to pseries but is now usable by the new "powernv" platform as well (no hypervisor) by Gavin Shan. - I fixed some bugs in our math-emu instruction decoding and made it usable to emulate some optional FP instructions on processors with hard FP that lack them (such as fsqrt on Freescale embedded processors). - Support for Power8 "Event Based Branch" facility by Michael Ellerman. This facility allows what is basically "userspace interrupts" for performance monitor events. - A bunch of Transactional Memory vs. Signals bug fixes and HW breakpoint/watchpoint fixes by Michael Neuling. And more ... I appologize in advance if I've failed to highlight something that somebody deemed worth it." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) pstore: Add hsize argument in write_buf call of pstore_ftrace_call powerpc/fsl: add MPIC timer wakeup support powerpc/mpic: create mpic subsystem object powerpc/mpic: add global timer support powerpc/mpic: add irq_set_wake support powerpc/85xx: enable coreint for all the 64bit boards powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig powerpc/mpic: Add get_version API both for internal and external use powerpc: Handle both new style and old style reserve maps powerpc/hw_brk: Fix off by one error when validating DAWR region end powerpc/pseries: Support compression of oops text via pstore powerpc/pseries: Re-organise the oops compression code pstore: Pass header size in the pstore write callback powerpc/powernv: Fix iommu initialization again powerpc/pseries: Inform the hypervisor we are using EBB regs powerpc/perf: Add power8 EBB support powerpc/perf: Core EBB support for 64-bit book3s powerpc/perf: Drop MMCRA from thread_struct powerpc/perf: Don't enable if we have zero events ...
2013-06-26mm/thp: define HPAGE_PMD_* constants as BUILD_BUG() if !THPKirill A. Shutemov
Currently, HPAGE_PMD_* constans rely on PMD_SHIFT regardless of CONFIG_TRANSPARENT_HUGEPAGE. PMD_SHIFT is not defined everywhere (e.g. arm nommu case). It means we can't use anything like this in generic code: if (PageTransHuge(page)) zero_huge_user(page, 0, HPAGE_PMD_SIZE); else clear_highpage(page); For !THP case, PageTransHuge() is 0 and compiler can eliminate zero_huge_user() call. But it still need to be valid C expression, means HPAGE_PMD_SIZE has to expand to something compiler can understand. Previously, HPAGE_PMD_* were defined to BUILD_BUG() for !THP. Let's come back to it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-20mm/THP: don't use HPAGE_SHIFT in transparent hugepage codeAneesh Kumar K.V
For architectures like powerpc that support multiple explicit hugepage sizes, HPAGE_SHIFT indicate the default explicit hugepage shift. For THP to work the hugepage size should be same as PMD_SIZE. So use PMD_SHIFT directly. So move the define outside CONFIG_TRANSPARENT_HUGEPAGE #ifdef because we want to use these defines in generic code with if (pmd_trans_huge()) conditional. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-14mm: thp: Correct the HPAGE_PMD_ORDER check.Steve Capper
All Transparent Huge Pages are allocated by the buddy allocator. A compile time check is in place that fails when the order of a transparent huge page is too large to be allocated by the buddy allocator. Unfortunately that compile time check passes when: HPAGE_PMD_ORDER == MAX_ORDER ( which is incorrect as the buddy allocator can only allocate memory of order strictly less than MAX_ORDER. ) This patch updates the compile time check to fail in the above case. Signed-off-by: Steve Capper <steve.capper@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Andrew Morton <akpm@linux-foundation.org>
2013-04-29mm: thp: add split tail pages to shrink page list in page reclaimShaohua Li
In page reclaim, huge page is split. split_huge_page() adds tail pages to LRU list. Since we are reclaiming a huge page, it's better we reclaim all subpages of the huge page instead of just the head page. This patch adds split tail pages to shrink page list so the tail pages can be reclaimed soon. Before this patch, run a swap workload: thp_fault_alloc 3492 thp_fault_fallback 608 thp_collapse_alloc 6 thp_collapse_alloc_failed 0 thp_split 916 With this patch: thp_fault_alloc 4085 thp_fault_fallback 16 thp_collapse_alloc 90 thp_collapse_alloc_failed 0 thp_split 1272 fallback allocation is reduced a lot. [akpm@linux-foundation.org: fix CONFIG_SWAP=n build] Signed-off-by: Shaohua Li <shli@fusionio.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm/rmap: rename anon_vma_unlock() => anon_vma_unlock_write()Konstantin Khlebnikov
The comment in commit 4fc3f1d66b1e ("mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable") says: | Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(), | to make it clearer that it's an exclusive write-lock in | that case - suggested by Rik van Riel. But that commit renames only anon_vma_lock() Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Ingo Molnar <mingo@kernel.org> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16Merge tag 'balancenuma-v11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma Pull Automatic NUMA Balancing bare-bones from Mel Gorman: "There are three implementations for NUMA balancing, this tree (balancenuma), numacore which has been developed in tip/master and autonuma which is in aa.git. In almost all respects balancenuma is the dumbest of the three because its main impact is on the VM side with no attempt to be smart about scheduling. In the interest of getting the ball rolling, it would be desirable to see this much merged for 3.8 with the view to building scheduler smarts on top and adapting the VM where required for 3.9. The most recent set of comparisons available from different people are mel: https://lkml.org/lkml/2012/12/9/108 mingo: https://lkml.org/lkml/2012/12/7/331 tglx: https://lkml.org/lkml/2012/12/10/437 srikar: https://lkml.org/lkml/2012/12/10/397 The results are a mixed bag. In my own tests, balancenuma does reasonably well. It's dumb as rocks and does not regress against mainline. On the other hand, Ingo's tests shows that balancenuma is incapable of converging for this workloads driven by perf which is bad but is potentially explained by the lack of scheduler smarts. Thomas' results show balancenuma improves on mainline but falls far short of numacore or autonuma. Srikar's results indicate we all suffer on a large machine with imbalanced node sizes. My own testing showed that recent numacore results have improved dramatically, particularly in the last week but not universally. We've butted heads heavily on system CPU usage and high levels of migration even when it shows that overall performance is better. There are also cases where it regresses. Of interest is that for specjbb in some configurations it will regress for lower numbers of warehouses and show gains for higher numbers which is not reported by the tool by default and sometimes missed in treports. Recently I reported for numacore that the JVM was crashing with NullPointerExceptions but currently it's unclear what the source of this problem is. Initially I thought it was in how numacore batch handles PTEs but I'm no longer think this is the case. It's possible numacore is just able to trigger it due to higher rates of migration. These reports were quite late in the cycle so I/we would like to start with this tree as it contains much of the code we can agree on and has not changed significantly over the last 2-3 weeks." * tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits) mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable mm/rmap: Convert the struct anon_vma::mutex to an rwsem mm: migrate: Account a transhuge page properly when rate limiting mm: numa: Account for failed allocations and isolations as migration failures mm: numa: Add THP migration for the NUMA working set scanning fault case build fix mm: numa: Add THP migration for the NUMA working set scanning fault case. mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG mm: sched: numa: Control enabling and disabling of NUMA balancing mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships mm: numa: migrate: Set last_nid on newly allocated page mm: numa: split_huge_page: Transfer last_nid on tail page mm: numa: Introduce last_nid to the page frame sched: numa: Slowly increase the scanning period as NUMA faults are handled mm: numa: Rate limit setting of pte_numa if node is saturated mm: numa: Rate limit the amount of memory that is migrated between nodes mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting mm: numa: Migrate pages handled during a pmd_numa hinting fault mm: numa: Migrate on reference policy ...
2012-12-12thp: introduce sysfs knob to disable huge zero pageKirill A. Shutemov
By default kernel tries to use huge zero page on read page fault. It's possible to disable huge zero page by writing 0 or enable it back by writing 1: echo 0 >/sys/kernel/mm/transparent_hugepage/khugepaged/use_zero_page echo 1 >/sys/kernel/mm/transparent_hugepage/khugepaged/use_zero_page Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12thp: change split_huge_page_pmd() interfaceKirill A. Shutemov
Pass vma instead of mm and add address parameter. In most cases we already have vma on the stack. We provides split_huge_page_pmd_mm() for few cases when we have mm, but not vma. This change is preparation to huge zero pmd splitting implementation. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: thp: set the accessed flag for old pages on access faultWill Deacon
On x86 memory accesses to pages without the ACCESSED flag set result in the ACCESSED flag being set automatically. With the ARM architecture a page access fault is raised instead (and it will continue to be raised until the ACCESSED flag is set for the appropriate PTE/PMD). For normal memory pages, handle_pte_fault will call pte_mkyoung (effectively setting the ACCESSED flag). For transparent huge pages, pmd_mkyoung will only be called for a write fault. This patch ensures that faults on transparent hugepages which do not result in a CoW update the access flags for the faulting pmd. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Ni zhan Chen <nizhan.chen@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalableIngo Molnar
rmap_walk_anon() and try_to_unmap_anon() appears to be too careful about locking the anon vma: while it needs protection against anon vma list modifications, it does not need exclusive access to the list itself. Transforming this exclusive lock to a read-locked rwsem removes a global lock from the hot path of page-migration intense threaded workloads which can cause pathological performance like this: 96.43% process 0 [kernel.kallsyms] [k] perf_trace_sched_switch | --- perf_trace_sched_switch __schedule schedule schedule_preempt_disabled __mutex_lock_common.isra.6 __mutex_lock_slowpath mutex_lock | |--50.61%-- rmap_walk | move_to_new_page | migrate_pages | migrate_misplaced_page | __do_numa_page.isra.69 | handle_pte_fault | handle_mm_fault | __do_page_fault | do_page_fault | page_fault | __memset_sse2 | | | --100.00%-- worker_thread | | | --100.00%-- start_thread | --49.39%-- page_lock_anon_vma try_to_unmap_anon try_to_unmap migrate_pages migrate_misplaced_page __do_numa_page.isra.69 handle_pte_fault handle_mm_fault __do_page_fault do_page_fault page_fault __memset_sse2 | --100.00%-- worker_thread start_thread With this change applied the profile is now nicely flat and there's no anon-vma related scheduling/blocking. Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(), to make it clearer that it's an exclusive write-lock in that case - suggested by Rik van Riel. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-12-11mm: mempolicy: Implement change_prot_numa() in terms of change_protection()Mel Gorman
This patch converts change_prot_numa() to use change_protection(). As pte_numa and friends check the PTE bits directly it is necessary for change_protection() to use pmd_mknuma(). Hence the required modifications to change_protection() are a little clumsy but the end result is that most of the numa page table helpers are just one or two instructions. Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-12-11mm: mempolicy: Use _PAGE_NUMA to migrate pagesMel Gorman
Note: Based on "mm/mpol: Use special PROT_NONE to migrate pages" but sufficiently different that the signed-off-bys were dropped Combine our previous _PAGE_NUMA, mpol_misplaced and migrate_misplaced_page() pieces into an effective migrate on fault scheme. Note that (on x86) we rely on PROT_NONE pages being !present and avoid the TLB flush from try_to_unmap(TTU_MIGRATION). This greatly improves the page-migration performance. Based-on-work-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-12-11mm: numa: Create basic numa page hinting infrastructureMel Gorman
Note: This patch started as "mm/mpol: Create special PROT_NONE infrastructure" and preserves the basic idea but steals *very* heavily from "autonuma: numa hinting page faults entry points" for the actual fault handlers without the migration parts. The end result is barely recognisable as either patch so all Signed-off and Reviewed-bys are dropped. If Peter, Ingo and Andrea are ok with this version, I will re-add the signed-offs-by to reflect the history. In order to facilitate a lazy -- fault driven -- migration of pages, create a special transient PAGE_NUMA variant, we can then use the 'spurious' protection faults to drive our migrations from. The meaning of PAGE_NUMA depends on the architecture but on x86 it is effectively PROT_NONE. Actual PROT_NONE mappings will not generate these NUMA faults for the reason that the page fault code checks the permission on the VMA (and will throw a segmentation fault on actual PROT_NONE mappings), before it ever calls handle_mm_fault. [dhillf@gmail.com: Fix typo] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com>
2012-10-09mm, thp: fix mapped pages avoiding unevictable list on mlockDavid Rientjes
When a transparent hugepage is mapped and it is included in an mlock() range, follow_page() incorrectly avoids setting the page's mlock bit and moving it to the unevictable lru. This is evident if you try to mlock(), munlock(), and then mlock() a range again. Currently: #define MAP_SIZE (4 << 30) /* 4GB */ void *ptr = mmap(NULL, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS, 0, 0); mlock(ptr, MAP_SIZE); $ grep -E "Unevictable|Inactive\(anon" /proc/meminfo Inactive(anon): 6304 kB Unevictable: 4213924 kB munlock(ptr, MAP_SIZE); Inactive(anon): 4186252 kB Unevictable: 19652 kB mlock(ptr, MAP_SIZE); Inactive(anon): 4198556 kB Unevictable: 21684 kB Notice that less than 2MB was added to the unevictable list; this is because these pages in the range are not transparent hugepages since the 4GB range was allocated with mmap() and has no specific alignment. If posix_memalign() were used instead, unevictable would not have grown at all on the second mlock(). The fix is to call mlock_vma_page() so that the mlock bit is set and the page is added to the unevictable list. With this patch: mlock(ptr, MAP_SIZE); Inactive(anon): 4056 kB Unevictable: 4213940 kB munlock(ptr, MAP_SIZE); Inactive(anon): 4198268 kB Unevictable: 19636 kB mlock(ptr, MAP_SIZE); Inactive(anon): 4008 kB Unevictable: 4213940 kB Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp: remove assumptions on pgtable_t typeGerald Schaefer
The thp page table pre-allocation code currently assumes that pgtable_t is of type "struct page *". This may not be true for all architectures, so this patch removes that assumption by replacing the functions prepare_pmd_huge_pte() and get_pmd_huge_pte() with two new functions that can be defined architecture-specific. It also removes two VM_BUG_ON checks for page_count() and page_mapcount() operating on a pgtable_t. Apart from the VM_BUG_ON removal, there will be no functional change introduced by this patch. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: move is_vma_temporary_stack() declaration to huge_mm.hAlex Shi
When transparent_hugepage_enabled() is used outside mm/, such as in arch/x86/xx/tlb.c: + if (!cpu_has_invlpg || vma->vm_flags & VM_HUGETLB + || transparent_hugepage_enabled(vma)) { + flush_tlb_mm(vma->vm_mm); is_vma_temporary_stack() isn't referenced in huge_mm.h, so it has compile errors: arch/x86/mm/tlb.c: In function `flush_tlb_range': arch/x86/mm/tlb.c:324:4: error: implicit declaration of function `is_vma_temporary_stack' [-Werror=implicit-function-declaration] Since is_vma_temporay_stack() is just used in rmap.c and huge_memory.c, it is better to move it to huge_mm.h from rmap.h to avoid such errors. Signed-off-by: Alex Shi <alex.shi@intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGENaoya Horiguchi
These macros will be used in a later patch, where all usages are expected to be optimized away without #ifdef CONFIG_TRANSPARENT_HUGEPAGE. But to detect unexpected usages, we convert the existing BUG() to BUILD_BUG(). [akpm@linux-foundation.org: fix build in mm/pgtable-generic.c] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21thp: optimize away unnecessary page table lockingNaoya Horiguchi
Currently when we check if we can handle thp as it is or we need to split it into regular sized pages, we hold page table lock prior to check whether a given pmd is mapping thp or not. Because of this, when it's not "huge pmd" we suffer from unnecessary lock/unlock overhead. To remove it, this patch introduces a optimized check function and replace several similar logics with it. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Rientjes <rientjes@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12thp: add tlb_remove_pmd_tlb_entryShaohua Li
We have tlb_remove_tlb_entry to indicate a pte tlb flush entry should be flushed, but not a corresponding API for pmd entry. This isn't a problem so far because THP is only for x86 currently and tlb_flush() under x86 will flush entire TLB. But this is confusion and could be missed if thp is ported to other arch. Also convert tlb->need_flush = 1 to a VM_BUG_ON(!tlb->need_flush) in __tlb_remove_page() as suggested by Andrea Arcangeli. The __tlb_remove_page() function is supposed to be called after tlb_remove_xxx_tlb_entry() and we can catch any misuse. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31thp: mremap support and TLB optimizationAndrea Arcangeli
This adds THP support to mremap (decreases the number of split_huge_page() calls). Here are also some benchmarks with a proggy like this: === #define _GNU_SOURCE #include <sys/mman.h> #include <stdlib.h> #include <stdio.h> #include <string.h> #include <sys/time.h> #define SIZE (5UL*1024*1024*1024) int main() { static struct timeval oldstamp, newstamp; long diffsec; char *p, *p2, *p3, *p4; if (posix_memalign((void **)&p, 2*1024*1024, SIZE)) perror("memalign"), exit(1); if (posix_memalign((void **)&p2, 2*1024*1024, SIZE)) perror("memalign"), exit(1); if (posix_memalign((void **)&p3, 2*1024*1024, 4096)) perror("memalign"), exit(1); memset(p, 0xff, SIZE); memset(p2, 0xff, SIZE); memset(p3, 0x77, 4096); gettimeofday(&oldstamp, NULL); p4 = mremap(p, SIZE, SIZE, MREMAP_FIXED|MREMAP_MAYMOVE, p3); gettimeofday(&newstamp, NULL); diffsec = newstamp.tv_sec - oldstamp.tv_sec; diffsec = newstamp.tv_usec - oldstamp.tv_usec + 1000000 * diffsec; printf("usec %ld\n", diffsec); if (p == MAP_FAILED || p4 != p3) //if (p == MAP_FAILED) perror("mremap"), exit(1); if (memcmp(p4, p2, SIZE)) printf("mremap bug\n"), exit(1); printf("ok\n"); return 0; } === THP on Performance counter stats for './largepage13' (3 runs): 69195836 dTLB-loads ( +- 3.546% ) (scaled from 50.30%) 60708 dTLB-load-misses ( +- 11.776% ) (scaled from 52.62%) 676266476 dTLB-stores ( +- 5.654% ) (scaled from 69.54%) 29856 dTLB-store-misses ( +- 4.081% ) (scaled from 89.22%) 1055848782 iTLB-loads ( +- 4.526% ) (scaled from 80.18%) 8689 iTLB-load-misses ( +- 2.987% ) (scaled from 58.20%) 7.314454164 seconds time elapsed ( +- 0.023% ) THP off Performance counter stats for './largepage13' (3 runs): 1967379311 dTLB-loads ( +- 0.506% ) (scaled from 60.59%) 9238687 dTLB-load-misses ( +- 22.547% ) (scaled from 61.87%) 2014239444 dTLB-stores ( +- 0.692% ) (scaled from 60.40%) 3312335 dTLB-store-misses ( +- 7.304% ) (scaled from 67.60%) 6764372065 iTLB-loads ( +- 0.925% ) (scaled from 79.00%) 8202 iTLB-load-misses ( +- 0.475% ) (scaled from 70.55%) 9.693655243 seconds time elapsed ( +- 0.069% ) grep thp /proc/vmstat thp_fault_alloc 35849 thp_fault_fallback 0 thp_collapse_alloc 3 thp_collapse_alloc_failed 0 thp_split 0 thp_split 0 confirms no thp split despite plenty of hugepages allocated. The measurement of only the mremap time (so excluding the 3 long memset and final long 10GB memory accessing memcmp): THP on usec 14824 usec 14862 usec 14859 THP off usec 256416 usec 255981 usec 255847 With an older kernel without the mremap optimizations (the below patch optimizes the non THP version too). THP on usec 392107 usec 390237 usec 404124 THP off usec 444294 usec 445237 usec 445820 I guess with a threaded program that sends more IPI on large SMP it'd create an even larger difference. All debug options are off except DEBUG_VM to avoid skewing the results. The only problem for native 2M mremap like it happens above both the source and destination address must be 2M aligned or the hugepmd can't be moved without a split but that is an hardware limitation. [akpm@linux-foundation.org: coding-style nitpicking] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: convert anon_vma->lock to a mutexPeter Zijlstra
Straightforward conversion of anon_vma->lock to a mutex. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-28mm: thp: fix /dev/zero MAP_PRIVATE and vm_flags cleanupsAndrea Arcangeli
The huge_memory.c THP page fault was allowed to run if vm_ops was null (which would succeed for /dev/zero MAP_PRIVATE, as the f_op->mmap wouldn't setup a special vma->vm_ops and it would fallback to regular anonymous memory) but other THP logics weren't fully activated for vmas with vm_file not NULL (/dev/zero has a not NULL vma->vm_file). So this removes the vm_file checks so that /dev/zero also can safely use THP (the other albeit safer approach to fix this bug would have been to prevent the THP initial page fault to run if vm_file was set). After removing the vm_file checks, this also makes huge_memory.c stricter in khugepaged for the DEBUG_VM=y case. It doesn't replace the vm_file check with a is_pfn_mapping check (but it keeps checking for VM_PFNMAP under VM_BUG_ON) because for a is_cow_mapping() mapping VM_PFNMAP should only be allowed to exist before the first page fault, and in turn when vma->anon_vma is null (so preventing khugepaged registration). So I tend to think the previous comment saying if vm_file was set, VM_PFNMAP might have been set and we could still be registered in khugepaged (despite anon_vma was not NULL to be registered in khugepaged) was too paranoid. The is_linear_pfn_mapping check is also I think superfluous (as described by comment) but under DEBUG_VM it is safe to stay. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=33682 Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Caspar Zhang <bugs@casparzhang.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: <stable@kernel.org> [2.6.38.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-15thp: prevent hugepages during args/env copying into the user stackAndrea Arcangeli
Transparent hugepages can only be created if rmap is fully functional. So we must prevent hugepages to be created while is_vma_temporary_stack() is true. This also optmizes away some harmless but unnecessary setting of khugepaged_scan.address and it switches some BUG_ON to VM_BUG_ON. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add compound_trans_head() helperAndrea Arcangeli
Cleanup some code with common compound_trans_head helper. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: khugepaged: make khugepaged aware about madviseAndrea Arcangeli
MADV_HUGEPAGE and MADV_NOHUGEPAGE were fully effective only if run after mmap and before touching the memory. While this is enough for most usages, it's little effort to make madvise more dynamic at runtime on an existing mapping by making khugepaged aware about madvise. MADV_HUGEPAGE: register in khugepaged immediately without waiting a page fault (that may not ever happen if all pages are already mapped and the "enabled" knob was set to madvise during the initial page faults). MADV_NOHUGEPAGE: skip vmas marked VM_NOHUGEPAGE in khugepaged to stop collapsing pages where not needed. [akpm@linux-foundation.org: tweak comment] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: madvise(MADV_NOHUGEPAGE)Andrea Arcangeli
Add madvise MADV_NOHUGEPAGE to mark regions that are not important to be hugepage backed. Return -EINVAL if the vma is not of an anonymous type, or the feature isn't built into the kernel. Never silently return success. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: fix anon memory statistics with transparent hugepagesRik van Riel
Count each transparent hugepage as HPAGE_PMD_NR pages in the LRU statistics, so the Active(anon) and Inactive(anon) statistics in /proc/meminfo are correct. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: avoid breaking huge pmd invariants in case of vma_adjust failuresAndrea Arcangeli
An huge pmd can only be mapped if the corresponding 2M virtual range is fully contained in the vma. At times the VM calls split_vma twice, if the first split_vma succeeds and the second fail, the first split_vma remains in effect and it's not rolled back. For split_vma or vma_adjust to fail an allocation failure is needed so it's a very unlikely event (the out of memory killer would normally fire before any allocation failure is visible to kernel and userland and if an out of memory condition happens it's unlikely to happen exactly here). Nevertheless it's safer to ensure that no huge pmd can be left around if the vma is adjusted in a way that can't fit hugepages anymore at the new vm_start/vm_end address. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: mprotect: transparent huge page supportJohannes Weiner
Natively handle huge pmds when changing page tables on behalf of mprotect(). I left out update_mmu_cache() because we do not need it on x86 anyway but more importantly the interface works on ptes, not pmds. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: mincore transparent hugepage supportJohannes Weiner
Handle transparent huge page pmd entries natively instead of splitting them into subpages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: khugepagedAndrea Arcangeli
Add khugepaged to relocate fragmented pages into hugepages if new hugepages become available. (this is indipendent of the defrag logic that will have to make new hugepages available) The fundamental reason why khugepaged is unavoidable, is that some memory can be fragmented and not everything can be relocated. So when a virtual machine quits and releases gigabytes of hugepages, we want to use those freely available hugepages to create huge-pmd in the other virtual machines that may be running on fragmented memory, to maximize the CPU efficiency at all times. The scan is slow, it takes nearly zero cpu time, except when it copies data (in which case it means we definitely want to pay for that cpu time) so it seems a good tradeoff. In addition to the hugepages being released by other process releasing memory, we have the strong suspicion that the performance impact of potentially defragmenting hugepages during or before each page fault could lead to more performance inconsistency than allocating small pages at first and having them collapsed into large pages later... if they prove themselfs to be long lived mappings (khugepaged scan is slow so short lived mappings have low probability to run into khugepaged if compared to long lived mappings). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: madvise(MADV_HUGEPAGE)Andrea Arcangeli
Add madvise MADV_HUGEPAGE to mark regions that are important to be hugepage backed. Return -EINVAL if the vma is not of an anonymous type, or the feature isn't built into the kernel. Never silently return success. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: transparent hugepage coreAndrea Arcangeli
Lately I've been working to make KVM use hugepages transparently without the usual restrictions of hugetlbfs. Some of the restrictions I'd like to see removed: 1) hugepages have to be swappable or the guest physical memory remains locked in RAM and can't be paged out to swap 2) if a hugepage allocation fails, regular pages should be allocated instead and mixed in the same vma without any failure and without userland noticing 3) if some task quits and more hugepages become available in the buddy, guest physical memory backed by regular pages should be relocated on hugepages automatically in regions under madvise(MADV_HUGEPAGE) (ideally event driven by waking up the kernel deamon if the order=HPAGE_PMD_SHIFT-PAGE_SHIFT list becomes not null) 4) avoidance of reservation and maximization of use of hugepages whenever possible. Reservation (needed to avoid runtime fatal faliures) may be ok for 1 machine with 1 database with 1 database cache with 1 database cache size known at boot time. It's definitely not feasible with a virtualization hypervisor usage like RHEV-H that runs an unknown number of virtual machines with an unknown size of each virtual machine with an unknown amount of pagecache that could be potentially useful in the host for guest not using O_DIRECT (aka cache=off). hugepages in the virtualization hypervisor (and also in the guest!) are much more important than in a regular host not using virtualization, becasue with NPT/EPT they decrease the tlb-miss cacheline accesses from 24 to 19 in case only the hypervisor uses transparent hugepages, and they decrease the tlb-miss cacheline accesses from 19 to 15 in case both the linux hypervisor and the linux guest both uses this patch (though the guest will limit the addition speedup to anonymous regions only for now...). Even more important is that the tlb miss handler is much slower on a NPT/EPT guest than for a regular shadow paging or no-virtualization scenario. So maximizing the amount of virtual memory cached by the TLB pays off significantly more with NPT/EPT than without (even if there would be no significant speedup in the tlb-miss runtime). The first (and more tedious) part of this work requires allowing the VM to handle anonymous hugepages mixed with regular pages transparently on regular anonymous vmas. This is what this patch tries to achieve in the least intrusive possible way. We want hugepages and hugetlb to be used in a way so that all applications can benefit without changes (as usual we leverage the KVM virtualization design: by improving the Linux VM at large, KVM gets the performance boost too). The most important design choice is: always fallback to 4k allocation if the hugepage allocation fails! This is the _very_ opposite of some large pagecache patches that failed with -EIO back then if a 64k (or similar) allocation failed... Second important decision (to reduce the impact of the feature on the existing pagetable handling code) is that at any time we can split an hugepage into 512 regular pages and it has to be done with an operation that can't fail. This way the reliability of the swapping isn't decreased (no need to allocate memory when we are short on memory to swap) and it's trivial to plug a split_huge_page* one-liner where needed without polluting the VM. Over time we can teach mprotect, mremap and friends to handle pmd_trans_huge natively without calling split_huge_page*. The fact it can't fail isn't just for swap: if split_huge_page would return -ENOMEM (instead of the current void) we'd need to rollback the mprotect from the middle of it (ideally including undoing the split_vma) which would be a big change and in the very wrong direction (it'd likely be simpler not to call split_huge_page at all and to teach mprotect and friends to handle hugepages instead of rolling them back from the middle). In short the very value of split_huge_page is that it can't fail. The collapsing and madvise(MADV_HUGEPAGE) part will remain separated and incremental and it'll just be an "harmless" addition later if this initial part is agreed upon. It also should be noted that locking-wise replacing regular pages with hugepages is going to be very easy if compared to what I'm doing below in split_huge_page, as it will only happen when page_count(page) matches page_mapcount(page) if we can take the PG_lock and mmap_sem in write mode. collapse_huge_page will be a "best effort" that (unlike split_huge_page) can fail at the minimal sign of trouble and we can try again later. collapse_huge_page will be similar to how KSM works and the madvise(MADV_HUGEPAGE) will work similar to madvise(MADV_MERGEABLE). The default I like is that transparent hugepages are used at page fault time. This can be changed with /sys/kernel/mm/transparent_hugepage/enabled. The control knob can be set to three values "always", "madvise", "never" which mean respectively that hugepages are always used, or only inside madvise(MADV_HUGEPAGE) regions, or never used. /sys/kernel/mm/transparent_hugepage/defrag instead controls if the hugepage allocation should defrag memory aggressively "always", only inside "madvise" regions, or "never". The pmd_trans_splitting/pmd_trans_huge locking is very solid. The put_page (from get_user_page users that can't use mmu notifier like O_DIRECT) that runs against a __split_huge_page_refcount instead was a pain to serialize in a way that would result always in a coherent page count for both tail and head. I think my locking solution with a compound_lock taken only after the page_first is valid and is still a PageHead should be safe but it surely needs review from SMP race point of view. In short there is no current existing way to serialize the O_DIRECT final put_page against split_huge_page_refcount so I had to invent a new one (O_DIRECT loses knowledge on the mapping status by the time gup_fast returns so...). And I didn't want to impact all gup/gup_fast users for now, maybe if we change the gup interface substantially we can avoid this locking, I admit I didn't think too much about it because changing the gup unpinning interface would be invasive. If we ignored O_DIRECT we could stick to the existing compound refcounting code, by simply adding a get_user_pages_fast_flags(foll_flags) where KVM (and any other mmu notifier user) would call it without FOLL_GET (and if FOLL_GET isn't set we'd just BUG_ON if nobody registered itself in the current task mmu notifier list yet). But O_DIRECT is fundamental for decent performance of virtualized I/O on fast storage so we can't avoid it to solve the race of put_page against split_huge_page_refcount to achieve a complete hugepage feature for KVM. Swap and oom works fine (well just like with regular pages ;). MMU notifier is handled transparently too, with the exception of the young bit on the pmd, that didn't have a range check but I think KVM will be fine because the whole point of hugepages is that EPT/NPT will also use a huge pmd when they notice gup returns pages with PageCompound set, so they won't care of a range and there's just the pmd young bit to check in that case. NOTE: in some cases if the L2 cache is small, this may slowdown and waste memory during COWs because 4M of memory are accessed in a single fault instead of 8k (the payoff is that after COW the program can run faster). So we might want to switch the copy_huge_page (and clear_huge_page too) to not temporal stores. I also extensively researched ways to avoid this cache trashing with a full prefault logic that would cow in 8k/16k/32k/64k up to 1M (I can send those patches that fully implemented prefault) but I concluded they're not worth it and they add an huge additional complexity and they remove all tlb benefits until the full hugepage has been faulted in, to save a little bit of memory and some cache during app startup, but they still don't improve substantially the cache-trashing during startup if the prefault happens in >4k chunks. One reason is that those 4k pte entries copied are still mapped on a perfectly cache-colored hugepage, so the trashing is the worst one can generate in those copies (cow of 4k page copies aren't so well colored so they trashes less, but again this results in software running faster after the page fault). Those prefault patches allowed things like a pte where post-cow pages were local 4k regular anon pages and the not-yet-cowed pte entries were pointing in the middle of some hugepage mapped read-only. If it doesn't payoff substantially with todays hardware it will payoff even less in the future with larger l2 caches, and the prefault logic would blot the VM a lot. If one is emebdded transparent_hugepage can be disabled during boot with sysfs or with the boot commandline parameter transparent_hugepage=0 (or transparent_hugepage=2 to restrict hugepages inside madvise regions) that will ensure not a single hugepage is allocated at boot time. It is simple enough to just disable transparent hugepage globally and let transparent hugepages be allocated selectively by applications in the MADV_HUGEPAGE region (both at page fault time, and if enabled with the collapse_huge_page too through the kernel daemon). This patch supports only hugepages mapped in the pmd, archs that have smaller hugepages will not fit in this patch alone. Also some archs like power have certain tlb limits that prevents mixing different page size in the same regions so they will not fit in this framework that requires "graceful fallback" to basic PAGE_SIZE in case of physical memory fragmentation. hugetlbfs remains a perfect fit for those because its software limits happen to match the hardware limits. hugetlbfs also remains a perfect fit for hugepage sizes like 1GByte that cannot be hoped to be found not fragmented after a certain system uptime and that would be very expensive to defragment with relocation, so requiring reservation. hugetlbfs is the "reservation way", the point of transparent hugepages is not to have any reservation at all and maximizing the use of cache and hugepages at all times automatically. Some performance result: vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largep ages3 memset page fault 1566023 memset tlb miss 453854 memset second tlb miss 453321 random access tlb miss 41635 random access second tlb miss 41658 vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largepages3 memset page fault 1566471 memset tlb miss 453375 memset second tlb miss 453320 random access tlb miss 41636 random access second tlb miss 41637 vmx andrea # ./largepages3 memset page fault 1566642 memset tlb miss 453417 memset second tlb miss 453313 random access tlb miss 41630 random access second tlb miss 41647 vmx andrea # ./largepages3 memset page fault 1566872 memset tlb miss 453418 memset second tlb miss 453315 random access tlb miss 41618 random access second tlb miss 41659 vmx andrea # echo 0 > /proc/sys/vm/transparent_hugepage vmx andrea # ./largepages3 memset page fault 2182476 memset tlb miss 460305 memset second tlb miss 460179 random access tlb miss 44483 random access second tlb miss 44186 vmx andrea # ./largepages3 memset page fault 2182791 memset tlb miss 460742 memset second tlb miss 459962 random access tlb miss 43981 random access second tlb miss 43988 ============ #include <stdio.h> #include <stdlib.h> #include <string.h> #include <sys/time.h> #define SIZE (3UL*1024*1024*1024) int main() { char *p = malloc(SIZE), *p2; struct timeval before, after; gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset page fault %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset second tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); for (p2 = p; p2 < p+SIZE; p2 += 4096) *p2 = 0; gettimeofday(&after, NULL); printf("random access tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); for (p2 = p; p2 < p+SIZE; p2 += 4096) *p2 = 0; gettimeofday(&after, NULL); printf("random access second tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); return 0; } ============ Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
