path: root/include/linux/hdlc.h
2007-04-28Generic HDLC sparse annotationsKrzysztof Halasa
Sparse annotations, including two minor bugfixes. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-26[PATCH] Modularize generic HDLCKrzysztof Halasa
This patch enables building of individual WAN protocol support routines (parts of generic HDLC) as separate modules. All protocol-private definitions are moved from hdlc.h file to protocol drivers. User-space interface and interface between generic HDLC and underlying low-level HDLC drivers are unchanged. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-12[WAN]: converting generic HDLC to use netif_dormant*()Krzysztof Halasa
This patch converts generic HDLC (and WAN drivers using it) from hdlc_set_carrier() to netif_dormant*() interface. WAN hardware drivers should now use netif_carrier_on|off() like other network drivers. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-22[PATCH] WAN: register_hdlc_device() doesn't need dev_alloc_name()Krzysztof Halasa
David Boggs noticed that register_hdlc_device() no longer needs to call dev_alloc_name() as it's called by register_netdev(). register_hdlc_device() is currently equivalent to register_netdev(). hdlc_setup() is now EXPORTed as per David's request. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-15[PATCH] Generic HDLC updateKrzysztof Halasa
The attached patch updates generic HDLC to version 1.18. FR Cisco LMI production-tested. Please apply to Linux 2.6. Thanks. Changes: - doc updates - added Cisco LMI support to Frame-Relay code - cleaned hdlc_fr.c a bit, removed some orphaned #defines etc. - fixed a problem with non-functional LMI in FR DCE mode. - changed diagnostic messages to better conform to FR standards - all protocols: information about carrier changes (DCD line) is now printed to kernel logs. Signed-Off-By: Krzysztof Halasa <khc@pm.waw.pl>
