kernel/lockdep.c: In function ‘print_bad_irq_dependency’:
kernel/lockdep.c:1476:3: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 7 has type ‘unsigned int’
kernel/lockdep.c: In function ‘print_usage_bug’:
kernel/lockdep.c:2193:3: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 7 has type ‘unsigned int’
kernel/lockdep.i show this:
printk("%s/%d [HC%u[%lu]:SC%u[%lu]:HE%u:SE%u] is trying to acquire:\n",
curr->comm, task_pid_nr(curr),
curr->hardirq_context, ((current_thread_info()->preempt_count) & (((1UL << (10))-1) << ((0 + 8) + 8))) >> ((0 + 8) + 8),
curr->softirq_context, (0U) >> (0 + 8),
curr->hardirqs_enabled,
curr->softirqs_enabled);
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Link: http://lkml.kernel.org/r/20111013091909.GA32739@zhy
Create a new CONFIG_PREEMPT_COUNT that handles the inc/dec
of preempt count offset independently. So that the offset
can be updated by preempt_disable() and preempt_enable()
even without the need for CONFIG_PREEMPT beeing set.
This prepares to make CONFIG_DEBUG_SPINLOCK_SLEEP working
with !CONFIG_PREEMPT where it currently doesn't detect
code that sleeps inside explicit preemption disabled
sections.
This removes the implementation of the big kernel lock,
at last. A lot of people have worked on this in the
past, I so the credit for this patch should be with
everyone who participated in the hunt.
The names on the Cc list are the people that were the
most active in this, according to the recorded git
history, in alphabetical order.
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Alessio Igor Bogani <abogani@texware.it>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Jan Blunck <jblunck@infradead.org>
Cc: John Kacur <jkacur@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: Paul Menage <menage@google.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
This really isn't the right thing to do, and strictly speaking we should
have the BKL depth count in the thread info right next to the preempt
count. The two really do go together.
However, since that would involve a patch to all architectures, and the
BKL is finally going away, it's simply not worth the effort to do the
RightThing(tm). Just re-instate the <linux/sched.h> include that we
used to get accidentally from the smp_lock.h one.
This is all fallout from the same old "BKL: remove extraneous #include
<smp_lock.h>" commit.
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Commit 451a3c24b013 ("BKL: remove extraneous #include <smp_lock.h>")
removed the #include line that was the only thing that was surrounded by
the #ifdef/#endif.
So now that #ifdef is guarding nothing at all. Just remove it.
Reported-by: Byeong-ryeol Kim <brofkims@gmail.com>
Arnd Bergmann did an automated scripting run to find left-over instances
of <linux/smp_lock.h>, and had made it trigger it on the normal BKL use
of lock_kernel and unlock_lernel (and apparently release_kernel_lock and
reacquire_kernel_lock too, used by the scheduler).
That resulted in commit 451a3c24b013 ("BKL: remove extraneous #include
<smp_lock.h>").
However, hardirq.h was the only remaining user of the old
'kernel_locked()' interface, and Arnd's script hadn't checked for that.
So depending on your configuration and what header files had been
included, you would get errors like "implicit declaration of function
'kernel_locked'" during the build.
The right fix is not to just re-instate the smp_lock.h include - it is
to just remove 'kernel_locked()' entirely, since the only use was this
one special low-level detail. Just make hardirq.h do it directly.
In fact this simplifies and clarifies the code, because some trivial
analysis makes it clear that hardirq.h only ever used _one_ of the two
definitions of kernel_locked(), so we can remove the other one entirely.
Reported-by: Zimny Lech <napohybelskurwysynom2010@gmail.com>
Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
The preempt count logic tries to take the BKL into account, which breaks
when CONFIG_BKL is not set.
Use the same preempt_count offset that we use without CONFIG_PREEMPT
when CONFIG_BKL is disabled.
Reported-and-tested-by: Kirill A. Shutemov <kirill@shutemov.name>
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags:
Fix IRQ flag handling naming
MIPS: Add missing #inclusions of <linux/irq.h>
smc91x: Add missing #inclusion of <linux/irq.h>
Drop a couple of unnecessary asm/system.h inclusions
SH: Add missing consts to sys_execve() declaration
Blackfin: Rename IRQ flags handling functions
Blackfin: Add missing dep to asm/irqflags.h
Blackfin: Rename DES PC2() symbol to avoid collision
Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header
Blackfin: Split PLL code from mach-specific cdef headers
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits)
sched: Export account_system_vtime()
sched: Call tick_check_idle before __irq_enter
sched: Remove irq time from available CPU power
sched: Do not account irq time to current task
x86: Add IRQ_TIME_ACCOUNTING
sched: Add IRQ_TIME_ACCOUNTING, finer accounting of irq time
sched: Add a PF flag for ksoftirqd identification
sched: Consolidate account_system_vtime extern declaration
sched: Fix softirq time accounting
sched: Drop group_capacity to 1 only if local group has extra capacity
sched: Force balancing on newidle balance if local group has capacity
sched: Set group_imb only a task can be pulled from the busiest cpu
sched: Do not consider SCHED_IDLE tasks to be cache hot
sched: Drop all load weight manipulation for RT tasks
sched: Create special class for stop/migrate work
sched: Unindent labels
sched: Comment updates: fix default latency and granularity numbers
tracing/sched: Add sched_pi_setprio tracepoint
sched: Give CPU bound RT tasks preference
sched: Try not to migrate higher priority RT tasks
s390/powerpc/ia64 have support for CONFIG_VIRT_CPU_ACCOUNTING which does
the fine granularity accounting of user, system, hardirq, softirq times.
Adding that option on archs like x86 will be challenging however, given the
state of TSC reliability on various platforms and also the overhead it will
add in syscall entry exit.
Instead, add a lighter variant that only does finer accounting of
hardirq and softirq times, providing precise irq times (instead of timer tick
based samples). This accounting is added with a new config option
CONFIG_IRQ_TIME_ACCOUNTING so that there won't be any overhead for users not
interested in paying the perf penalty.
This accounting is based on sched_clock, with the code being generic.
So, other archs may find it useful as well.
This patch just adds the core logic and does not enable this logic yet.
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-5-git-send-email-venki@google.com>
Just a minor cleanup patch that makes things easier to the following patches.
No functionality change in this patch.
LKML-Reference: <1286237003-12406-3-git-send-email-venki@google.com>
Peter Zijlstra found a bug in the way softirq time is accounted in
VIRT_CPU_ACCOUNTING on this thread:
http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html
The problem is, softirq processing uses local_bh_disable internally. There
is no way, later in the flow, to differentiate between whether softirq is
being processed or is it just that bh has been disabled. So, a hardirq when bh
is disabled results in time being wrongly accounted as softirq.
Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING
as well. As account_system_time() in normal tick based accouting also uses
softirq_count, which will be set even when not in softirq with bh disabled.
Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count
for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq
processing. The patch below does that and adds API in_serving_softirq() which
returns whether we are currently processing softirq or not.
Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c
to in_serving_softirq.
Looks like many usages of in_softirq really want in_serving_softirq. Those
changes can be made individually on a case by case basis.
LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com>
Drop inclusions of asm/system.h from linux/hardirq.h and linux/list.h as
they're no longer required and prevent the M68K arch's IRQ flag handling macros
from being made into inlined functions due to circular dependencies.
Acked-by: Greg Ungerer <gerg@uclinux.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Implement a small-memory-footprint uniprocessor-only implementation of
preemptible RCU. This implementation uses but a single blocked-tasks
list rather than the combinatorial number used per leaf rcu_node by
TREE_PREEMPT_RCU, which reduces memory consumption and greatly simplifies
processing. This version also takes advantage of uniprocessor execution
to accelerate grace periods in the case where there are no readers.
The general design is otherwise broadly similar to that of TREE_PREEMPT_RCU.
This implementation is a step towards having RCU implementation driven
off of the SMP and PREEMPT kernel configuration variables, which can
happen once this implementation has accumulated sufficient experience.
Removed ACCESS_ONCE() from __rcu_read_unlock() and added barrier() as
suggested by Steve Rostedt in order to avoid the compiler-reordering
issue noted by Mathieu Desnoyers (http://lkml.org/lkml/2010/8/16/183).
As can be seen below, CONFIG_TINY_PREEMPT_RCU represents almost 5Kbyte
savings compared to CONFIG_TREE_PREEMPT_RCU. Of course, for non-real-time
workloads, CONFIG_TINY_RCU is even better.
text data bss dec filename
13 0 0 13 kernel/rcupdate.o
6170 825 28 7023 kernel/rcutree.o
7026 Total
2081 81 8 2170 kernel/rcutiny.o
2183 Total
CONFIG_TINY_RCU (non-preemptible)
719 25 0 744 kernel/rcutiny.o
757 Total
Requested-by: Loïc Minier <loic.minier@canonical.com>
This patch is a version of RCU designed for !SMP provided for a
small-footprint RCU implementation. In particular, the
implementation of synchronize_rcu() is extremely lightweight and
high performance. It passes rcutorture testing in each of the
four relevant configurations (combinations of NO_HZ and PREEMPT)
on x86. This saves about 1K bytes compared to old Classic RCU
(which is no longer in mainline), and more than three kilobytes
compared to Hierarchical RCU (updated to 2.6.30):
CONFIG_TREE_RCU:
183 4 0 187 kernel/rcupdate.o
2783 520 36 3339 kernel/rcutree.o
3526 Total (vs 4565 for v7)
CONFIG_TREE_PREEMPT_RCU:
263 4 0 267 kernel/rcupdate.o
4594 776 52 5422 kernel/rcutree.o
5689 Total (6155 for v7)
CONFIG_TINY_RCU:
96 4 0 100 kernel/rcupdate.o
734 24 0 758 kernel/rcutiny.o
858 Total (vs 848 for v7)
The above is for x86. Your mileage may vary on other platforms.
Further compression is possible, but is being procrastinated.
Changes from v7 (http://lkml.org/lkml/2009/10/9/388)
o Apply Lai Jiangshan's review comments (aside from
might_sleep() in synchronize_sched(), which is covered by SMP builds).
o Fix up expedited primitives.
Changes from v6 (http://lkml.org/lkml/2009/9/23/293).
o Forward ported to put it into the 2.6.33 stream.
o Added lockdep support.
o Make lightweight rcu_barrier.
Changes from v5 (http://lkml.org/lkml/2009/6/23/12).
o Ported to latest pre-2.6.32 merge window kernel.
- Renamed rcu_qsctr_inc() to rcu_sched_qs().
- Renamed rcu_bh_qsctr_inc() to rcu_bh_qs().
- Provided trivial rcu_cpu_notify().
- Provided trivial exit_rcu().
- Provided trivial rcu_needs_cpu().
- Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h.
o Removed the dependence on EMBEDDED, with a view to making
TINY_RCU default for !SMP at some time in the future.
o Added (trivial) support for expedited grace periods.
Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include:
o Squeeze the size down a bit further by removing the
->completed field from struct rcu_ctrlblk.
o This permits synchronize_rcu() to become the empty function.
Previous concerns about rcutorture were unfounded, as
rcutorture correctly handles a constant value from
rcu_batches_completed() and rcu_batches_completed_bh().
Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include:
o Changed rcu_batches_completed(), rcu_batches_completed_bh()
rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and
rcu_nmi_exit(), to be static inlines, as suggested by David
Howells. Doing this saves about 100 bytes from rcutiny.o.
(The numbers between v3 and this v4 of the patch are not directly
comparable, since they are against different versions of Linux.)
Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include:
o Fix whitespace issues.
o Change short-circuit "||" operator to instead be "+" in order
to fix performance bug noted by "kraai" on LWN.
(http://lwn.net/Articles/324348/)
Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include:
o This version depends on EMBEDDED as well as !SMP, as suggested
by Ingo.
o Updated rcu_needs_cpu() to unconditionally return zero,
permitting the CPU to enter dynticks-idle mode at any time.
This works because callbacks can be invoked upon entry to
dynticks-idle mode.
o Paul is now OK with this being included, based on a poll at
the Kernel Miniconf at linux.conf.au, where about ten people said
that they cared about saving 900 bytes on single-CPU systems.
o Applies to both mainline and tip/core/rcu.
Acked-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: avi@redhat.com
Cc: mtosatti@redhat.com
LKML-Reference: <12565226351355-git-send-email->
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (64 commits)
sched: Fix sched::sched_stat_wait tracepoint field
sched: Disable NEW_FAIR_SLEEPERS for now
sched: Keep kthreads at default priority
sched: Re-tune the scheduler latency defaults to decrease worst-case latencies
sched: Turn off child_runs_first
sched: Ensure that a child can't gain time over it's parent after fork()
sched: enable SD_WAKE_IDLE
sched: Deal with low-load in wake_affine()
sched: Remove short cut from select_task_rq_fair()
sched: Turn on SD_BALANCE_NEWIDLE
sched: Clean up topology.h
sched: Fix dynamic power-balancing crash
sched: Remove reciprocal for cpu_power
sched: Try to deal with low capacity, fix update_sd_power_savings_stats()
sched: Scale down cpu_power due to RT tasks
sched: Implement dynamic cpu_power
sched: Add smt_gain
sched: Update the cpu_power sum during load-balance
sched: Add SD_PREFER_SIBLING
A couple of references to CONFIG_CLASSIC_RCU have survived.
Although these are harmless, it is past time for them to go.
The one in hardirq.h is strictly a readability problem.
The two in pagemap.h appear to disable a !SMP performance
optimization (which this patch re-enables).
This does raise the issue as to whether pagemap.h should really
be referring to the CPU implementation. Long term, I intend to
make the RCU implementation driven by CONFIG_PREEMPT, at which
point these should change from defined(CONFIG_TREE_RCU) to
!defined(CONFIG_PREEMPT). In the meantime, is there something
else that could be done in pagemap.h?
Cc: laijs@cn.fujitsu.com
Cc: akpm@linux-foundation.org
Cc: josht@linux.vnet.ibm.com
Cc: niv@us.ibm.com
LKML-Reference: <20090822050851.GA8414@linux.vnet.ibm.com>
The PREEMPT_ACTIVE setting doesn't actually need to be
arch-specific, so set up a sane default for all arches to
(hopefully) migrate to.
> if we look at linux/hardirq.h, it makes this claim:
> * - bit 28 is the PREEMPT_ACTIVE flag
> if that's true, then why are we letting any arch set this define ? a
> quick survey shows that half the arches (11) are using 0x10000000 (bit
> 28) while the other half (10) are using 0x4000000 (bit 26). and then
> there is the ia64 oddity which uses bit 30. the exact value here
> shouldnt really matter across arches though should it ?
actually alpha, arm and avr32 also use bit 30 (0x40000000),
there are only five (or eight, depending on how you count)
architectures (blackfin, h8300, m68k, s390 and sparc) using bit
26.
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
include/linux/irq.h
kernel/irq/handle.c
Add support for threaded interrupt handlers:
A device driver can request that its main interrupt handler runs in a
thread. To achive this the device driver requests the interrupt with
request_threaded_irq() and provides additionally to the handler a
thread function. The handler function is called in hard interrupt
context and needs to check whether the interrupt originated from the
device. If the interrupt originated from the device then the handler
can either return IRQ_HANDLED or IRQ_WAKE_THREAD. IRQ_HANDLED is
returned when no further action is required. IRQ_WAKE_THREAD causes
the genirq code to invoke the threaded (main) handler. When
IRQ_WAKE_THREAD is returned handler must have disabled the interrupt
on the device level. This is mandatory for shared interrupt handlers,
but we need to do it as well for obscure x86 hardware where disabling
an interrupt on the IO_APIC level redirects the interrupt to the
legacy PIC interrupt lines.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Impact: avoid corruption in system time accounting
Martin Schwidefsky told me that there was an issue with NMIs and
system accounting. The problem is that the accounting code is
not reentrant, and if an NMI goes off after an interrupt it can
corrupt the accounting.
For now, the best we can do is to treat NMIs like SMIs and they
are not accounted for.
This patch changes nmi_enter to not call __irq_enter and to do
the preempt-count and tracing calls directly.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
To add a bit in the preempt_count to be set when in NMI context, we
found that some archs did not have enough bits to spare. This is
due to the hardirq_count being a mask that can hold NR_IRQS.
Some archs allow for over 16000 IRQs, and that would require a mask
of 14 bits. The sofitrq mask is 8 bits and the preempt disable mask
is also 8 bits. The PREEMP_ACTIVE bit is bit 30, and bit 31 would
make the preempt_count (which is type int) a negative number.
A negative preempt_count is a sign of failure.
Add them up 14+8+8+1+1 you get 32 bits. No room for the NMI bit.
But the hardirq_count is to track the number of nested IRQs, not
the number of total IRQs. This originally took the paranoid approach
of setting the max nesting to NR_IRQS. But when we have archs with
over 1000 IRQs, it is not practical to think they will ever all
nest on a single CPU. Not to mention that this would most definitely
cause a stack overflow.
This patch sets a max of 10 bits to be used for IRQ nesting.
I did a 'git grep HARDIRQ' to examine all users of HARDIRQ_BITS and
HARDIRQ_MASK, and found that making it a max of 10 would not hurt
anyone. I did find that the m68k expected it to be 8 bits, so
I allow for the archs to set the number to be less than 10.
I removed the setting of HARDIRQ_BITS from the archs that set it
to more than 10. This includes ALPHA, ia64 and avr32.
This will always allow room for the NMI bit, and if we need to allow
for NMI nesting, we have 4 bits to play with.
This code adds an in_nmi() macro that uses the current tasks preempt count
to track when it is in NMI context. Other parts of the kernel can
use this to determine if the context is in NMI context or not.
This code was inspired by the -rt patch in_nmi version that was
written by Peter Zijlstra, who borrowed that code from
Mathieu Desnoyers.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
* 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits)
stacktrace: provide save_stack_trace_tsk() weak alias
rcu: provide RCU options on non-preempt architectures too
printk: fix discarding message when recursion_bug
futex: clean up futex_(un)lock_pi fault handling
"Tree RCU": scalable classic RCU implementation
futex: rename field in futex_q to clarify single waiter semantics
x86/swiotlb: add default swiotlb_arch_range_needs_mapping
x86/swiotlb: add default phys<->bus conversion
x86: unify pci iommu setup and allow swiotlb to compile for 32 bit
x86: add swiotlb allocation functions
swiotlb: consolidate swiotlb info message printing
swiotlb: support bouncing of HighMem pages
swiotlb: factor out copy to/from device
swiotlb: add arch hook to force mapping
swiotlb: allow architectures to override phys<->bus<->phys conversions
swiotlb: add comment where we handle the overflow of a dma mask on 32 bit
rcu: fix rcutorture behavior during reboot
resources: skip sanity check of busy resources
swiotlb: move some definitions to header
swiotlb: allow architectures to override swiotlb pool allocation
Fix up trivial conflicts in
arch/x86/kernel/Makefile
arch/x86/mm/init_32.c
include/linux/hardirq.h
as per Ingo's suggestions.
This patch fixes a long-standing performance bug in classic RCU that
results in massive internal-to-RCU lock contention on systems with
more than a few hundred CPUs. Although this patch creates a separate
flavor of RCU for ease of review and patch maintenance, it is intended
to replace classic RCU.
This patch still handles stress better than does mainline, so I am still
calling it ready for inclusion. This patch is against the -tip tree.
Nevertheless, experience on an actual 1000+ CPU machine would still be
most welcome.
Most of the changes noted below were found while creating an rcutiny
(which should permit ejecting the current rcuclassic) and while doing
detailed line-by-line documentation.
Updates from v9 (http://lkml.org/lkml/2008/12/2/334):
o Fixes from remainder of line-by-line code walkthrough,
including comment spelling, initialization, undesirable
narrowing due to type conversion, removing redundant memory
barriers, removing redundant local-variable initialization,
and removing redundant local variables.
I do not believe that any of these fixes address the CPU-hotplug
issues that Andi Kleen was seeing, but please do give it a whirl
in case the machine is smarter than I am.
A writeup from the walkthrough may be found at the following
URL, in case you are suffering from terminal insomnia or
masochism:
http://www.kernel.org/pub/linux/kernel/people/paulmck/tmp/rcutree-walkthrough.2008.12.16a.pdf
o Made rcutree tracing use seq_file, as suggested some time
ago by Lai Jiangshan.
o Added a .csv variant of the rcudata debugfs trace file, to allow
people having thousands of CPUs to drop the data into
a spreadsheet. Tested with oocalc and gnumeric. Updated
documentation to suit.
Updates from v8 (http://lkml.org/lkml/2008/11/15/139):
o Fix a theoretical race between grace-period initialization and
force_quiescent_state() that could occur if more than three
jiffies were required to carry out the grace-period
initialization. Which it might, if you had enough CPUs.
o Apply Ingo's printk-standardization patch.
o Substitute local variables for repeated accesses to global
variables.
o Fix comment misspellings and redundant (but harmless) increments
of ->n_rcu_pending (this latter after having explicitly added it).
o Apply checkpatch fixes.
Updates from v7 (http://lkml.org/lkml/2008/10/10/291):
o Fixed a number of problems noted by Gautham Shenoy, including
the cpu-stall-detection bug that he was having difficulty
convincing me was real. ;-)
o Changed cpu-stall detection to wait for ten seconds rather than
three in order to reduce false positive, as suggested by Ingo
Molnar.
o Produced a design document (http://lwn.net/Articles/305782/).
The act of writing this document uncovered a number of both
theoretical and "here and now" bugs as noted below.
o Fix dynticks_nesting accounting confusion, simplify WARN_ON()
condition, fix kerneldoc comments, and add memory barriers
in dynticks interface functions.
o Add more data to tracing.
o Remove unused "rcu_barrier" field from rcu_data structure.
o Count calls to rcu_pending() from scheduling-clock interrupt
to use as a surrogate timebase should jiffies stop counting.
o Fix a theoretical race between force_quiescent_state() and
grace-period initialization. Yes, initialization does have to
go on for some jiffies for this race to occur, but given enough
CPUs...
Updates from v6 (http://lkml.org/lkml/2008/9/23/448):
o Fix a number of checkpatch.pl complaints.
o Apply review comments from Ingo Molnar and Lai Jiangshan
on the stall-detection code.
o Fix several bugs in !CONFIG_SMP builds.
o Fix a misspelled config-parameter name so that RCU now announces
at boot time if stall detection is configured.
o Run tests on numerous combinations of configurations parameters,
which after the fixes above, now build and run correctly.
Updates from v5 (http://lkml.org/lkml/2008/9/15/92, bad subject line):
o Fix a compiler error in the !CONFIG_FANOUT_EXACT case (blew a
changeset some time ago, and finally got around to retesting
this option).
o Fix some tracing bugs in rcupreempt that caused incorrect
totals to be printed.
o I now test with a more brutal random-selection online/offline
script (attached). Probably more brutal than it needs to be
on the people reading it as well, but so it goes.
o A number of optimizations and usability improvements:
o Make rcu_pending() ignore the grace-period timeout when
there is no grace period in progress.
o Make force_quiescent_state() avoid going for a global
lock in the case where there is no grace period in
progress.
o Rearrange struct fields to improve struct layout.
o Make call_rcu() initiate a grace period if RCU was
idle, rather than waiting for the next scheduling
clock interrupt.
o Invoke rcu_irq_enter() and rcu_irq_exit() only when
idle, as suggested by Andi Kleen. I still don't
completely trust this change, and might back it out.
o Make CONFIG_RCU_TRACE be the single config variable
manipulated for all forms of RCU, instead of the prior
confusion.
o Document tracing files and formats for both rcupreempt
and rcutree.
Updates from v4 for those missing v5 given its bad subject line:
o Separated dynticks interface so that NMIs and irqs call separate
functions, greatly simplifying it. In particular, this code
no longer requires a proof of correctness. ;-)
o Separated dynticks state out into its own per-CPU structure,
avoiding the duplicated accounting.
o The case where a dynticks-idle CPU runs an irq handler that
invokes call_rcu() is now correctly handled, forcing that CPU
out of dynticks-idle mode.
o Review comments have been applied (thank you all!!!).
For but one example, fixed the dynticks-ordering issue that
Manfred pointed out, saving me much debugging. ;-)
o Adjusted rcuclassic and rcupreempt to handle dynticks changes.
Attached is an updated patch to Classic RCU that applies a hierarchy,
greatly reducing the contention on the top-level lock for large machines.
This passes 10-hour concurrent rcutorture and online-offline testing on
128-CPU ppc64 without dynticks enabled, and exposes some timekeeping
bugs in presence of dynticks (exciting working on a system where
"sleep 1" hangs until interrupted...), which were fixed in the
2.6.27 kernel. It is getting more reliable than mainline by some
measures, so the next version will be against -tip for inclusion.
See also Manfred Spraul's recent patches (or his earlier work from
2004 at http://marc.info/?l=linux-kernel&m=108546384711797&w=2).
We will converge onto a common patch in the fullness of time, but are
currently exploring different regions of the design space. That said,
I have already gratefully stolen quite a few of Manfred's ideas.
This patch provides CONFIG_RCU_FANOUT, which controls the bushiness
of the RCU hierarchy. Defaults to 32 on 32-bit machines and 64 on
64-bit machines. If CONFIG_NR_CPUS is less than CONFIG_RCU_FANOUT,
there is no hierarchy. By default, the RCU initialization code will
adjust CONFIG_RCU_FANOUT to balance the hierarchy, so strongly NUMA
architectures may choose to set CONFIG_RCU_FANOUT_EXACT to disable
this balancing, allowing the hierarchy to be exactly aligned to the
underlying hardware. Up to two levels of hierarchy are permitted
(in addition to the root node), allowing up to 16,384 CPUs on 32-bit
systems and up to 262,144 CPUs on 64-bit systems. I just know that I
am going to regret saying this, but this seems more than sufficient
for the foreseeable future. (Some architectures might wish to set
CONFIG_RCU_FANOUT=4, which would limit such architectures to 64 CPUs.
If this becomes a real problem, additional levels can be added, but I
doubt that it will make a significant difference on real hardware.)
In the common case, a given CPU will manipulate its private rcu_data
structure and the rcu_node structure that it shares with its immediate
neighbors. This can reduce both lock and memory contention by multiple
orders of magnitude, which should eliminate the need for the strange
manipulations that are reported to be required when running Linux on
very large systems.
Some shortcomings:
o More bugs will probably surface as a result of an ongoing
line-by-line code inspection.
Patches will be provided as required.
o There are probably hangs, rcutorture failures, &c. Seems
quite stable on a 128-CPU machine, but that is kind of small
compared to 4096 CPUs. However, seems to do better than
mainline.
o The memory footprint of this version is several KB larger
than rcuclassic.
A separate UP-only rcutiny patch will be provided, which will
reduce the memory footprint significantly, even compared
to the old rcuclassic. One such patch passes light testing,
and has a memory footprint smaller even than rcuclassic.
Initial reaction from various embedded guys was "it is not
worth it", so am putting it aside.
Credits:
o Manfred Spraul for ideas, review comments, and bugs spotted,
as well as some good friendly competition. ;-)
o Josh Triplett, Ingo Molnar, Peter Zijlstra, Mathieu Desnoyers,
Lai Jiangshan, Andi Kleen, Andy Whitcroft, and Andrew Morton
for reviews and comments.
o Thomas Gleixner for much-needed help with some timer issues
(see patches below).
o Jon M. Tollefson, Tim Pepper, Andrew Theurer, Jose R. Santos,
Andy Whitcroft, Darrick Wong, Nishanth Aravamudan, Anton
Blanchard, Dave Kleikamp, and Nathan Lynch for keeping machines
alive despite my heavy abuse^Wtesting.
Impact: moving of function prototypes into own header file
ftrace.h is too big of a file for hardirq.h, and some archs will fail
to build because of the include dependencies not being met.
This patch pulls out the required prototypes for hardirq.h into a smaller
and safer ftrace_irq.h file.
Impact: build fix for non-ftrace architectures
Not all archs implement ftrace, and therefore do not have an asm/ftrace.h.
This patch corrects the problem.
The ftrace_nmi_enter/exit now must be defined for all archs that implement
dynamic ftrace. Currently, only x86 does.
Impact: fix crashes that can occur in NMI handlers, if their code is modified
Modifying code is something that needs special care. On SMP boxes,
if code that is being modified is also being executed on another CPU,
that CPU will have undefined results.
The dynamic ftrace uses kstop_machine to make the system act like a
uniprocessor system. But this does not address NMIs, that can still
run on other CPUs.
One approach to handle this is to make all code that are used by NMIs
not be traced. But NMIs can call notifiers that spread throughout the
kernel and this will be very hard to maintain, and the chance of missing
a function is very high.
The approach that this patch takes is to have the NMIs modify the code
if the modification is taking place. The way this works is that just
writing to code executing on another CPU is not harmful if what is
written is the same as what exists.
Two buffers are used: an IP buffer and a "code" buffer.
The steps that the patcher takes are:
1) Put in the instruction pointer into the IP buffer
and the new code into the "code" buffer.
2) Set a flag that says we are modifying code
3) Wait for any running NMIs to finish.
4) Write the code
5) clear the flag.
6) Wait for any running NMIs to finish.
If an NMI is executed, it will also write the pending code.
Multiple writes are OK, because what is being written is the same.
Then the patcher must wait for all running NMIs to finish before
going to the next line that must be patched.
This is basically the RCU approach to code modification.
Thanks to Ingo Molnar for suggesting the idea, and to Arjan van de Ven
for his guidence on what is safe and what is not.
The generic semaphore rewrite had a huge performance regression on AIM7
(and potentially other BKL-heavy benchmarks) because the generic
semaphores had been rewritten to be simple to understand and fair. The
latter, in particular, turns a semaphore-based BKL implementation into a
mess of scheduling.
The attempt to fix the performance regression failed miserably (see the
previous commit 00b41ec2611dc98f87f30753ee00a53db648d662 'Revert
"semaphore: fix"'), and so for now the simple and sane approach is to
instead just go back to the old spinlock-based BKL implementation that
never had any issues like this.
This patch also has the advantage of being reported to fix the
regression completely according to Yanmin Zhang, unlike the semaphore
hack which still left a couple percentage point regression.
As a spinlock, the BKL obviously has the potential to be a latency
issue, but it's not really any different from any other spinlock in that
respect. We do want to get rid of the BKL asap, but that has been the
plan for several years.
These days, the biggest users are in the tty layer (open/release in
particular) and Alan holds out some hope:
"tty release is probably a few months away from getting cured - I'm
afraid it will almost certainly be the very last user of the BKL in
tty to get fixed as it depends on everything else being sanely locked."
so while we're not there yet, we do have a plan of action.
Tested-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Cc: Alexander Viro <viro@ftp.linux.org.uk>
Discourage people from inappropriately using in_atomic()
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
The PREEMPT-RCU can get stuck if a CPU goes idle and NO_HZ is set. The
idle CPU will not progress the RCU through its grace period and a
synchronize_rcu my get stuck. Without this patch I have a box that will
not boot when PREEMPT_RCU and NO_HZ are set. That same box boots fine
with this patch.
This patch comes from the -rt kernel where it has been tested for
several months.
remove the !PREEMPT_BKL code.
this removes 160 lines of legacy code.
add in_atomic_preempt_off() - debugging helper that will
simplify schedule().
With Ingo Molnar <mingo@elte.hu>
Add functions to provide dynamic ticks and high resolution timers. The code
which keeps track of jiffies and handles the long idle periods is shared
between tick based and high resolution timer based dynticks. The dyntick
functionality can be disabled on the kernel commandline. Provide also the
infrastructure to support high resolution timers.
Cc: john stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Uninline irq_enter(). [dynticks adds more stuff to it]
No functional changes.
This patch adds support for systems that cannot receive every interrupt on a
single cpu simultaneously, in the check to see if we have enough HARDIRQ_BITS.
MAX_HARDIRQS_PER_CPU becomes the count of the maximum number of hardare
generated interrupts per cpu.
On architectures that support per cpu interrupt delivery this can be a
significant space savings and scalability bonus.
Cc: Rajesh Shah <rajesh.shah@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: "Protasevich, Natalie" <Natalie.Protasevich@UNISYS.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Do 'make oldconfig' and accept all the defaults for new config options -
reboot into the kernel and if everything goes well it should boot up fine and
you should have /proc/lockdep and /proc/lockdep_stats files.
Typically if the lock validator finds some problem it will print out
voluminous debug output that begins with "BUG: ..." and which syslog output
can be used by kernel developers to figure out the precise locking scenario.
What does the lock validator do? It "observes" and maps all locking rules as
they occur dynamically (as triggered by the kernel's natural use of spinlocks,
rwlocks, mutexes and rwsems). Whenever the lock validator subsystem detects a
new locking scenario, it validates this new rule against the existing set of
rules. If this new rule is consistent with the existing set of rules then the
new rule is added transparently and the kernel continues as normal. If the
new rule could create a deadlock scenario then this condition is printed out.
When determining validity of locking, all possible "deadlock scenarios" are
considered: assuming arbitrary number of CPUs, arbitrary irq context and task
context constellations, running arbitrary combinations of all the existing
locking scenarios. In a typical system this means millions of separate
scenarios. This is why we call it a "locking correctness" validator - for all
rules that are observed the lock validator proves it with mathematical
certainty that a deadlock could not occur (assuming that the lock validator
implementation itself is correct and its internal data structures are not
corrupted by some other kernel subsystem). [see more details and conditionals
of this statement in include/linux/lockdep.h and
Documentation/lockdep-design.txt]
Furthermore, this "all possible scenarios" property of the validator also
enables the finding of complex, highly unlikely multi-CPU multi-context races
via single single-context rules, increasing the likelyhood of finding bugs
drastically. In practical terms: the lock validator already found a bug in
the upstream kernel that could only occur on systems with 3 or more CPUs, and
which needed 3 very unlikely code sequences to occur at once on the 3 CPUs.
That bug was found and reported on a single-CPU system (!). So in essence a
race will be found "piecemail-wise", triggering all the necessary components
for the race, without having to reproduce the race scenario itself! In its
short existence the lock validator found and reported many bugs before they
actually caused a real deadlock.
To further increase the efficiency of the validator, the mapping is not per
"lock instance", but per "lock-class". For example, all struct inode objects
in the kernel have inode->inotify_mutex. If there are 10,000 inodes cached,
then there are 10,000 lock objects. But ->inotify_mutex is a single "lock
type", and all locking activities that occur against ->inotify_mutex are
"unified" into this single lock-class. The advantage of the lock-class
approach is that all historical ->inotify_mutex uses are mapped into a single
(and as narrow as possible) set of locking rules - regardless of how many
different tasks or inode structures it took to build this set of rules. The
set of rules persist during the lifetime of the kernel.
To see the rough magnitude of checking that the lock validator does, here's a
portion of /proc/lockdep_stats, fresh after bootup:
lock-classes: 694 [max: 2048]
direct dependencies: 1598 [max: 8192]
indirect dependencies: 17896
all direct dependencies: 16206
dependency chains: 1910 [max: 8192]
in-hardirq chains: 17
in-softirq chains: 105
in-process chains: 1065
stack-trace entries: 38761 [max: 131072]
combined max dependencies: 2033928
hardirq-safe locks: 24
hardirq-unsafe locks: 176
softirq-safe locks: 53
softirq-unsafe locks: 137
irq-safe locks: 59
The lock validator has observed 1598 actual single-thread locking patterns,
and has validated all possible 2033928 distinct locking scenarios.
More details about the design of the lock validator can be found in
Documentation/lockdep-design.txt, which can also found at:
http://redhat.com/~mingo/lockdep-patches/lockdep-design.txt
[bunk@stusta.de: cleanups]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Accurate hard-IRQ-flags and softirq-flags state tracing.
This allows us to attach extra functionality to IRQ flags on/off
events (such as trace-on/off).
finish_arch_switch needs to update the user cpu time as well, not just the
system cpu time. Otherwise the partial user cpu time of a process that is
stored in the lowcore will be (mis-)accounted to the next process.
a) in smp_lock.h #include of sched.h and spinlock.h moved under #ifdef
CONFIG_LOCK_KERNEL.
b) interrupt.h now explicitly pulls sched.h (not via smp_lock.h from
hardirq.h as it used to)
c) in three more places we need changes to compensate for (a) - one place
in arch/sparc needs string.h now, hardirq.h needs forward declaration of
task_struct and preempt.h needs direct include of thread_info.h.
d) thread_info-related helpers in sched.h and thread_info.h put under
ifndef __HAVE_THREAD_FUNCTIONS. Obviously safe.
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
hardirq.h uses preempt_count() from preempt.h
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
After porting this fixlet to UML:
http://linux.bkbits.net:8080/linux-2.5/cset@41791ab52lfMuF2i3V-eTIGRBbDYKQ
, I've also added a warning which should refuse compilation with insane values
for PREEMPT_ACTIVE... maybe we should simply move PREEMPT_ACTIVE out of
architectures using GENERIC_IRQS.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
infrastructure for it.
Let it rip!
