path: root/include/linux/genhd.h
2013-02-26block: fix part_pack_uuid() build errorMimi Zohar
Commit "85865c1 ima: add policy support for file system uuid" introduced a CONFIG_BLOCK dependency. This patch defines a wrapper called blk_part_pack_uuid(), which returns -EINVAL, when CONFIG_BLOCK is not defined. security/integrity/ima/ima_policy.c:538:4: error: implicit declaration of function 'part_pack_uuid' [-Werror=implicit-function-declaration] Changelog v2: - Reference commit number in patch description Changelog v1: - rename ima_part_pack_uuid() to blk_part_pack_uuid() - resolve scripts/checkpatch.pl warnings Changelog v0: - fix UUID scripts/Lindent msgs Reported-by: Randy Dunlap <rdunlap@infradead.org> Reported-by: David Rientjes <rientjes@google.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-11-23block: store partition_meta_info.uuid as a stringStephen Warren
This will allow other types of UUID to be stored here, aside from true UUIDs. This also simplifies code that uses this field, since it's usually constructed from a, used as a, or compared to other, strings. Note: A simplistic approach here would be to set uuid_str[36]=0 whenever a /PARTNROFF option was found to be present. However, this modifies the input string, and causes subsequent calls to devt_from_partuuid() not to see the /PARTNROFF option, which causes different results. In order to avoid misleading future maintainers, this parameter is marked const. Signed-off-by: Stephen Warren <swarren@nvidia.com> Cc: Tejun Heo <tj@kernel.org> Cc: Will Drewry <wad@chromium.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-01Merge branch 'for-3.6/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO bits from Jens Axboe: "The most complicated part if this is the request allocation rework by Tejun, which has been queued up for a long time and has been in for-next ditto as well. There are a few commits from yesterday and today, mostly trivial and obvious fixes. So I'm pretty confident that it is sound. It's also smaller than usual." * 'for-3.6/core' of git://git.kernel.dk/linux-block: block: remove dead func declaration block: add partition resize function to blkpg ioctl block: uninitialized ioc->nr_tasks triggers WARN_ON block: do not artificially constrain max_sectors for stacking drivers blkcg: implement per-blkg request allocation block: prepare for multiple request_lists block: add q->nr_rqs[] and move q->rq.elvpriv to q->nr_rqs_elvpriv blkcg: inline bio_blkcg() and friends block: allocate io_context upfront block: refactor get_request[_wait]() block: drop custom queue draining used by scsi_transport_{iscsi|fc} mempool: add @gfp_mask to mempool_create_node() blkcg: make root blkcg allocation use %GFP_KERNEL blkcg: __blkg_lookup_create() doesn't need radix preload
2012-08-01block: add partition resize function to blkpg ioctlVivek Goyal
Add a new operation code (BLKPG_RESIZE_PARTITION) to the BLKPG ioctl that allows altering the size of an existing partition, even if it is currently in use. This patch converts hd_struct->nr_sects into sequence counter because One might extend a partition while IO is happening to it and update of nr_sects can be non-atomic on 32bit machines with 64bit sector_t. This can lead to issues like reading inconsistent size of a partition. Sequence counter have been used so that readers don't have to take bdev mutex lock as we call sector_in_part() very frequently. Now all the access to hd_struct->nr_sects should happen using sequence counter read/update helper functions part_nr_sects_read/part_nr_sects_write. There is one exception though, set_capacity()/get_capacity(). I think theoritically race should exist there too but this patch does not modify set_capacity()/get_capacity() due to sheer number of call sites and I am afraid that change might break something. I have left that as a TODO item. We can handle it later if need be. This patch does not introduce any new races as such w.r.t set_capacity()/get_capacity(). v2: Add CONFIG_LBDAF test to UP preempt case as suggested by Phillip. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Phillip Susi <psusi@ubuntu.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-07-16driver-core: Move kobj_to_dev from genhd.h to device.hLars-Peter Clausen
This function is not really specific to the genhd layer and there are various re-implementations or open-coded variants of it all throughout the kernel. To avoid further duplications move the function to a more generic place. While moving also convert it from a macro to a inline function. Potential users of this function can be detected and converted using the following coccinelle patch: // <smpl> @@ expression k; @@ -container_of(k, struct device, kobj) +kobj_to_dev(kobj) // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-15block: fix buffer overflow when printing partition UUIDsTejun Heo
6d1d8050b4bc8 "block, partition: add partition_meta_info to hd_struct" added part_unpack_uuid() which assumes that the passed in buffer has enough space for sprintfing "%pU" - 37 characters including '\0'. Unfortunately, b5af921ec0233 "init: add support for root devices specified by partition UUID" supplied 33 bytes buffer to the function leading to the following panic with stackprotector enabled. Kernel panic - not syncing: stack-protector: Kernel stack corrupted in: ffffffff81b14c7e [<ffffffff815e226b>] panic+0xba/0x1c6 [<ffffffff81b14c7e>] ? printk_all_partitions+0x259/0x26xb [<ffffffff810566bb>] __stack_chk_fail+0x1b/0x20 [<ffffffff81b15c7e>] printk_all_paritions+0x259/0x26xb [<ffffffff81aedfe0>] mount_block_root+0x1bc/0x27f [<ffffffff81aee0fa>] mount_root+0x57/0x5b [<ffffffff81aee23b>] prepare_namespace+0x13d/0x176 [<ffffffff8107eec0>] ? release_tgcred.isra.4+0x330/0x30 [<ffffffff81aedd60>] kernel_init+0x155/0x15a [<ffffffff81087b97>] ? schedule_tail+0x27/0xb0 [<ffffffff815f4d24>] kernel_thread_helper+0x5/0x10 [<ffffffff81aedc0b>] ? start_kernel+0x3c5/0x3c5 [<ffffffff815f4d20>] ? gs_change+0x13/0x13 Increase the buffer size, remove the dangerous part_unpack_uuid() and use snprintf() directly from printk_all_partitions(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Szymon Gruszczynski <sz.gruszczynski@googlemail.com> Cc: Will Drewry <wad@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-02block: Fix NULL pointer dereference in sd_revalidate_diskJun'ichi Nomura
Since 2.6.39 (1196f8b), when a driver returns -ENOMEDIUM for open(), __blkdev_get() calls rescan_partitions() to remove in-kernel partition structures and raise KOBJ_CHANGE uevent. However it ends up calling driver's revalidate_disk without open and could cause oops. In the case of SCSI: process A process B ---------------------------------------------- sys_open __blkdev_get sd_open returns -ENOMEDIUM scsi_remove_device <scsi_device torn down> rescan_partitions sd_revalidate_disk <oops> Oopses are reported here: http://marc.info/?l=linux-scsi&m=132388619710052 This patch separates the partition invalidation from rescan_partitions() and use it for -ENOMEDIUM case. Reported-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-03switch device_get_devnode() and ->devnode() to umode_t *Al Viro
both callers of device_get_devnode() are only interested in lower 16bits and nobody tries to return anything wider than 16bit anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-10block: Revert "[SCSI] genhd: add a new attribute "alias" in gendisk"Tejun Heo
This reverts commit a72c5e5eb738033938ab30d6a634b74d1d060f10. The commit introduced alias for block devices which is intended to be used during logging although actual usage hasn't been committed yet. This approach adds very limited benefit (raw log might be easier to follow) which can be trivially implemented in userland but has a lot of problems. It is much worse than netif renames because it doesn't rename the actual device but just adds conveninence name which isn't used universally or enforced. Everything internal including device lookup and sysfs still uses the internal name and nothing prevents two devices from using conflicting alias - ie. sda can have sdb as its alias. This has been nacked by people working on device driver core, block layer and kernel-userland interface and shouldn't have been upstreamed. Revert it. http://thread.gmane.org/gmane.linux.kernel/1155104 http://thread.gmane.org/gmane.linux.scsi/68632 http://thread.gmane.org/gmane.linux.scsi/69776 Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Nao Nishijima <nao.nishijima.xt@hitachi.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-04Merge branch 'for-3.2/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.2/drivers' of git://git.kernel.dk/linux-block: (30 commits) virtio-blk: use ida to allocate disk index hpsa: add small delay when using PCI Power Management to reset for kump cciss: add small delay when using PCI Power Management to reset for kump xen/blkback: Fix two races in the handling of barrier requests. xen/blkback: Check for proper operation. xen/blkback: Fix the inhibition to map pages when discarding sector ranges. xen/blkback: Report VBD_WSECT (wr_sect) properly. xen/blkback: Support 'feature-barrier' aka old-style BARRIER requests. xen-blkfront: plug device number leak in xlblk_init() error path xen-blkfront: If no barrier or flush is supported, use invalid operation. xen-blkback: use kzalloc() in favor of kmalloc()+memset() xen-blkback: fixed indentation and comments xen-blkfront: fix a deadlock while handling discard response xen-blkfront: Handle discard requests. xen-blkback: Implement discard requests ('feature-discard') xen-blkfront: add BLKIF_OP_DISCARD and discard request struct drivers/block/loop.c: remove unnecessary bdev argument from loop_clr_fd() drivers/block/loop.c: emit uevent on auto release drivers/block/cpqarray.c: use pci_dev->revision loop: always allow userspace partitions and optionally support automatic scanning ... Fic up trivial header file includsion conflict in drivers/block/loop.c
2011-08-29[SCSI] genhd: add a new attribute "alias" in gendiskNao Nishijima
This patch allows the user to set an "alias" of the disk via sysfs interface. This patch only adds a new attribute "alias" in gendisk structure. To show the alias instead of the device name in kernel messages, we need to revise printk messages and use alias_name() in them. Example: (current) printk("disk name is %s\n", disk->disk_name); (new) printk("disk name is %s\n", alias_name(disk)); Users can use alphabets, numbers, '-' and '_' in "alias" attribute. A disk can have an "alias" which length is up to 255 bytes. This attribute is write-once. Suggested-by: James Bottomley <James.Bottomley@HansenPartnership.com> Suggested-by: Jon Masters <jcm@redhat.com> Signed-off-by: Nao Nishijima <nao.nishijima.xt@hitachi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-23block: add GENHD_FL_NO_PART_SCANTejun Heo
There are cases where suppressing partition scan is useful - e.g. for lo devices and pseudo SATA devices which advertise to be a disk but get upset on partition scan (some port multiplier control devices show such behavior). This patch adds GENHD_FL_NO_PART_SCAN which suppresses partition scan regardless of the number of possible partitions. disk_partitionable() is renamed to disk_part_scan_enabled() as suppressing partition scan doesn't imply the device can't be partitioned using BLKPG_ADD/DEL_PARTITION calls from userland. show_partition() now directly tests disk_max_parts() to maintain backward-compatibility. -v2: Updated to make it clear that only partition scan is suppressed not partitioning itself as suggested by Kay Sievers. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-01block: flush MEDIA_CHANGE from drivers on close(2)Tejun Heo
Currently, only open(2) is defined as the 'clearing' point. It has two roles - first, it's an acknowledgement from userland indicating that the event has been received and kernel can clear pending states and proceed to generate more events. Secondly, it's passed on to device drivers as a hint indicating that a synchronization point has been reached and it might want to take a deeper look at the device. The latter currently is only used by sr which uses two different mechanisms - GET_EVENT_MEDIA_STATUS_NOTIFICATION and TEST_UNIT_READY to discover events, where the former is lighter weight and safe to be used repeatedly but may not provide full coverage. Among other things, GET_EVENT can't detect media removal while TUR can. This patch makes close(2) - blkdev_put() - indicate clearing hint for MEDIA_CHANGE to drivers. disk_check_events() is renamed to disk_flush_events() and updated to take @mask for events to flush which is or'd to ev->clearing and will be passed to the driver on the next ->check_events() invocation. This change makes sr generate MEDIA_CHANGE when media is ejected from userland - e.g. with eject(1). Note: Given the current usage, it seems @clearing hint is needlessly complex. disk_clear_events() can simply clear all events and the hint can be boolean @flush. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-30Revert "block: Remove extra discard_alignment from hd_struct."Jens Axboe
It was not a good idea to start dereferencing disk->queue from the fs sysfs strategy for displaying discard alignment. We ran into first a NULL pointer deref, and after fixing that we sometimes see unvalid disk->queue pointer values. Since discard is the only one of the bunch actually looking into the queue, just revert the change. This reverts commit 23ceb5b7719e9276d4fa72a3ecf94dd396755276. Conflicts: fs/partitions/check.c
2011-05-06block: Remove extra discard_alignment from hd_struct.Tao Ma
Currently, hd_struct.discard_alignment is only used when we show /sys/block/sdx/sdx/discard_alignment. So remove it and calculate when it is asked to show. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21block: don't block events on excl write for non-optical devicesTejun Heo
Disk event code automatically blocks events on excl write. This is primarily to avoid issuing polling commands while burning is in progress. This behavior doesn't fit other types of devices with removeable media where polling commands don't have adverse side effects and door locking usually doesn't exist. This patch introduces new genhd flag which controls the auto-blocking behavior and uses it to enable auto-blocking only on optical devices. Note for stable: 2.6.38 and later only Cc: stable@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-22block: fix non-atomic access to genhd inflight structuresShaohua Li
After the stack plugging introduction, these are called lockless. Ensure that the counters are updated atomically. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge branch 'for-2.6.38/event-handling' into for-2.6.38/coreJens Axboe
2011-01-07block: add internal hd part table referencesJens Axboe
We can't use krefs since it's apparently restricted to very basic reference counting. This reverts commit e4a683c8. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-05block: fix accounting bug on cross partition mergesJerome Marchand
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. Also add a refcount to struct hd_struct to keep the partition in memory as long as users exist. We use kref_test_and_get() to ensure we don't add a reference to a partition which is going away. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16implement in-kernel gendisk events handlingTejun Heo
Currently, media presence polling for removeable block devices is done from userland. There are several issues with this. * Polling is done by periodically opening the device. For SCSI devices, the command sequence generated by such action involves a few different commands including TEST_UNIT_READY. This behavior, while perfectly legal, is different from Windows which only issues single command, GET_EVENT_STATUS_NOTIFICATION. Unfortunately, some ATAPI devices lock up after being periodically queried such command sequences. * There is no reliable and unintrusive way for a userland program to tell whether the target device is safe for media presence polling. For example, polling for media presence during an on-going burning session can make it fail. The polling program can avoid this by opening the device with O_EXCL but then it risks making a valid exclusive user of the device fail w/ -EBUSY. * Userland polling is unnecessarily heavy and in-kernel implementation is lighter and better coordinated (workqueue, timer slack). This patch implements framework for in-kernel disk event handling, which includes media presence polling. * bdops->check_events() is added, which supercedes ->media_changed(). It should check whether there's any pending event and return if so. Currently, two events are defined - DISK_EVENT_MEDIA_CHANGE and DISK_EVENT_EJECT_REQUEST. ->check_events() is guaranteed not to be called parallelly. * gendisk->events and ->async_events are added. These should be initialized by block driver before passing the device to add_disk(). The former contains the mask of all supported events and the latter the mask of all events which the device can report without polling. /sys/block/*/events[_async] export these to userland. * Kernel parameter block.events_dfl_poll_msecs controls the system polling interval (default is 0 which means disable) and /sys/block/*/events_poll_msecs control polling intervals for individual devices (default is -1 meaning use system setting). Note that if a device can report all supported events asynchronously and its polling interval isn't explicitly set, the device won't be polled regardless of the system polling interval. * If a device is opened exclusively with write access, event checking is automatically disabled until all write exclusive accesses are released. * There are event 'clearing' events. For example, both of currently defined events are cleared after the device has been successfully opened. This information is passed to ->check_events() callback using @clearing argument as a hint. * Event checking is always performed from system_nrt_wq and timer slack is set to 25% for polling. * Nothing changes for drivers which implement ->media_changed() but not ->check_events(). Going forward, all drivers will be converted to ->check_events() and ->media_change() will be dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16block: move register_disk() and del_gendisk() to block/genhd.cTejun Heo
There's no reason for register_disk() and del_gendisk() to be in fs/partitions/check.c. Move both to genhd.c. While at it, collapse unlink_gendisk(), which was artificially in a separate function due to genhd.c / check.c split, into del_gendisk(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16block: kill genhd_media_change_notify()Tejun Heo
There's no user of the facility. Kill it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-24Revert "block: fix accounting bug on cross partition merges"Jens Axboe
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327. Conflicts: include/linux/genhd.h It has numerous issues with the cleanup path and non-elevator devices. Revert it for now so we can come up with a clean version without rushing things. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-10-19block: fix accounting bug on cross partition mergesYasuaki Ishimatsu
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. When reloading partition tables, quiesce IO to ensure that no request references to the partition struct exists. When it is safe to free the partition table, the IO for that device is restarted again. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-15block, partition: add partition_meta_info to hd_structWill Drewry
I'm reposting this patch series as v4 since there have been no additional comments, and I cleaned up one extra bit of unneeded code (in 3/3). The patches are against Linus's tree: 2bfc96a127bc1cc94d26bfaa40159966064f9c8c (2.6.36-rc3). Would this patchset be suitable for inclusion in an mm branch? This changes adds a partition_meta_info struct which itself contains a union of structures that provide partition table specific metadata. This change leaves the union empty. The subsequent patch includes an implementation for CONFIG_EFI_PARTITION-based metadata. Signed-off-by: Will Drewry <wad@chromium.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-19kernel: __rcu annotationsArnd Bergmann
This adds annotations for RCU operations in core kernel components Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-03-16Remove GENHD_FL_DRIVERFSNeilBrown
This flag is not used, so best discarded. Signed-off-by: NeilBrown <neilb@suse.de> -- Hi Jens, I came across this recently - these are the only two occurances of "GENHD_FL_DRIVERFS" in the kernel, so it cannot be needed. NeilBrown Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-17percpu: add __percpu sparse annotations to core kernel subsystemsTejun Heo
Add __percpu sparse annotations to core subsystems. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-mm@kvack.org Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Biederman <ebiederm@xmission.com>
2010-01-11genhd: overlapping variable definitionStephen Hemminger
This fixes the sparse warning: fs/ext4/super.c:2390:40: warning: symbol 'i' shadows an earlier one fs/ext4/super.c:2368:22: originally declared here Using 'i' in a macro is dubious practice. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-10block: Expose discard granularityMartin K. Petersen
While SSDs track block usage on a per-sector basis, RAID arrays often have allocation blocks that are bigger. Allow the discard granularity and alignment to be set and teach the topology stacking logic how to handle them. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-06block: Seperate read and write statistics of in_flight requests v2Nikanth Karthikesan
Commit a9327cac440be4d8333bba975cbbf76045096275 added seperate read and write statistics of in_flight requests. And exported the number of read and write requests in progress seperately through sysfs. But Corrado Zoccolo <czoccolo@gmail.com> reported getting strange output from "iostat -kx 2". Global values for service time and utilization were garbage. For interval values, utilization was always 100%, and service time is higher than normal. So this was reverted by commit 0f78ab9899e9d6acb09d5465def618704255963b The problem was in part_round_stats_single(), I missed the following: if (now == part->stamp) return; - if (part->in_flight) { + if (part_in_flight(part)) { __part_stat_add(cpu, part, time_in_queue, part_in_flight(part) * (now - part->stamp)); __part_stat_add(cpu, part, io_ticks, (now - part->stamp)); With this chunk included, the reported regression gets fixed. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> -- Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-04Revert "Seperate read and write statistics of in_flight requests"Jens Axboe
This reverts commit a9327cac440be4d8333bba975cbbf76045096275. Corrado Zoccolo <czoccolo@gmail.com> reports: "with 2.6.32-rc1 I started getting the following strange output from "iostat -kx 2": Linux 2.6.31bisect (et2) 04/10/2009 _i686_ (2 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 10,70 0,00 3,16 15,75 0,00 70,38 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 18,22 0,00 0,67 0,01 14,77 0,02 43,94 0,01 10,53 39043915,03 2629219,87 sdb 60,89 9,68 50,79 3,04 1724,43 50,52 65,95 0,70 13,06 488437,47 2629219,87 avg-cpu: %user %nice %system %iowait %steal %idle 2,72 0,00 0,74 0,00 0,00 96,53 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 sdb 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 avg-cpu: %user %nice %system %iowait %steal %idle 6,68 0,00 0,99 0,00 0,00 92,33 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 sdb 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 avg-cpu: %user %nice %system %iowait %steal %idle 4,40 0,00 0,73 1,47 0,00 93,40 Device: rrqm/s wrqm/s r/s w/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util sda 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 0,00 100,00 sdb 0,00 4,00 0,00 3,00 0,00 28,00 18,67 0,06 19,50 333,33 100,00 Global values for service time and utilization are garbage. For interval values, utilization is always 100%, and service time is higher than normal. I bisected it down to: [a9327cac440be4d8333bba975cbbf76045096275] Seperate read and write statistics of in_flight requests and verified that reverting just that commit indeed solves the issue on 2.6.32-rc1." So until this is debugged, revert the bad commit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-14Seperate read and write statistics of in_flight requestsNikanth Karthikesan
Currently, there is a single in_flight counter measuring the number of requests in the request_queue. But some monitoring tools would like to know how many read requests and write requests are in progress. Split the current in_flight counter into two seperate counters for read and write. This information is exported as a sysfs attribute, as changing the currently available stat files would break the existing tools. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-15Driver Core: block: add nodename support for block drivers.Kay Sievers
This adds support for block drivers to report their requested nodename to userspace. It also updates a number of block drivers to provide the needed subdirectory and device name to be used for them. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-12Merge branch 'for-2.6.31' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-2.6.31' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (29 commits) ide: re-implement ide_pci_init_one() on top of ide_pci_init_two() ide: unexport ide_find_dma_mode() ide: fix PowerMac bootup oops ide: skip probe if there are no devices on the port (v2) sl82c105: add printk() logging facility ide-tape: fix proc warning ide: add IDE_DFLAG_NIEN_QUIRK device flag ide: respect quirk_drives[] list on all controllers hpt366: enable all quirks for devices on quirk_drives[] list hpt366: sync quirk_drives[] list with pdc202xx_{new,old}.c ide: remove superfluous SELECT_MASK() call from do_rw_taskfile() ide: remove superfluous SELECT_MASK() call from ide_driveid_update() icside: remove superfluous ->maskproc method ide-tape: fix IDE_AFLAG_* atomic accesses ide-tape: change IDE_AFLAG_IGNORE_DSC non-atomically pdc202xx_old: kill resetproc() method pdc202xx_old: don't call pdc202xx_reset() on IRQ timeout pdc202xx_old: use ide_dma_test_irq() ide: preserve Host Protected Area by default (v2) ide-gd: implement block device ->set_capacity method (v2) ...
2009-06-07partitions: add ->set_capacity block device methodBartlomiej Zolnierkiewicz
* Add ->set_capacity block device method and use it in rescan_partitions() to attempt enabling native capacity of the device upon detecting the partition which exceeds device capacity. * Add GENHD_FL_NATIVE_CAPACITY flag to try limit attempts of enabling native capacity during partition scan. Together with the consecutive patch implementing ->set_capacity method in ide-gd device driver this allows automatic disabling of Host Protected Area (HPA) if any partitions overlapping HPA are detected. Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-22block: Export I/O topology for block devices and partitionsMartin K. Petersen
To support devices with physical block sizes bigger than 512 bytes we need to ensure proper alignment. This patch adds support for exposing I/O topology characteristics as devices are stacked. logical_block_size is the smallest unit the device can address. physical_block_size indicates the smallest I/O the device can write without incurring a read-modify-write penalty. The io_min parameter is the smallest preferred I/O size reported by the device. In many cases this is the same as the physical block size. However, the io_min parameter can be scaled up when stacking (RAID5 chunk size > physical block size). The io_opt characteristic indicates the optimal I/O size reported by the device. This is usually the stripe width for arrays. The alignment_offset parameter indicates the number of bytes the start of the device/partition is offset from the device's natural alignment. Partition tools and MD/DM utilities can use this to pad their offsets so filesystems start on proper boundaries. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22block: include empty disks in /proc/diskstatsTejun Heo
/proc/diskstats used to show stats for all disks whether they're zero-sized or not and their non-zero partitions. Commit 074a7aca7afa6f230104e8e65eba3420263714a5 accidentally changed the behavior such that it doesn't print out zero sized disks. This patch implements DISK_PITER_INCL_EMPTY_PART0 flag to partition iterator and uses it in diskstats_show() such that empty part0 is shown in /proc/diskstats. Reported and bisectd by Dianel Collins. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Daniel Collins <solemnwarning@solemnwarning.no-ip.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: genhd.h cleanup patchPetros Koutoupis
In include/linux/genhd.h: Line 335 has a comment that needs to be updated from: /* drivers/block/ll_rw_blk.c */ to /* block/blk-core.c */. Also as of kernel 2.6.16, the function definition for get_blkdev_list was removed from block/genhd.c but the function declaration is still present on line 339. This patch addresses both those fixes, by updating the comment and removing the declaration. Signed-off-by: Petros Koutoupis <pkoutoupis@hydrasystemsllc.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: genhd.h comment needs updatingPetros Koutoupis
The include/linux/genhd.h file, on line 338-352 declares some function prototypes in which the comment on line 338 states that the definition of these prototypes are to be found at drivers/block/genhd.c. The problem is that genhd.c has been relocated to block/genhd.c. See attached patch to correct this minor cosmetic typo. Signed-off-by: Petros Koutoupis <pkoutoupis@hydrasystemsllc.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: add one-hit cache for disk partition lookupJens Axboe
disk_map_sector_rcu() returns a partition from a sector offset, which we use for IO statistics on a per-partition basis. The lookup itself is an O(N) list lookup, where N is the number of partitions. This actually hurts performance quite a bit, even on the lower end partitions. On higher numbered partitions, it can get pretty bad. Solve this by adding a one-hit cache for partition lookup. This makes the lookup O(1) for the case where we do most IO to one partition. Even for mixed partition workloads, amortized cost is pretty close to O(1) since the natural IO batching makes the one-hit cache last for lots of IOs. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-18block: make add_partition() return pointer to hd_structTejun Heo
Make add_partition() return pointer to the new hd_struct on success and ERR_PTR() value on failure. This change will be used to fix md autodetection bug. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23proc: move /proc/diskstats boilerplate to block/genhd.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23proc: move rest of /proc/partitions code to block/genhd.cAlexey Dobriyan
2008-10-09block: allow disk to have extended device numberTejun Heo
Now that disk and partition handlings are mostly unified, it's easy to allow disk to have extended device number. This patch makes add_disk() use extended device number if disk->minors is zero. Both sd and ide-disk are updated to use this. * sd_format_disk_name() is implemented which can generically determine the drive name. This removes disk number restriction stemming from limited device names. * If sd index goes over SD_MAX_DISKS (which can be increased now BTW), sd simply doesn't initialize minors letting block layer choose extended device number. * If CONFIG_DEBUG_EXT_DEVT is set, both sd and ide-disk always set minors to 0 and use extended device numbers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: replace @ext_minors with GENHD_FL_EXT_DEVTTejun Heo
With previous changes, it's meaningless to limit the number of partitions. Replace @ext_minors with GENHD_FL_EXT_DEVT such that setting the flag allows the disk to have maximum number of allowed partitions (only limited by the number of entries in parsed_partitions as determined by MAX_PART constant). This kills not-too-pretty alloc_disk_ext[_node]() functions and makes @minors parameter to alloc_disk[_node]() unnecessary. The parameter is left alone to avoid disturbing the users. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
