Convert all users of struct acpi_reference_args to more generic
fwnode_reference_args. This will
1) avoid an ACPI specific references to device nodes with integer
arguments as well as
2) allow making references to nodes other than device nodes in ACPI.
As a by-product, convert the fwnode interger arguments to u64. The
arguments were 64-bit integers on ACPI but the fwnode arguments were
just 32-bit.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Constify device_get_match_data() as OF and ACPI variants return
constant value.
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
There is an OF/ACPI function to obtain the driver data. We want to hide
OF/ACPI details from the device drivers and abstract following the device
family of functions.
Signed-off-by: Sinan Kaya <okaya@codeaurora.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The fwnode_handle_get() function is used to obtain a reference to an
fwnode. A common usage pattern for the OF equivalent of the function is:
mynode = of_node_get(node);
Similarly make fwnode_handle_get() return the fwnode to which the
reference was obtained.
The new fwnode_property_get_reference_args() interface amends the fwnode
property API with the functionality of both of_parse_phandle_with_args()
and __acpi_node_get_property_reference().
The semantics is slightly different: the cells property is ignored on ACPI
as the number of arguments can be explicitly obtained from the firmware
interface.
Make fwnode arguments to the fwnode property API const.
Instead of relying on the struct fwnode_handle type field, define
fwnode_operations structs for all separate types of fwnodes. To find out
the type, compare to the ops field to relevant ops structs.
This change has two benefits:
1. it avoids adding the type field to each and every instance of struct
fwnode_handle, thus saving memory and
2. makes the ops field the single factor that defines both the types of
the fwnode as well as defines the implementation of its operations,
decreasing the possibility of bugs when developing code dealing with
fwnode internals.
Suggested-by: Rob Herring <robh@kernel.org>
fwnode_call_int_op() isn't suitable for calling ops that return bool
since it effectively causes the result returned to the user to be
true when an op hasn't been defined or the fwnode is NULL.
Address this by introducing fwnode_call_bool_op() for calling ops
that return bool.
Fixes: 3708184afc77 "device property: Move FW type specific functionality to FW specific files"
Fixes: 2294b3af05e9 "device property: Introduce fwnode_device_is_available()"
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Add fwnode_device_is_available() to tell whether the device corresponding
to a certain fwnode_handle is available for use.
Acked-by: Rob Herring <robh@kernel.org>
Move firmware specific implementations of the fwnode graph operations to
firmware specific locations.
The device and fwnode property API supports Devicetree, ACPI and pset
properties. The implementation of this functionality for each firmware
type was embedded in the fwnode property core. Move it out to firmware
type specific locations, making it easier to maintain.
Depends-on: ("of: Move OF property and graph API from base.c to property.c")
Similar to OF endpoints, endpoint type nodes can be also supported on
ACPI. In order to make it possible for drivers to ignore the matter,
add a type for fwnode_endpoint and a function to parse them.
On ACPI, find the child node index instead of relying on the "endpoint"
property.
On systems booting with a device tree, every struct device is associated
with a struct device_node, that provides its DT firmware representation.
The device node can be used in generic kernel contexts (eg IRQ
translation, IOMMU streamid mapping), to retrieve the properties
associated with the device and carry out kernel operations accordingly.
Owing to the 1:1 relationship between the device and its device_node,
the device_node can also be used as a look-up token for the device (eg
looking up a device through its device_node), to retrieve the device in
kernel paths where the device_node is available.
On systems booting with ACPI, the same abstraction provided by
the device_node is required to provide look-up functionality.
The struct acpi_device, that represents firmware objects in the
ACPI namespace already includes a struct fwnode_handle of
type FWNODE_ACPI as their member; the same abstraction is missing
though for devices that are instantiated out of static ACPI tables
entries (eg ARM SMMU devices).
Add a new fwnode_handle type to associate devices created out
of static ACPI table entries to the respective firmware components
and create a simple ACPI core layer interface to dynamically allocate
and free the corresponding firmware nodes so that kernel subsystems
can use it to instantiate the nodes and associate them with the
respective devices.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Tomasz Nowicki <tn@semihalf.com>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Tomasz Nowicki <tn@semihalf.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Pull power management and ACPI updates from Rafael Wysocki:
"Quite a new features are included this time.
First off, the Collaborative Processor Performance Control interface
(version 2) defined by ACPI will now be supported on ARM64 along with
a cpufreq frontend for CPU performance scaling.
Second, ACPI gets a new infrastructure for the early probing of IRQ
chips and clock sources (along the lines of the existing similar
mechanism for DT).
Next, the ACPI core and the generic device properties API will now
support a recently introduced hierarchical properties extension of the
_DSD (Device Specific Data) ACPI device configuration object. If the
ACPI platform firmware uses that extension to organize device
properties in a hierarchical way, the kernel will automatically handle
it and make those properties available to device drivers via the
generic device properties API.
It also will be possible to build the ACPICA's AML interpreter
debugger into the kernel now and use that to diagnose AML-related
problems more efficiently. In the future, this should make it
possible to single-step AML execution and do similar things.
Interesting stuff, although somewhat experimental at this point.
Finally, the PM core gets a new mechanism that can be used by device
drivers to distinguish between suspend-to-RAM (based on platform
firmware support) and suspend-to-idle (or other variants of system
suspend the platform firmware is not involved in) and possibly
optimize their device suspend/resume handling accordingly.
In addition to that, some existing features are re-organized quite
substantially.
First, the ACPI-based handling of PCI host bridges on x86 and ia64 is
unified and the common code goes into the ACPI core (so as to reduce
code duplication and eliminate non-essential differences between the
two architectures in that area).
Second, the Operating Performance Points (OPP) framework is
reorganized to make the code easier to find and follow.
Next, the cpufreq core's sysfs interface is reorganized to get rid of
the "primary CPU" concept for configurations in which the same
performance scaling settings are shared between multiple CPUs.
Finally, some interfaces that aren't necessary any more are dropped
from the generic power domains framework.
On top of the above we have some minor extensions, cleanups and bug
fixes in multiple places, as usual.
Specifics:
- ACPICA update to upstream revision 20150930 (Bob Moore, Lv Zheng).
The most significant change is to allow the AML debugger to be
built into the kernel. On top of that there is an update related
to the NFIT table (the ACPI persistent memory interface) and a few
fixes and cleanups.
- ACPI CPPC2 (Collaborative Processor Performance Control v2) support
along with a cpufreq frontend (Ashwin Chaugule).
This can only be enabled on ARM64 at this point.
- New ACPI infrastructure for the early probing of IRQ chips and
clock sources (Marc Zyngier).
- Support for a new hierarchical properties extension of the ACPI
_DSD (Device Specific Data) device configuration object allowing
the kernel to handle hierarchical properties (provided by the
platform firmware this way) automatically and make them available
to device drivers via the generic device properties interface
(Rafael Wysocki).
- Generic device properties API extension to obtain an index of
certain string value in an array of strings, along the lines of
of_property_match_string(), but working for all of the supported
firmware node types, and support for the "dma-names" device
property based on it (Mika Westerberg).
- ACPI core fix to parse the MADT (Multiple APIC Description Table)
entries in the order expected by platform firmware (and mandated by
the specification) to avoid confusion on systems with more than 255
logical CPUs (Lukasz Anaczkowski).
- Consolidation of the ACPI-based handling of PCI host bridges on x86
and ia64 (Jiang Liu).
- ACPI core fixes to ensure that the correct IRQ number is used to
represent the SCI (System Control Interrupt) in the cases when it
has been re-mapped (Chen Yu).
- New ACPI backlight quirk for Lenovo IdeaPad S405 (Hans de Goede).
- ACPI EC driver fixes (Lv Zheng).
- Assorted ACPI fixes and cleanups (Dan Carpenter, Insu Yun, Jiri
Kosina, Rami Rosen, Rasmus Villemoes).
- New mechanism in the PM core allowing drivers to check if the
platform firmware is going to be involved in the upcoming system
suspend or if it has been involved in the suspend the system is
resuming from at the moment (Rafael Wysocki).
This should allow drivers to optimize their suspend/resume handling
in some cases and the changes include a couple of users of it (the
i8042 input driver, PCI PM).
- PCI PM fix to prevent runtime-suspended devices with PME enabled
from being resumed during system suspend even if they aren't
configured to wake up the system from sleep (Rafael Wysocki).
- New mechanism to report the number of a wakeup IRQ that woke up the
system from sleep last time (Alexandra Yates).
- Removal of unused interfaces from the generic power domains
framework and fixes related to latency measurements in that code
(Ulf Hansson, Daniel Lezcano).
- cpufreq core sysfs interface rework to make it handle CPUs that
share performance scaling settings (represented by a common cpufreq
policy object) more symmetrically (Viresh Kumar).
This should help to simplify the CPU offline/online handling among
other things.
- cpufreq core fixes and cleanups (Viresh Kumar).
- intel_pstate fixes related to the Turbo Activation Ratio (TAR)
mechanism on client platforms which causes the turbo P-states range
to vary depending on platform firmware settings (Srinivas
Pandruvada).
- intel_pstate sysfs interface fix (Prarit Bhargava).
- Assorted cpufreq driver (imx, tegra20, powernv, integrator) fixes
and cleanups (Bai Ping, Bartlomiej Zolnierkiewicz, Shilpasri G
Bhat, Luis de Bethencourt).
- cpuidle mvebu driver cleanups (Russell King).
- OPP (Operating Performance Points) framework code reorganization to
make it more maintainable (Viresh Kumar).
- Intel Broxton support for the RAPL (Running Average Power Limits)
power capping driver (Amy Wiles).
- Assorted power management code fixes and cleanups (Dan Carpenter,
Geert Uytterhoeven, Geliang Tang, Luis de Bethencourt, Rasmus
Villemoes)"
* tag 'pm+acpi-4.4-rc1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (108 commits)
cpufreq: postfix policy directory with the first CPU in related_cpus
cpufreq: create cpu/cpufreq/policyX directories
cpufreq: remove cpufreq_sysfs_{create|remove}_file()
cpufreq: create cpu/cpufreq at boot time
cpufreq: Use cpumask_copy instead of cpumask_or to copy a mask
cpufreq: ondemand: Drop unnecessary locks from update_sampling_rate()
PM / Domains: Merge measurements for PM QoS device latencies
PM / Domains: Don't measure ->start|stop() latency in system PM callbacks
PM / clk: Fix broken build due to non-matching code and header #ifdefs
ACPI / Documentation: add copy_dsdt to ACPI format options
ACPI / sysfs: correctly check failing memory allocation
ACPI / video: Add a quirk to force native backlight on Lenovo IdeaPad S405
ACPI / CPPC: Fix potential memory leak
ACPI / CPPC: signedness bug in register_pcc_channel()
ACPI / PAD: power_saving_thread() is not freezable
ACPI / PM: Fix incorrect wakeup IRQ setting during suspend-to-idle
ACPI: Using correct irq when waiting for events
ACPI: Use correct IRQ when uninstalling ACPI interrupt handler
cpuidle: mvebu: disable the bind/unbind attributes and use builtin_platform_driver
cpuidle: mvebu: clean up multiple platform drivers
In order to be able to reference an irqdomain from ACPI, we need
to be able to create an identifier, which is usually a struct
device_node.
This device node does't really fit the ACPI infrastructure, so
we cunningly allocate a new structure containing a fwnode_handle,
and return that.
This structure doesn't really point to a device (interrupt
controllers are not "real" devices in Linux), but as we cannot
really deny that they exist, we create them with a new fwnode_type
(FWNODE_IRQCHIP).
Reviewed-and-tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Tomasz Nowicki <tomasz.nowicki@linaro.org>
Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Cc: Graeme Gregory <graeme@xora.org.uk>
Cc: Jake Oshins <jakeo@microsoft.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Link: http://lkml.kernel.org/r/1444737105-31573-9-git-send-email-marc.zyngier@arm.com
In some cases, the information expressed via device properties is
hierarchical by nature. For example, the properties of a composite
device consisting of multiple semi-dependent components may need
to be represented in the form of a tree of property data sets
corresponding to specific components of the device.
Unfortunately, using ACPI device objects for this purpose turns out
to be problematic, mostly due to the assumption made by some operating
systems (that platform firmware generally needs to work with) that
each device object in the ACPI namespace represents a device requiring
a separate driver. That assumption leads to complications which
reportedly are impractically difficult to overcome and a different
approach is needed for the sake of interoperability.
The approach implemented here is based on extending _DSD via pointers
(links) to additional ACPI objects returning data packages formatted
in accordance with the _DSD formatting rules defined by Section 6.2.5
of ACPI 6. Those additional objects are referred to as data-only
subnodes of the device object containing the _DSD pointing to them.
The links to them need to be located in a separate section of the
_DSD data package following UUID dbb8e3e6-5886-4ba6-8795-1319f52a966b
referred to as the Hierarchical Data Extension UUID as defined in [1].
Each of them is represented by a package of two strings. The first
string in that package (the key) is regarded as the name of the
data-only subnode pointed to by the link. The second string in it
(the target) is expected to hold the ACPI namespace path (possibly
utilizing the usual ACPI namespace search rules) of an ACPI object
evaluating to a data package extending the _DSD.
The device properties initialization code follows those links,
creates a struct acpi_data_node object for each of them to store
the data returned by the ACPI object pointed to by it and processes
those data recursively (which may lead to the creation of more
struct acpi_data_node objects if the returned data package contains
the Hierarchical Data Extension UUID section with more links in it).
All of the struct acpi_data_node objects are present until the the
ACPI device object containing the _DSD with links to them is deleted
and they are deleted along with that object.
[1]: http://www.uefi.org/sites/default/files/resources/_DSD-hierarchical-data-extension-UUID-v1.pdf
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Introduce data structures and code allowing "built-in" properties
to be associated with devices in such a way that they will be used
by the device_property_* API if no proper firmware node (neither DT
nor ACPI) is present for the given device.
Each property is to be represented by a property_entry structure.
An array of property_entry structures (terminated with a null
entry) can be pointed to by the properties field of struct
property_set that can be added as a firmware node to a struct
device using device_add_property_set(). That will cause the
device_property_* API to use that property_set as the source
of properties if the given device does not have a DT node or
an ACPI companion device object associated with it.
Tested-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Add a secondary pointer to struct fwnode_handle so as to make it
possible for a device to have two firmware nodes associated with
it at the same time, for example, an ACPI node and a node with
a set of properties provided by platform initialization code.
In the future that will allow device property lookup to fall back
from the primary firmware node to the secondary one if the given
property is not present there to make it easier to provide defaults
for device properties used by device drivers.
Introduce two helper routines, set_primary_fwnode() and
set_secondary_fwnode() allowing callers to add a primary/secondary
firmware node to the given device in such a way that
(1) If there's only one firmware node for that device, it will be
pointed to by the device's firmware node pointer.
(2) If both the primary and secondary firmware nodes are present,
the primary one will be pointed to by the device's firmware
node pointer, while the secondary one will be pointed to by the
primary node's secondary pointer.
(3) If one of these nodes is removed (by calling one of the new
nelpers with NULL as the second argument), the other one will
be preserved.
Make ACPI use set_primary_fwnode() for attaching its firmware nodes
to devices.
Now that we have struct fwnode_handle, we can use that to point to
ACPI companions from struct device objects instead of pointing to
struct acpi_device directly.
There are two benefits from that. First, the somewhat ugly and
hackish struct acpi_dev_node can be dropped and, second, the same
struct fwnode_handle pointer can be used in the future to point
to other (non-ACPI) firmware device node types.
Acked-by: Grant Likely <grant.likely@linaro.org>
