path: root/include/linux/fsl_devices.h
2008-07-16gianfar: Add magic packet and suspend/resume support.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16powerpc/mpc83xx: Power Management supportScott Wood
Basic PM support for 83xx. Standby is implemented as sleep. Suspend-to-RAM is implemented as "deep sleep" (with the processor turned off) on 831x. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-07-18Fix RGMII-ID handling in gianfarAndy Fleming
The TSEC/eTSEC can detect the interface to the PHY automatically, but it isn't able to detect whether the RGMII connection needs internal delay. So we need to detect that change in the device tree, propagate it to the platform data, and then check it if we're in RGMII. This fixes a bug on the 8641D HPCN board where the Vitesse PHY doesn't use the delay for RGMII. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-07-17spi_mpc83xx.c: support QE enabled 83xx CPU's like mpc832xJoakim Tjernlund
Quicc Engine enabled mpc83xx CPU's has a somewhat different HW interface to the SPI controller. This patch adds a qe_mode knob that sees to that needed adaptions are performed. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[POWERPC] 8xx: mpc885ads pcmcia supportVitaly Bordug
Adds support for PowerQuicc on-chip PCMCIA. The driver is implemented as of_device, so only arch/powerpc stuff is capable to use it, which now implies only mpc885ads reference board. To cope with the code that should be hooked inside driver, but is really board specific (like set_voltage), global structure mpc8xx_pcmcia_ops holds necessary function pointers that are filled in the BSP code. [akpm@linux-foundation.org: whitespace diddles] Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-28ucc_geth: migrate ucc_geth to phylibKim Phillips
migrate ucc_geth to use the common phylib code. There are several side effects from doing this: o deprecate 'interface' property specification present in some old device tree source files in favour of a split 'max-speed' and 'interface-type' description to appropriately match definitions in include/linux/phy.h. Note that 'interface' property is still honoured if max-speed or interface-type are not present (backward compatible). o compile-time CONFIG_UGETH_HAS_GIGA is eliminated in favour of probe time speed derivation logic. o adjust_link streamlined to only operate on maccfg2 and upsmr.r10m, instead of reapplying static initial values related to the interface-type. o Addition of UEC MDIO of_platform driver requires platform code add 'mdio' type to id list prior to calling of_platform_bus_probe (separate patch). o ucc_struct_init introduced to reduce ucc_geth_startup complexity. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-10[PPC] Fix compile failure do to introduction of PHY_POLLKumar Gala
PHY_POLL is defined in <linux/phy.h> include it in <linux/fsl_devices.h> so board code will have it defined. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-04[POWERPC] Add QUICC Engine (QE) infrastructureLi Yang
Add QUICC Engine (QE) configuration, header files, and QE management and library code that are used by QE devices drivers. Includes Leo's modifications up to, and including, the platform_device to of_device adaptation: "The series of patches add generic QE infrastructure called qe_lib, and MPC8360EMDS board support. Qe_lib is used by QE device drivers such as ucc_geth driver. This version updates QE interrupt controller to use new irq mapping mechanism, addresses all the comments received with last submission and includes some style fixes. v2: Change to use device tree for BCSR and MURAM; Remove I/O port interrupt handling code as it is not generic enough. v3: Address comments from Kumar; Update definition of several device tree nodes; Copyright style change." In addition, the following changes have been made: o removed typedefs o uint -> u32 conversions o removed following defines: QE_SIZEOF_BD, BD_BUFFER_ARG, BD_BUFFER_CLEAR, BD_BUFFER, BD_STATUS_AND_LENGTH_SET, BD_STATUS_AND_LENGTH, and BD_BUFFER_SET because they hid sizeof/in_be32/out_be32 operations from the reader. o fixed qe_snums_init() serial num assignment to use a const array o made CONFIG_UCC_FAST select UCC_SLOW o reduced NR_QE_IC_INTS from 128 to 64 o remove _IO_BASE, etc. defines (not used) o removed irrelevant comments, added others to resemble removed BD_ defines o realigned struct definitions in headers o various other style fixes including things like pinMask -> pin_mask o fixed a ton of whitespace issues o marked ioregs as __be32/__be16 o removed platform_device code and redundant get_qe_base() o removed redundant comments o added cpu_relax() to qe_reset o uncasted all get_property() assignments o eliminated unneeded casts o eliminated immrbar_phys_to_virt (not used) Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Shlomi Gridish <gridish@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-21[PATCH] spi: add spi master driver for Freescale MPC83xx SPI controllerKumar Gala
This driver supports the SPI controller on the MPC83xx SoC devices from Freescale. Note, this driver supports only the simple shift register SPI controller and not the descriptor based CPM or QUICCEngine SPI controller. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] USB: EHCI for Freescale 83xxRandy Vinson
Adding a Host Mode USB driver for the Freescale 83xx. This driver supports both the Dual-Role (DR) controller and the Multi-Port-Host (MPH) controller present in the Freescale MPC8349. It has been tested with the MPC8349CDS reference system. This driver depends on platform support code for setting up the pins on the device package in a manner appropriate for the board in use. Note that this patch requires selecting the EHCI controller option under the USB Host menu. Signed-off-by: Randy Vinson <rvinson@mvista.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-12[PATCH] gianfar: Use new PHY_ID_FMT macroKumar Gala
Make the driver produce the string used by phy_connect and have board specific code pass the integer mii bus id and phy device id for the specific controller instance. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-12[PATCH] gianfar mii: Use proper resource for MII memory regionKumar Gala
We can now have the gianfar mii platform device have a proper resource for the IO memory region for its registers. Previously we passed this information that the platform_data structure because we couldn't handle overlapping memory regions for platform devices. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] ppc32: 85xx PHY Platform UpdateAndy Fleming
This patch updates the 85xx platform code to support the new PHY Layer. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <Kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-21[PATCH] ppc32: Added support for new MPC8548 family of PowerQUICC III processorsKumar Gala
Added descriptions of the new MPC8548 family processors, e500 core and peripherals. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
