Add the VESA Display Monitor Timing (DMT) table.
During parsing of Standard Timings, it compare the 2 byte STD code
with DMT to see what the VESA mode should be. If there is no entry
in the vesa_modes table or no match found, it fallsback to the
GTF timings.
Signed-off-by: David Ung <davidu@nvidia.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Add high resolution modes to vesa_modes struct.
This removes the sparse warnings on arm platforms:
warning: cast removes address space of expression
Signed-off-by: Archit Taneja <archit@ti.com>
Cc: H Hartley Sweeten <hsweeten at visionengravers.com>
Cc: Alexander Shiyan <shc_work@mail.ru>
Silence the warning when building with -Wsign-compare when fb.h is
included:
include/linux/fb.h: In function ‘__fb_pad_aligned_buffer’:
include/linux/fb.h:650:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (j = 0; j < s_pitch; j++)
Signed-off-by: Brian W Hart <hartb@linux.vnet.ibm.com>
Check EDID Vendor Specific Data Block bytes to see if the connection
is HDMI and set FB_MISC_HDMI.
Signed-off-by: Christopher Freeman <cfreeman@nvidia.com>
If we fail to remove a conflicting fb driver, we need to abort the
loading of the second driver to avoid likely kernel panics.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: linux-fbdev@vger.kernel.org
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Add fb_<level> convenience macros for emitting the
"fb%d: ", struct fb_info->node value.
Neatens and shortens the code a bit.
drm_get_connector_name now returns a const value, which causes the following
compilation warning:
drivers/gpu/drm/drm_fb_helper.c: In function ‘drm_fb_helper_parse_command_line’:
drivers/gpu/drm/drm_fb_helper.c:127:3: warning: passing argument 1 of ‘fb_get_options’ discards ‘const’ qualifier from pointer target type [enabled by default]
In file included from drivers/gpu/drm/drm_fb_helper.c:35:0:
include/linux/fb.h:627:12: note: expected ‘char *’ but argument is of type ‘const char *’
As fb_get_options uses its name argument as read only, make it const. This
fixes the aforementioned compilation warning.
Signed-off-by: Vincent Stehlé <vincent.stehle@freescale.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: trivial@kernel.org
Use the new PM routines to indicate whether we need to VT switch at suspend
and resume time. When a new driver is bound, set its flag accordingly,
and when unbound, remove it from the PM's console tracking list.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Add helper to get fb_videomode from devicetree.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Thierry Reding <thierry.reding@avionic-design.de>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Tested-by: Philipp Zabel <p.zabel@pengutronix.de>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Tested-by: Afzal Mohammed <Afzal@ti.com>
Tested-by: Rob Clark <robclark@gmail.com>
Tested-by: Leela Krishna Amudala <leelakrishna.a@gmail.com>
Add a function to convert from the generic videomode to a fb_videomode.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Pull fbdev updates from Florian Tobias Schandinat:
- driver for AUO-K1900 and AUO-K1901 epaper controller
- large updates for OMAP (e.g. decouple HDMI audio and video)
- some updates for Exynos and SH Mobile
- various other small fixes and cleanups
* tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits)
video: bfin_adv7393fb: Fix cleanup code
video: exynos_dp: reduce delay time when configuring video setting
video: exynos_dp: move sw reset prioir to enabling sw defined function
video: exynos_dp: use devm_ functions
fb: handle NULL pointers in framebuffer release
OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request
OMAPDSS: Apply VENC timings even if panel is disabled
OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC
OMAPDSS: DISPC: Support rotation through TILER
OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n
OMAPFB: remove compiler warnings when CONFIG_BUG=n
OMAPDSS: remove compiler warnings when CONFIG_BUG=n
OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv
OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays
OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods
OMAPDSS: DISPC: Update Accumulator configuration for chroma plane
drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers
video: exynos mipi dsi: support reverse panel type
video: exynos mipi dsi: Properly interpret the interrupt source flags
video: exynos mipi dsi: Avoid races in probe()
Add FB_EARLY_EVENT_BLANK and FB_R_EARLY_EVENT_BLANK event mode supports.
first, fb_notifier_call_chain() is called with FB_EARLY_EVENT_BLANK and
fb_blank() of specific fb driver is called and then
fb_notifier_call_chain() is called with FB_EVENT_BLANK again at
fb_blank(). and if fb_blank() was failed then fb_nitifier_call_chain()
would be called with FB_R_EARLY_EVENT_BLANK to revert the previous
effects.
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Richard Purdie <rpurdie@rpsys.net>
With this optional callback the driver is notified when the first page
is entered into the pagelist and a new deferred_io call is scheduled.
A possible use-case for this is runtime-pm. In the first_io call
pm_runtime_get()
could be called, which starts an asynchronous runtime_resume of the
device. In the deferred_io callback a call to
pm_runtime_barrier()
makes the sure, the device is resumed by then and a
pm_runtime_put()
may put the device back to sleep.
Also, some SoCs may use the runtime-pm system to determine if they
are able to enter deeper idle states. Therefore it is necessary to
keep the use-count from the first written page until the conclusion
of the screen update, to prevent the system from going to sleep before
completing the pending update.
Two users of defio were using kmalloc to allocate the structure.
These allocations are changed to kzalloc, to prevent uninitialised
.first_io members in those drivers.
Signed-off-by: Heiko Stübner <heiko@sntech.de>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/device.h> avoidance patches from Paul Gortmaker:
"Nearly every subsystem has some kind of header with a proto like:
void foo(struct device *dev);
and yet there is no reason for most of these guys to care about the
sub fields within the device struct. This allows us to significantly
reduce the scope of headers including headers. For this instance, a
reduction of about 40% is achieved by replacing the include with the
simple fact that the device is some kind of a struct.
Unlike the much larger module.h cleanup, this one is simply two
commits. One to fix the implicit <linux/device.h> users, and then one
to delete the device.h includes from the linux/include/ dir wherever
possible."
* tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
device.h: audit and cleanup users in main include dir
device.h: cleanup users outside of linux/include (C files)
The <linux/device.h> header includes a lot of stuff, and
it in turn gets a lot of use just for the basic "struct device"
which appears so often.
Clean up the users as follows:
1) For those headers only needing "struct device" as a pointer
in fcn args, replace the include with exactly that.
2) For headers not really using anything from device.h, simply
delete the include altogether.
3) For headers relying on getting device.h implicitly before
being included themselves, now explicitly include device.h
4) For files in which doing #1 or #2 uncovers an implicit
dependency on some other header, fix by explicitly adding
the required header(s).
Any C files that were implicitly relying on device.h to be
present have already been dealt with in advance.
Total removals from #1 and #2: 51. Total additions coming
from #3: 9. Total other implicit dependencies from #4: 7.
As of 3.3-rc1, there were 110, so a net removal of 42 gives
about a 38% reduction in device.h presence in include/*
The USB graphics card driver delays the unregistering of the framebuffer
device to a workqueue, which breaks the userspace visible remove uevent
sequence. Recent userspace tools started to support USB graphics card
hotplug out-of-the-box and rely on proper events sent by the kernel.
The framebuffer device is a direct child of the USB interface which is
removed immediately after the USB .disconnect() callback. But the fb device
in /sys stays around until its final cleanup, at a time where all the parent
devices have been removed already.
To work around that, we remove the sysfs fb device directly in the USB
.disconnect() callback and leave only the cleanup of the internal fb
data to the delayed work.
Before:
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb)
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb)
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb0 (graphics)
remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb)
remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb)
remove /2-1.2:1.0/graphics/fb0 (graphics)
After:
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics)
remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics)
Cc: stable@vger.kernel.org
Tested-by: Bernie Thompson <bernie@plugable.com>
Acked-by: Bernie Thompson <bernie@plugable.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This API will be used to support YUV frame buffer formats in a standard
way.
Last but not least, create a much needed fbdev API documentation and
document the format setting APIs.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
This just adds the refcount and the new registration lock logic. It
does not (for example) actually change the read/write/ioctl routines to
actually use the frame buffer that was opened: those function still end
up alway susing whatever the current frame buffer is at the time of the
call.
Without this, if something holds the frame buffer open over a
framebuffer switch, the close() operation after the switch will access a
fb_info that has been free'd by the unregistering of the old frame
buffer.
(The read/write/ioctl operations will normally not cause problems,
because they will - illogically - pick up the new fbcon instead. But a
switch that happens just as one of those is going on might see problems
too, the window is just much smaller: one individual op rather than the
whole open-close sequence.)
This use-after-free is apparently fairly easily triggered by the Ubuntu
11.04 boot sequence.
Acked-by: Tim Gardner <tim.gardner@canonical.com>
Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
Tested-by: Anca Emanuel <anca.emanuel@gmail.com>
Cc: Bruno Prémont <bonbons@linux-vserver.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Andy Whitcroft <andy.whitcroft@canonical.com>
change from original version -- by advice of Paul Mundt
1. remove videomemorysize definitions
2. remove unifb_enable and unifb_setup
3. use dev_warn instead of printk in fb driver
4. remove judgement for FB_ACCEL_PUV3_UNIGFX
5. adjust clk_get and clk_set_rate calls
6. add resources definitions
7. remove unifb_option
8. adjust register for platform_device
9. adjust unifb_ops position and unifb_regs assignment position
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
There is an integer overflow in fb_set_user_cmap() because cmap->len * 2
can wrap. It's basically harmless. Your terminal will be messed up
until you type reset.
This patch does three things to fix the bug.
First, it checks the return value of fb_copy_cmap() in fb_alloc_cmap().
That is enough to fix address the overflow.
Second it checks for the integer overflow in fb_set_user_cmap().
Lastly I wanted to cap "cmap->len" in fb_set_user_cmap() much lower
because it gets used to determine the size of allocation. Unfortunately
no one knows what the limit should be. Instead what this patch does
is makes the allocation happen with GFP_KERNEL instead of GFP_ATOMIC
and lets the kmalloc() decide what values of cmap->len are reasonable.
To do this, the patch introduces a function called fb_alloc_cmap_gfp()
which is like fb_alloc_cmap() except that it takes a GFP flag.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add parsing of E-EDID SVD entries. In this first version only a few
CEA/EIA-861E modes are implemented, more can be added as needed.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Modern monitors/tvs have more extended EDID information blocks which can
contain extra detailed modes. This adds a fb_edid_add_monspecs function
which drivers can use to parse those additions blocks.
Signed-off-by: Erik Gilling <konkers@android.com>
fb_{read,write} access the framebuffer using lots of fb_{read,write}l's
but don't check that the file position is aligned which can cause problems
on some architectures which do not support unaligned accesses.
Since the operations are essentially memcpy_{from,to}io, new
fb_memcpy_{from,to}fb macros have been defined and these are used instead.
For Sparc, fb_{read,write} macros use sbus_{read,write}, so this defines
new sbus_memcpy_{from,to}io functions the same as memcpy_{from,to}io but
using sbus_{read,write}b instead of {read,write}b.
Signed-off-by: James Hogan <james@albanarts.com>
Jesse's initial patch commit said:
"At panic time (i.e. when oops_in_progress is set) we should try a bit
harder to update the screen and make sure output gets to the VT, since
some drivers are capable of flipping back to it.
So make sure we try to unblank and update the display if called from a
panic context."
I've enhanced this to add a flag to the vc that console layer can set to
indicate they want this behaviour to occur. This also adds support to
fbcon for that flag and adds an fb flag for drivers to indicate they want
to use the support. It enables this for KMS drivers.
Acked-by: James Simmons <jsimmons@infradead.org>
Add fb ops to handle enter/exit of the kernel debugger. If present, the
fb core will register them with KGDB and they'll be called when the
debugger is entered and exited. The new functions are responsible for
switching to an appropriate debug framebuffer and restoring the
interrupted state at exit time.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
If the kzalloc() fails we should return NULL. All the places that call
alloc_apertures() check for this already.
Acked-by: Marcin Slusarz <marcin.slusarz@gmail.com>
When I added the flags I must have been using a 25 line terminal and missed the following flags.
The collided with flag has one user in staging despite being in-tree for 5 years.
I'm happy to push this via my drm tree unless someone really wants to do it.
Cc: stable@kernel.org
FBIO_WAITFORVSYNC is currently implemented by matroxfb, atyfb, intelfb and
more. All of them keep redefining the same FBIO_WAITFORVSYNC macro over
and over again, so move it to linux/fb.h and clean up those duplicate
defines.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Cc: Ville Syrjala <syrjala@sci.fi>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Maik Broemme <mbroemme@plusserver.de>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: "Hiremath, Vaibhav" <hvaibhav@ti.com>
let vga16fb claim 0xA0000+0x10000 region as its aperture;
drm drivers don't use it, so we have to detect it and kick
vga16fb manually - but only if drm is driving the primary card
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: James Simmons <jsimmons@infradead.org>
Cc: Ben Skeggs <bskeggs@redhat.com>
Currently vesafb/efifb/... is kicked when hardware driver is registering
framebuffer. To do it hardware must be fully functional, so there's a short
window between start of initialisation and framebuffer registration when
two drivers touch the hardware. Unfortunately sometimes it breaks nouveau
initialisation.
Fix it by kicking firmware driver(s) before we start touching the hardware.
Reported-by: Didier Spaier <didier.spaier@epsm.fr>
Tested-by: Didier Spaier <didier.spaier@epsm.fr>
Cc: Peter Jones <pjones@redhat.com>
It removes a hack from nouveau code which had to detect which
region to pass to kick vesafb/efifb.
Cc: Eric Anholt <eric@anholt.net>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Many new laptops now come with 2 gpus, one to be used for low power
modes and one for gaming/on-ac applications. These GPUs are typically
wired to the laptop panel and VGA ports via a multiplexer unit which
is controlled via ACPI methods.
4 combinations of systems typically exist - with 2 ACPI methods.
Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method
ATI/ATI - some ASUS - use ATPX ACPI Method
Intel/Nvidia - - use _DSM ACPI method
Nvidia/Nvidia - - use _DSM ACPI method.
TODO:
This patch adds support for the ATPX method and initial bits
for the _DSM methods that need to written by someone with
access to the hardware.
Add a proper non-debugfs interface - need to get some proper
testing first.
v2: add power up/down support for both devices
on W500 puts i915/radeon into D3 and cuts power to radeon.
v3: redo probing methods, no DMI list, drm devices call to
register with switcheroo, it tries to find an ATPX method on
any device and once there is two devices + ATPX it inits the
switcher.
v4: ATPX msg handling using buffers - should work on more machines
v5: rearchitect after more mjg59 discussion - move ATPX handling to
radeon driver.
v6: add file headers + initial nouveau bits (to be filled out).
v7: merge delayed switcher code.
v8: avoid suspend/resume of gpu that is off
v9: rearchitect - mjg59 is always right. - move all ATPX code to
radeon, should allow simpler DSM also proper ATRM handling
v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv
v11: fix bug in resuming Intel for 2nd time.
v12: start fixing up nvidia code blindly.
v13: blindly guess at finishing nvidia code
v14: remove radeon audio hacks - fix up intel resume more like upstream
v15: clean up printks + remove unnecessary igd/dis pointers
mount debugfs
/sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected
+ 2 cards.
DIS - immediate change to discrete
IGD - immediate change to IGD
DDIS - delayed change to discrete
DIGD - delayed change to IGD
ON - turn on not in use
OFF - turn off not in use
Tested on W500 (Intel/ATI) and T500 (Intel/ATI)
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'xen/fbdev' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen pvfb: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers.
fb-defio: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers.
fb-defio: If FBINFO_VIRTFB is defined, do not set VM_IO flag.
Fix toogle whether xenbus driver should be built as module or part of kernel.
Most users (except sh_mobile_lcdcfb.c) get their framebuffer from
vmalloc. Setting VM_IO is not necessary as the memory obtained
from vmalloc is System RAM type and is not susceptible to PCI memory
constraints.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
Remove fb_save_state() and fb_restore_state operations from frame buffer layer.
They are used only in two drivers:
1. savagefb - and cause bug #11248
2. uvesafb
Usage of these operations is misunderstood in both drivers so kill these
operations, fix the bug #11248 and avoid confusion in the future.
Tested on Savage 3D/MV card and the patch fixes the bug #11248.
The frame buffer layer uses these funtions during switch between graphics
and text mode of the console, but these drivers saves state before
switching of the frame buffer (in the fb_open) and after releasing it (in
the fb_release). This defeats the purpose of these operations.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Reported-by: Jochen Hein <jochen@jochen.org>
Tested-by: Jochen Hein <jochen@jochen.org>
Cc: Michal Januszewski <spock@gentoo.org>
Add ID 99 for PXA3xx frame buffers and report it in the pxa frame buffer
conditionally, depending on a new flag in struct pxafb_mach_info.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: linux-fbdev-devel@lists.sourceforge.net
Cc: Dennis Oliver Kropp <dok@directfb.org>
Cc: Sven Neumann <s.neumann@raumfeld.com>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Add a mutex to avoid a circular locking problem between the mm layer
semaphore and fbdev ioctl mutex through the fb_mmap() call.
Also, add mutex to all places where smem_start and smem_len fields change
so the mutex inside the fb_mmap() is actually used. Changing of these
fields before calling the framebuffer_register() are not mutexed.
This is 2.6.31 material. It removes one lockdep (fb_mmap() and
register_framebuffer()) but there is still another one (fb_release() and
register_framebuffer()). It also cleans up handling of the smem_start and
smem_len fields used by mutexed section of the fb_mmap().
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: <stable@kernel.org>
With KMS we have ran into an issue where we really want the KMS fb driver
to be the one running the console, so panics etc can be shown by switching
out of X etc.
However with vesafb/efifb built-in, we end up with those on fb0 and the
KMS fb driver on fb1, driving the same piece of hw, so this adds an fb
info flag to denote a firmware fbdev, and adds a new aperture base/size
range which can be compared when the hw drivers are installed to see if
there is a conflict with a firmware driver, and if there is the firmware
driver is unregistered and the hw driver takes over.
It uses new aperture_base/size members instead of comparing on the fix
smem_start/length, as smem_start/length might for example only cover the
first 1MB of the PCI aperture, and we could allocate the kms fb from 8MB
into the aperture, thus they would never overlap.
Acked-by: Peter Jones <pjones@redhat.com>
The documentation about the meaning of the color component bitfield
lengths in pseudocolor modes is inconsistent. Fix it, so that it
indicates the correct interpretation everywhere, i.e. that 1 << length is
the number of palette entries.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: <syrjala@sci.fi>
Acked-by: Geert Uytterhoeven <geert.uytterhoeven@gmail.com>
Before:
3648 2910 32 6590 19be drivers/video/backlight/backlight.o
3226 2812 32 6070 17b6 drivers/video/backlight/lcd.o
30990 16688 8480 56158 db5e drivers/video/console/fbcon.o
15488 8400 24 23912 5d68 drivers/video/fbmem.o
After:
3537 2870 32 6439 1927 drivers/video/backlight/backlight.o
3131 2772 32 5935 172f drivers/video/backlight/lcd.o
30876 16648 8480 56004 dac4 drivers/video/console/fbcon.o
15506 8400 24 23930 5d7a drivers/video/fbmem.o
Cc: Andrea Righi <righi.andrea@gmail.com>
Add an accelerator constant so almost all Cirrus are recognized as
accelerators by the fbset command.
Avoid calling copy_from/to_user() with fb_info->lock mutex held in fbmem
ioctl().
fb_mmap() is called under mm->mmap_sem (A) held, that also acquires
fb_info->lock (B); fb_ioctl() takes fb_info->lock (B) and does
copy_from/to_user() that might acquire mm->mmap_sem (A), causing a
deadlock.
NOTE: it doesn't push down the fb_info->lock in each own driver's
fb_ioctl(), so there are still potential deadlocks elsewhere.
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Johannes Weiner <hannes@saeurebad.de>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Impact: fix 15 make headers_check warnings:
include of <linux/types.h> is preferred over <asm/types.h>
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
