This patch implements multiple devices support for f2fs.
Given multiple devices by mkfs.f2fs, f2fs shows them entirely as one big
volume under one f2fs instance.
Internal block management is very simple, but we will modify block allocation
and background GC policy to boost IO speed by exploiting them accoording to
each device speed.
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
Previously, we used cp_version only to detect recoverable dnodes.
In order to avoid same garbage cp_version, we needed to truncate the next
dnode during checkpoint, resulting in additional discard or data write.
If we can distinguish this by using crc in addition to cp_version, we can
remove this overhead.
There is backward compatibility concern where it changes node_footer layout.
So, this patch introduces a new checkpoint flag, CP_CRC_RECOVERY_FLAG, to
detect new layout. New layout will be activated only when this flag is set.
With below serials, we will lose parts of dirents:
1) mount f2fs with inline_dentry option
2) echo 1 > /sys/fs/f2fs/sdX/dir_level
3) mkdir dir
4) touch 180 files named [1-180] in dir
5) touch 181 in dir
6) echo 3 > /proc/sys/vm/drop_caches
7) ll dir
ls: cannot access 2: No such file or directory
ls: cannot access 4: No such file or directory
ls: cannot access 5: No such file or directory
ls: cannot access 6: No such file or directory
ls: cannot access 8: No such file or directory
ls: cannot access 9: No such file or directory
total 360
drwxr-xr-x 2 root root 4096 Feb 19 15:12 ./
drwxr-xr-x 3 root root 4096 Feb 19 15:11 ../
-rw-r--r-- 1 root root 0 Feb 19 15:12 1
-rw-r--r-- 1 root root 0 Feb 19 15:12 10
-rw-r--r-- 1 root root 0 Feb 19 15:12 100
-????????? ? ? ? ? ? 101
-????????? ? ? ? ? ? 102
-????????? ? ? ? ? ? 103
The reason is: when doing the inline dir conversion, we didn't consider
that directory has hierarchical hash structure which can be configured
through sysfs interface 'dir_level'.
By default, dir_level of directory inode is 0, it means we have one bucket
in hash table located in first level, all dirents will be hashed in this
bucket, so it has no problem for us to do the duplication simply between
inline dentry page and converted normal dentry page.
However, if we configured dir_level with the value N (greater than 0), it
will expand the bucket number of first level hash table by 2^N - 1, it
hashs dirents into different buckets according their hash value, if we
still move all dirents to first bucket, it makes incorrent locating for
inline dirents, the result is, although we can iterate all dirents through
->readdir, we can't stat some of them in ->lookup which based on hash
table searching.
This patch fixes this issue by rehashing dirents into correct position
when converting inline directory.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Introduce a new structure f2fs_journal to wrap journal info in struct
f2fs_summary_block for readability.
struct f2fs_journal {
union {
__le16 n_nats;
__le16 n_sits;
union {
struct nat_journal nat_j;
struct sit_journal sit_j;
struct f2fs_extra_info info;
} __packed;
struct f2fs_summary_block {
struct f2fs_summary entries[ENTRIES_IN_SUM];
struct f2fs_journal journal;
struct summary_footer footer;
} __packed;
This patch preallocates data blocks for buffered aio writes.
With this patch, we can avoid redundant locking and unlocking of node pages
given consecutive aio request.
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
Reviewed-by: Chao Yu <chao2.yu@samsung.com>
There are redundant pointer conversion in following call stack:
- at position a, inode was been converted to f2fs_file_info.
- at position b, f2fs_file_info was been converted to inode again.
- truncate_blocks(inode,..)
- fi = F2FS_I(inode) ---a
- ADDRS_PER_PAGE(node_page, fi)
- addrs_per_inode(fi)
- inode = &fi->vfs_inode ---b
- f2fs_has_inline_xattr(inode)
- is_inode_flag_set(fi,..)
In order to avoid unneeded conversion, alter ADDRS_PER_PAGE and
addrs_per_inode to acept parameter with type of inode pointer.
This patch introduces lifetime IO write statistics exposed to the sysfs interface.
The write IO amount is obtained from block layer, accumulated in the file system and
stored in the hot node summary of checkpoint.
Signed-off-by: Shuoran Liu <liushuoran@huawei.com>
Signed-off-by: Pengyang Hou <houpengyang@huawei.com>
[Jaegeuk Kim: add sysfs documentation]
This patch adds MAX_VOLUME_NAME to sync with f2fs-tools.
Add annotation to let us know more clearly about space utilization
information of regular dentry and inline dentry.
This definitions will be used by inode and superblock for encyption.
This patch introduces a feature in superblock, which will indicate any new
features for f2fs.
The mkfs.f2fs remains kernel version in superblock, but f2fs module has not
added that so far.
If f2fs was corrupted with missing dot dentries, it needs to recover them after
fsck.f2fs detection.
The underlying precedure is:
1. The fsck.f2fs remains F2FS_INLINE_DOTS flag in directory inode, if it detects
missing dot dentries.
2. When f2fs looks up the corrupted directory, it triggers f2fs_add_link with
proper inode numbers and their dot and dotdot names.
3. Once f2fs recovers the directory without errors, it removes F2FS_INLINE_DOTS
finally.
Rename a filed name from 'blk_addr' to 'blk' in struct {f2fs_extent,extent_info}
as annotation of this field descripts its meaning well to us.
By this way, we can avoid long statement in code of following patches.
This patch adds two macros for transition between byte and block offsets.
Currently, f2fs only supports 4KB blocks, so use the default size for now.
This patch adds FASTBOOT flag into checkpoint as follows.
- CP_UMOUNT_FLAG is set when system is umounted.
- CP_FASTBOOT_FLAG is set when intermediate checkpoint having node summaries
was done.
So, if you get CP_UMOUNT_FLAG from checkpoint, the system was umounted cleanly.
Instead, if there was sudden-power-off, you can get CP_FASTBOOT_FLAG or nothing.
In do_recover_data, we find and update previous node pages after updating
its new block addresses.
After then, we call fill_node_footer without reset field, we erase its
cold bit so that this new cold node block is written to wrong log area.
This patch fixes not to miss its old flag.
Let's remove unused macro.
This patch simplifies the inline_data usage with the following rule.
1. inline_data is set during the file creation.
2. If new data is requested to be written ranges out of inline_data,
f2fs converts that inode permanently.
3. There is no cases which converts non-inline_data inode to inline_data.
4. The inline_data flag should be changed under inode page lock.
This patch defines macro/inline dentry structure, and adds some helpers for
inline dir infrastructure.
This patch fixes to use highmem for directory pages.
Block size in f2fs is 4096 bytes, so theoretically, f2fs can support 4096 bytes
sector device at maximum. But now f2fs only support 512 bytes size sector, so
block device such as zRAM which uses page cache as its block storage space will
not be mounted successfully as mismatch between sector size of zRAM and sector
size of f2fs supported.
In this patch we support large sector size in f2fs, so block device with sector
size of 512/1024/2048/4096 bytes can be supported in f2fs.
This patch adds sbi->need_fsck to conduct fsck.f2fs later.
This flag can only be removed by fsck.f2fs.
This patch introduces DEF_NIDS_PER_INODE/GET_ORPHAN_BLOCKS/F2FS_CP_PACKS macro
instead of numbers in code for readability.
change log from v1:
o fix typo pointed out by Jaegeuk Kim.
Theoretically, our total inodes number is the same as total node number, but
there are three node ids are reserved in f2fs, they are 0, 1 (node nid), and 2
(meta nid), and they should never be used by user, so our total/free inode
number calculated in ->statfs is wrong.
This patch indroduces F2FS_RESERVED_NODE_NUM and then fixes this issue by
recalculating total/free inode number with the macro.
f2fs's cp has one page which consists of struct f2fs_checkpoint and
version bitmap of sit and nat. To support lots of segments, we need more
blocks for sit bitmap. So let's arrange sit bitmap as following:
| f2fs_checkpoint | sit bitmap |
| + nat bitmap | |
0 4k N blocks
Signed-off-by: Changman Lee <cm224.lee@samsung.com>
[Jaegeuk Kim: simple code change for readability]
When large directory feathure is enable, We have one case which could cause
overflow in dir_buckets() as following:
special case: level + dir_level >= 32 and level < MAX_DIR_HASH_DEPTH / 2.
Here we define MAX_DIR_BUCKETS to limit the return value when the condition
could trigger potential overflow.
Changes from V1
o modify description of calculation in f2fs.txt suggested by Changman Lee.
Suggested-by: Changman Lee <cm224.lee@samsung.com>
Introduce help macro ADDRS_PER_PAGE() to get the number of address pointers in
direct node or inode.
Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
This patch introduces an i_dir_level field to support large directory.
Previously, f2fs maintains multi-level hash tables to find a dentry quickly
from a bunch of chiild dentries in a directory, and the hash tables consist of
the following tree structure as below.
In Documentation/filesystems/f2fs.txt,
A : bucket
B : block
N : MAX_DIR_HASH_DEPTH
level #0 | A(2B)
level #1 | A(2B) - A(2B)
level #2 | A(2B) - A(2B) - A(2B) - A(2B)
level #N/2 | A(2B) - A(2B) - A(2B) - A(2B) - A(2B) - ... - A(2B)
level #N | A(4B) - A(4B) - A(4B) - A(4B) - A(4B) - ... - A(4B)
But, if we can guess that a directory will handle a number of child files,
we don't need to traverse the tree from level #0 to #N all the time.
Since the lower level tables contain relatively small number of dentries,
the miss ratio of the target dentry is likely to be high.
In order to avoid that, we can configure the hash tables sparsely from level #0
like this.
level #0 | A(2B) - A(2B) - A(2B) - A(2B)
level #1 | A(2B) - A(2B) - A(2B) - A(2B) - A(2B) - ... - A(2B)
With this structure, we can skip the ineffective tree searches in lower level
hash tables.
This patch adds just a facility for this by introducing i_dir_level in
f2fs_inode.
This patch adds a inline_data recovery routine with the following policy.
[prev.] [next] of inline_data flag
o o -> recover inline_data
o x -> remove inline_data, and then recover data blocks
x o -> remove inline_data, and then recover inline_data
x x -> recover data blocks
Add new inode flags F2FS_INLINE_DATA and FI_INLINE_DATA to indicate
whether the inode has inline data.
Inline data makes use of inode block's data indices region to save small
file. Currently there are 923 data indices in an inode block. Since
inline xattr has made use of the last 50 indices to save its data, there
are 873 indices left which can be used for inline data. When
FI_INLINE_DATA is set, the layout of inode block's indices region is
like below:
| | Reserved. reserve_new_block() will make use of
| i_addr[0] | i_addr[0] when we need to reserve a new data block
| | to convert inline data into regular one's.
| | Used by inline data. A file whose size is less than
| i_addr[1~872] | 3488 bytes(~3.4k) and doesn't reserve extra
| | blocks by fallocate() can be saved here.
| i_addr[873~922] | Reserved for inline xattr
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
Signed-off-by: Huajun Li <huajun.li@intel.com>
Signed-off-by: Weihong Xu <weihong.xu@intel.com>
0. modified inode structure
metadata (e.g., i_mtime, i_ctime, etc)
direct pointers [0 ~ 873]
inline xattrs (200 bytes by default)
indirect pointers [0 ~ 4]
node footer
1. setxattr flow
- read_all_xattrs copies all the xattrs from inline and xattr node block.
- handle xattr entries
- write_all_xattrs copies modified xattrs into inline and xattr node block.
2. getxattr flow
- check target entries
3. Usage
# mount -t f2fs -o inline_xattr $DEV $MNT
Once mounted with the inline_xattr option, f2fs marks all the newly created
files to reserve an amount of inline xattr space explicitly inside the inode
block. Without the mount option, f2fs will not touch any existing files and
newly created files as well.
This patch enables the number of direct pointers inside on-disk inode block to
be changed dynamically according to the size of inline xattr space.
The number of direct pointers, ADDRS_PER_INODE, can be changed only if the file
has inline xattr flag.
The number of direct pointers that will be used by inline xattrs is defined as
F2FS_INLINE_XATTR_ADDRS.
Current patch assigns F2FS_INLINE_XATTR_ADDRS to 0 temporarily.
This patch adds basic inode flags for inline xattrs, F2FS_INLINE_XATTR,
and add a mount option, inline_xattr, which is enabled when xattr is set.
If the mount option is enabled, all the files are marked with the inline_xattrs
flag.
The on-disk block address is defined as __le32, but in-memory block address,
block_t, does as u64.
Let's synchronize them to 32 bits.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
The maximum filename length supported in linux is 255 characters.
So let's follow that.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com>
Simplify code by providing the accessor macro to retrieve the
number of dentry slots for a given filename length.
This patch should resolve the bugs reported by the sparse tool.
Initial reports were written by "kbuild test robot" managed by fengguang.wu.
In my local machines, I've tested also by running:
> make C=2 CF="-D__CHECK_ENDIAN__"
Accordingly, I've found lots of warnings and bugs related to the endian
conversion. And I've fixed all at this moment.
This adds a header file describing the on-disk layout of f2fs.
Signed-off-by: Chul Lee <chur.lee@samsung.com>
