path: root/include/linux/ext3_fs.h
2012-03-31ext3: move headers to fs/ext3/Al Viro
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-03ext3: propagate umode_tAl Viro
2011-11-02Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (97 commits) jbd2: Unify log messages in jbd2 code jbd/jbd2: validate sb->s_first in journal_get_superblock() ext4: let ext4_ext_rm_leaf work with EXT_DEBUG defined ext4: fix a syntax error in ext4_ext_insert_extent when debugging enabled ext4: fix a typo in struct ext4_allocation_context ext4: Don't normalize an falloc request if it can fit in 1 extent. ext4: remove comments about extent mount option in ext4_new_inode() ext4: let ext4_discard_partial_buffers handle unaligned range correctly ext4: return ENOMEM if find_or_create_pages fails ext4: move vars to local scope in ext4_discard_partial_page_buffers_no_lock() ext4: Create helper function for EXT4_IO_END_UNWRITTEN and i_aiodio_unwritten ext4: optimize locking for end_io extent conversion ext4: remove unnecessary call to waitqueue_active() ext4: Use correct locking for ext4_end_io_nolock() ext4: fix race in xattr block allocation path ext4: trace punch_hole correctly in ext4_ext_map_blocks ext4: clean up AGGRESSIVE_TEST code ext4: move variables to their scope ext4: fix quota accounting during migration ext4: migrate cleanup ...
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Cleanup metadata flags handling udf: Skip mirror metadata FE loading when metadata FE is ok ext3: Allow quota file use root reservation udf: Remove web reference from UDF MAINTAINERS entry quota: Drop path reference on error exit from quotactl udf: Neaten udf_debug uses udf: Neaten logging output, use vsprintf extension %pV udf: Convert printks to pr_<level> udf: Rename udf_warning to udf_warn udf: Rename udf_error to udf_err udf: Promote some debugging messages to udf_error ext3: Remove the obsolete broken EXT3_IOC32_WAIT_FOR_READONLY. udf: Add readpages support for udf. ext3/balloc.c: local functions should be static ext2: fix the outdated comment in ext2_nfs_get_inode() ext3: remove deprecated oldalloc fs/ext3/balloc.c: delete useless initialization fs/ext2/balloc.c: delete useless initialization ext3: fix message in ext3_remount for rw-remount case ext3: Remove i_mutex from ext3_sync_file() Fix up trivial (printf format cleanup) conflicts in fs/udf/udfdecl.h
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-31ext2,ext3,ext4: don't inherit APPEND_FL or IMMUTABLE_FL for new inodesTheodore Ts'o
This doesn't make much sense, and it exposes a bug in the kernel where attempts to create a new file in an append-only directory using O_CREAT will fail (but still leave a zero-length file). This was discovered when xfstests #79 was generalized so it could run on all file systems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc:stable@kernel.org
2011-08-17ext3: remove deprecated oldallocLukas Czerner
For a long time now orlov is the default block allocator in the ext3. It performs better than the old one and no one seems to claim otherwise so we can safely drop it and make oldalloc and orlov mount option deprecated. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-25ext3: use proper little-endian bitopsAkinobu Mita
ext3_{set,clear}_bit() is defined as __test_and_{set,clear}_bit_le() for ext3. But all ext3_{set,clear}_bit() calls ignore return values. So these can be replaced with __{set,clear}_bit_le(). This changes ext3_{set,clear}_bit safely, because if someone uses these macros without noticing the change, new ext3_{set,clear}_bit don't have return value and causes compiler errors where the return value is used. This also removes unused ext3_find_first_zero_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: linux-ext4@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3: Convert ext3 to new truncate calling conventionJan Kara
Mostly trivial conversion. We fix a bug that IS_IMMUTABLE and IS_APPEND files could not be truncated during failed writes as we change the code. In fact the test is not needed at all because both IS_IMMUTABLE and IS_APPEND is tested in upper layers in do_sys_[f]truncate(), may_write(), etc. Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-27fs: pass exact type of data dirties to ->dirty_inodeChristoph Hellwig
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or anything else, so that the filesystem can track internally if it needs to push out a transaction for fdatasync or not. This is just the prototype change with no user for it yet. I plan to push large XFS changes for the next merge window, and getting this trivial infrastructure in this window would help a lot to avoid tree interdependencies. Also remove incorrect comments that ->dirty_inode can't block. That has been changed a long time ago, and many implementations rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23ext3: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-10ext3: speed up file creates by optimizing rec_len functionsEric Sandeen
The addition of 64k block capability in the rec_len_from_disk and rec_len_to_disk functions added a bit of math overhead which slows down file create workloads needlessly when the architecture cannot even support 64k blocks, thanks to page size limits. Similar changes already exist in the ext4 codebase. The directory entry checking can also be optimized a bit by sprinkling in some unlikely() conditions to move the error handling out of line. bonnie++ sequential file creates on a 512MB ramdisk speeds up from about 77,000/s to about 82,000/s, about a 6% improvement. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-10ext3: Add batched discard support for ext3Lukas Czerner
Walk through allocation groups and trim all free extents. It can be invoked through FITRIM ioctl on the file system. The main idea is to provide a way to trim the whole file system if needed, since some SSD's may suffer from performance loss after the whole device was filled (it does not mean that fs is full!). It search for free extents in allocation groups specified by Byte range start -> start+len. When the free extent is within this range, blocks are marked as used and then trimmed. Afterwards these blocks are marked as free in per-group bitmap. [JK: Fixed up error handling and trimming of a single group] Signed-off-by: Lukas Czerner <lczerner@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09convert ext3 to ->evict_inode()Al Viro
2010-07-21ext3: remove vestiges of nobh supportChristoph Hellwig
The nobh option was only supported for writeback mode, but given that all write paths (except mmapped writed) actually create buffer heads, it effectively was a no-op already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-03-29ext3: fix broken handling of EXT3_STATE_NEWLinus Torvalds
In commit 9df93939b735 ("ext3: Use bitops to read/modify EXT3_I(inode)->i_state") ext3 changed its internal 'i_state' variable to use bitops for its state handling. However, unline the same ext4 change, it didn't actually change the name of the field when it changed the semantics of it. As a result, an old use of 'i_state' remained in fs/ext3/ialloc.c that initialized the field to EXT3_STATE_NEW. And that does not work _at_all_ when we're now working with individually named bits rather than values that get masked. So the code tried to mark the state to be new, but in actual fact set the field to EXT3_STATE_JDATA. Which makes no sense at all, and screws up all the code that checks whether the inode was newly allocated. In particular, it made the xattr code unhappy, and caused various random behavior, like apparently https://bugzilla.redhat.com/show_bug.cgi?id=577911 So fix the initialization, and rename the field to match ext4 so that we don't have this happen again. Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Daniel J Walsh <dwalsh@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05ext3: Use bitops to read/modify EXT3_I(inode)->i_stateJan Kara
At several places we modify EXT3_I(inode)->i_state without holding i_mutex (ext3_release_file, ext3_bmap, ext3_journalled_writepage, ext3_do_update_inode, ...). These modifications are racy and we can lose updates to i_state. So convert handling of i_state to use bitops which are atomic. Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10ext3: Unify log messages in ext3Alexey Fisher
Make messages produced by ext3 more unified. It should be easy to parse. dmesg before patch: [ 4893.684892] reservations ON [ 4893.684896] xip option not supported [ 4893.684964] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended dmesg after patch: [ 873.300792] EXT3-fs (loop0): using internal journaln [ 873.300796] EXT3-fs (loop0): mounted filesystem with writeback data mode [ 924.163657] EXT3-fs (loop0): error: can't find ext3 filesystem on dev loop0. [ 723.755642] EXT3-fs (loop0): error: bad blocksize 8192 [ 357.874687] EXT3-fs (loop0): error: no journal found. mounting ext3 over ext2? [ 873.300764] EXT3-fs (loop0): warning: maximal mount count reached, running e2fsck is recommended [ 924.163657] EXT3-fs (loop0): error: can't find ext3 filesystem on dev loop0. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Jan Kara <jack@suse.cz>
2009-07-15ext3: Get rid of extenddisksize parameter of ext3_get_blocks_handle()Jan Kara
Get rid of extenddisksize parameter of ext3_get_blocks_handle(). This seems to be a relict from some old days and setting disksize in this function does not make much sence. Currently it was set only by ext3_getblk(). Since the parameter has some effect only if create == 1, it is easy to check that the three callers which end up calling ext3_getblk() with create == 1 (ext3_append, ext3_quota_write, ext3_mkdir) do the right thing and set disksize themselves. Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-03Merge branch 'ext3-latency-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'ext3-latency-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext3: Add replace-on-rename hueristics for data=writeback mode ext3: Add replace-on-truncate hueristics for data=writeback mode ext3: Use WRITE_SYNC for commits which are caused by fsync() block_write_full_page: Use synchronous writes for WBC_SYNC_ALL writebacks
2009-04-03ext3: Add replace-on-truncate hueristics for data=writeback modeTheodore Ts'o
In data=writeback mode, start an asynchronous flush when closing a file which had been previously truncated down to zero. This lowers the probability of data loss in the case of applications that attempt to replace a file using truncate. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-02ext3: remove the BKL in ext3/ioctl.cCyrus Massoumi
Reformat ext3/ioctl.c to make it look more like ext4/ioctl.c and remove the BKL around ext3_ioctl(). Signed-off-by: Cyrus Massoumi <cyrusm@gmx.net> Cc: <linux-ext4@vger.kernel.org> Acked-by: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (57 commits) jbd2: Fix oops in jbd2_journal_init_inode() on corrupted fs ext4: Remove "extents" mount option block: Add Kconfig help which notes that ext4 needs CONFIG_LBD ext4: Make printk's consistently prefixed with "EXT4-fs: " ext4: Add sanity checks for the superblock before mounting the filesystem ext4: Add mount option to set kjournald's I/O priority jbd2: Submit writes to the journal using WRITE_SYNC jbd2: Add pid and journal device name to the "kjournald2 starting" message ext4: Add markers for better debuggability ext4: Remove code to create the journal inode ext4: provide function to release metadata pages under memory pressure ext3: provide function to release metadata pages under memory pressure add releasepage hooks to block devices which can be used by file systems ext4: Fix s_dirty_blocks_counter if block allocation failed with nodelalloc ext4: Init the complete page while building buddy cache ext4: Don't allow new groups to be added during block allocation ext4: mark the blocks/inode bitmap beyond end of group as used ext4: Use new buffer_head flag to check uninit group bitmaps initialization ext4: Fix the race between read_inode_bitmap() and ext4_new_inode() ext4: code cleanup ...
2009-01-08ext3: tighten restrictions on inode flagsDuane Griffin
At the moment there are few restrictions on which flags may be set on which inodes. Specifically DIRSYNC may only be set on directories and IMMUTABLE and APPEND may not be set on links. Tighten that to disallow TOPDIR being set on non-directories and only NODUMP and NOATIME to be set on non-regular file, non-directories. Introduces a flags masking function which masks flags based on mode and use it during inode creation and when flags are set via the ioctl to facilitate future consistency. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext3: don't inherit inappropriate inode flags from parentDuane Griffin
At present INDEX is the only flag that new ext3 inodes do NOT inherit from their parent. In addition prevent the flags DIRTY, ECOMPR, IMAGIC and TOPDIR from being inherited. List inheritable flags explicitly to prevent future flags from accidentally being inherited. This fixes the TOPDIR flag inheritance bug reported at http://bugzilla.kernel.org/show_bug.cgi?id=9866. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-28ext3: Add support for non-native signed/unsigned htree hash algorithmsTheodore Ts'o
The original ext3 hash algorithms assumed that variables of type char were signed, as God and K&R intended. Unfortunately, this assumption is not true on some architectures. Userspace support for marking filesystems with non-native signed/unsigned chars was added two years ago, but the kernel-side support was never added (until now). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: akpm@linux-foundation.org Cc: linux-kernel@vger.kernel.org
2008-10-20ext3: add an option to control error handling on file dataHidehiro Kawai
If the journal doesn't abort when it gets an IO error in file data blocks, the file data corruption will spread silently. Because most of applications and commands do buffered writes without fsync(), they don't notice the IO error. It's scary for mission critical systems. On the other hand, if the journal aborts whenever it gets an IO error in file data blocks, the system will easily become inoperable. So this patch introduces a filesystem option to determine whether it aborts the journal or just call printk() when it gets an IO error in file data. If you mount a ext3 fs with data_err=abort option, it aborts on file data write error. If you mount it with data_err=ignore, it doesn't abort, just call printk(). data_err=ignore is the default. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16include: replace __FUNCTION__ with __func__Harvey Harrison
2008-10-03generic block based fiemap implementationJosef Bacik
Any block based fs (this patch includes ext3) just has to declare its own fiemap() function and then call this generic function with its own get_block_t. This works well for block based filesystems that will map multiple contiguous blocks at one time, but will work for filesystems that only map one block at a time, you will just end up with an "extent" for each block. One gotcha is this will not play nicely where there is hole+data after the EOF. This function will assume its hit the end of the data as soon as it hits a hole after the EOF, so if there is any data past that it will not pick that up. AFAIK no block based fs does this anyway, but its in the comments of the function anyway just in case. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org
2008-07-25ext3: handle corrupted orphan list at mountDuane Griffin
If the orphan node list includes valid, untruncatable nodes with nlink > 0 the ext3_orphan_cleanup loop which attempts to delete them will not do so, causing it to loop forever. Fix by checking for such nodes in the ext3_orphan_get function. This patch fixes the second case (image hdb.20000009.softlockup.gz) reported in http://bugzilla.kernel.org/show_bug.cgi?id=10882. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: printk warning fix] Signed-off-by: Duane Griffin <duaneg@dghda.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop EXT3 from using iget() and read_inode()David Howells
Stop the EXT3 filesystem from using iget() and read_inode(). Replace ext3_read_inode() with ext3_iget(), and call that instead of iget(). ext3_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ext3_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Fix 64KB blocksize in ext3 directoriesJan Kara
With 64KB blocksize, a directory entry can have size 64KB which does not fit into 16 bits we have for entry lenght. So we store 0xffff instead and convert value when read from / written to disk. The patch also converts some places to use ext3_next_entry() when we are changing them anyway. [akpm@linux-foundation.org: coding-style cleanups] Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18ext3: support large blocksize up to PAGESIZETakashi Sato
This patch set supports large block size(>4k, <=64k) in ext3 just enlarging the block size limit. But it is NOT possible to have 64kB blocksize on ext3 without some changes to the directory handling code. The reason is that an empty 64kB directory block would have a rec_len == (__u16)2^16 == 0, and this would cause an error to be hit in the filesystem. The proposed solution is treat 64k rec_len with a an impossible value like rec_len = 0xffff to handle this. The Patch-set consists of the following 2 patches. [1/2] ext3: enlarge blocksize - Allow blocksize up to pagesize [2/2] ext3: fix rec_len overflow - prevent rec_len from overflow with 64KB blocksize Now on 64k page ppc64 box runs with this patch set we could create a 64k block size ext3, and able to handle empty directory block. Signed-off-by: Takashi Sato <sho@tnes.nec.co.jp> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext3: remove #ifdef CONFIG_EXT3_INDEXEric Sandeen
CONFIG_EXT3_INDEX is not an exposed config option in the kernel, and it is unconditionally defined in ext3_fs.h. tune2fs is already able to turn off dir indexing, so at this point it's just cluttering up the code. Remove it. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ext3: copy i_flags to inode flags on writeJan Kara
A patch that stores inode flags such as S_IMMUTABLE, S_APPEND, etc. from i_flags to EXT3_I(inode)->i_flags when inode is written to disk. The same thing is done on GETFLAGS ioctl. Quota code changes these flags on quota files (to make it harder for sysadmin to screw himself) and these changes were not correctly propagated into the filesystem (especially, lsattr did not show them and users were wondering...). Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ext3-specific i_flags. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-09-30[PATCH] BLOCK: Move the Ext3 device ioctl compat stuff to the Ext3 driver ↵David Howells
[try #6] Move the Ext3 device ioctl compat stuff from fs/compat_ioctl.c to the Ext3 driver so that the Ext3 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-27[PATCH] ext3: Fix sparse warningsDave Kleikamp
Fixing up some endian-ness warnings in preparation to clone ext4 from ext3. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: More whitespace cleanupsDave Kleikamp
More white space cleanups in preparation of cloning ext4 from ext3. Removing spaces that precede a tab. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
