path: root/include/linux/ethtool.h
2011-03-27net: fix ethtool->set_flags not intended -EINVAL return valueStanislaw Gruszka
After commit d5dbda23804156ae6f35025ade5307a49d1db6d7 "ethtool: Add support for vlan accleration.", drivers that have NETIF_F_HW_VLAN_TX, and/or NETIF_F_HW_VLAN_RX feature, but do not allow enable/disable vlan acceleration via ethtool set_flags, always return -EINVAL from that function. Fix by returning -EINVAL only if requested features do not match current settings and can not be changed by driver. Change any driver that define ethtool->set_flags to use ethtool_invalid_flags() to avoid similar problems in the future (also on drivers that do not have the problem). Tested with modified (to reproduce this bug) myri10ge driver. Cc: stable@kernel.org # 2.6.37+ Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-22net: implement dev_disable_lro() hw_features compatibilityMichał Mirosław
Implement compatibility with new hw_features for dev_disable_lro(). This is a transition path - dev_disable_lro() should be later integrated into netdev_fix_features() after all drivers are converted. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18ethtool: Compat handling for struct ethtool_rxnfcBen Hutchings
This structure was accidentally defined such that its layout can differ between 32-bit and 64-bit processes. Add compat structure definitions and an ioctl wrapper function. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Cc: stable@kernel.org [2.6.30+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23net: Implement SFEATURES compatibility for not updated driversMichał Mirosław
Use discrete setting ops for not updated drivers. This will not make them conform to full G/SFEATURES semantics, though. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: introduce NETIF_F_RXCSUMMichał Mirosław
Introduce NETIF_F_RXCSUM to replace device-private flags for RX checksum offload. Integrate it with ndo_fix_features. ethtool_op_get_rx_csum() is removed altogether as nothing in-tree uses it. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: Introduce new feature setting opsMichał Mirosław
This introduces a new framework to handle device features setting. It consists of: - new fields in struct net_device: + hw_features - features that hw/driver supports toggling + wanted_features - features that user wants enabled, when possible - new netdev_ops: + feat = ndo_fix_features(dev, feat) - API checking constraints for enabling features or their combinations + ndo_set_features(dev) - API updating hardware state to match changed dev->features - new ethtool commands: + ETHTOOL_GFEATURES/ETHTOOL_SFEATURES: get/set dev->wanted_features and trigger device reconfiguration if resulting dev->features changed + ETHTOOL_GSTRINGS(ETH_SS_FEATURES): get feature bits names (meaning) Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10ethtool: Report link-down while interface is downBen Hutchings
While an interface is down, many implementations of ethtool_ops::get_link, including the default, ethtool_op_get_link(), will report the last link state seen while the interface was up. In general the current physical link state is not available if the interface is down. Define ETHTOOL_GLINK to reflect whether the interface *and* any physical port have a working link, and consistently return 0 when the interface is down. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21ethtool: Add support for vlan accleration.Jesse Gross
Now that vlan acceleration is handled consistently regardless of usage, it is possible to enable and disable it at will. This adds support for Ethtool operations that change the offloading status for debugging purposes, similar to other forms of hardware acceleration. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21ethtool: Add Ethernet MAC-level filtering/steeringBen Hutchings
2010-09-21ethtool: Define RX n-tuple action to clear a ruleBen Hutchings
2010-09-17ethtool: Add comments for valid use of flow typesBen Hutchings
2010-09-17ethtool, ixgbe: Move RX n-tuple mask fixup to ethtoolBen Hutchings
The ethtool utility does not set masks for flow parameters that are not specified, so if both value and mask are 0 then this must be treated as equivalent to a mask with all bits set. Currently that is done in the only driver that implements RX n-tuple filtering, ixgbe. Move it to the ethtool core. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ethtool: Remove unimplemented flow specification typesBen Hutchings
struct ethtool_rawip4_spec and struct ethtool_ether_spec are neither commented nor used by any driver, so remove them. Adjust padding in the user-visible unions that included these structures. Fix references to struct ethtool_rawip4_spec in ethtool_get_rx_ntuple(), which should use struct ethtool_usrip4_spec. struct ethtool_usrip4_spec cannot hold IPv6 host addresses and there is no separate structure that can, so remove ETH_RX_NFC_IP6 and the reference to it in niu. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ethtool: Complete kernel-doc comments for RX flow filter and hash controlBen Hutchings
There are now several interfaces within the ethtool API for getting and setting RX flow filtering and hashing behaviour, most of which are poorly documented. This adds kernel-doc comments for all these interfaces, based on the existing incomplete comments and on the initial implementations. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07Merge branch 'master' of ↵David S. Miller
2010-06-30ethtool: Add support for control of RX flow hash indirectionBen Hutchings
Many NICs use an indirection table to map an RX flow hash value to one of an arbitrary number of queues (not necessarily a power of 2). It can be useful to remove some queues from this indirection table so that they are only used for flows that are specifically filtered there. It may also be useful to weight the mapping to account for user processes with the same CPU-affinity as the RX interrupts. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29ethtool: Fix potential user buffer overflow for ETHTOOL_{G, S}RXFHBen Hutchings
struct ethtool_rxnfc was originally defined in 2.6.27 for the ETHTOOL_{G,S}RXFH command with only the cmd, flow_type and data fields. It was then extended in 2.6.30 to support various additional commands. These commands should have been defined to use a new structure, but it is too late to change that now. Since user-space may still be using the old structure definition for the ETHTOOL_{G,S}RXFH commands, and since they do not need the additional fields, only copy the originally defined fields to and from user-space. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-14ethtool: Revert incorrect indentation changesBen Hutchings
commit 97f8aefbbfb5aa5c9944e5fa8149f1fdaf71c7b6 "net: fix ethtool coding style errors and warnings" changed the indentation of several macro definitions in ethtool.h. These definitions line up in the diff where there is an extra character at the start of each line, but not in the resulting file. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07net: fix ethtool coding style errors and warningschavey
Fix coding style errors and warnings output while running checkpatch.pl on the files net/core/ethtool.c and include/linux/ethtool.h Signed-off-by: chavey <chavey@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30netdev: ethtool RXHASH flagstephen hemminger
This adds ethtool and device feature flag to allow control of receive hashing offload. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-05ethtool: Add direct access to ops->get_sset_countJeff Garzik
On 03/04/2010 09:26 AM, Ben Hutchings wrote: > On Thu, 2010-03-04 at 00:51 -0800, Jeff Kirsher wrote: >> From: Jeff Garzik<jgarzik@redhat.com> >> >> This patch is an alternative approach for accessing string >> counts, vs. the drvinfo indirect approach. This way the drvinfo >> space doesn't run out, and we don't break ABI later. > [...] >> --- a/net/core/ethtool.c >> +++ b/net/core/ethtool.c >> @@ -214,6 +214,10 @@ static noinline int ethtool_get_drvinfo(struct net_device *dev, void __user *use >> info.cmd = ETHTOOL_GDRVINFO; >> ops->get_drvinfo(dev,&info); >> >> + /* >> + * this method of obtaining string set info is deprecated; >> + * consider using ETHTOOL_GSSET_INFO instead >> + */ > > This comment belongs on the interface (ethtool.h) not the > implementation. Debatable -- the current comment is located at the callsite of ops->get_sset_count(), which is where an implementor might think to add a new call. Not all the numeric fields in ethtool_drvinfo are obtained from ->get_sset_count(). Hence the "some" in the attached patch to include/linux/ethtool.h, addressing your comment. > [...] >> +static noinline int ethtool_get_sset_info(struct net_device *dev, >> + void __user *useraddr) >> +{ > [...] >> + /* calculate size of return buffer */ >> + for (i = 0; i< 64; i++) >> + if (sset_mask& (1ULL<< i)) >> + n_bits++; > [...] > > We have a function for this: > > n_bits = hweight64(sset_mask); Agreed. I've attached a follow-up patch, which should enable my/Jeff's kernel patch to be applied, followed by this one. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
This patch is an alternative approach for accessing string counts, vs. the drvinfo indirect approach. This way the drvinfo space doesn't run out, and we don't break ABI later. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26Revert "ethtool: Add n-tuple string length to drvinfo and return it"David S. Miller
This reverts commit c79c5ffdce14abb4de3878c5aa8c3c6e5093c69b. As Jeff points out we can't break the user visible interface like this, we need to add this into the reserved[] thing. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26ethtool: Add n-tuple string length to drvinfo and return itPeter Waskiewicz
The drvinfo struct should include the number of strings that get_rx_ntuple will return. It will be variable if an underlying driver implements its own get_rx_ntuple routine, so userspace needs to know how much data is coming. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-14ethtool: Fix includes build breakDavid S. Miller
Based upon a patch by Oliver Hartkopp <oliver@hartkopp.net>. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-10ethtool: Introduce n-tuple filter programming supportPeter P Waskiewicz Jr
This patchset enables the ethtool layer to program n-tuple filters to an underlying device. The idea is to allow capable hardware to have static rules applied that can assist steering flows into appropriate queues. Hardware that is known to support these types of filters today are ixgbe and niu. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03tg3: Add some VPD preprocessor constantsMatt Carlson
This patch cleans up the VPD code by creating preprocessor definitions and using them in the place of hardcoded constants. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29ethtool: Add Direct Attach support to connector port reportingPJ Waskiewicz
This patch allows a base driver to specify Direct Attach as the type of port through the ethtool interface. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02gianfar: Basic Support for programming hash rulesSandeep Gopalpet
This patch provides basic hash rules programming via the ethtool interface. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07ethtool: Add reset operationBen Hutchings
After updating firmware stored in flash, users may wish to reset the relevant hardware and start the new firmware immediately. This should not be completely automatic as it may be disruptive. A selective reset may also be useful for debugging or diagnostics. This adds a separate reset operation which takes flags indicating the components to be reset. Drivers are allowed to reset only a subset of those requested, and must indicate the actual subset. This allows the use of generic component masks and some future expansion. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05ethtool: Remove support for obsolete string query operationsBen Hutchings
The in-tree implementations have all been converted to get_sset_count(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02net/ethtool: Add support for the ethtool feature to flash firmware image ↵Ajit Khaparde
from a specified file. This patch adds support to flash a firmware image to a device using ethtool. The driver gets the filename of the firmware image and flashes the image using the request firmware path. The region "on the chip" to be flashed can be specified by an option. It is upto the device driver to enumerate the region number passed by ethtool, to the region to be flashed. The default behavior is to flash all the regions on the chip. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27net: ethtool_op_get_rx_csum() should be public and exportedEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09e1000e: Expose MDI-X status via ethtool changeChaitanya Lala
Ethtool is a standard way of getting information about ethernet interfaces. We enhance ethtool kernel interface & e1000e to make the MDI-X status readable via ethtool in userspace. Signed-off-by: Chaitanya Lala <clala@riverbed.com> Signed-off-by: Arthur Jones <ajones@riverbed.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29ethtool/mdio: Support backplane mode negotiationBen Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29ethtool/mdio: Report MDIO mode support and link partner advertisingBen Hutchings
Add mdio_support and lp_advertising fields to ethtool_cmd. Set these in mdio45_ethtool_gset{,_npage}(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29ethtool: Add port type PORT_OTHERBen Hutchings
Add a PORT_OTHER to represent all other physical port types. Current NICs generally do not allow switching between multiple port types in software so specific types should not be needed. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-20ethtool: Add RX pkt classification interfaceSantwona Behera
Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15ethtool: Add GGRO and SGRO opsHerbert Xu
This patch adds the ethtool ops to enable and disable GRO. It also makes GRO depend on RX checksum offload much the same as how TSO depends on SG support. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-07ethtool: Expand ethtool_cmd.speed to 32 bitsBrandon Philips
Introduce the speed_hi field to ethtool_cmd, using the reserved space, to expand the speed field to 2^32 Megabits/second. Making this field expansion now gives us plenty of time to fix up the user-space pieces that use SIOCETHTOOL before hardware faster than 64 Gb/s is available. Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-02netdev: Add support for rx flow hash configuration, using ethtool.Santwona Behera
Added new interfaces to ethtool to configure receive network flow distribution across multiple rx rings using hashing. Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-07[NET]: include <linux/types.h> into linux/ethtool.h for __u* typedefKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03include/linux/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-10[ETHTOOL]: Introduce ->{get,set}_priv_flags, ETHTOOL_[GS]PFLAGSJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL]: Introduce get_sset_count. Obsolete get_stats_count, self_test_countJeff Garzik
2007-10-10[ETHTOOL]: Add ETHTOOL_[GS]FLAGS sub-ioctlsJeff Garzik
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[NET]: Add ethtool support for NETIF_F_IPV6_CSUM devices.Michael Chan
Add ethtool utility function to set or clear IPV6_CSUM feature flag. Modify tg3.c and bnx2.c to use this function when doing ethtool -K to change tx checksum. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[ETHTOOL]: Add 2.5G bit definitions.Michael Chan
Add 2.5G supported and advertising bit definitions. 2.5G is supported by the bnx2 driver. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
