path: root/include/linux/edma.h
2019-07-22dmaengine: edma: make edma_filter_fn privateArnd Bergmann
With the audio driver no longer referring to this function, it can be made private to the dmaengine driver itself, and the header file removed. Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20190722081705.2084961-2-arnd@arndb.de Signed-off-by: Vinod Koul <vkoul@kernel.org>
2012-09-01dmaengine: add TI EDMA DMA engine driverMatt Porter
Add a DMA engine driver for the TI EDMA controller. This driver is implemented as a wrapper around the existing DaVinci private DMA implementation. This approach allows for incremental conversion of each peripheral driver to the DMA engine API. The EDMA driver supports slave transfers but does not yet support cyclic transfers. Signed-off-by: Matt Porter <mporter@ti.com> Tested-by: Tom Rini <trini@ti.com> Tested-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
