Currently, CONFIG_JUMP_LABEL just means "I _want_ to use jump label".
The jump label is controlled by HAVE_JUMP_LABEL, which is defined
like this:
#if defined(CC_HAVE_ASM_GOTO) && defined(CONFIG_JUMP_LABEL)
# define HAVE_JUMP_LABEL
#endif
We can improve this by testing 'asm goto' support in Kconfig, then
make JUMP_LABEL depend on CC_HAS_ASM_GOTO.
Ugly #ifdef HAVE_JUMP_LABEL will go away, and CONFIG_JUMP_LABEL will
match to the real kernel capability.
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Although dynamic debug is often only used for debug builds, sometimes
its enabled for production builds as well. Minimize its impact by using
jump labels. This reduces the text section by 7000+ bytes in the kernel
image below. It does increase data, but this should only be referenced
when changing the direction of the branches, and hence usually not in
cache.
8194852 4879776 925696 14000324 d5a0c4 vmlinux.pre
8187337 4960224 925696 14073257 d6bda9 vmlinux.post
Link: http://lkml.kernel.org/r/d165b465e8c89bc582d973758d40be44c33f018b.1467837322.git.jbaron@akamai.com
Signed-off-by: Jason Baron <jbaron@akamai.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Joe Perches <joe@perches.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
The return value is not used by callers of these functions
so change the functions to return void.
Acked-by: Jason Baron <jbaron@akamai.com>
Introduce print_hex_dump_debug() that can be dynamically controlled, similar to
pr_debug.
Also, make print_hex_dump_bytes() dynamically controlled
Implement only 'p' flag (_DPRINTK_FLAGS_PRINT) to keep it simple since hex dump prints
multiple lines and long prefix would impact readability.
To provide line/file etc. information, use pr_debug or similar
before/after print_hex_dump_debug()
Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
The __used attribute prevents gcc from eliminating
unnecessary, otherwise optimized away, metadata for
debugging logging messages.
Remove the __used attribute.
Acked-by: Jason Baron <jbaron@redhat.com>
drivers/infiniband/ulp/srp/ib_srp.c #defines pr_fmt() PFX fmt, but PFX
is not #defined until after <linux/*> headers are included.
This results in a bad expansion of the pr_warn() in the stub function.
2084c2084
< printk("<4>" PFX "dyndbg supported only in " "CONFIG_DYNAMIC_DEBUG builds\n")
This introduces a fake module param $module.dyndbg. Its based upon
Thomas Renninger's $module.ddebug boot-time debugging patch from
https://lkml.org/lkml/2010/9/15/397
The 'fake' module parameter is provided for all modules, whether or
not they need it. It is not explicitly added to each module, but is
implemented in callbacks invoked from parse_args.
For builtin modules, dynamic_debug_init() now directly calls
parse_args(..., &ddebug_dyndbg_boot_params_cb), to process the params
undeclared in the modules, just after the ddebug tables are processed.
While its slightly weird to reprocess the boot params, parse_args() is
already called repeatedly by do_initcall_levels(). More importantly,
the dyndbg queries (given in ddebug_query or dyndbg params) cannot be
activated until after the ddebug tables are ready, and reusing
parse_args is cleaner than doing an ad-hoc parse. This reparse would
break options like inc_verbosity, but they probably should be params,
like verbosity=3.
ddebug_dyndbg_boot_params_cb() handles both bare dyndbg (aka:
ddebug_query) and module-prefixed dyndbg params, and ignores all other
parameters. For example, the following will enable pr_debug()s in 4
builtin modules, in the order given:
dyndbg="module params +p; module aio +p" module.dyndbg=+p pci.dyndbg
For loadable modules, parse_args() in load_module() calls
ddebug_dyndbg_module_params_cb(). This handles bare dyndbg params as
passed from modprobe, and errors on other unknown params.
Note that modprobe reads /proc/cmdline, so "modprobe foo" grabs all
foo.params, strips the "foo.", and passes these to the kernel.
ddebug_dyndbg_module_params_cb() is again called for the unknown
params; it handles dyndbg, and errors on others. The "doing" arg
added previously contains the module name.
For non CONFIG_DYNAMIC_DEBUG builds, the stub function accepts
and ignores $module.dyndbg params, other unknowns get -ENOENT.
If no param value is given (as in pci.dyndbg example above), "+p" is
assumed, which enables all pr_debug callsites in the module.
The dyndbg fake parameter is not shown in /sys/module/*/parameters,
thus it does not use any resources. Changes to it are made via the
control file.
Also change pr_info in ddebug_exec_queries to vpr_info,
no need to see it all the time.
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
CC: Thomas Renninger <trenn@suse.de>
CC: Rusty Russell <rusty@rustcorp.com.au>
clean up some space-before-tabs problems.
lineno:24 allows files with 4 million lines, an insane file-size, even
for never-to-get-in-tree machine generated code. Reduce this to 18
bits, which still allows 256k lines. This is still insanely big, but
its not raving mad.
Change describe_flags() to emit '=[pmflt_]+' for current callsite
flags, or just '=_' when they're disabled. Having '=' in output
allows a more selective grep expression; in contrast '-' may appear
in filenames, line-ranges, and format-strings. '=' also has better
mnemonics, saying; "the current setting is equal to <flags>".
This allows grep "=_" <dbgfs>/dynamic_debug/control to see disabled
callsites while avoiding the many occurrences of " = " seen in format
strings.
Enlarge flagsbufs to handle additional flag char, and alter
ddebug_parse_flags() to allow flags=0, so that user can turn off all
debug flags via:
~# echo =_ > <dbgfs>/dynamic_debug/control
If CONFIG_DYNAMIC_DEBUG is defined, honor it over DEBUG, so that
pr_debug()s are controllable, instead of always-on. When DEBUG is
also defined, change _DPRINTK_FLAGS_DEFAULT to enable printing by
default.
Also adding _DPRINTK_FLAGS_INCL_MODNAME would be nice, but there are
numerous cases of pr_debug(NAME ": ...), which would result in double
printing of module-name. So defer this until things settle.
Currently any enabled dynamic-debug flag on a pr_debug callsite will
enable printing, even if _DPRINTK_FLAGS_PRINT is off. Checking print
flag directly allows "-p" to disable callsites without fussing with
other flags, so the following disables everything, without altering
flags user may have set:
echo -p > $DBGFS/dynamic_debug/control
Standardize the style for compiler based printf format verification.
Standardized the location of __printf too.
Done via script and a little typing.
$ grep -rPl --include=*.[ch] -w "__attribute__" * | \
grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \
xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }'
[akpm@linux-foundation.org: revert arch bits]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Replace the repetitive struct _ddebug descriptor definitions with a new
DECLARE_DYNAMIC_DEBUG_META_DATA(name, fmt) macro.
[akpm@linux-foundation.org: s/DECLARE/DEFINE/]
Signed-off-by: Andrew Morton <akpm@google.com>
Previously, if dynamic debug was enabled netdev_dbg() was using
dynamic_dev_dbg() to print out the underlying msg. Fix this by making
sure netdev_dbg() uses __netdev_printk().
Remove no longer used dynamic debug control variables. The
definitions were removed a while ago, but we forgot to clean
up the extern references.
Unlike dynamic_pr_debug, dynamic uses of dev_dbg can not
currently add task_pid/KBUILD_MODNAME/__func__/__LINE__
to selected debug output.
Add a new function similar to dynamic_pr_debug to
optionally emit these prefixes.
Cc: Aloisio Almeida <aloisio.almeida@openbossa.org>
Noticed-by: Aloisio Almeida <aloisio.almeida@openbossa.org>
Introduce:
static __always_inline bool static_branch(struct jump_label_key *key);
instead of the old JUMP_LABEL(key, label) macro.
In this way, jump labels become really easy to use:
Define:
struct jump_label_key jump_key;
Can be used as:
if (static_branch(&jump_key))
do unlikely code
enable/disale via:
jump_label_inc(&jump_key);
jump_label_dec(&jump_key);
that's it!
For the jump labels disabled case, the static_branch() becomes an
atomic_read(), and jump_label_inc()/dec() are simply atomic_inc(),
atomic_dec() operations. We show testing results for this change below.
Thanks to H. Peter Anvin for suggesting the 'static_branch()' construct.
Since we now require a 'struct jump_label_key *key', we can store a pointer into
the jump table addresses. In this way, we can enable/disable jump labels, in
basically constant time. This change allows us to completely remove the previous
hashtable scheme. Thanks to Peter Zijlstra for this re-write.
Testing:
I ran a series of 'tbench 20' runs 5 times (with reboots) for 3
configurations, where tracepoints were disabled.
jump label configured in
avg: 815.6
jump label *not* configured in (using atomic reads)
avg: 800.1
jump label *not* configured in (regular reads)
avg: 803.4
LKML-Reference: <20110316212947.GA8792@redhat.com>
Suggested-by: H. Peter Anvin <hpa@linux.intel.com>
Tested-by: David Daney <ddaney@caviumnetworks.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Add flags that allow the user to specify via debugfs whether or not the
module name, function name, line number and/or thread ID have to be
included in the printed message.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Greg Banks <gnb@fmeh.org>
Cc: Konrad Rzeszutek Wilk <konrad@darnok.org>
On older gcc (3.3) dynamic debug fails to compile:
include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer':
include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk'
include/net/inet_connection_sock.h:219: error: this is a previous declaration
include/net/inet_connection_sock.h:236: error: duplicate label declaration `out'
include/net/inet_connection_sock.h:236: error: duplicate label `do_printk'
include/net/inet_connection_sock.h:236: error: duplicate label `out'
Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now.
Cc: <stable@kernel.org>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
* 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-block: (95 commits)
cciss: fix PCI IDs for new Smart Array controllers
drbd: add race-breaker to drbd_go_diskless
drbd: use dynamic_dev_dbg to optionally log uuid changes
dynamic_debug.h: Fix dynamic_dev_dbg() macro if CONFIG_DYNAMIC_DEBUG not set
drbd: cleanup: change "<= 0" to "== 0"
drbd: relax the grace period of the md_sync timer again
drbd: add some more explicit drbd_md_sync
drbd: drop wrong debug asserts, fix recently introduced race
drbd: cleanup useless leftover warn/error printk's
drbd: add explicit drbd_md_sync to drbd_resync_finished
drbd: Do not log an ASSERT for P_OV_REQUEST packets while C_CONNECTED
drbd: fix for possible deadlock on IO error during resync
drbd: fix unlikely access after free and list corruption
drbd: fix for spurious fullsync (uuids rotated too fast)
drbd: allow for explicit resync-finished notifications
drbd: preparation commit, using full state in receive_state()
drbd: drbd_send_ack_dp must not rely on header information
drbd: Fix regression in recv_bm_rle_bits (compressed bitmap)
drbd: Fixed a stupid copy and paste error
drbd: Allow larger values for c-fill-target.
Fix up trivial conflict in drivers/block/ataflop.c due to BKL removal
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Convert the 'dynamic debug' infrastructure to use jump labels.
LKML-Reference: <b77627358cea3e27d7be4386f45f66219afb8452.1284733808.git.jbaron@redhat.com>
We should initialize the module dynamic debug datastructures
only after determining that the module is not loaded yet. This
fixes a bug that introduced in 2.6.35-rc2, where when a trying
to load a module twice, we also load it's dynamic printing data
twice which causes all sorts of nasty issues. Also handle
the dynamic debug cleanup later on failure.
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef)
Signed-off-by: Florian Ragwitz <rafl@debian.org>
Cc: Jason Baron <jbaron@redhat.com>
If CONFIG_DYNAMIC_DEBUG is enabled and a source file has:
#define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
#include <linux/kernel.h>
dynamic_debug.h will duplicate KBUILD_MODNAME
in the output string.
Remove the use of KBUILD_MODNAME from the
output format string generated by dynamic_debug.h
If CONFIG_DYNAMIC_DEBUG is not enabled, no compile-time
check is done to printk/dev_printk arguments.
Add it.
When pr_fmt() was added to the pr_debug() code, we added it not only to the
dynamic_pr_debug() function, but also to the dynamic_dev_dbg() funciton.
However, dev_dbg() doesn't make use of pr_fmt(), so neither should
dynamic_dev_dbg().
When CONFIG_DYNAMIC_DEBUG is enabled, allow callers of pr_debug()
to provide their own definition of pr_fmt() even if that definition
uses tricks like
#define pr_fmt(fmt) "%s:" fmt, __func__
Signed-off-by: Greg Banks <gnb@sgi.com>
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
This patch combines Greg Bank's dprintk() work with the existing dynamic
printk patchset, we are now calling it 'dynamic debug'.
The new feature of this patchset is a richer /debugfs control file interface,
(an example output from my system is at the bottom), which allows fined grained
control over the the debug output. The output can be controlled by function,
file, module, format string, and line number.
for example, enabled all debug messages in module 'nf_conntrack':
echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control
to disable them:
echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control
A further explanation can be found in the documentation patch.
