path: root/include/linux/delayacct.h
2006-09-01[PATCH] task delay accounting fixesShailabh Nagar
Cleanup allocation and freeing of tsk->delays used by delay accounting. This solves two problems reported for delay accounting: 1. oops in __delayacct_blkio_ticks http://www.uwsg.indiana.edu/hypermail/linux/kernel/0608.2/1844.html Currently tsk->delays is getting freed too early in task exit which can cause a NULL tsk->delays to get accessed via reading of /proc/<tgid>/stats. The patch fixes this problem by freeing tsk->delays closer to when task_struct itself is freed up. As a result, it also eliminates the use of tsk->delays_lock which was only being used (inadequately) to safeguard access to tsk->delays while a task was exiting. 2. Possible memory leak in kernel/delayacct.c http://www.uwsg.indiana.edu/hypermail/linux/kernel/0608.2/1389.html The patch cleans up tsk->delays allocations after a bad fork which was missing earlier. The patch has been tested to fix the problems listed above and stress tested with rapid calls to delay accounting's taskstats command interface (which is the other path that can access the same data, besides the /proc interface causing the oops above). Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] delay accounting: temporarily enable by defaultShailabh Nagar
Enable delay accounting by default so that feature gets coverage testing without requiring special measures. Earlier, it was off by default and had to be enabled via a boot time param. This patch reverses the default behaviour to improve coverage testing. It can be removed late in the kernel development cycle if its believed users shouldn't have to incur any cost if they don't want delay accounting. Or it can be retained forever if the utility of the stats is deemed common enough to warrant keeping the feature on. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] make taskstats sending completely independent of delay accounting ↵Shailabh Nagar
on/off status Complete the separation of delay accounting and taskstats by ignoring the return value of delay accounting functions that fill in parts of taskstats before it is sent out (either in response to a command or as part of a task exit). Also make delayacct_add_tsk return silently when delay accounting is turned off rather than treat it as an error. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: /proc export of aggregated block I/O delaysShailabh Nagar
Export I/O delays seen by a task through /proc/<tgid>/stats for use in top etc. Note that delays for I/O done for swapping in pages (swapin I/O) is clubbed together with all other I/O here (this is not the case in the netlink interface where the swapin I/O is kept distinct) [akpm@osdl.org: printk warning fix] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: delay accounting usage of taskstats interfaceShailabh Nagar
Usage of taskstats interface by delay accounting. Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: sync block I/O and swapin delay collectionShailabh Nagar
Unlike earlier iterations of the delay accounting patches, now delays are only collected for the actual I/O waits rather than try and cover the delays seen in I/O submission paths. Account separately for block I/O delays incurred as a result of swapin page faults whose frequency can be affected by the task/process' rss limit. Hence swapin delays can act as feedback for rss limit changes independent of I/O priority changes. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: setupShailabh Nagar
Initialization code related to collection of per-task "delay" statistics which measure how long it had to wait for cpu, sync block io, swapping etc. The collection of statistics and the interface are in other patches. This patch sets up the data structures and allows the statistics collection to be disabled through a kernel boot parameter. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
