path: root/include/linux/dcache.h
2011-12-21fix apparmor dereferencing potentially freed dentry, sanitize __d_path() APIAl Viro
commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream. __d_path() API is asking for trouble and in case of apparmor d_namespace_path() getting just that. The root cause is that when __d_path() misses the root it had been told to look for, it stores the location of the most remote ancestor in *root. Without grabbing references. Sure, at the moment of call it had been pinned down by what we have in *path. And if we raced with umount -l, we could have very well stopped at vfsmount/dentry that got freed as soon as prepend_path() dropped vfsmount_lock. It is safe to compare these pointers with pre-existing (and known to be still alive) vfsmount and dentry, as long as all we are asking is "is it the same address?". Dereferencing is not safe and apparmor ended up stepping into that. d_namespace_path() really wants to examine the place where we stopped, even if it's not connected to our namespace. As the result, it looked at ->d_sb->s_magic of a dentry that might've been already freed by that point. All other callers had been careful enough to avoid that, but it's really a bad interface - it invites that kind of trouble. The fix is fairly straightforward, even though it's bigger than I'd like: * prepend_path() root argument becomes const. * __d_path() is never called with NULL/NULL root. It was a kludge to start with. Instead, we have an explicit function - d_absolute_root(). Same as __d_path(), except that it doesn't get root passed and stops where it stops. apparmor and tomoyo are using it. * __d_path() returns NULL on path outside of root. The main caller is show_mountinfo() and that's precisely what we pass root for - to skip those outside chroot jail. Those who don't want that can (and do) use d_path(). * __d_path() root argument becomes const. Everyone agrees, I hope. * apparmor does *NOT* try to use __d_path() or any of its variants when it sees that path->mnt is an internal vfsmount. In that case it's definitely not mounted anywhere and dentry_path() is exactly what we want there. Handling of sysctl()-triggered weirdness is moved to that place. * if apparmor is asked to do pathname relative to chroot jail and __d_path() tells it we it's not in that jail, the sucker just calls d_absolute_path() instead. That's the other remaining caller of __d_path(), BTW. * seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway - the normal seq_file logics will take care of growing the buffer and redoing the call of ->show() just fine). However, if it gets path not reachable from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped ignoring the return value as it used to do). Reviewed-by: John Johansen <john.johansen@canonical.com> ACKed-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-06vfs: renumber DCACHE_xyz flags, remove some stale onesLinus Torvalds
Gcc tends to generate better code with small integers, including the DCACHE_xyz flag tests - so move the common ones to be first in the list. Also just remove the unused DCACHE_INOTIFY_PARENT_WATCHED and DCACHE_AUTOFS_PENDING values, their users no longer exists in the source tree. And add a "unlikely()" to the DCACHE_OP_COMPARE test, since we want the common case to be a nice straight-line fall-through. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20kill lookup_create()Al Viro
folded into the only caller (kern_path_create()) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: add a DCACHE_NEED_LOOKUP flag for d_flagsJosef Bacik
Btrfs (and I'd venture most other fs's) stores its indexes in nice disk order for readdir, but unfortunately in the case of anything that stats the files in order that readdir spits back (like oh say ls) that means we still have to do the normal lookup of the file, which means looking up our other index and then looking up the inode. What I want is a way to create dummy dentries when we find them in readdir so that when ls or anything else subsequently does a stat(), we already have the location information in the dentry and can go straight to the inode itself. The lookup stuff just assumes that if it finds a dentry it is done, it doesn't perform a lookup. So add a DCACHE_NEED_LOOKUP flag so that the lookup code knows it still needs to run i_op->lookup() on the parent to get the inode for the dentry. I have tested this with btrfs and I went from something that looks like this http://people.redhat.com/jwhiter/ls-noreada.png To this http://people.redhat.com/jwhiter/ls-good.png Thats a savings of 1300 seconds, or 22 minutes. That is a significant savings. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-04-24vfs: get rid of insane dentry hashing rulesLinus Torvalds
The dentry hashing rules have been really quite complicated for a long while, in odd ways. That made functions like __d_drop() very fragile and non-obvious. In particular, whether a dentry was hashed or not was indicated with an explicit DCACHE_UNHASHED bit. That's despite the fact that the hash abstraction that the dentries use actually have a 'is this entry hashed or not' model (which is a simple test of the 'pprev' pointer). The reason that was done is because we used the normal 'is this entry unhashed' model to mark whether the dentry had _ever_ been hashed in the dentry hash tables, and that logic goes back many years (commit b3423415fbc2: "dcache: avoid RCU for never-hashed dentries"). That, in turn, meant that __d_drop had totally different unhashing logic for the dentry hash table case and for the anonymous dcache case, because in order to use the "is this dentry hashed" logic as a flag for whether it had ever been on the RCU hash table, we had to unhash such a dentry differently so that we'd never think that it wasn't 'unhashed' and wouldn't be free'd correctly. That's just insane. It made the logic really hard to follow, when there were two different kinds of "unhashed" states, and one of them (the one that used "list_bl_unhashed()") really had nothing at all to do with being unhashed per se, but with a very subtle lifetime rule instead. So turn all of it around, and make it logical. Instead of having a DENTRY_UNHASHED bit in d_flags to indicate whether the dentry is on the hash chains or not, use the hash chain unhashed logic for that. Suddenly "d_unhashed()" just uses "list_bl_unhashed()", and everything makes sense. And for the lifetime rule, just use an explicit DENTRY_RCUACCEES bit. If we ever insert the dentry into the dentry hash table so that it is visible to RCU lookup, we mark it DENTRY_RCUACCESS to show that it now needs the RCU lifetime rules. Now suddently that test at dentry free time makes sense too. And because unhashing now is sane and doesn't depend on where the dentry got unhashed from (because the dentry hash chain details doesn't have some subtle side effects), we can re-unify the __d_drop() logic and use common code for the unhashing. Also fix one more open-coded hash chain bit_spin_lock() that I missed in the previous chain locking cleanup commit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21FS: lookup_mnt() is only used in the core fs routines nowDavid Howells
lookup_mnt() is only used in the core fs routines now, so it doesn't need to be globally declared anymore. It isn't exported to modules at the moment, so nothing that can be modularised seems to be using it. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-18lose 'mounting_here' argument in ->d_manage()Al Viro
it's always false... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Allow d_manage() to be used in RCU-walk modeDavid Howells
Allow d_manage() to be called from pathwalk when it is in RCU-walk mode as well as when it is in Ref-walk mode. This permits __follow_mount_rcu() to call d_manage() directly. d_manage() needs a parameter to indicate that it is in RCU-walk mode as it isn't allowed to sleep if in that mode (but should return -ECHILD instead). autofs4_d_manage() can then be set to retain RCU-walk mode if the daemon accesses it and otherwise request dropping back to ref-walk mode. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to allow processes to be held during pathwalk transitDavid Howells
Add a dentry op (d_manage) to permit a filesystem to hold a process and make it sleep when it tries to transit away from one of that filesystem's directories during a pathwalk. The operation is keyed off a new dentry flag (DCACHE_MANAGE_TRANSIT). The filesystem is allowed to be selective about which processes it holds and which it permits to continue on or prohibits from transiting from each flagged directory. This will allow autofs to hold up client processes whilst letting its userspace daemon through to maintain the directory or the stuff behind it or mounted upon it. The ->d_manage() dentry operation: int (*d_manage)(struct path *path, bool mounting_here); takes a pointer to the directory about to be transited away from and a flag indicating whether the transit is undertaken by do_add_mount() or do_move_mount() skipping through a pile of filesystems mounted on a mountpoint. It should return 0 if successful and to let the process continue on its way; -EISDIR to prohibit the caller from skipping to overmounted filesystems or automounting, and to use this directory; or some other error code to return to the user. ->d_manage() is called with namespace_sem writelocked if mounting_here is true and no other locks held, so it may sleep. However, if mounting_here is true, it may not initiate or wait for a mount or unmount upon the parameter directory, even if the act is actually performed by userspace. Within fs/namei.c, follow_managed() is extended to check with d_manage() first on each managed directory, before transiting away from it or attempting to automount upon it. follow_down() is renamed follow_down_one() and should only be used where the filesystem deliberately intends to avoid management steps (e.g. autofs). A new follow_down() is added that incorporates the loop done by all other callers of follow_down() (do_add/move_mount(), autofs and NFSD; whilst AFS, NFS and CIFS do use it, their use is removed by converting them to use d_automount()). The new follow_down() calls d_manage() as appropriate. It also takes an extra parameter to indicate if it is being called from mount code (with namespace_sem writelocked) which it passes to d_manage(). follow_down() ignores automount points so that it can be used to mount on them. __follow_mount_rcu() is made to abort rcu-walk mode if it hits a directory with DCACHE_MANAGE_TRANSIT set on the basis that we're probably going to have to sleep. It would be possible to enter d_manage() in rcu-walk mode too, and have that determine whether to abort or not itself. That would allow the autofs daemon to continue on in rcu-walk mode. Note that DCACHE_MANAGE_TRANSIT on a directory should be cleared when it isn't required as every tranist from that directory will cause d_manage() to be invoked. It can always be set again when necessary. ========================== WHAT THIS MEANS FOR AUTOFS ========================== Autofs currently uses the lookup() inode op and the d_revalidate() dentry op to trigger the automounting of indirect mounts, and both of these can be called with i_mutex held. autofs knows that the i_mutex will be held by the caller in lookup(), and so can drop it before invoking the daemon - but this isn't so for d_revalidate(), since the lock is only held on _some_ of the code paths that call it. This means that autofs can't risk dropping i_mutex from its d_revalidate() function before it calls the daemon. The bug could manifest itself as, for example, a process that's trying to validate an automount dentry that gets made to wait because that dentry is expired and needs cleaning up: mkdir S ffffffff8014e05a 0 32580 24956 Call Trace: [<ffffffff885371fd>] :autofs4:autofs4_wait+0x674/0x897 [<ffffffff80127f7d>] avc_has_perm+0x46/0x58 [<ffffffff8009fdcf>] autoremove_wake_function+0x0/0x2e [<ffffffff88537be6>] :autofs4:autofs4_expire_wait+0x41/0x6b [<ffffffff88535cfc>] :autofs4:autofs4_revalidate+0x91/0x149 [<ffffffff80036d96>] __lookup_hash+0xa0/0x12f [<ffffffff80057a2f>] lookup_create+0x46/0x80 [<ffffffff800e6e31>] sys_mkdirat+0x56/0xe4 versus the automount daemon which wants to remove that dentry, but can't because the normal process is holding the i_mutex lock: automount D ffffffff8014e05a 0 32581 1 32561 Call Trace: [<ffffffff80063c3f>] __mutex_lock_slowpath+0x60/0x9b [<ffffffff8000ccf1>] do_path_lookup+0x2ca/0x2f1 [<ffffffff80063c89>] .text.lock.mutex+0xf/0x14 [<ffffffff800e6d55>] do_rmdir+0x77/0xde [<ffffffff8005d229>] tracesys+0x71/0xe0 [<ffffffff8005d28d>] tracesys+0xd5/0xe0 which means that the system is deadlocked. This patch allows autofs to hold up normal processes whilst the daemon goes ahead and does things to the dentry tree behind the automouter point without risking a deadlock as almost no locks are held in d_manage() and none in d_automount(). Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add a dentry op to handle automounting rather than abusing follow_link()David Howells
Add a dentry op (d_automount) to handle automounting directories rather than abusing the follow_link() inode operation. The operation is keyed off a new dentry flag (DCACHE_NEED_AUTOMOUNT). This also makes it easier to add an AT_ flag to suppress terminal segment automount during pathwalk and removes the need for the kludge code in the pathwalk algorithm to handle directories with follow_link() semantics. The ->d_automount() dentry operation: struct vfsmount *(*d_automount)(struct path *mountpoint); takes a pointer to the directory to be mounted upon, which is expected to provide sufficient data to determine what should be mounted. If successful, it should return the vfsmount struct it creates (which it should also have added to the namespace using do_add_mount() or similar). If there's a collision with another automount attempt, NULL should be returned. If the directory specified by the parameter should be used directly rather than being mounted upon, -EISDIR should be returned. In any other case, an error code should be returned. The ->d_automount() operation is called with no locks held and may sleep. At this point the pathwalk algorithm will be in ref-walk mode. Within fs/namei.c itself, a new pathwalk subroutine (follow_automount()) is added to handle mountpoints. It will return -EREMOTE if the automount flag was set, but no d_automount() op was supplied, -ELOOP if we've encountered too many symlinks or mountpoints, -EISDIR if the walk point should be used without mounting and 0 if successful. The path will be updated to point to the mounted filesystem if a successful automount took place. __follow_mount() is replaced by follow_managed() which is more generic (especially with the patch that adds ->d_manage()). This handles transits from directories during pathwalk, including automounting and skipping over mountpoints (and holding processes with the next patch). __follow_mount_rcu() will jump out of RCU-walk mode if it encounters an automount point with nothing mounted on it. follow_dotdot*() does not handle automounts as you don't want to trigger them whilst following "..". I've also extracted the mount/don't-mount logic from autofs4 and included it here. It makes the mount go ahead anyway if someone calls open() or creat(), tries to traverse the directory, tries to chdir/chroot/etc. into the directory, or sticks a '/' on the end of the pathname. If they do a stat(), however, they'll only trigger the automount if they didn't also say O_NOFOLLOW. I've also added an inode flag (S_AUTOMOUNT) so that filesystems can mark their inodes as automount points. This flag is automatically propagated to the dentry as DCACHE_NEED_AUTOMOUNT by __d_instantiate(). This saves NFS and could save AFS a private flag bit apiece, but is not strictly necessary. It would be preferable to do the propagation in d_set_d_op(), but that doesn't normally have access to the inode. [AV: fixed breakage in case if __follow_mount_rcu() fails and nameidata_drop_rcu() succeeds in RCU case of do_lookup(); we need to fall through to non-RCU case after that, rather than just returning with ungrabbed *path] Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-10fs: fix dcache.h kernel-doc notationRandy Dunlap
Fix new kernel-doc notation warning in dcache.h: Warning(include/linux/dcache.h:316): Excess function parameter 'Returns' description in '__d_rcu_to_refcount' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: implement faster dentry memcmpNick Piggin
The standard memcmp function on a Westmere system shows up hot in profiles in the `git diff` workload (both parallel and single threaded), and it is likely due to the costs associated with trapping into microcode, and little opportunity to improve memory access (dentry name is not likely to take up more than a cacheline). So replace it with an open-coded byte comparison. This increases code size by 8 bytes in the critical __d_lookup_rcu function, but the speedup is huge, averaging 10 runs of each: git diff st user sys elapsed CPU before 1.15 2.57 3.82 97.1 after 1.14 2.35 3.61 96.8 git diff mt user sys elapsed CPU before 1.27 3.85 1.46 349 after 1.26 3.54 1.43 333 Elapsed time for single threaded git diff at 95.0% confidence: -0.21 +/- 0.01 -5.45% +/- 0.24% It's -0.66% +/- 0.06% elapsed time on my Opteron, so rep cmp costs on the fam10h seem to be relatively smaller, but there is still a win. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: improve scalability of pseudo filesystemsNick Piggin
Regardless of how much we possibly try to scale dcache, there is likely always going to be some fundamental contention when adding or removing children under the same parent. Pseudo filesystems do not seem need to have connected dentries because by definition they are disconnected. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache per-bucket dcache hash lockingNick Piggin
We can turn the dcache hash locking from a global dcache_hash_lock into per-bucket locking. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: cache optimise dentry and inode for rcu-walkNick Piggin
Put dentry and inode fields into top of data structure. This allows RCU path traversal to perform an RCU dentry lookup in a path walk by touching only the first 56 bytes of the dentry. We also fit in 8 bytes of inline name in the first 64 bytes, so for short names, only 64 bytes needs to be touched to perform the lookup. We should get rid of the hash->prev pointer from the first 64 bytes, and fit 16 bytes of name in there, which will take care of 81% rather than 32% of the kernel tree. inode is also rearranged so that RCU lookup will only touch a single cacheline in the inode, plus one in the i_ops structure. This is important for directory component lookups in RCU path walking. In the kernel source, directory names average is around 6 chars, so this works. When we reach the last element of the lookup, we need to lock it and take its refcount which requires another cacheline access. Align dentry and inode operations structs, so members will be at predictable offsets and we can group common operations into head of structure. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove d_mountedNick Piggin
Rather than keep a d_mounted count in the dentry, set a dentry flag instead. The flag can be cleared by checking the hash table to see if there are any mounts left, which is not time critical because it is performed at detach time. The mounted state of a dentry is only used to speculatively take a look in the mount hash table if it is set -- before following the mount, vfsmount lock is taken and mount re-checked without races. This saves 4 bytes on 32-bit, nothing on 64-bit but it does provide a hole I might use later (and some configs have larger than 32-bit spinlocks which might make use of the hole). Autofs4 conversion and changelog by Ian Kent <raven@themaw.net>: In autofs4, when expring direct (or offset) mounts we need to ensure that we block user path walks into the autofs mount, which is covered by another mount. To do this we clear the mounted status so that follows stop before walking into the mount and are essentially blocked until the expire is completed. The automount daemon still finds the correct dentry for the umount due to the follow mount logic in fs/autofs4/root.c:autofs4_follow_link(), which is set as an inode operation for direct and offset mounts only and is called following the lookup that stopped at the covered mount. At the end of the expire the covering mount probably has gone away so the mounted status need not be restored. But we need to check this and only restore the mounted status if the expire failed. XXX: autofs may not work right if we have other mounts go over the top of it? Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache rationalise dget variantsNick Piggin
dget_locked was a shortcut to avoid the lazy lru manipulation when we already held dcache_lock (lru manipulation was relatively cheap at that point). However, how that the lru lock is an innermost one, we never hold it at any caller, so the lock cost can now be avoided. We already have well working lazy dcache LRU, so it should be fine to defer LRU manipulations to scan time. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: Use rename lock and RCU for multi-step operationsNick Piggin
The remaining usages for dcache_lock is to allow atomic, multi-step read-side operations over the directory tree by excluding modifications to the tree. Also, to walk in the leaf->root direction in the tree where we don't have a natural d_lock ordering. This could be accomplished by taking every d_lock, but this would mean a huge number of locks and actually gets very tricky. Solve this instead by using the rename seqlock for multi-step read-side operations, retry in case of a rename so we don't walk up the wrong parent. Concurrent dentry insertions are not serialised against. Concurrent deletes are tricky when walking up the directory: our parent might have been deleted when dropping locks so also need to check and retry for that. We can also use the rename lock in cases where livelock is a worry (and it is introduced in subsequent patch). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: scale inode alias listNick Piggin
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list from concurrent modification. d_alias is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale subdirsNick Piggin
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't using dcache_lock for these anyway (eg. using i_mutex). Note: if we change the locking rule in future so that ->d_child protection is provided only with ->d_parent->d_lock, it may allow us to reduce some locking. But it would be an exception to an otherwise regular locking scheme, so we'd have to see some good results. Probably not worthwhile. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale dentry refcountNick Piggin
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a 0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when we start protecting many other dentry members with d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale hashNick Piggin
Add a new lock, dcache_hash_lock, to protect the dcache hash table from concurrent modification. d_hash is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07hostfs: simplify lockingNick Piggin
Remove dcache_lock locking from hostfs filesystem, and move it into dcache helpers. All that is required is a coherent path name. Protection from concurrent modification of the namespace after path name generation is not provided in current code, because dcache_lock is dropped before the path is used. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: name case update methodNick Piggin
smpfs and ncpfs want to update a live dentry name in-place. Rather than have them open code the locking, provide a documented dcache API. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache documentation cleanupNick Piggin
Remove redundant (and incorrect, since dcache RCU lookup) dentry locking documentation and point to the canonical document. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-08-11vfs: show unreachable paths in getcwd and procMiklos Szeredi
Prepend "(unreachable)" to path strings if the path is not reachable from the current root. Two places updated are - the return string from getcwd() - and symlinks under /proc/$PID. Other uses of d_path() are left unchanged (we know that some old software crashes if /proc/mounts is changed). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09new helper: __dentry_path()Al Viro
builds path relative to fs root, called under dcache_lock, doesn't append any nonsense to unlinked ones. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-15Fix the regression created by "set S_DEAD on unlink()..." commitAl Viro
1) i_flags simply doesn't work for mount/unlink race prevention; we may have many links to file and rm on one of those obviously shouldn't prevent bind on top of another later on. To fix it right way we need to mark _dentry_ as unsuitable for mounting upon; new flag (DCACHE_CANT_MOUNT) is protected by d_flags and i_mutex on the inode in question. Set it (with dont_mount(dentry)) in unlink/rmdir/etc., check (with cant_mount(dentry)) in places in namespace.c that used to check for S_DEAD. Setting S_DEAD is still needed in places where we used to set it (for directories getting killed), since we rely on it for readdir/rmdir race prevention. 2) rename()/mount() protection has another bogosity - we unhash the target before we'd checked that it's not a mountpoint. Fixed. 3) ancient bogosity in pivot_root() - we locked i_mutex on the right directory, but checked S_DEAD on the different (and wrong) one. Noticed and fixed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11dcache: extrace and use d_unlinked()Alexey Dobriyan
d_unlinked() will be used in middle-term to ban checkpointing when opened but unlinked file is detected, and in long term, to detect such situation and special case on it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11switch lookup_mnt()Al Viro
2009-06-11fsnotify: parent event notificationEric Paris
inotify and dnotify both use a similar parent notification mechanism. We add a generic parent notification mechanism to fsnotify for both of these to use. This new machanism also adds the dentry flag optimization which exists for inotify to dnotify. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-03-27fs: make struct dentry->d_op constJan Engelhardt
This change will allow for tagging many dentry_operations const in the source tree. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31shrink struct dentryNick Piggin
struct dentry is one of the most critical structures in the kernel. So it's sad to see it going neglected. With CONFIG_PROFILING turned on (which is probably the common case at least for distros and kernel developers), sizeof(struct dcache) == 208 here (64-bit). This gives 19 objects per slab. I packed d_mounted into a hole, and took another 4 bytes off the inline name length to take the padding out from the end of the structure. This shinks it to 200 bytes. I could have gone the other way and increased the length to 40, but I'm aiming for a magic number, read on... I then got rid of the d_cookie pointer. This shrinks it to 192 bytes. Rant: why was this ever a good idea? The cookie system should increase its hash size or use a tree or something if lookups are a problem. Also the "fast dcookie lookups" in oprofile should be moved into the dcookie code -- how can oprofile possibly care about the dcookie_mutex? It gets dropped after get_dcookie() returns so it can't be providing any sort of protection. At 192 bytes, 21 objects fit into a 4K page, saving about 3MB on my system with ~140 000 entries allocated. 192 is also a multiple of 64, so we get nice cacheline alignment on 64 and 32 byte line systems -- any given dentry will now require 3 cachelines to touch all fields wheras previously it would require 4. I know the inline name size was chosen quite carefully, however with the reduction in cacheline footprint, it should actually be just about as fast to do a name lookup for a 36 character name as it was before the patch (and faster for other sizes). The memory footprint savings for names which are <= 32 or > 36 bytes long should more than make up for the memory cost for 33-36 byte names. Performance is a feature... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH vfs-2.6 2/6] vfs: add d_ancestor()OGAWA Hirofumi
This adds d_ancestor() instead of d_isparent(), then use it. If new_dentry == old_dentry, is_subdir() returns 1, looks strange. "new_dentry == old_dentry" is not subdir obviously. But I'm not checking callers for now, so this keeps current behavior. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-10-23[PATCH] kill d_alloc_anonChristoph Hellwig
Remove d_alloc_anon now that no users are left. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] new helper: d_obtain_aliasChristoph Hellwig
The calling conventions of d_alloc_anon are rather unfortunate for all users, and it's name is not very descriptive either. Add d_obtain_alias as a new exported helper that drops the inode reference in the failure case, too and allows to pass-through NULL pointers and inodes to allow for tail-calls in the export operations. Incidentally this helper already existed as a private function in libfs.c as exportfs_d_alloc so kill that one and switch the callers to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-25[PATCH] change d_add_ci argument orderingChristoph Hellwig
As pointed out during review d_add_ci argument order should match d_add, so switch the dentry and inode arguments. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-28dcache: Add case-insensitive support d_ci_add() routineBarry Naujok
This add a dcache entry to the dcache for lookup, but changing the name that is associated with the entry rather than the one passed in to the lookup routine. First, it sees if the case-exact match already exists in the dcache and uses it if one exists. Otherwise, it allocates a new node with the new name and splices it into the dcache. Original code from ntfs_lookup in fs/ntfs/namei.c by Anton Altaparmakov. Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Acked-by: Christoph Hellwig <hch@infradead.org>
2008-07-11Merge branch 'linus' into core/rcuIngo Molnar
Conflicts: include/linux/rculist.h kernel/rcupreempt.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-23[patch 2/4] fs: make struct file arg to d_path constJan Engelhardt
2008-05-19rcu: split list.h and move rcu-protected lists into rculist.hFranck Bui-Huu
Move rcu-protected lists from list.h into a new header file rculist.h. This is done because list are a very used primitive structure all over the kernel and it's currently impossible to include other header files in this list.h without creating some circular dependencies. For example, list.h implements rcu-protected list and uses rcu_dereference() without including rcupdate.h. It actually compiles because users of rcu_dereference() are macros. Others RCU functions could be used too but aren't probably because of this. Therefore this patch creates rculist.h which includes rcupdates without to many changes/troubles. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
