path: root/include/linux/compiler-gcc3.h
2015-06-25compiler-gcc: integrate the various compiler-gcc[345].h filesJoe Perches
As gcc major version numbers are going to advance rather rapidly in the future, there's no real value in separate files for each compiler version. Deduplicate some of the macros #defined in each file too. Neaten comments using normal kernel commenting style. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Segher Boessenkool <segher@kernel.crashing.org> Cc: Sasha Levin <levinsasha928@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Alan Modra <amodra@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21compiler-gcc{3,4}.h: Use GCC_VERSION macroDaniel Santos
Using GCC_VERSION reduces complexity, is easier to read and is GCC's recommended mechanism for doing version checks. (Just don't ask me why they didn't define it in the first place.) This also makes it easy to merge compiler-gcc{,3,4}.h should somebody want to. Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Borislav Petkov <bp@alien8.de> Cc: Andi Kleen <ak@linux.intel.com> Cc: Joe Perches <joe@perches.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22include/linux/compiler-gcc*.h: unify macro definitionsBorislav Petkov
Unify identical gcc3.x and gcc4.x macros. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18gcov: add gcov profiling infrastructurePeter Oberparleiter
Enable the use of GCC's coverage testing tool gcov [1] with the Linux kernel. gcov may be useful for: * debugging (has this code been reached at all?) * test improvement (how do I change my test to cover these lines?) * minimizing kernel configurations (do I need this option if the associated code is never run?) The profiling patch incorporates the following changes: * change kbuild to include profiling flags * provide functions needed by profiling code * present profiling data as files in debugfs Note that on some architectures, enabling gcc's profiling option "-fprofile-arcs" for the entire kernel may trigger compile/link/ run-time problems, some of which are caused by toolchain bugs and others which require adjustment of architecture code. For this reason profiling the entire kernel is initially restricted to those architectures for which it is known to work without changes. This restriction can be lifted once an architecture has been tested and found compatible with gcc's profiling. Profiling of single files or directories is still available on all platforms (see config help text). [1] http://gcc.gnu.org/onlinedocs/gcc/Gcov.html Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Li Wei <W.Li@Sun.COM> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com> Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Disallow gcc versions 3.{0,1}Ingo Molnar
GCC 3.0 and 3.1 are too old to build a working kernel. Signed-off-by: Ingo Molnar <mingo@elte.hu> [ This check got dropped as obsolete when I simplified the gcc header inclusion mess in f153b82121b0366fe0e5f9553545cce237335175, but Willy Tarreau reports actually having those old versions still.. -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Sanitize gcc version header includesLinus Torvalds
- include the gcc version-dependent header files from the generic gcc header file, rather than the other way around (iow: don't make the non-gcc header file have to know about gcc versions) - don't include compiler-gcc4.h for gcc 5 (for whenever it gets released). That's just confusing and made us do odd things in the gcc4 header file (testing that we really had version 4!) - generate the name from the __GNUC__ version directly, rather than having a mess of #if conditionals. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-17Force erroneous inclusions of compiler-*.h files to be errorsRobert P. J. Day
Replace worthless comments with actual preprocessor errors when including the wrong versions of the compiler.h files. [akpm@linux-foundation.org: make it work] Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09compiler: introduce __used and __maybe_unusedDavid Rientjes
__used is defined to be __attribute__((unused)) for all pre-3.3 gcc compilers to suppress warnings for unused functions because perhaps they are referenced only in inline assembly. It is defined to be __attribute__((used)) for gcc 3.3 and later so that the code is still emitted for such functions. __maybe_unused is defined to be __attribute__((unused)) for both function and variable use if it could possibly be unreferenced due to the evaluation of preprocessor macros. Function prototypes shall be marked with __maybe_unused if the actual definition of the function is dependant on preprocessor macros. No update to compiler-intel.h is necessary because ICC supports both __attribute__((used)) and __attribute__((unused)) as specified by the gcc manual. __attribute_used__ is deprecated and will be removed once all current code is converted to using __used. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Add unitialized_var() macro for suppressing gcc warningsBorislav Petkov
Introduce a macro for suppressing gcc from generating a warning about a probable uninitialized state of a variable. Example: - spinlock_t *ptl; + spinlock_t *uninitialized_var(ptl); Not a happy solution, but those warnings are obnoxious. - Using the usual pointlessly-set-it-to-zero approach wastes several bytes of text. - Using a macro means we can (hopefully) do something else if gcc changes cause the `x = x' hack to stop working - Using a macro means that people who are worried about hiding true bugs can easily turn it off. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-14[PATCH] Make __always_inline actually force always inliningIngo Molnar
This patch is the first in a series that tries to optimize the kernel in terms of size (and thus cache behavior, both cpu and pagecache). This first patch changes __always_inline to be a forced inline instead of the "regular" inline it was on everything except alpha. This forced inline matches the intention of the define better as a matter of documentation. There is no change in behavior by this patch, since "inline" currently is mapped to a forced inline anyway. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
