path: root/include/linux/clk
2014-01-28Merge tag 'clk-for-linus-3.14-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework changes from Mike Turquette: "The second half of the clock framework pull requeust for 3.14 is dominated by platform support for Qualcomm's MSM SoCs, DT binding updates for TI's OMAP-ish processors and additional support for Samsung chips. Additionally there are other smaller clock driver changes and several last minute fixes. This pull request also includes the HiSilicon support that depends on the already-merged arm-soc pull request" [ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ] * tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits) clk: sort Makefile clk: sunxi: fix overflow when setting up divided factors clk: Export more clk-provider functions dt-bindings: qcom: Fix warning with duplicate dt define clk: si5351: remove variant from platform_data clk: samsung: Remove unneeded semicolon clk: qcom: Fix modular build ARM: OMAP3: use DT clock init if DT data is available ARM: AM33xx: remove old clock data and link in new clock init code ARM: AM43xx: Enable clock init ARM: OMAP: DRA7: Enable clock init ARM: OMAP4: remove old clock data and link in new clock init code ARM: OMAP2+: io: use new clock init API ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT ARM: OMAP3: hwmod: initialize clkdm from clkdm_name ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm ARM: OMAP2+: clock: use driver API instead of direct memory read/write ARM: OMAP2+: clock: add support for indexed memmaps ARM: dts: am43xx clock data ARM: dts: AM35xx: use DT clock data ...
2014-01-17CLK: TI: add am43xx clock init fileTero Kristo
clk-43xx.c now contains the clock init functionality for am43xx, including DT clock registration and adding of static clkdev entries. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add omap3 clock init fileTero Kristo
clk-3xxx.c now contains the clock init functionality for omap3, including DT clock registration and adding of static clkdev entries. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add interface clock support for OMAP3Tero Kristo
OMAP3 has interface clocks in addition to functional clocks, which require special handling for the autoidle and idle status register offsets mainly. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add am33xx clock init fileTero Kristo
clk-33xx.c now contains the clock init functionality for am33xx, including DT clock registration and adding of static clkdev entries. This patch also moves the omap2_clk_enable_init_clocks declaration to the driver include, as this is needed by the am33xx clock init code. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add dra7 clock init fileTero Kristo
clk-7xx.c now contains the clock init functionality for dra7, including DT clock registration and adding of static clkdev entries. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add omap5 clock init fileTero Kristo
clk-54xx.c now contains the clock init functionality for omap5, including DT clock registration and adding of static clkdev entries. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add omap4 clock init fileTero Kristo
clk-44xx.c now contains the clock init functionality for omap4, including DT clock registration and adding of static clkdev entries. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17clk: ti: add support for basic mux clockTero Kristo
ti,mux-clock provides now a binding for basic mux support. This is just using the basic clock type. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add support for clockdomain bindingTero Kristo
Some OMAP clocks require knowledge about their parent clockdomain for book keeping purposes. This patch creates a new DT binding for TI clockdomains, which act as a collection of device clocks. Clockdomain itself is rather misleading name for the hardware functionality, as at least on OMAP4 / OMAP5 / DRA7 the clockdomains can be collections of either clocks and/or IP blocks, thus idle-domain or such might be more appropriate. For most cases on these SoCs, the kernel doesn't even need the information and the mappings can be ignored. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add support for gate clockTero Kristo
This patch adds support for TI specific gate clocks. These behave as basic gate-clock, but have different ops / hw-ops for controlling the actual gate, for example waiting until the clock is ready. Several sub-types are supported: - ti,gate-clock: basic gate clock with default ops/hwops - ti,clkdm-gate-clock: clockdomain level gate control - ti,dss-gate-clock: gate clock with DSS specific hardware handling - ti,am35xx-gate-clock: gate clock with AM35xx specific hardware handling - ti,hsdiv-gate-clock: gate clock with OMAP36xx hardware errata handling Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: ti: add support for ti divider-clockTero Kristo
This patch adds support for TI divider clock binding, which simply uses the basic clock divider to provide the features needed. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17clk: ti: add composite clock supportTero Kristo
This is a multipurpose clock node, which contains support for multiple sub-clocks. Uses basic composite clock type to implement the actual functionality, and TI specific gate, mux and divider clocks. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add autoidle supportTero Kristo
TI clk driver now routes some of the basic clocks through own registration routine to allow autoidle support. This routine just checks a couple of device node properties and adds autoidle support if required, and just passes the registration forward to basic clocks. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: Add DPLL clock supportTero Kristo
The OMAP clock driver now supports DPLL clock type. This patch also adds support for DT DPLL nodes. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: ti: add init support for clock IP blocksTero Kristo
ti_dt_clk_init_provider() can now be used to initialize the contents of a single clock IP block. This parses all the clocks under the IP block and calls the corresponding init function for them. This patch also introduces a helper function for the TI clock drivers to get register info from DT and append the master IP info to this. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-17CLK: TI: add DT alias clock registration mechanismTero Kristo
Some devices require their clocks to be available with a specific dev-id con-id mapping. With DT, the clocks can be found by default only with their name, or alternatively through the device node of the consumer. With drivers, that don't support DT fully yet, add mechanism to register specific clock names. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-03Merge tag 'renesas-dt3-for-v3.14' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt From Simon Horman: Third Round of Renesas ARM Based SoC DT Updates for v3.14 * r8a7791 (R-Car M2) and r8a7790 (R-Car H2) SoCSs - Add SSI, QSPI and MSIOF clocks in device tree r8a7791 (R-Car M2) based Koelsch and r8a7790 (R-Car H2) based Lager boards - Remove reference DTS - Specify external clock frequency in DT - Sync non-reference DTS with referene DTS - Add clocks to DTS * r8a7740 (R-Mobile A1) based Armadillo board - Add gpio-keys device - Add PWM backlight enable GPIO - Add PWM backlight power supply * r8a73a0 (SH-Mobile AG5), r8a7740 (R-Mobile A1) and r8a73a4 (SH-Mobile APE6) SoCs - Specify PFC interrupts in DT * tag 'renesas-dt3-for-v3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: (72 commits) ARM: shmobile: r8a7791: Add SSI clocks in device tree ARM: shmobile: r8a7790: Add SSI clocks in device tree ARM: shmobile: r8a7791: Add QSPI module clock in device tree ARM: shmobile: r8a7790: Add QSPI module clock in device tree ARM: shmobile: r8a7791: Add MSIOF clocks in device tree ARM: shmobile: r8a7790: Add MSIOF clocks in device tree ARM: shmobile: Remove Koelsch reference DTS ARM: shmobile: Remove Lager reference DTS ARM: shmobile: koelsch: Specify external clock frequency in DT ARM: shmobile: lager: Specify external clock frequency in DT ARM: shmobile: Sync Koelsch DTS with Koelsch reference DTS ARM: shmobile: Sync Lager DTS with Lager reference DTS ARM: shmobile: r8a7791: Add clocks ARM: shmobile: r8a7790: Reference clocks ARM: shmobile: r8a7790: Add clocks ARM: shmobile: armadillo: dts: Add gpio-keys device ARM: shmobile: sh73a0: Specify PFC interrupts in DT ARM: shmobile: r8a7740: Specify PFC interrupts in DT ARM: shmobile: r8a73a4: Specify PFC interrupts in DT ARM: shmobile: armadillo: dts: Add PWM backlight enable GPIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-26Merge branch 'tegra/dma-reset-rework' into next/dtOlof Johansson
Bringing in the tegra dma/reset framework cleanup as a base for the DT changes. * tegra/dma-reset-rework: (320 commits) spi: tegra: checking for ERR_PTR instead of NULL ASoC: tegra: update module reset list for Tegra124 clk: tegra: remove bogus PCIE_XCLK clk: tegra: remove legacy reset APIs ARM: tegra: remove legacy DMA entries from DT ARM: tegra: remove legacy clock entries from DT USB: EHCI: tegra: use reset framework Input: tegra-kbc - use reset framework serial: tegra: convert to standard DMA DT bindings serial: tegra: use reset framework spi: tegra: convert to standard DMA DT bindings spi: tegra: use reset framework staging: nvec: use reset framework i2c: tegra: use reset framework ASoC: tegra: convert to standard DMA DT bindings ASoC: tegra: allocate AHUB FIFO during probe() not startup() ASoC: tegra: call pm_runtime APIs around register accesses ASoC: tegra: use reset framework dma: tegra: register as an OF DMA controller dma: tegra: use reset framework ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-12clk: shmobile: Add R-Car Gen2 clocks supportLaurent Pinchart
The R-Car Gen2 SoCs (R8A7790 and R8A7791) have several clocks that are too custom to be supported in a generic driver. Those clocks can be divided in two categories: - Fixed rate clocks with multiplier and divisor set according to boot mode configuration - Custom divider clocks with SoC-specific divider values This driver supports both. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-12-11clk: tegra: remove legacy reset APIsStephen Warren
Now that no code uses the custom Tegra module reset API, we can remove its implementation. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Acked-By: Peter De Schrijver <pdeschrijver@nvidia.com>
2013-12-02clk: at91: add PMC pll clocksBoris BREZILLON
This patch adds new at91 pll clock implementation using common clk framework. The pll clock layout describe the PLLX register layout. There are four pll clock layouts: - at91rm9200 - at91sam9g20 - at91sam9g45 - sama5d3 PLL clocks are given characteristics: - min/max clock source rate - ranges of valid clock output rates - values to set in out and icpll fields for each supported output range These characteristics are checked during rate change to avoid over/underclocking. These characteristics are described in atmel's SoC datasheet in "Electrical Characteristics" paragraph. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02ARM: at91: move at91_pmc.h to include/linux/clk/at91_pmc.hBoris BREZILLON
This patch moves at91_pmc.h header from machine specific directory (arch/arm/mach-at91/include/mach/at91_pmc.h) to clk include directory (include/linux/clk/at91_pmc.h). We need this to avoid reference to machine specific headers in clk drivers. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-09-29ARM: mxs: remove custom .init_time hookSebastian Hesselbarth
This patch converts clk-imx2[38] clocksource_of_init compatible init associated with fsl,imx2[38]-clkctrl. With arch/arm calling of_clk_init(NULL) from time_init(), we can now also remove custom .init_time hooks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-29clk: sunxi: declare OF clock providerSebastian Hesselbarth
Common clock framework allows to register clock providers to get called on of_clk_init() by using CLK_OF_DECLARE. This converts sunxi clock providers to make use of it and get rid of the mach specific clk init call. As sunxi has a bunch of independent clk provider nodes, we hook current clock init to board compatible to make it called once. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-07-03Merge tag 'clk-for-linus-3.11' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull clock framework updates from Mike Turquette: "The common clock framework changes for 3.11 include new clock drivers across several different platforms and architectures, fixes to existing drivers, a MAINTAINERS file fix and improvements to the basic clock types that allow them to be of use to more platforms than before. Only a few fixes to the core framework are included with most all of the changes landing in the various clock drivers themselves." * tag 'clk-for-linus-3.11' of git://git.linaro.org/people/mturquette/linux: (55 commits) clk: tegra: fix ifdef for tegra_periph_reset_assert inline clk: tegra: provide tegra_periph_reset_assert alternative clk: exynos4: Fix clock aliases for cpufreq related clocks clk: samsung: Add MUX_FA macro to pass flag and alias clk: add support for Rockchip gate clocks clk: vexpress: Make the clock drivers directly available for arm64 clk: vexpress: Use full node name to identify individual clocks clk: tegra: T114: add DFLL DVCO reset control clk: tegra: T114: add DFLL source clocks clk: tegra: T114: add FCPU clock shaper programming, needed by the DFLL clk: gate: add CLK_GATE_HIWORD_MASK clk: divider: add CLK_DIVIDER_HIWORD_MASK flag clk: mux: add CLK_MUX_HIWORD_MASK clk: Always notify whole subtree when reparenting MAINTAINERS: make drivers/clk entry match subdirs clk: honor CLK_GET_RATE_NOCACHE in clk_set_rate clk: use clk_get_rate() for debugfs clk: tegra: Use override bits when needed clk: tegra: override bits for Tegra30 PLLM clk: tegra: override bits for Tegra114 PLLM ...
2013-06-24clk: tegra: fix ifdef for tegra_periph_reset_assert inlineStephen Warren
Commit 7064f6b "clk: tegra: provide tegra_periph_reset_assert alternative" added ifdef'd static inline versions of some functions, but tested ARCH_TEGRA rather than CONFIG_ARCH_TEGRA, thus disabling these function in all cases. In some cases, this caused HW modules to misbehave; for example, the Tegra I2C driver BUG()d during boot on Seaboard. Reported-by: Olof Johansson <olof@lixom.net> Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Paul Walmsley <pwalmsley@nvidia.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-06-22clk: tegra: provide tegra_periph_reset_assert alternativeArnd Bergmann
We have some tegra device drivers that are written to be platform independent but still use the tegra specific tegra_periph_reset_assert function. In order to build and link them without errors, this provides a static inline version of these functions that does nothing when Tegra support is disabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mike Turquette <mturquette@linaro.org> [mturquette@linaro.org: fixed up trivial merge issue]
2013-06-07Merge tag 'zynq-clk-for-3.11' of git://git.xilinx.com/linux-xlnx into next/socOlof Johansson
From Michal Simek: arm: Xilinx Zynq clock changes for v3.11 Change Xilinx Zynq DT clock description which reflects logical abstraction of Zynq's clock tree. - Refactor PLL driver - Use new clock controller driver - Change timer and uart drivers * tag 'zynq-clk-for-3.11' of git://git.xilinx.com/linux-xlnx: clk: zynq: Remove deprecated clock code arm: zynq: Migrate platform to clock controller clk: zynq: Add clock controller driver clk: zynq: Factor out PLL driver Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-31clk: tegra: Use common of_clk_init functionPrashant Gaikwad
Use common of_clk_init() function for clocks initialization. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-by: Thierry Reding <thierry.reding@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-05-29clk: mvebu: disintegrate obsolete fileSebastian Hesselbarth
Switch from function-centric to soc-centric clock drivers now makes a bunch of files obsolete. This deletes all files and Kconfig options that are not required anymore. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: zynq: Migrate platform to clock controllerSoren Brinkmann
Migrate the Zynq platform and its drivers to use the new clock controller driver. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: linux-serial@vger.kernel.org Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-04-11Merge branch 'depends/clk-for-3.10' into next/cleanupOlof Johansson
Bringin in clk subsystem dependencies needed by sunxi. * depends/clk-for-3.10: (26 commits) clk: sunxi: drop an unnecesary kmalloc clk: sunxi: drop CLK_IGNORE_UNUSED clk: sunxi: Add support for AXI, AHB, APB0 and APB1 gates clk: divider: Introduce CLK_DIVIDER_ALLOW_ZERO flag clk: mvebu: Use common of_clk_init() function clk: fix clk_mux::flags kerneldoc clk: allow reentrant calls into the clk framework clk: abstract locking out into helper functions clk: zynq: Add missing zynq clk header clk: sunxi: rename compatible strings arm: sunxi: Add useful information about sunxi clocks clk: arm: sunxi: Add a new clock driver for sunxi SOCs clk: ux500: Fix prcmu clocks registration ARM: imx: adapt clk_busy_mux to new clk_mux struct clk: Add composite clock type clk: add table lookup to mux clk: Fix incorrect return type in clk.c clk: prima2: fix return value check in sirfsoc_of_clk_init() clk:SPEAr1340: Correct parent clock configuration documentation: clk: fix couple of misspelling ...
2013-04-04clk: tegra: defer application of init tableStephen Warren
The Tegra clock driver is initialized during the ARM machine descriptor's .init_irq() hook. It can't be initialized earlier, since dynamic memory usage is required. It can't be initialized later, since the .init_timer() hook needs the clocks initialized. However, at this time, udelay() doesn't work. The Tegra clock initialization table may enable some PLLs. Enabling a PLL may require usage of udelay(). Hence, this can't happen right when the clock driver is initialized. To solve this, separate the clock driver initialization from the clock table processing, so they can execute at separate times. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-04-01ARM: mxs: remove common.hShawn Guo
All three remaining functions declared in common.h are implemented by clock driver. Create header include/linux/clk/mxs.h to contain them and remove common.h. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-03-27clk: arm: sunxi: Add a new clock driver for sunxi SOCsEmilio López
This commit implements the base CPU clocks for sunxi devices. It has been tested using a slightly modified cpufreq driver from the linux-sunxi 3.0 tree. Additionally, document the new bindings introduced by this patch. Idling: / # cat /sys/kernel/debug/clk/clk_summary clock enable_cnt prepare_cnt rate --------------------------------------------------------------------- osc32k 0 0 32768 osc24M_fixed 0 0 24000000 osc24M 0 0 24000000 apb1_mux 0 0 24000000 apb1 0 0 24000000 pll1 0 0 60000000 cpu 0 0 60000000 axi 0 0 60000000 ahb 0 0 60000000 apb0 0 0 30000000 dummy 0 0 0 After "yes >/dev/null &": / # cat /sys/kernel/debug/clk/clk_summary clock enable_cnt prepare_cnt rate --------------------------------------------------------------------- osc32k 0 0 32768 osc24M_fixed 0 0 24000000 osc24M 0 0 24000000 apb1_mux 0 0 24000000 apb1 0 0 24000000 pll1 0 0 1008000000 cpu 0 0 1008000000 axi 0 0 336000000 ahb 0 0 168000000 apb0 0 0 84000000 dummy 0 0 0 Signed-off-by: Emilio López <emilio@elopez.com.ar> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-02-21Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC-specific updates from Arnd Bergmann: "This is a larger set of new functionality for the existing SoC families, including: - vt8500 gains support for new CPU cores, notably the Cortex-A9 based wm8850 - prima2 gains support for the "marco" SoC family, its SMP based cousin - tegra gains support for the new Tegra4 (Tegra114) family - socfpga now supports a newer version of the hardware including SMP - i.mx31 and bcm2835 are now using DT probing for their clocks - lots of updates for sh-mobile - OMAP updates for clocks, power management and USB - i.mx6q and tegra now support cpuidle - kirkwood now supports PCIe hot plugging - tegra clock support is updated - tegra USB PHY probing gets implemented diffently" * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits) ARM: prima2: remove duplicate v7_invalidate_l1 ARM: shmobile: r8a7779: Correct TMU clock support again ARM: prima2: fix __init section for cpu hotplug ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3) ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3) arm: socfpga: Add SMP support for actual socfpga harware arm: Add v7_invalidate_l1 to cache-v7.S arm: socfpga: Add entries to enable make dtbs socfpga arm: socfpga: Add new device tree source for actual socfpga HW ARM: tegra: sort Kconfig selects for Tegra114 ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114 ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC ARM: tegra: Fix build error for gic update ARM: tegra: remove empty tegra_smp_init_cpus() ARM: shmobile: Register ARM architected timer ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move ARM: shmobile: r8a7779: Correct TMU clock support ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles ARM: mxs: use apbx bus clock to drive the timers on timrotv2 ...
2013-01-28ARM: tegra: remove legacy clock codePrashant Gaikwad
Remove all legacy clock code from mach-tegra. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28ARM: tegra: migrate to new clock codePrashant Gaikwad
Migrate Tegra clock support to drivers/clk/tegra, this involves moving: 1. definition of tegra_cpu_car_ops to clk.c 2. definition of reset functions to clk-peripheral.c 3. change parent of cpu clock. 4. Remove legacy clock initialization. 5. Initialize clocks using DT. 6. Remove all instance of mach/clk.h Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> [swarren: use to_clk_periph_gate().] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28ARM: tegra: move tegra_cpu_car.h to linux/clk/tegra.hPrashant Gaikwad
tegra_cpu_car_ops struct is going to be accessed from drivers/clk/tegra. Move the tegra_cpu_car_ops to include/linux/clk/tegra.h. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-24clk: sunxi: Use common of_clk_init() functionPrashant Gaikwad
Use common of_clk_init() function to initialize clocks. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Acked-by: Maxime Ripard <maxime.ripard@anandra.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-12-14Merge tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson: "This is a branch with updates for Marvell's mvebu/kirkwood platforms. They came in late-ish, and were heavily interdependent such that it didn't make sense to split them up across the cross-platform topic branches. So here they are (for the second release in a row) in a branch on their own." * tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits) arm: l2x0: add aurora related properties to OF binding arm: mvebu: add Aurora L2 Cache Controller to the DT arm: mvebu: add L2 cache support dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit ...
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
2012-11-20clk: mvebu: add mvebu core clocks.Sebastian Hesselbarth
This driver allows to provide DT clocks for core clocks found on Marvell Kirkwood, Dove & 370/XP SoCs. The core clock frequencies and ratios are determined by decoding the Sample-At-Reset registers. Although technically correct, using a divider of 0 will lead to div_by_zero panic. Let's use a ratio of 0/1 instead to fail later with a zero clock. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by Gregory CLEMENT <gregory.clement@free-electrons.com>
2012-11-16clk: sunxi: Add dummy fixed rate clock for Allwinner A1X SoCsMaxime Ripard
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Mike Turquette <mturquette@ti.com>
2012-11-14clk: Add support for fundamental zynq clksJosh Cartwright
Provide simplified models for the necessary clocks on the zynq-7000 platform. Currently, the PLLs, the CPU clock network, and the basic peripheral clock networks (for SDIO, SMC, SPI, QSPI, UART) are modelled. OF bindings are also provided and documented. Signed-off-by: Josh Cartwright <josh.cartwright@ni.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Michal Simek <michal.simek@xilinx.com>
2012-09-19ARM: bcm2835: add stub clock driverSimon Arlott
This patch adds a minimal stub clock driver for the BCM2835. Its sole purpose is to allow the PL011 AMBA clk_get() API calls to provide something that looks enough like a clock that the driver probes and operates correctly. This patch was extracted from git://github.com/lp0/linux.git branch rpi-split as of 2012/09/08, and modified as follows: * Reworked to call clk_register_fixed_rate(), and clk_register_clkdev() rather than using static data to represent the clocks. * Moved implementation to drivers/clk/. * Modified .dev_id for UART clocks to match UART DT node names. * s/bcm2708/bcm2835/. * Modified device tree vendor prefix. Signed-off-by: Chris Boot <bootc@bootc.net> Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Dom Cobley <popcornmix@gmail.com> Signed-off-by: Dom Cobley <dc4@broadcom.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Mike Turquette <mturquette@linaro.org>
