path: root/include/linux/clk-private.h
2012-07-11clk: Add CLK_IS_BASIC flag to identify basic clocksRajendra Nayak
Most platforms end up using a mix of basic clock types and some which use clk_hw_foo struct for filling in custom platform information when the clocks don't fit into basic types supported. In platform code, its useful to know if a clock is using a basic type or clk_hw_foo, which helps platforms know if they can safely use to_clk_hw_foo to derive the clk_hw_foo pointer from clk_hw. Mark all basic clocks with a CLK_IS_BASIC flag. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-07-11clk: Add support for rate table based dividersRajendra Nayak
Some divider clks do not have any obvious relationship between the divider and the value programmed in the register. For instance, say a value of 1 could signify divide by 6 and a value of 2 could signify divide by 4 etc. Also there are dividers where not all values possible based on the bitfield width are valid. For instance a 3 bit wide bitfield can be used to program a value from 0 to 7. However its possible that only 0 to 4 are valid values. All these cases need the platform code to pass a simple table of divider/value tuple, so the framework knows the exact value to be written based on the divider calculation and can also do better error checking. This patch adds support for such rate table based dividers and as part of the support adds a new registration function 'clk_register_divider_table()' and a new macro for static definition 'DEFINE_CLK_DIVIDER_TABLE'. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08clk: add a fixed factor clockSascha Hauer
Having fixed factors/dividers in hardware is a common pattern, so add a basic clock type doing this. It basically describes a fixed factor clock using a nominator and a denominator. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Viresh Kumar <viresh.kumar@st.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> [mturquette@linaro.org: constify parent_names in static init macro] [mturquette@linaro.org: copy/paste bug from mux in static init macro] [mturquette@linaro.org: fix error handling in clk_register_fixed_factor] [mturquette@linaro.org: improve division accuracy; thanks to Saravana] Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-01clk: Use a separate struct for holding init data.Saravana Kannan
Create a struct clk_init_data to hold all data that needs to be passed from the platfrom specific driver to the common clock framework during clock registration. Add a pointer to this struct inside clk_hw. This has several advantages: * Completely hides struct clk from many clock platform drivers and static clock initialization code that don't care for static initialization of the struct clks. * For platforms that want to do complete static initialization, it removed the need to directly mess with the struct clk's fields while still allowing to statically allocate struct clk. This keeps the code more future proof even if they include clk-private.h. * Simplifies the generic clk_register() function and allows adding optional fields in the future without modifying the function signature. * Simplifies the static initialization of clocks on all platforms by removing the need for forward delcarations or convoluted macros. Signed-off-by: Saravana Kannan <skannan@codeaurora.org> [mturquette@linaro.org: kept DEFINE_CLK_* macros and __clk_init] Signed-off-by: Mike Turquette <mturquette@linaro.org> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Jeremy Kerr <jeremy.kerr@canonical.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergman <arnd.bergmann@linaro.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Richard Zhao <richard.zhao@linaro.org> Cc: Saravana Kannan <skannan@codeaurora.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Amit Kucheria <amit.kucheria@linaro.org> Cc: Deepak Saxena <dsaxena@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca>
2012-05-01clk: constify parent name arrays in macrosRajendra Nayak
parent name array is now expected to be const char *, make the relevent changes in the clk macros which define default clock types. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: clk-private: Add DEFINE_CLK macroViresh Kumar
All macros used for creating different kind of clocks have similar code for initializing struct clk. This patch removes those redundant lines and create another macro DEFINE_CLK. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: core: copy parent_names & return error codesMike Turquette
This patch cleans up clk_register and solves a few bugs by teaching clk_register and __clk_init to return error codes (instead of just NULL) to better align with the existing clk.h api. Along with that change this patch also introduces a new behavior whereby clk_register copies the parent_names array, thus allowing platforms to declare their parent_names arrays as __initdata. Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: Constify parent name arraysMark Brown
Drivers should be able to declare their arrays of parent names as const so the APIs need to accept const arguments. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [mturquette@linaro.org: constified gate] Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: declare clk_ops of basic clks in clk-provider.hShawn Guo
Besides the static initialization, the clk_ops of basic clks could also be used by particular clk type being subclass of the basic clks. For example, clk_busy_divider has the same clk_ops as clk_divider, except it has to wait for a busy bit before return success with .set_rate. clk_busy_divider will somehow reuse clk_ops of clk_divider. Since clk-provider.h is included by clk-private.h, it's safe to move those clk_ops declaration of basic clks form clk-private.h into clk-provider.h, so that implementation of clks like clk_busy_divider above do not need to include clk-private.h to access those clk_ops. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: add "const" for clk_ops of basic clksShawn Guo
The clk_ops of basic clks should have "const" to match the definition in "struct clk" and clk_register prototype. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-03-16clk: basic clock hardware typesMike Turquette
Many platforms support simple gateable clocks, fixed-rate clocks, adjustable divider clocks and multi-parent multiplexer clocks. This patch introduces basic clock types for the above-mentioned hardware which share some common characteristics. Based on original work by Jeremy Kerr and contribution by Jamie Iles. Dividers and multiplexor clocks originally contributed by Richard Zhao & Sascha Hauer. Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Mike Turquette <mturquette@ti.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Jeremy Kerr <jeremy.kerr@canonical.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergman <arnd.bergmann@linaro.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Richard Zhao <richard.zhao@linaro.org> Cc: Saravana Kannan <skannan@codeaurora.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Amit Kucheria <amit.kucheria@linaro.org> Cc: Deepak Saxena <dsaxena@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-16clk: introduce the common clock frameworkMike Turquette
The common clock framework defines a common struct clk useful across most platforms as well as an implementation of the clk api that drivers can use safely for managing clocks. The net result is consolidation of many different struct clk definitions and platform-specific clock framework implementations. This patch introduces the common struct clk, struct clk_ops and an implementation of the well-known clock api in include/clk/clk.h. Platforms may define their own hardware-specific clock structure and their own clock operation callbacks, so long as it wraps an instance of struct clk_hw. See Documentation/clk.txt for more details. This patch is based on the work of Jeremy Kerr, which in turn was based on the work of Ben Herrenschmidt. Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Mike Turquette <mturquette@ti.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Rob Herring <rob.herring <at> calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Jeremy Kerr <jeremy.kerr@canonical.com> Cc: Arnd Bergman <arnd.bergmann@linaro.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Richard Zhao <richard.zhao@linaro.org> Cc: Saravana Kannan <skannan@codeaurora.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Amit Kucheria <amit.kucheria@linaro.org> Cc: Deepak Saxena <dsaxena@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
