Support for message signing was merged into 3.19, along with
nocephx_require_signatures option. But, all that option does is allow
the kernel client to talk to clusters that don't support MSG_AUTH
feature bit. That's pretty useless, given that it's been supported
since bobtail.
Meanwhile, if one disables message signing on the server side with
"cephx sign messages = false", it becomes impossible to use the kernel
client since it expects messages to be signed if MSG_AUTH was
negotiated. Add nocephx_sign_messages option to support this use case.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
supported_features and required_features serve no purpose at all, while
nocrc and tcp_nodelay belong to ceph_options::flags.
Signed-off-by: Yan, Zheng <zyan@redhat.com>
There are currently three libceph-level timeouts that the user can
specify on mount: mount_timeout, osd_idle_ttl and osdkeepalive. All of
these are in seconds and no checking is done on user input: negative
values are accepted, we multiply them all by HZ which may or may not
overflow, arbitrarily large jiffies then get added together, etc.
There is also a bug in the way mount_timeout=0 is handled. It's
supposed to mean "infinite timeout", but that's not how wait.h APIs
treat it and so __ceph_open_session() for example will busy loop
without much chance of being interrupted if none of ceph-mons are
there.
Fix all this by verifying user input, storing timeouts capped by
msecs_to_jiffies() in jiffies and using the new ceph_timeout_jiffies()
helper for all user-specified waits to handle infinite timeouts
correctly.
Reviewed-by: Alex Elder <elder@linaro.org>
Unused since ceph got merged into mainline I guess.
Add a client_options attribute for showing libceph options.
Split ceph_show_options() into two pieces and move the piece
responsible for printing client (libceph) options into net/ceph. This
way people adding a libceph option wouldn't have to remember to update
code in fs/ceph.
TCP_NODELAY socket option set on connection sockets,
disables Nagle’s algorithm and improves latency characteristics.
tcp_nodelay(default)/notcp_nodelay option flags provided to
enable/disable setting the socket option.
Signed-off-by: Chaitanya Huilgol <chaitanya.huilgol@sandisk.com>
[idryomov@redhat.com: NO_TCP_NODELAY -> TCP_NODELAY, minor adjustments]
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
Reviewed-by: Ilya Dryomov <idryomov@redhat.com>
Use kvfree() from linux/mm.h instead, which is identical. Also fix the
ceph_buffer comment: we will allocate with kmalloc() up to 32k - the
value of PAGE_ALLOC_COSTLY_ORDER, but that really is just an
implementation detail so don't mention it at all.
ceph_release_page_vector was defined twice in libceph.h
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Encapsulate kmalloc vs vmalloc memory allocation and freeing logic into
two helpers, ceph_kvmalloc() and ceph_kvfree(), and switch to them.
ceph_kvmalloc() kmalloc()'s a maximum of 8 pages, anything bigger is
vmalloc()'ed with __GFP_HIGHMEM set. This changes the existing
behaviour:
- for buffers (ceph_buffer_new()), from trying to kmalloc() everything
and using vmalloc() just as a fallback
- for messages (ceph_msg_new()), from going to vmalloc() for anything
bigger than a page
- for messages (ceph_msg_new()), from disallowing vmalloc() to use high
memory
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
In preparation for ceph_features.h update, change all features fields
from unsigned int/u32 to u64. (ceph.git has ~40 feature bits at this
point.)
This creates a new source file "net/ceph/snapshot.c" to contain
utility routines related to ceph snapshot contexts. The main
motivation was to define ceph_create_snap_context() as a common way
to create these structures, but I've moved the definitions of
ceph_get_snap_context() and ceph_put_snap_context() there too.
(The benefit of inlining those is very small, and I'd rather
keep this collection of functions together.)
Signed-off-by: Alex Elder <elder@inktank.com>
Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
This is probably unnecessary but the code read as if it were wrong
in read_partial_message().
The return values provided for ceph_copy_to_page_vector() and
ceph_copy_from_page_vector() serve no purpose, so get rid of them.
The functions used for working with ceph page vectors are defined
with char pointers, but they're really intended to operate on
untyped data. Change the types of these function parameters
to (void *) to reflect this.
(Note that the functions now assume void pointer arithmetic works
like arithmetic on char pointers.)
An upcoming change implements semantic change that could lead to
a crash if an old version of the libceph kernel module is used with
a new version of the rbd kernel module.
In order to preclude that possibility, this adds a compatibilty
check interface. If this interface doesn't exist, the modules are
obviously not compatible. But if it does exist, this provides a way
of letting the caller know whether it will operate properly with
this libceph module.
Perhaps confusingly, it returns false right now. The semantic
change mentioned above will make it return true.
This resolves:
http://tracker.ceph.com/issues/3800
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph update from Sage Weil:
"There are a few different groups of commits here. The largest is
Alex's ongoing work to enable the coming RBD features (cloning,
striping). There is some cleanup in libceph that goes along with it.
Cyril and David have fixed some problems with NFS reexport (leaking
dentries and page locks), and there is a batch of patches from Yan
fixing problems with the fs client when running against a clustered
MDS. There are a few bug fixes mixed in for good measure, many of
which will be going to the stable trees once they're upstream.
My apologies for the late pull. There is still a gremlin in the rbd
map/unmap code and I was hoping to include the fix for that as well,
but we haven't been able to confirm the fix is correct yet; I'll send
that in a separate pull once it's nailed down."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (68 commits)
rbd: get rid of rbd_{get,put}_dev()
libceph: register request before unregister linger
libceph: don't use rb_init_node() in ceph_osdc_alloc_request()
libceph: init event->node in ceph_osdc_create_event()
libceph: init osd->o_node in create_osd()
libceph: report connection fault with warning
libceph: socket can close in any connection state
rbd: don't use ENOTSUPP
rbd: remove linger unconditionally
rbd: get rid of RBD_MAX_SEG_NAME_LEN
libceph: avoid using freed osd in __kick_osd_requests()
ceph: don't reference req after put
rbd: do not allow remove of mounted-on image
libceph: Unlock unprocessed pages in start_read() error path
ceph: call handle_cap_grant() for cap import message
ceph: Fix __ceph_do_pending_vmtruncate
ceph: Don't add dirty inode to dirty list if caps is in migration
ceph: Fix infinite loop in __wake_requests
ceph: Don't update i_max_size when handling non-auth cap
bdi_register: add __printf verification, fix arg mismatch
This would reset a connection with any OSD that had an outstanding
request that was taking more than N seconds. The idea was that if the
OSD was buggy, the client could compensate by resending the request.
In reality, this only served to hide server bugs, and we haven't
actually seen such a bug in quite a while. Moreover, the userspace
client code never did this.
More importantly, often the request is taking a long time because the
OSD is trying to recover, or overloaded, and killing the connection
and retrying would only make the situation worse by giving the OSD
more work to do.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
system headers
Convert #include "..." to #include <path/...> in kernel system headers.
Acked-by: Dave Jones <davej@redhat.com>
There are two structures in which a count of snapshots are
maintained:
struct ceph_snap_context {
u32 num_snaps;
and
struct ceph_snap_realm {
u32 num_prior_parent_snaps; /* had prior to parent_since */
u32 num_snaps;
These fields never take on negative values (e.g., to hold special
meaning), and so are really inherently unsigned. Furthermore they
take their value from over-the-wire or on-disk formatted 32-bit
values.
So change their definition to have type u32, and change some spots
elsewhere in the code to account for this change.
This is simply cleanup that will keep things more closely synced with the
userland code.
Reviewed-by: Yehuda Sadeh <yehuda@inktank.com>
Linux 3.5-rc1
net/ceph/messenger.c
A ceph client has a pointer to a ceph messenger structure in it.
There is always exactly one ceph messenger for a ceph client, so
there is no need to allocate it separate from the ceph client
structure.
Switch the ceph_client structure to embed its ceph_messenger
structure.
Pull Ceph updates for 3.4-rc1 from Sage Weil:
"Alex has been busy. There are a range of rbd and libceph cleanups,
especially surrounding device setup and teardown, and a few critical
fixes in that code. There are more cleanups in the messenger code,
virtual xattrs, a fix for CRC calculation/checks, and lots of other
miscellaneous stuff.
There's a patch from Amon Ott to make inos behave a bit better on
32-bit boxes, some decode check fixes from Xi Wang, and network
throttling fix from Jim Schutt, and a couple RBD fixes from Josh
Durgin.
No new functionality, just a lot of cleanup and bug fixing."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (65 commits)
rbd: move snap_rwsem to the device, rename to header_rwsem
ceph: fix three bugs, two in ceph_vxattrcb_file_layout()
libceph: isolate kmap() call in write_partial_msg_pages()
libceph: rename "page_shift" variable to something sensible
libceph: get rid of zero_page_address
libceph: only call kernel_sendpage() via helper
libceph: use kernel_sendpage() for sending zeroes
libceph: fix inverted crc option logic
libceph: some simple changes
libceph: small refactor in write_partial_kvec()
libceph: do crc calculations outside loop
libceph: separate CRC calculation from byte swapping
libceph: use "do" in CRC-related Boolean variables
ceph: ensure Boolean options support both senses
libceph: a few small changes
libceph: make ceph_tcp_connect() return int
libceph: encapsulate some messenger cleanup code
libceph: make ceph_msgr_wq private
libceph: encapsulate connection kvec operations
libceph: move prepare_write_banner()
ceph_parse_options() takes the address of a pointer as an argument
and uses it to return the address of an allocated structure if
successful. With this interface is not evident at call sites that
the pointer is always initialized. Change the interface to return
the address instead (or a pointer-coded error code) to make the
validity of the returned pointer obvious.
Signed-off-by: Alex Elder <elder@dreamhost.com>
Signed-off-by: Sage Weil <sage@newdream.net>
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
This simplifies the init/shutdown paths, and makes client->msgr available
during the rest of the setup process.
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
This makes the base64 logic be contained in mount option parsing,
and prepares us for replacing the homebew key management with the
kernel key retention service.
Signed-off-by: Tommi Virtanen <tommi.virtanen@dreamhost.com>
For read operation, we have to set the argument _write_ of get_user_pages
to 1 since we will write data to pages. Also, we need to SetPageDirty before
releasing these pages.
Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com>
The offset/length arguments aren't used.
This factors out protocol and low-level storage parts of ceph into a
separate libceph module living in net/ceph and include/linux/ceph. This
is mostly a matter of moving files around. However, a few key pieces
of the interface change as well:
- ceph_client becomes ceph_fs_client and ceph_client, where the latter
captures the mon and osd clients, and the fs_client gets the mds client
and file system specific pieces.
- Mount option parsing and debugfs setup is correspondingly broken into
two pieces.
- The mon client gets a generic handler callback for otherwise unknown
messages (mds map, in this case).
- The basic supported/required feature bits can be expanded (and are by
ceph_fs_client).
No functional change, aside from some subtle error handling cases that got
cleaned up in the refactoring process.
