path: root/include/linux/buffer_head.h
2008-04-29remove generic_commit_write()Adrian Bunk
Remove the obsolete and no longer used generic_commit_write(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13include/linux: Remove all users of FASTCALL() macroHarvey Harrison
FASTCALL() is always expanded to empty, remove it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28Add buffer head related helper functionsAneesh Kumar K.V
Add buffer head related helper function bh_uptodate_or_lock and bh_submit_read which can be used by file system Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2007-10-16fs: restore nobhNick Piggin
Implement nobh in new aops. This is a bit tricky. FWIW, nobh_truncate is now implemented in a way that does not create blocks in sparse regions, which is a silly thing for it to have been doing (isn't it?) ext2 survives fsx and fsstress. jfs is converted as well... ext3 should be easy to do (but not done yet). [akpm@linux-foundation.org: coding-style fixes] Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16With reiserfs no longer using the weird generic_cont_expand, remove it ↵Nick Piggin
completely. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: new cont helpersNick Piggin
Rework the generic block "cont" routines to handle the new aops. Supporting cont_prepare_write would take quite a lot of code to support, so remove it instead (and we later convert all filesystems to use it). write_begin gets passed AOP_FLAG_CONT_EXPAND when called from generic_cont_expand, so filesystems can avoid the old hacks they used. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: introduce write_begin, write_end, and perform_write aopsNick Piggin
These are intended to replace prepare_write and commit_write with more flexible alternatives that are also able to avoid the buffered write deadlock problems efficiently (which prepare_write is unable to do). [mark.fasheh@oracle.com: API design contributions, code review and fixes] [akpm@linux-foundation.org: various fixes] [dmonakhov@sw.ru: new aop block_write_begin fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19[FS] Implement block_page_mkwrite.David Chinner
Many filesystems need a ->page-mkwrite callout to correctly set up pages that have been written to by mmap. This is especially important when mmap is writing into holes as it allows filesystems to correctly account for and allocate space before the mmap write is allowed to proceed. Protection against truncate races is provided by locking the page and checking to see whether the page mapping is correct and whether it is beyond EOF so we don't end up allowing allocations beyond the current EOF or changing EOF as a result of a mmap write. SGI-PV: 940392 SGI-Modid: 2.6.x-xfs-melb:linux:29146a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-07mm: optimize kill_bdev()Peter Zijlstra
Remove duplicate work in kill_bdev(). It currently invalidates and then truncates the bdev's mapping. invalidate_mapping_pages() will opportunistically remove pages from the mapping. And truncate_inode_pages() will forcefully remove all pages. The only thing truncate doesn't do is flush the bh lrus. So do that explicitly. This avoids (very unlikely) but possible invalid lookup results if the same bdev is quickly re-issued. It also will prevent extreme kernel latencies which are observed when blockdevs which have a large amount of pagecache are unmounted, by avoiding invalidate_mapping_pages() on that path. invalidate_mapping_pages() has no cond_resched (it can be called under spinlock), whereas truncate_inode_pages() has one. [akpm@linux-foundation.org: restore nrpages==0 optimisation] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] warning fix: unsigned->signedTomasz Kvarsin
While compiling my code with -Wconversion using gcc-trunk, I always get a bunch of warrning from headers, here is fix for them: __getblk is alawys called with unsigned argument, but it takes signed, the same story with __bread,__breadahead and so on. Signed-off-by: Tomasz Kvarsin Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Make BH_Unwritten a first class bufferhead flag V2David Chinner
Currently, XFS uses BH_PrivateStart for flagging unwritten extent state in a bufferhead. Recently, I found the long standing mmap/unwritten extent conversion bug, and it was to do with partial page invalidation not clearing the unwritten flag from bufferheads attached to the page but beyond EOF. See here for a full explaination: http://oss.sgi.com/archives/xfs/2006-12/msg00196.html The solution I have checked into the XFS dev tree involves duplicating code from block_invalidatepage to clear the unwritten flag from the bufferhead(s), and then calling block_invalidatepage() to do the rest. Christoph suggested that this would be better solved by pushing the unwritten flag into the common buffer head flags and just adding the call to discard_buffer(): http://oss.sgi.com/archives/xfs/2006-12/msg00239.html The following patch makes BH_Unwritten a first class citizen. Signed-off-by: Dave Chinner <dgc@sgi.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-17[PATCH] Fix IO error reporting on fsync()Jan Kara
When IO error happens on metadata buffer, buffer is freed from memory and later fsync() is called, filesystems like ext2 fail to report EIO. We solve the problem by introducing a pointer to associated address space into the buffer_head. When a buffer is removed from a list of metadata buffers associated with an address space, IO error is transferred from the buffer to the address space, so that fsync can later report it. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move functions out of buffer code [try #6]David Howells
Move some functions out of the buffering code that aren't strictly buffering specific. This is a precursor to being able to disable the block layer. (*) Moved some stuff out of fs/buffer.c: (*) The file sync and general sync stuff moved to fs/sync.c. (*) The superblock sync stuff moved to fs/super.c. (*) do_invalidatepage() moved to mm/truncate.c. (*) try_to_release_page() moved to mm/filemap.c. (*) Moved some related declarations between header files: (*) declarations for do_invalidatepage() and try_to_release_page() moved to linux/mm.h. (*) __set_page_dirty_buffers() moved to linux/buffer_head.h. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-27[PATCH] fs/buffer.c: cleanupsAdrian Bunk
- add a proper prototype for the following global function: - buffer_init() - make the following needlessly global function static: - end_buffer_async_write() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] pass b_size to ->get_block()Badari Pulavarty
Pass amount of disk needs to be mapped to get_block(). This way one can modify the fs ->get_block() functions to map multiple blocks at the same time. [akpm@osdl.org: performance tweak] [akpm@osdl.org: remove unneeded assignments] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] change buffer_head.b_size to size_tBadari Pulavarty
Increase the size of the buffer_head b_size field (only) for 64 bit platforms. Update some old and moldy comments in and around the structure as well. The b_size increase allows us to perform larger mappings and allocations for large I/O requests from userspace, which tie in with other changes allowing the get_block_t() interface to map multiple blocks at once. Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Make address_space_operations->invalidatepage return voidNeilBrown
The return value of this function is never used, so let's be honest and declare it as void. Some places where invalidatepage returned 0, I have inserted comments suggesting a BUG_ON. [akpm@osdl.org: JBD BUG fix] [akpm@osdl.org: rework for git-nfs] [akpm@osdl.org: don't go BUG in block_invalidate_page()] Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Make address_space_operations->sync_page return voidNeilBrown
The only user ignores the return value, and the only instanace (block_sync_page) always returns 0... Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fat: support a truncate() for expanding size (generic_cont_expand)OGAWA Hirofumi
This patch changes generic_cont_expand(), in order to share the code with fatfs. - Use vmtruncate() if ->prepare_write() returns a error. Even if ->prepare_write() returns an error, it may already have added some blocks. So, this truncates blocks outside of ->i_size by vmtruncate(). - Add generic_cont_expand_simple(). The generic_cont_expand_simple() assumes that ->prepare_write() can handle the block boundary. With this, we don't need to care the extra byte. And for expanding a file size by truncate(), fatfs uses the added generic_cont_expand_simple(). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ext3: Fix unmapped buffers in transaction's listsJan Kara
Fix the problem (BUG 4964) with unmapped buffers in transaction's t_sync_data list. The problem is we need to call filesystem's own invalidatepage() from block_write_full_page(). block_write_full_page() must call filesystem's invalidatepage(). Otherwise following nasty race can happen: proc 1 proc 2 ------ ------ - write some new data to 'offset' => bh gets to the transactions data list - starts truncate => i_size set to new size - mpage_writepages() - ext3_ordered_writepage() to 'offset' - block_write_full_page() - page->index > end_index+1 - block_invalidatepage() - discard_buffer() - clear_buffer_mapped() - commit triggers and finds unmapped buffer - BOOM! Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: split page table lockHugh Dickins
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with a many-threaded application which concurrently initializes different parts of a large anonymous area. This patch corrects that, by using a separate spinlock per page table page, to guard the page table entries in that page, instead of using the mm's single page_table_lock. (But even then, page_table_lock is still used to guard page table allocation, and anon_vma allocation.) In this implementation, the spinlock is tucked inside the struct page of the page table page: with a BUILD_BUG_ON in case it overflows - which it would in the case of 32-bit PA-RISC with spinlock debugging enabled. Splitting the lock is not quite for free: another cacheline access. Ideally, I suppose we would use split ptlock only for multi-threaded processes on multi-cpu machines; but deciding that dynamically would have its own costs. So for now enable it by config, at some number of cpus - since the Kconfig language doesn't support inequalities, let preprocessor compare that with NR_CPUS. But I don't think it's worth being user-configurable: for good testing of both split and unsplit configs, split now at 4 cpus, and perhaps change that to 8 later. There is a benefit even for singly threaded processes: kswapd can be attacking one part of the mm while another part is busy faulting. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] page_uptodate locking scalabilityNick Piggin
Use a bit spin lock in the first buffer of the page to synchronise asynch IO buffer completions, instead of the global page_uptodate_lock, which is showing some scalabilty problems. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
